Aggiornamento GraphicConverter
GraphicConverter - 8.5.3
New features
added option to geotag from map view
added search field to map view
added "Copy EXIF Tags to IPTC Caption" feature
added option to open folder in new browser
added option to use cursor left/right without command for image change
added option to use default display behaviour for zoom/scale after image change
added option to clear recent files and browsers list upon quitting
added batch support for image catalog creation
added framerate option to picture to movie conversion
added separate iptc window as option to the browser
added option to define overlap printing width
Updated features
enlarged maximum delay during slideshow
updated Hagens Manual
did split some preferences panels for small displays
improved byte array export
Bug fixes
rename bug in browser from lowercase to uppercase or vise-versa fixed
bug with animation palette on 10.6.8 fixed
fixed a bug in GIF loop detection
fixed many localization issues (size of dialogs)
fixed a possible memory leak in image to QuickTime conversion
fixed a possible with clippings
fixed swap of top/bottom in trim batch
fixed a bug with move folder shortcuts
fixed a bug in import of uncompressed psd files.
http://www.lemkesoft.com/xd/public/cont ... M0NA_.html" onclick="window.open(this.href);return false;
Rilasciato GraphicConverter 8.6.
Ecco la lista degli elementi aggiornati:
http://www.lemkesoft.org/files/graphicc ... /1200.html" onclick="window.open(this.href);return false;
Link per il download diretto:
http://www.lemkesoft.org/files/graphicc ... ld1200.dmg" onclick="window.open(this.href);return false;
http://www.lemkesoft.org/files/graphicc ... /1254.html" onclick="window.open(this.href);return false;
Rilasciato GraphicConverter 8.7.
http://www.lemkesoft.org/files/graphicc ... ld1254.dmg" onclick="window.open(this.href);return false;
Rilasciato GraphicConverter 8.7.1.
Uff a me non scarica… server affollati?
[Edit] adesso sì, anche se lentamente:
http://www.lemkesoft.org/files/graphicc ... ld1316.dmg" onclick="window.open(this.href);return false;
Rilasciato GraphicConverter 8.8.1.
http://www.lemkesoft.de/en/products/gra ... /download/" onclick="window.open(this.href);return false;
Note di rilascio:
http://www.lemkesoft.org/files/graphicc ... /1346.html" onclick="window.open(this.href);return false;
Azz! Grazie KP! Nemmeno sapevo fosse uscita la 9! Come funziona per chi ha la licenza della versione 8?
Sul sito i prezzi valgono esattamente per gli ordini tramite KAGI e tramite PayPal.
Full version: just €34.95 Upgrade: just €23.95
Mentre qui costa 22,99? Boh.
https://itunes.apple.com/it/app/graphic ... 9092?mt=12" onclick="window.open(this.href);return false;
E la versione vecchia 34,99?
https://itunes.apple.com/it/app/graphic ... 4640?mt=12" onclick="window.open(this.href);return false;
Disponibile per il download GraphicConverter - 9.0.2
Release notes: http://www.lemkesoft.de/en/products/gra ... -versions/" onclick="window.open(this.href);return false;
Disponibile per il download GraphicConverter - 9.1
Nuove funzioni
aggiunta la procedura ed effetto Media
aggiunta l'importazione del formato .422 (creato da Magic Lantern)
aggiunto il comando "Consulta Copia" per consultare unità disco di copie locali (se è installato un client cloud)
Aggiunto il comando "Consulta Google Drive" per consultare l'unità disco locale (se è installato un client cloud)
aggiunto il comando per allegare un file all'email
aggiunta la modalità rapida per migliorare notevolmente la velocità dell'operatore
aggiunto l'antialias allo strumento Penna
aggiunta la procedura di ritaglio dei contenuti
aggiunta l'opzione per mostrare un indicatore RAW per file RAW nel browser
aggiunta l'opzione per mostrare l'etichetto colore a dimensioni più elevate nel browser
aggiunto il supporto della rotella di scorrimento nella presentazione, per poter ingrandire (oltre al gesto di ingrandimento)
aggiunte le icone di salvataggio, annulla e ripristina alla barra degli strumenti
aggiunto il profilo di conversione a colori
la selezione ora può essere trascinata in verticale o orizzontale premendo il tasto Maiuscole
aggiunta la funzione "Estrai immagini da PDF" a Converti e Modifica
aggiunta la copia del colore in primo piano o di sfondo come HTML al sottomenu Copia nel menu Composizione
aggiunto il supporto di file ithmb con contenuti compressi in JPEG
Funzioni migliorate
aggiunta l'opzione per disattivare le impostazioni memorizzate per le stampanti
la rinomina manuale di un singolo file nel browser adesso rinomina anche il file XMP esistente
L'opzione Salva per il web adesso mostra il pannello di salvataggio col solo nome del file selezionato
adesso il browser ignora gli eventi "InodeMetaMod" da unità disco per evitare i ricaricare molte volte i contenuti
adesso, l'estrazione di miniature JPEG da dati EXIF archivia le miniature con le date dei file sorgente
l'anteprima Xe847 supporta la visualizzazione con profilo colore
aggiunto il supporto dei 16 bit per ciascun canale e l'esportazione di png
migliorata la funzione di concatenamento in Converti e Modifica
migliorato il dialogo di notifica se una fotocamera viene connessa
Bug risolti
risolto un bug che poteva verificarsi con selezioni e l'applicazione di filtri Core Image
risolto un bug legato al comando "Nuova cartella con gli elementi selezionati"
risolto un bug nell'opzione offset di variazione della data
risolto un bug che poteva verificarsi modificando la luminosità/contrasto di immagini in scala di grigi
risolto un bug che poteva verificarsi durante conversioni rapide
risolto un problema di ordinamento nelle presentazioni
risolto un bug legato all'importazione dei commenti nei file TIFF
risolto un bug che poteva verificarsi se una cartella conteneva un link ricorsivo
risolto un bug legato all'importazione PCD
http://www.lemkesoft.com/xd/public/content/index.html" onclick="window.open(this.href);return false;
Rilasciato GraphicConverter 9.2 e si scarica da qui:
Susanna
...software utilissimo per vedere le anteprime dei file raw di molte nuove fotocamere, dato che il (mio) povero Snow leopard non lo considerano più ed Anteprima non vede i raw della Olympus EM1 :crybaby: :crybaby: :crybaby: ...GraziA Franz, sei stato il solito TE SO RO NE :)
Susanna… troppo buona!
Torna a “Aggiornamenti”
