Zoc Terminal aggiornato
Oggetto del messaggio: Zoc Terminal aggiornato
ZOC è un famoso emulatore di Terminale e client Telnet che permette di accedere ai server Web in modalità testuale via telnet, modem, Secure Shell (SSH/SSH2), ISDN, etc.
Il programma è stato aggiornato alla versione 6.13 con le seguenti novità:
NEW: REXX command ZocLoadTranslationProfile
CHG: REXX renamed command ZocLoadOpts to ZocLoadSessionProfile
CHG: REXX renamed command ZocLoadKeyfile to ZocLoadKeyboardProfile
NEW: new option wyse emulation to start with label line off
NEW: option for xterm to send f-keys as vt220/rxvt codes
FIX: problem with using backspace in the Local Typing field
FIX: possible random characters appearing with telnet
CHG: speeding up text output while pasting text into the session
FIX: possible crash with LOGIT enabled (introduced only in betas after 6.12)
FIX: possible crash when switching host directory folders
FIX: another possible beachball when pasting long text (OSX only)
FIX: don't eat CPU time after trying to open a nonaccessable com port (Windows only)
FIX: possible internal error/crash while dragging tabs
FIX: possible beachball situation with local shells (OS X only)
FIX: don't crash when trying to SCP upload a nonexisting file
FIX: possible problem with logfile after using Reconnect
FIX: fixed broken double width/double height characters in VT emulations
FIX: fixed delayed changing of the log name after connecting
FIX: function Send Text File over serial device sometimes repeated a warning
http://www.apple.com/downloads/macosx/n ... minal.html
Forse nessuno di voi lo userà mai, ma (tanto per curiosità) è tra i freeware preferiti di Lucio Bragagnolo (Lux).
