reindirizzamento motore di ricerca google
lele_ct
Salve a tutti, vi allego il report Etrecheck pro (trial)
Google chrome mi viene sempre reindirizzato a ad altri motori di ricerca (tra cui weknow). non so cosa fare. ho già provato a bloccare solo a google il motore di ricerca am appena chiudo e riapro di nuovo lo stesso problema. Qualcuno può aiutarmi?
EtreCheck version: 5.1 (5A022)
Report generated: 2019-01-07 13:32:08
Runtime: 2:33
Performance: Excellent
Major Issues: None
Minor Issues:
These issues do not need immediate attention but they may indicate future problems.
Apps crashing - There have been numerous app crashes.
Unsigned files - There are unsigned software files installed. They appear to be legitimate but should be reviewed.
System modifications - There are a large number of system modifications running in the background.
Abnormal shutdown - Your machine shut down abnormally.
Hardware Information:
MacBook Pro (13-inch, Mid 2012)
MacBook Pro Model: MacBookPro9,2
1 2,9 GHz Intel Core i7 (i7-3520M) CPU: 2-core
8 RAM - At maximum
BANK 0/DIMM0 - 4 GB DDR3 1600 ok
BANK 1/DIMM0 - 4 GB DDR3 1600 ok
Battery: Health = Normal - Cycle count = 406
Video Information:
Intel HD Graphics 4000 - VRAM: 1536 MB
DELL U2415 1920 x 1200
Drives:
disk0 - Samsung SSD 850 EVO 500GB 500.11 GB (Solid State - TRIM: No)
Internal SATA 6 Gigabit Serial ATA
disk0s1 - EFI (MS-DOS FAT32) [EFI] 210 MB
disk0s2 [APFS Container] 499.90 GB
disk1 [APFS Virtual drive] 499.90 GB (Shared by 4 volumes)
disk1s1 - Macintosh HD (APFS) (Shared - 362.57 GB used)
disk1s2 - Preboot (APFS) [APFS Preboot] (Shared - 46 MB used)
disk1s3 - Recovery (APFS) [Recovery] (Shared - 1.03 GB used)
disk1s4 - VM (APFS) [APFS VM] (Shared - 1.07 GB used)
disk2 - ASMT 2115 750.16 GB
External USB 5 Gbit/s USB
disk2s1 - EFI (MS-DOS FAT32) [EFI] 210 MB
disk2s2 - T**********e (Journaled HFS+) 749.81 GB (734.27 GB used)
Mounted Volumes:
disk1s1 - Macintosh HD 499.90 GB (135.01 GB free)
APFS
Mount point: /
disk1s4 - VM [APFS VM] (Shared - 1.07 GB used)
APFS
Mount point: /private/var/vm
disk2s2 - T**********e 749.81 GB (15.54 GB free)
Journaled HFS+
Mount point: /Volumes/T**********e
disk4s2 - D***********t 40 MB (16 MB free)
Mac OS Extended
Disk Image
Mount point: /Volumes/D***********t
Network:
Interface en0: Ethernet
Proxy Auto Discovery
Interface en4: iPhone
Interface fw0: FireWire
Interface en1: Wi-Fi
802.11 a/b/g/n
Interface en5: iPad
Interface bridge0: Thunderbolt Bridge
iCloud Quota: 17.67 GB available
System Software:
macOS Mojave 10.14.2 (18C54)
Time since boot: Less than an hour
Configuration Files:
/etc/hosts - Count: 20
Security:
System Status
Gatekeeper Enabled
System Integrity Protection Enabled
Unsigned Files:
Launchd: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/com.oracle.java.Java-Updater.plist
Executable: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/Java Updater.app/Contents/MacOS/Java Updater -bgcheck
Details: Exact match found in the whitelist - probably OK
Launchd: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/com.oracle.java.Helper-Tool.plist
Executable: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/Helper-Tool
Launchd: /Library/LaunchDaemons/com.microsoft.office.licensing.helper.plist
Executable: /Library/PrivilegedHelperTools/com.microsoft.office.licensing.helper
Kernel Extensions:
/Library/Application Support/Malwarebytes/MBAM/Kext
[Loaded] MB_MBAM_Protection.kext (3.6 - SDK 10.14)
/Library/Extensions
[Loaded] Soundflower.kext (2.0b2 - SDK 10.10)
[Loaded] DisplayLinkDriver.kext (5.0 (42) - SDK 10.11)
[Loaded] ufsd_NTFS.kext (15.4.11 - SDK 10.10)
/System/Library/Extensions
[Loaded] eqMac2Driver.kext (2.0 - SDK 10.13)
System Launch Agents:
[Not Loaded] 13 Apple tasks
[Loaded] 180 Apple tasks
[Running] 106 Apple tasks
System Launch Daemons:
[Not Loaded] 36 Apple tasks
[Loaded] 186 Apple tasks
[Running] 112 Apple tasks
[Other] One Apple task
Launch Agents:
[Not Loaded] com.paragon-software.ntfs.notification-agent.plist (Paragon Software GmbH - installed 2018-09-19)
[Not Loaded] com.adobe.AdobeCreativeCloud.plist (Adobe Systems, Inc. - installed 2018-09-24)
[Not Loaded] com.Um4dm.plist (? 0 - installed 2018-11-13)
[Loaded] com.microsoft.update.agent.plist (Microsoft Corporation - installed 2018-12-12)
[Not Loaded] com.adobe.GC.AGM.plist (Adobe Systems, Inc. - installed 2018-12-28)
[Not Loaded] com.adobe.ARMDCHelper.cc24aef4a1b90ed56a725c38014c95072f92651fb65e1bf9c8e43c37a23d420d.plist (Adobe Systems, Inc. - installed 2018-02-20)
[Running] com.displaylink.useragent.plist (DisplayLink Corp - installed 2018-09-28)
[Not Loaded] com.adobe.AAM.Updater-1.0.plist (? ffb65062 - installed 2018-11-02)
[Running] com.malwarebytes.mbam.frontend.agent.plist (Malwarebytes Corporation - installed 2018-12-07)
[Not Loaded] com.displaylink.useragent-prelogin.plist (DisplayLink Corp - installed 2018-09-28)
[Loaded] uk.co.canimaansoftware.ClamXAV.UninstallWatcher.plist (Mark Allan - installed 2018-12-18)
[Not Loaded] com.adobe.GC.Invoker-1.0.plist (Adobe Systems, Inc. - installed 2018-12-28)
[Running] uk.co.canimaansoftware.ClamXAV.UI-Helper.plist (Mark Allan - installed 2018-12-18)
Launch Daemons:
[Running] com.malwarebytes.mbam.rtprotection.daemon.plist (Malwarebytes Corporation - installed 2019-01-02)
[Loaded] com.adobe.fpsaud.plist (Adobe Systems, Inc. - installed 2018-11-29)
[Running] uk.co.canimaansoftware.ClamXAV.HelperTool.plist (Mark Allan - installed 2018-12-18)
[Loaded] com.microsoft.office.licensing.helper.plist (? 6d8cb30e - installed 2010-08-25)
[Running] com.malwarebytes.mbam.settings.daemon.plist (Malwarebytes Corporation - installed 2018-12-07)
[Loaded] com.adobe.ARMDC.Communicator.plist (Adobe Systems, Inc. - installed 2018-02-20)
[Loaded] com.adobe.acc.installer.v2.plist (Adobe Systems, Inc. - installed 2018-09-24)
[Running] com.adobe.agsservice.plist (Adobe Systems, Inc. - installed 2018-12-28)
[Loaded] com.BlueStacks.AppPlayer.bstservice_helper.plist (BlueStack Systems, Inc. - installed 2017-11-27)
[Loaded] com.paragon-software.ntfsd.plist (Paragon Software GmbH - installed 2018-09-19)
[Running] uk.co.canimaansoftware.ClamXAV.Engine.plist (Mark Allan - installed 2018-12-18)
[Loaded] com.microsoft.autoupdate.helper.plist (Microsoft Corporation - installed 2018-12-12)
[Loaded] com.paragon-software.installer.plist (Paragon Software GmbH - installed 2018-10-09)
[Running] com.displaylink.displaylinkmanager.plist (DisplayLink Corp - installed 2018-09-28)
[Loaded] uk.co.canimaansoftware.ClamXAV.HelperToolUpdater.plist (Mark Allan - installed 2018-12-18)
[Loaded] com.paragon-software.ntfs.loader.plist (Apple - installed 2018-11-30)
[Loaded] com.apple.installer.osmessagetracing.plist (Apple - installed 2018-11-30)
[Loaded] com.microsoft.office.licensingV2.helper.plist (Microsoft Corporation - installed 2016-09-10)
[Loaded] com.adobe.ARMDC.SMJobBlessHelper.plist (Adobe Systems, Inc. - installed 2018-02-20)
User Launch Agents:
[Loaded] com.google.keystone.agent.plist (Google, Inc. - installed 2019-01-07)
Internet Plug-ins:
AdobeAAMDetect: 3.0.0.0 (installed 2018-09-24)
FlashPlayer-10.6: 32.0.0.101 (installed 2018-12-05)
QuickTime Plugin: 7.7.3 (installed 2018-12-13)
AdobePDFViewerNPAPI: 17.012.20098 (installed 2018-11-02)
AdobePDFViewer: 19.008.20080 (installed 2018-11-02)
Flash Player: 32.0.0.101 (installed 2018-12-05)
SharePointBrowserPlugin: 14.7.7 (installed 2017-09-28)
PepperFlashPlayer: (installed 2018-11-13)
Silverlight: 5.1.50901.0 (installed 2017-09-21)
JavaAppletPlugin: Java 8 Update 191 build 12 (installed 2018-12-18)
3rd Party Preference Panes:
CodeMeter (installed 2017-02-21)
Flash Player (installed 2018-11-29)
Java (installed 2018-12-18)
NTFS (installed 2018-09-19)
Time Machine:
Skip System Files:
Mobile backups:
Auto backup: Yes
Volumes being backed up:
Macintosh HD: Disk size: 499.90 GB - Disk used: 364.89 GB
Destinations:
T**********e [Local] (Last used)
Total size: 749.81 GB
Total number of backups: 47
Oldest backup: 2018-10-05 10:17:16
Last backup: 2019-01-07 12:51:04
Performance:
System Load: 3.87 (1 min ago) 3.66 (5 min ago) 3.41 (15 min ago)
Nominal I/O speed: 6.03 MB/s
File system: 39.83 seconds
Write speed: 417 MB/s
Read speed: 518 MB/s
CPU Usage:
Type Overall
System 8 %
User 14 %
Idle 78 %
Top Processes by CPU:
Process (count) CPU (Source - Location)
RTProtectionDaemon 13.20 % (Malwarebytes Corporation)
DisplayLinkManager 11.28 % (DisplayLink Corp)
WindowServer 9.02 % (Apple)
Finder 6.92 % (Apple)
distnoted (5) 5.92 % (Apple)
Top Processes by Memory:
Process (count) RAM usage (Source - Location)
EtreCheckPro 803 MB (Etresoft, Inc.)
com.apple.WebKit.WebContent (9) 253 MB (Apple)
mdworker_shared (9) 251 MB (Apple)
MTLCompilerService (19) 213 MB (Apple)
RTProtectionDaemon 212 MB (Malwarebytes Corporation)
Top Processes by Network Use:
Process Input / Output (Source - Location)
mDNSResponder 183 KB / 67 KB (Apple)
cloudd 8 KB / 2 KB (Apple)
apsd 4 KB / 4 KB (Apple)
netbiosd 2 KB / 2 KB (Apple)
rapportd 369 B / 355 B (Apple)
Virtual Memory Information:
Available RAM 2.95 GB
Free RAM 301 MB
Used RAM 5.05 GB
Cached files 2.66 GB
Swap Used 0 B
Software Installs (past 30 days):
Install Date Name (Version)
2018-12-12 XProtectPlistConfigData (2101)
2018-12-12 Gatekeeper Configuration Data (157)
2018-12-12 Microsoft AutoUpdate (4.6.18120801)
2018-12-13 Microsoft Excel for Mac (16.16.18120901)
2018-12-13 Microsoft PowerPoint for Mac (16.16.18120901)
2018-12-13 Microsoft Word for Mac (16.16.18120901)
2018-12-13 MRTConfigData (1.38)
2018-12-18 Java 8 Update 121 (1.0)
2018-12-18 CodeMeter Runtime Kit (KEXT3G) (6.40)
2018-12-18 WibuKey Runtime (9.55)
2018-12-18 Java 8 Update 191 (1.0)
2018-12-28 ClamXAV v3.0.8 (3.0.8)
2019-01-02 Reimage Cleaner
Diagnostics Information (past 7 days):
2019-01-07 13:07:16 bluetoothd Crash
/usr/sbin/bluetoothd
dyld3 mode
*** Terminating app due to uncaught exception 'NSInvalidArgumentException', reason: '*** -[__NSDictionaryM setObject:forKeyedSubscript:]: key cannot be nil'
abort() called
terminating with uncaught exception of type NSException
2019-01-07 13:05:18 Last Shutdown Cause: 3 - Hard shutdown
2019-01-04 20:49:09 backupd CPU
/System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd
2019-01-02 08:09:00 DisplayLinkManager CPU
/Library/PrivilegedHelperTools/DisplayLink/DisplayLinkManager
End of report
Benvenuto.
viewforum.php?f=30
Saremo in tanti a salutarti.
Attualmente EtreCheck non serve quasi più a nulla.
Ti consiglio di scaricare ed usare DetectX pe una scansione di adware.
Qui il topic in cui lo consigliamo:
viewtopic.php?f=5&t=32846&p=490423#p490423
Un po' d'attenzione nello scaricarlo, perché il sito richiede registrazione, anche se gratuito.
Dacci cortesemente un riscontro...
Intanto ti consiglio di:
- Aggiornare Java (visto che lo usi per altri strumenti avanzati)
viewtopic.php?f=5&t=19867&p=488018#p488018
- Eliminare l'inutile, pesante e pericoloso Malwarebytes
- Eliminare l'inutile, pesante e pericoloso ClamXav
- Eliminare l'inutile e pesante Adobe Viewer
Come opinione personale ritengo inadeguati NTSF for Mac, DisplayLink, BlueStacks e altro.
Se trovi di meglio...
Vedo che tieni molto alla sicurezza.
Ti consiglierei la serie di utilità che uso io e molti altri del Forum:
Santa, sicurezza a lista bianca
https://github.com/google/santa
F Secure X-Fence, sorveglianza cartelle critiche
https://beta.f-secure.com/key/XFence
BlockBlock, sorveglianza cartelle critiche
https://objective-see.com/products/blockblock.html
File Spy, analizzatore di applicazioni
https://itunes.apple.com/us/app/file-sp ... 5479?mt=12
Suspicious Package, analizzatore di pacchetti
http://www.mothersruin.com/software/SuspiciousPackage/
Pacifist, analizzatore e utility di pacchetti
https://www.charlessoft.com
Murus, personal firewall in entrata.
https://www.murusfirewall.com
Per curiosità, a che software appartiene la preferenza Um4dm?
Qualcosa che hai installato il 13 Novembre
lele_ct
Grazie mille Faxus per le gentili risposte!
Mi spiace per la mancata presentazione, avverrà a breve!
Circa l'ultima domanda...non ne ho la piu pallida idea...lo disinstallo?
Non riesco a trovare adobe viewer per disinstallarlo.. Come dovrei fare?
Grazie mille
lele_ct ha scritto:
lun, 07 gen 2019 17:52
... Circa l'ultima domanda...non ne ho la piu pallida idea...lo disinstallo?...
Non sapendo cosa sia è cautela non farlo.
Non si sa se è il metodo giusto o se si va a danneggiare un'applicazione utile.
Ho aggiunto la data di installazione, forse aiuta...
O usa EasyFind
http://www.devontechnologies.com/products/freeware/
Quasi sempre trovi il resto dei pezzi e si capisce cos'è
... Non riesco a trovare adobe viewer per disinstallarlo.. Come dovrei fare?...
Esegui:
sudo rm -rf /Library/Internet Plug-ins/AdobePDFViewer.plugin /Library/Internet Plug-ins/AdobePDFViewerNPAPI.plugin
Oppure
https://labs.adobe.com/downloads/acrobatcleaner.html
Visitano il forum: Google [Bot] e 22 ospiti
