Aggiornamento VLC
Polo
Oggetto del messaggio:
Messaggio da Polo »
fragrua ha scritto:Veramente i video della RAI li vedo con Safari
Con Safari ??? ops :shock:
... ma ... a parte il trucchetto/inganno con VLC, come fai a vedere i video della Rai con Safari se è proprio lui che chiede di installare Silverlight ?
-> io Paolo :) questo il mio garage Apple
È ovvio che l'ho installato, Silverlight.
Oggetto del messaggio: VLC Media Player 1.1.0
Rilasciato VLC Media Player 1.1.0.
Buon download: http://www.videolan.org/
Ecco le note di rilascio in inglese:
What's new in this version:
GPU decoding on Windows Vista and 7, using DxVA2 for H.264, VC-1 and MPEG-2
GPU decoding on GNU/Linux, using VAAPI for H.264, VC-1 and MPEG-2
DSP decoding using OpenMax IL, for compatible embedded devices
Improved support for MKV HD, including seeking fixes, and 7.1 channels codecs
Support for new codecs, like Blu-Ray subtitles, MPEG-4 lossless and VP8
New add-ons and script framework so one can personalize its vlc.
Support for WebM decoding and encoding
Improved web plugins
Better streaming capabilities
Integrated playlist in the Qt4 interface
Multiple views (like album art) in the playlist in the Qt4 interface
Support for AMR-NB, Mpeg-4 ALS, Vorbis 6.1/7.1, FLAC 6.1/7.1 and WMAS
CDDB and CD-Text works now on the Windows port when listening to CD-Audio
Support for DVD-Audio files (.aob)
Improved meta-data and album-art support
Faster decoding, with up to 40% speed-ups, in HD resolutions
First part of the Video Output core rewrite
Removal or rewrite of dozens of modules, code simplification and tens of thousands of lines of code removed
Some functionalities that are less used are now moved to extensions
More assembly optimizatinons, especially SSSE3/SSE4 and ARM Neon
Fewer threads used
Simplified and improved libVLC, removal of exceptions for better C integration
New phonon-backend for Qt applications, on all platforms
New C++ bindings
Polo
Messaggio da Polo »
Grazie,
io ho la versione 1.0.5 Goldeneye (Intel 32bit)
vado subilto di download :D
Rilasciato VLC Media Player 1.1.1 che risolve problemi di crash del programma in Multi-Channel, corregge e migliora il Multiple libVLC, aggiunge la decodifica DxVA2 su GPU ATI con Catalyst con 10.7, inoltre alcune correzioni all'interfaccia e ai vari decoder.
Aggiornate anche le traduzioni e altri fissati altri bug.
http://www.videolan.org/vlc/
enrico8
Messaggio da enrico8 »
 iMac 27" Late 2013 [SSD PCI-E 256 GB - 12 GB Ram- macOS Monterey 12.0.1 patched - Windows 11]
 Macbook 12" Early 2016 [SSD 256 GB - 8 GB Ram- macOS Monterey 12.0.1 - Windows 11]
 iPhone XS [64 GB - iOS 15.1]
 Time Capsule [2 TB - Refurbished]
francescolupo7
Lupus in fabula
Lupus in fabula
Messaggio da francescolupo7 »
che velocità!
_____________________________
Disponibile VLC Media Player 1.1.3 che fissa vari bug presenti nella versione precedente. Richiede Mac OS X 10.5 (Leopard) o successivi.
http://sourceforge.net/projects/vlc/fil ... g/download
Oggetto del messaggio: Re: VLC Media Player 1.1.0
Rilasciato VLC Media Player 1.1.5.
• 1000 Web-shows listing integrated inside VLC's playlist, provided by Channels.com
• New Game Music Emu (GME) support
• Windows SMB security issue - VideoLAN-SA-1006
• Major updates in translations, and new translations in Asturian, Armenian and Modern Greek
• Mac/Power-PC port fixed in 1.1.4.1
• live .webm streams support
• GPU HD decoding using Intel IGP on Windows, using DxVA2
• Miscellaneous fixes on all Interfaces, Demuxers and Decoders modules
• Codecs updates
Messaggio da Scialla »
Ma come mai, se da VLC ricerco aggiornamenti, avendo la 1.1.3 mi dice che ho la versione più aggiornata? :shock:
Scialla ha scritto:Ma come mai, se da VLC ricerco aggiornamenti, avendo la 1.1.3 mi dice che ho la versione più aggiornata? :shock:
Perché lo fa a tutti, è un bug.
e che cavolo, tirano fuori versioni nuove una dopo l'altra e non correggono un bug?? :shock:
Scialla ha scritto:e che cavolo, tirano fuori versioni nuove una dopo l'altra e non correggono un bug?? :shock:
È un bug della 1.1.3 che non vede la presenza dell'aggiornamento.
:-D
fracas
Oggetto del messaggio: VLC 1.1.6
Messaggio da fracas »
Aggiornato VLC alla versione 1.1.6 con queste novità:
- Security updates in codecs and demuxers
- Support for RTP/PCM 24bits, audio/L24
- Support for MPC SV7/SV8 on Windows and MacOS builds
- Faster Webm/VP8 decoding
- Support for Midi on MacOS
- Major updates in most language translations
- Support for projectM visualisation on Windows
- KDE and PulseAudio integration improvements
- Subtitles fixes and improvements
- Improvements in visualisations and interfaces
- Codecs updates
- Many miscellaneous fixes
Si scarica a partire da http://www.videolan.org/ oppure dal menu "Controlla aggiornamenti..." del programma stesso.
VLC 1.1.7 disponibile per il download.
