macOS High Sierra - discussione tecnica
U241
ok grazie
;) le lascio con EC, al massimo si vedrà a settembre
Cunnilingus is the new black
Salve.
Vi scrivo dalla atmosfera irreale di Recovery di HSierra.
Irreale perché qui è tutto azzurrino e le ventole al massimo, rinfrescano.
Se c'è un paradiso l'atmosfera sarà questa...
Ecco il diskutil list di Recovery
-bash-3.2# diskutil list
   #:                       TYPE NAME                    SIZE       IDENTIFIER
   0:      GUID_partition_scheme                        *250.1 GB   disk0
   1:                        EFI EFI                     209.7 MB   disk0s1
   2:                  Apple_HFS Macintosh SDD           189.2 GB   disk0s2
   3:                 Apple_Boot Recovery HD             650.0 MB   disk0s3
   4:                 Apple_APFS Container disk2         59.3 GB    disk0s4
   5:       Apple_KernelCoreDump                         655.4 MB   disk0s5
/dev/disk1 (disk image):
   0:      GUID_partition_scheme                        +2.1 GB     disk1
   1:                  Apple_HFS OS X Base System        2.0 GB     disk1s1
/dev/disk2 (synthesized):
   0:      APFS Container Scheme -                      +59.3 GB    disk2
                                 Physical Store disk0s4
   1:                APFS Volume HSierra                 12.0 GB    disk2s1
   2:                APFS Volume Preboot                 20.1 MB    disk2s2
   3:                APFS Volume Recovery                518.9 MB   disk2s3
   4:                APFS Volume VM                      4.3 GB     disk2s4
/dev/disk3 (disk image):
   0:                            untitled               +5.2 MB     disk3
/dev/disk4 (disk image):
   0:                            untitled               +524.3 KB   disk4
/dev/disk5 (disk image):
   0:                            untitled               +524.3 KB   disk5
/dev/disk6 (disk image):
   0:                            untitled               +524.3 KB   disk6
/dev/disk7 (disk image):
   0:                            untitled               +2.1 MB     disk7
/dev/disk8 (disk image):
   0:                            untitled               +524.3 KB   disk8
/dev/disk9 (disk image):
   0:                            untitled               +524.3 KB   disk9
/dev/disk10 (disk image):
   0:                            untitled               +12.6 MB    disk10
/dev/disk11 (disk image):
   0:                            untitled               +2.1 MB     disk11
/dev/disk12 (disk image):
   0:                            untitled               +1.0 MB     disk12
/dev/disk13 (disk image):
   0:                            untitled               +2.1 MB     disk13
/dev/disk14 (disk image):
   0:                            untitled               +524.3 KB   disk14
/dev/disk15 (disk image):
   0:                            untitled               +524.3 KB   disk15
/dev/disk16 (disk image):
   0:                            untitled               +1.0 MB     disk16
/dev/disk17 (disk image):
   0:                            untitled               +6.3 MB     disk17
/dev/disk18 (disk image):
   0:                            untitled               +6.3 MB     disk18
/dev/disk19 (disk image):
   0:                            untitled               +524.3 KB   disk19
/dev/disk20 (disk image):
   0:                            untitled               +2.1 MB     disk20
-bash-3.2#
Sono venuto a vedere perché avviando il Mac con alt ho la scelta fra:
Macintosh SSD (partizione di sistema con Sierra)
Recovery 10.12.1 (sì, proprio così)
HSierra (partizione di sistema con High Sierra)
Poi da HSierra ho riavviato con cmd+R e sono entrato nella partizione di ripristino di HSierra.
Evidentemente questo è l'unico modo
Edit: ad un certo punto da Recovery di Sierra non riuscivo più a vedere questa pagina.
Me lo impediva un blocco del parental control si Safari su Recovery di HSierra.
viewtopic.php?f=4&t=41073" onclick="window.open(this.href);return false;
Quindi continuo.
Ho verificato che è sempre possibile disattivare il Sip di HSierra
Catalambano
faxus ha scritto:
Uno_qualunque ha scritto:Vorrei capire bene le novità relative a APFS... qualcuno ha già chiaro cosa cambia rispetto a HFS+? La scelta di adottare un nuovo filesystem deve essere spinta da motivazioni forti, cosa c'è di nuovo e particolarmente vantaggioso rispetto al passato?
C'è già una discussione in proposito, sul Forum.
viewtopic.php?f=9&t=40638" onclick="window.open(this.href);return false;
Per il resto sto ancora armeggiando per installare con sicurezza.
Per adesso mi sembra di aver capito che posso usare anche due filesystem.
Sto per fare la prova pratica, poi ti dico
Mi stavo chiedendo la stessa cosa. Quest'anno non voglio sporcare l'iMac fino alla versione finale. Ho un nuovo mbp 13 late 2016, che però mi serve per lavoro. Se potessi partizionarlo e installare High Sierra su una sola partizione, convertendo solo questa in apfs, potrei sbizzarrirmi senza timore di nulla. In fondo, se si può fare con ntfs (Boot Camp) sarà possibile anche in questo caso. O no?
iMac Retina 5k late 2014 (Intel 4 ghz, 32 GB Ram, Radeon R9 m295X, SSD 1tb) - MacBook Pro 13" touch bar late 2016 (Intel 2,9 ghz, 16 GB Ram, SSD 512 GB) - iPad Pro 9.7 256 GB cellular - iPhone 6, 128gb
fenix
cosa e il sip?
Mac studio - macbookpro 2019 intel - macbookpro 2011 15"- 16 gb - ssd 1000 cx - high sierra -
Hammarby
Adesso forse si può aggiornare a Sierra, prima che mettano il capitano fuori manutenzione (sigh!)
Ma che schifo di filosofia quella di aggiornare OS una volta all'anno per risparmiare il costo di manutenzione...
Poi spacciare per novità un file system ampiamente copiato (e male)...
...e spesso peggio.
Cervantes
Catalambano ha scritto:... Se potessi partizionarlo e installare High Sierra su una sola partizione, convertendo solo questa in apfs, potrei sbizzarrirmi senza timore di nulla... O no?
Sì. Sto facendo questo, esattamente.
Se rileggi i posta dell'installazione lo potrai vedere elencato
fenix ha scritto:cosa e il sip?
https://support.apple.com/en-us/HT204899" onclick="window.open(this.href);return false;
https://en.wikipedia.org/wiki/System_In ... Protection" onclick="window.open(this.href);return false;
Safari 11...
Safari è in netta ripresa sulle performance precedenti.
Lo evidenzia il test html 5.
Che ha un senso limitato ma ce l'ha.
In realtà l'integrazione, la eccellente velocità (surclassa Chrome), la leggerezza (surclassa Firefox), lo fa preferire.
Ma comunque un senso ce l'ha sempre...
fenix
si vabbe è una protezione per non farmi fare troppi guasti e per questo motivo che ogni volta devo autorizzare alcunev cartelle e dischi per poterci scrivere che rottura ft gestione non funziona più sui nuovi os
lo ricorda anche franz quello che combinavo sui dish
fenix ha scritto:lo ricorda anche franz quello che combinavo sui dish
Indimenticabile Fenix.
Sì. Sto facendo questo, esattamente. .....
Perché allora non procurarsi un SSD esterno con interfaccia Thunderbolt e installare lì ......
faxus ha scritto: Siri... Hahaha, prende per il cu_o.
...... Gli chiedo di aprire la mia cartella utente:
Se ce lo mandassi come pensi che la prenderebbe?
Sto attrezzando come si deve High Sierra.
Hahaha... Veramente la differenza con Sierra è proprio poca.
Avevo fatto ridere Fragrua quando ho detto che rispetto a El Capitan Sierra poteva chiamarsi El Colonel...
Comincia ad annoiare...
In realtà funziona lo stesso.
È una finestra che si ripete spesso quando apri un'applicazione o fai qualche manovra
Intanto sistemiamo la questione del Gatekeeper che comincia a farsi noiosa
Sto postando da Yandex...
È più veloce di Safari e senza nessun problema con nessun sito.
Ho testato le app che uso su HSierra:
Funzionano bene
Istat Menus
Telegram
Skim
App Cleaner
Macs Fan Control (aggiornata il 6 Giugno)
cDock (disabilitare il SIP e installare SIMBL)
EtreCheck
Yandex
Opera Developer
FirefoxDeveloperEdition
IINA
Non funzionano
Safari Technology Preview (richiede Sierra)
Murus Firewall (OS non supportato)
fabio cf ha scritto:... quando hai tempo mi dic come e se va ps?...
Non uso nulla della suite Adobe.
Ma sui forum si dice che non va
Catalambano
Stai svegliando la scimmia, il mio Apple Pay comincia a preoccuparsi...
fenix
ho istallato su una partizione con sistema gia presente, al riavvio gli account sono diventati tutti standard .nessun amministratore. per cui non salva su nessun disco
