Aggiornamenti VMware Fusion
Oggetto del messaggio:
Rilasciato VMware Fusion 3.1
http://downloads.vmware.com/
What's new in this version:
Improved Overall Performance - 35% Faster than VMware Fusion 3.0
*Reduced time for suspending virtual machines
*Faster Windows application launch times
*Greatly improved scrolling speeds in Windows Vista and Windows 7 with Mac OS X 10.6.3
2D/3D Graphics Improvements - Up to 5X Better 3D Graphics than VMware Fusion 3.0
*OpenGL 2.1 for Windows Vista
*OpenGL 2.1 for Windows 7
*Greatly improved graphics performance
*Aero is much faster on Windows Vista and Windows 7
*Some games up to 10x faster than VMware Fusion 3.0 with VMware Fusion 3.1 and latest Mac OS X release
Unity Improvements
*Minimizing Unity apps to the dock now shows app contents
*Works with Exposé and Dock Exposé
USB "EasyConnect"
*Easily assign USB devices to virtual machine or Mac when connected
*Remember USB device assignment between Mac and virtual machine restarts
Bigger, More Complex Virtual Machines
*8-way SMP
*2 TB virtual disks
PC Migration Improvements
*Improvements to Migrate Your PC assistant, including better validation of names and better location prompt
*Prompt user if Mac OS X guest account prevents guest access to shared folders instead of failing
*Open new virtual machine upon successful migration
*Enhanced user interface on PC being migrated including:
New progress dialog on the PC being migrated as well as in VMware Fusion
Option to show converter logs and troubleshooting steps on PC if PC migration fails
Avoids port conflicts with Web server software installed on PC being migrated such as IIS, Tomcat, and Apache
Boot Camp Improvements
*Up to 5x disk performance in Boot Camp virtual machines
*New option to minimize prompting for password (authentication dialogs) when using Boot Camp virtual machines
*Handle Mac OS X disk changes better to avoid multiple references to Boot Camp partition in the Virtual Machine Library
*Support for Office 2010 activation in Boot Camp virtual machines
OVF Tool 2 Comes with VMware Fusion 3.1
*Directly convert between any vSphere, VMX, or OVF source format to any vSphere, VMX, or OVF target format
*Deploy virtual machines to vSphere using OVF Tool
*Import and export of OVF packages into a vApprun 1.0 workspace.
User Interface Enhancements
*Drag a disk image or virtual disk to the installation media pane of the assistant
*Add shortcut for opening a virtual machines configuration file in default text editor for VMware Fusion (Hold down option and right-click in Virtual Machine Library)
*User Experience Improvement Program
New Guest Operating Systems Supported
*Ubuntu 8.0.4.4: 32- and 64-bit
*Ubuntu 10.04: 32- and 64-bit
*SUSE Linux Enterprise Desktop 11 Service Pack 1: 32- and 64-bit
*SUSE Linux Enterprise Server 11 Service Pack 1: 32- and 64-bit
*RHEL 5.4: 32- and 64-bit
Rilasciato VMware Fusion 3.1.2, un aggiornamento che risolve numerosi problemi.
https://www.vmware.com/tryvmware/
Rilasciato VMware Fusion 3.1.3.
Il download degli aggiornamenti di Fusion richiede il login.
iKrypt
Messaggio da iKrypt »
Rilasciata vmware-fusion 3.1.3.
Con windows va meglio, ma linux lo lascia con un sacco di problemi nell'installazione dei vmware-tools, che vmware-fusion rende obbligatorio ma non dice come si deve fare.
Ho già fatto una richiesta di aiuto a riguardo, quindi non mi prodigo in quanto non è la sezione adatta.
iKrypt
iKrypt ha scritto:Rilasciata vmware-fusion 3.1.3.
rettifico. Ho sbagliato io i comandi da terminale. Tutto bene anche con linux. Fedora 15 non è compatibile (per ora) con i vmware-tools. Comunque la 14 va, senza le cartelle in condivisione.
Oggetto del messaggio: Re: Aggiornamenti VMware Fusion
fragrua ha scritto:Si scarica a partire da qui:
http://www.vmware.com/download/fusion/" onclick="window.open(this.href);return false;
Rilasciato VMware Fusion 4.1.0 che stranamente permetterebbe l'avvio di Mac OS X 10.5, 10.6 e 10.7 client.
Rilasciato VMware Fusion 4.1.0.
Sto cercando di installare Mac OS X Client su Fusion 4.1 e funziona, però solo Leopard, mentre Snow Leopard mi espone il divieto.
http://blogs.vmware.com/teamfusion/2011 ... hines.html" onclick="window.open(this.href);return false;
Mah…
Ecco qui, prontamente rilasciato VMware Fusion 4.1.1 che "risolve" il problema legale, e cioè esclude la possibilità di avviare Sistemi Mac OS X client su richieste specifiche di Apple.
Quindi chi ci tiene a virtualizzare altri OS made in Cupertino, oltre ai server, farebbe bene a restare alla versione 4.1.0.
Ieri è stato rilasciato VMware Fusion 4.1.2 che risolve oltre 20 problemi, fra cui:
Risolto un “messaggio di memoria insufficiente” dopo la ripresa di alcune macchine virtuali.
Risolto un problema di stampa intermittente quando si utilizza Mac OS X Lion.
Risolto un problema con la funzione di copia e incolla sulle distribuzioni Linux più recenti.
Risolto l'accesso ai file in cartelle condivise utilizzando nomi brevi.
Numerosi miglioramenti nella compatibilità con Mac OS X, incluso Developer ID.
Risolto un problema di spegnimento in Windows 2000.
Versione aggiornata di McAfee VirusScan.
Per ulteriori informazioni, consultare le note di rilascio di VMware Fusion.
Ma io continuo a tenermi stretto il 4.1!
Appena rilasciato VMware Fusion 4.1.3…io continuo a tenermi stretto il 4.1!
:D
francescolupo7
Lupus in fabula
Lupus in fabula
Messaggio da francescolupo7 »
fragrua ha scritto:Appena rilasciato VMware Fusion 4.1.3…io continuo a tenermi stretto il 4.1!
:D
antiquato... ;)
_____________________________
VMware Fusion - 5.0.0
Designed for Mountain Lion - Run Windows on Mountain Lion and search Windows programs in Launchpad, use "AirPlay Mirroring" to stream Mac and Windows applications on an HDTV and get VMware Fusion notifications in Mountain Lion's notification center.
Windows 8 Optimization - VMware Fusion 5 supports Windows 8 standard, pro and enterprise editions so consumers can optimize the new Windows 8 "Metro" environment directly on a Mac.
Enhanced Mac Support - Support for the latest Mac technologies include compatibility with Mountain Lion, retina display optimization, USB 3 connectivity, and improved support for large memory Macs.
Next Generation Performance - Performance enhancements include up to 40% faster general performance speeds compared to the previous version of the product, improved power management for longer battery life and faster 3D graphics.
Additional Functionalities - New, powerful ways to experience Windows on a Mac are available through an updated virtual machine library that enables seamless transitions between multiple operating systems, one click snapshots with improved graphical appearance, a brand new graphics driver for Linux 3D desktops, and a new embedded learning center for immediate support.
https://my.vmware.com/web/vmware/info/s ... fusion/5_0" onclick="window.open(this.href);return false;
Messaggio da Scialla »
Franz ma scusa, ma il 4.1 (che ho anche io) ti funziona ancora sotto M-lion?
A me no.... :evil:
Scialla ha scritto:Franz ma scusa, ma il 4.1 (che ho anche io) ti funziona ancora sotto M-lion?
A me no.... :evil:
Non so, perché Mountain Lion ce l'ho sul portatile, mentre VMware Fusion ce l'ho sul Mac Pro che non supporta l'ultimo felino di Apple.
Dovrei installare Mountain Lion sul portatile per risponderti, ma pensandoci bene chi m'o ffa fà? :twisted:
VMware Fusion - 5.0.1
https://my.vmware.com/web/vmware/detail ... &rPId=2979" onclick="window.open(this.href);return false;
