Blocco senza rotella ....
paraffo
Saluti a tutti!
Ieri ho installato El Capitan. Tutto bene salvo che, ogni tanto, il mio iMac si blocca. Nessuna rotella che gira e il cursore del mouse si muove normalmente.
Dopo un minuto (forse meno) riparte tutto.
C'é qualcosa che debba fare per risolvere 'sto problema non grave, ma seccante?
Grazie! :lol:
iMac 27" (metà 2011) 2.7 GHz Intel Core i5 RAM 20 GB OS X El Capitan 10.11
Bonnie3
Installato da zero o aggiornato? Il Mac è quello in firma?
paraffo
Sì, é quello in firma e la installazione e' stata in forma di aggiornamento, come faccio sempre ....
paraffo
Sperando possa essere utile a capire cosa succede:
Oct 5 05:14:54 iMac-di-Paolo AddressBookSourceSync[7579]: Error, could not create MachMessagePort for com.apple.AddressBook.abd
Oct 5 05:15:08 iMac-di-Paolo AddressBookSourceSync[7579]: -[ABAddressBook save] failed. (<ABAddressBook: 0x7fb83b4887e0>)
Oct 5 05:15:08 iMac-di-Paolo AddressBookSourceSync[7579]: [CardDAVPlugin-ERROR] -_saveChanges: [syncAddressBook(<ABAddressBook: 0x7fb83b4887e0>) save] FAILED
Oct 5 05:15:10 iMac-di-Paolo AddressBookManager[7846]: Validate metadata timed out, cancelling
Oct 5 05:15:10 iMac-di-Paolo AddressBookManager[7846]: *** -[NSRecursiveLock unlock]: lock (<NSRecursiveLock: 0x7f8cfb76ea60> '/private/var/folders/83/xl3g5gdj68n_d5t1z13jnmlc0000gn/T/.AddressBookLocks/_Users_pg_Library_Application Support_AddressBook_Sources_63872BD6-04D8-45BF-9F1E-559C22693B41_Metadata_.MetaData.lock_lock') unlocked when not locked
Oct 5 05:15:10 iMac-di-Paolo AddressBookManager[7846]: *** Break on _NSLockError() to debug.
Oct 5 05:15:14 iMac-di-Paolo AddressBookSourceSync[7579]: Error, could not create MachMessagePort for com.apple.AddressBook.abd
Oct 5 05:15:28 iMac-di-Paolo AddressBookSourceSync[7579]: -[ABAddressBook save] failed. (<ABAddressBook: 0x7fb83b4887e0>)
Oct 5 05:15:28 iMac-di-Paolo AddressBookSourceSync[7579]: [CardDAVPlugin-ERROR] -_saveChanges: [syncAddressBook(<ABAddressBook: 0x7fb83b4887e0>) save] FAILED
Oct 5 05:15:30 iMac-di-Paolo AddressBookManager[7847]: Validate metadata timed out, cancelling
Oct 5 05:15:30 iMac-di-Paolo AddressBookManager[7847]: *** -[NSRecursiveLock unlock]: lock (<NSRecursiveLock: 0x7f9d43df6220> '/private/var/folders/83/xl3g5gdj68n_d5t1z13jnmlc0000gn/T/.AddressBookLocks/_Users_pg_Library_Application Support_AddressBook_Sources_63872BD6-04D8-45BF-9F1E-559C22693B41_Metadata_.MetaData.lock_lock') unlocked when not locked
Oct 5 05:15:30 iMac-di-Paolo AddressBookManager[7847]: *** Break on _NSLockError() to debug.
Oct 5 05:15:34 iMac-di-Paolo AddressBookSourceSync[7579]: Error, could not create MachMessagePort for com.apple.AddressBook.abd
Bonnie3
Posta un log di EtreCheck http://www.etresoft.com/etrecheck" onclick="window.open(this.href);return false; e il log di un riavvio che trovi in console (apri console, segnati l'ora precisa, riavvia e poi riapri console e trova il log del riavvio)
Visto che ci sei controlla lo stato del disco con Smart utility https://www.volitans-software.com/apps/smart-utility/" onclick="window.open(this.href);return false;
paraffo
Grazie della risposta, Bonnie. Ti mando la prima cosa che mi hai richiesto. Per la seconda (report della Console), temo di non aver capito sotto quale voce del menu (di Console) trovo il log del riavvio. Potresti indicarmelo?
Grazie mille ...
EtreCheck version: 2.5.3 (206)
Report generated 10/5/15, 2:54 PM
Download EtreCheck from http://etresoft.com/etrecheck" onclick="window.open(this.href);return false;
Click the [Click for support] links for help with non-Apple products.
Click the [Click for details] links for more information about that line.
Hardware Information: (What does this mean?)
iMac (27-inch, Mid 2011)
[Click for Technical Specifications]
[Click for User Guide]
iMac - model: iMac12,2
1 2,7 GHz Intel Core i5 CPU: 4-core
20 GB RAM Upgradeable
[Click for upgrade instructions]
BANK 0/DIMM0
2 GB DDR3 1333 MHz ok
BANK 1/DIMM0
8 GB DDR3 1333 MHz ok
BANK 0/DIMM1
BANK 1/DIMM1
Wireless: en1: 802.11 a/b/g/n
Video Information: (What does this mean?)
AMD Radeon HD 6770M - VRAM: 512 MB
iMac 1280 x 720
SAMSUNG 1280 x 720
System Software: (What does this mean?)
OS X El Capitan 10.11 (15A284) - Time since boot: about 9 hours
Disk Information: (What does this mean?)
ST32000541AS disk0 : (2 TB) (Rotational)
iMac HD_Avvio (disk0s2) /Volumes/iMac HD_Avvio : 285.33 GB (284.90 GB free)
Recovery HD (disk0s3) /Volumes/Recovery HD [Recovery]: 113.92 GB (113.66 GB free)
iMac HD (disk0s4) / : 1.38 TB (1.26 TB free)
Recovery HD (disk0s5) <not mounted> [Recovery]: 650 MB
iMac HD 2 (disk0s6) /Volumes/iMac HD 2 : 210.71 GB (59.34 GB free)
OPTIARC DVD RW AD-5680H ()
USB Information: (What does this mean?)
Apple Inc. BRCM2046 Hub
Primax Electronics Apple Optical USB Mouse
Apple Card Reader
Thunderbolt Information: (What does this mean?)
Apple Inc. thunderbolt_bus
Gatekeeper: (What does this mean?)
Kernel Extensions: (What does this mean?)
/Library/Extensions
[loaded] com.globaldelight.driver.BoomDevice (1.3 - SDK 10.9) [Click for support]
/System/Library/Extensions
[not loaded] com.cisco.nke.ipsec (2.0.1) [Click for support]
[not loaded] com.elgato.driver.DontMatchAfaTech (1.1) [Click for support]
[not loaded] com.elgato.driver.DontMatchCinergy450 (1.1) [Click for support]
[not loaded] com.elgato.driver.DontMatchCinergyXS (1.1) [Click for support]
[not loaded] com.elgato.driver.DontMatchEmpia (1.1) [Click for support]
[not loaded] com.elgato.driver.DontMatchVoyager (1.1) [Click for support]
[not loaded] com.pctools.iantivirus.kfs (1.0.1) [Click for support]
[not loaded] com.roxio.BluRaySupport (1.1.3) [Click for support]
[not loaded] com.targus.driver.EventDriver (2.1.0f2) [Click for support]
[not loaded] com.wdc.driver.USBHP (1.0.2) [Click for support]
/Volumes/iMac HD 2/Applications/Altre applicazioni/MacX Video Converter Pro.app
[not loaded] com.macxdvd.driver.goodSysAudioCapture (1 - SDK 10.10) [Click for support]
/Volumes/iMac HD 2/Applications/Altre applicazioni/Toast Titanium.app
[not loaded] com.roxio.TDIXController (1.7) [Click for support]
Launch Agents: (What does this mean?)
[loaded] com.oracle.java.Java-Updater.plist [Click for support]
[running] com.teamviewer.teamviewer.plist [Click for support]
[running] com.teamviewer.teamviewer_desktop.plist [Click for support]
[running] com.wdc.raidmanagerstatusmenu.plist [Click for support]
[loaded] org.macosforge.xquartz.startx.plist [Click for support]
Launch Daemons: (What does this mean?)
[loaded] com.adobe.fpsaud.plist [Click for support]
[loaded] com.bombich.ccc.plist [Click for support]
[loaded] com.bombich.ccchelper.plist [Click for support]
[running] com.iobit.AMCDaemon.plist [Click for support]
[loaded] com.macpaw.CleanMyMac2.Agent.plist [Click for support]
[loaded] com.microsoft.office.licensing.helper.plist [Click for support]
[loaded] com.oracle.java.Helper-Tool.plist [Click for support]
[loaded] com.teamviewer.Helper.plist [Click for support]
[running] com.teamviewer.teamviewer_service.plist [Click for support]
[running] com.wdc.SmartwareDriveService.plist [Click for support]
[running] com.wdc.WDRAIDDriveService.plist [Click for support]
[running] com.wdc.WDSmartWareService.plist [Click for support]
[loaded] com.westerndigital.WD-Drive-Manager-Installer.plist [Click for support]
[loaded] org.macosforge.xquartz.privileged_startx.plist [Click for support]
User Launch Agents: (What does this mean?)
[loaded] Javeview.update.plist [Click for support]
[loaded] Manroling.update.plist [Click for support]
[loaded] Otwexplain.AppRemoval.plist [Click for support]
[loaded] Otwexplain.download.plist [Click for support]
[loaded] Otwexplain.ltvbit.plist [Click for support]
[running] Otwexplain.update.plist [Click for support]
[loaded] Perfetnight.AppRemoval.plist [Click for support]
[loaded] Perfetnight.download.plist [Click for support]
[loaded] Perfetnight.ltvbit.plist [Click for support]
[running] Perfetnight.update.plist [Click for support]
[loaded] com.adobe.ARM.[...].plist [Click for support]
[running] com.iobit.MacBoosterMini.plist [Click for support]
[loaded] com.macpaw.CleanMyMac2Helper.diskSpaceWatcher.plist [Click for support]
[loaded] com.macpaw.CleanMyMac2Helper.scheduledScan.plist [Click for support]
[loaded] com.macpaw.CleanMyMac2Helper.trashWatcher.plist [Click for support]
[running] com.pcv.hlpramc.plist [Click for support]
User Login Items: (What does this mean?)
Jumpcut Applicazione (/Applications/Altre applicazioni/Jumpcut.app)
Alarm Clock Applicazione (/Applications/Altre applicazioni/Alarm Clock.app)
Other Apps: (What does this mean?)
[running] 2BUA8C4S2C.com.agilebits.onepassword-osx-helper
[running] com.apple.xpc.launchd.oneshot.0x10000004.ChitChat
[running] com.apple.xpc.launchd.oneshot.0x10000005.AdobeReader
[running] com.apple.xpc.launchd.oneshot.0x10000006.Skype
[running] com.apple.xpc.launchd.oneshot.0x1000000f.EtreCheck
[running] com.digitallity.alarmclock2.47392
[running] net.sf.Jumpcut.49632
Internet Plug-ins: (What does this mean?)
o1dbrowserplugin: Version: 5.38.6.0 - SDK 10.8 [Click for support]
PandoWebInst: Version: 1.0 [Click for support]
Default Browser: Version: 601 - SDK 10.11
Unity Web Player: Version: UnityPlayer version 4.5.2f1 - SDK 10.6 [Click for support]
RealPlayer Plugin: Version: Unknown [Click for support]
PDF Browser Plugin: Version: 2.2.3 [Click for support]
FlashPlayer-10.6: Version: 19.0.0.185 - SDK 10.6 [Click for support]
DivX Web Player: Version: 3.2.4.1250 - SDK 10.6 [Click for support]
Silverlight: Version: 5.1.40416.0 - SDK 10.6 [Click for support]
QuickTime Plugin: Version: 7.7.3
Flash Player: Version: 19.0.0.185 - SDK 10.6 [Click for support]
googletalkbrowserplugin: Version: 5.38.6.0 - SDK 10.8 [Click for support]
NP_2020Player_IKEA: Version: 5.0.94.1 - SDK 10.6 [Click for support]
iPhotoPhotocast: Version: 7.0
np-tfglaunch-plugin: Version: ©Tenderfoot Games, LLC. All rights reserved. [Click for support]
PDEPrint: Version: 2.0 [Click for support]
SharePointBrowserPlugin: Version: 14.0.0 [Click for support]
WidevineMediaTransformer: Version: Unknown [Click for support]
JavaAppletPlugin: Version: Java 8 Update 60 build 27 Check version
User internet Plug-ins: (What does this mean?)
Google Earth Web Plug-in: Version: 7.1 [Click for support]
Safari Extensions: (What does this mean?)
1Password
AdBlock
ClickToFlash
Ember
Webmemes
Translate
Audio Plug-ins: (What does this mean?)
DVCPROHDAudio: Version: 1.2
3rd Party Preference Panes: (What does this mean?)
A Better Finder Preferences [Click for support]
AppTrap [Click for support]
Déjà Vu [Click for support]
Flash Player [Click for support]
Front Row Trailers [Click for support]
Java [Click for support]
MacFUSE [Click for support]
NTFS-3G [Click for support]
Perian [Click for support]
Quicktime X Preferences [Click for support]
Targus [Click for support]
Time Machine: (What does this mean?)
Skip System Files: NO
Volumes being backed up:
Destinations:
Time Machine iMac [Local]
Total size: 0 B
Total number of backups: 0
Oldest backup: -
Last backup: -
Size of backup disk: Excellent
Backup size 0 B > (Disk size 0 B X 3)
Top Processes by CPU: (What does this mean?)
69% AddressBookSourceSync
34% AddressBookManager
2% WindowServer
1% launchd
1% fontd
Top Processes by Memory: (What does this mean?)
1.22 GB kernel_task
451 MB softwareupdated
348 MB com.apple.WebKit.WebContent(2)
348 MB mdworker(17)
328 MB AddressBookSourceSync
Virtual Memory Information: (What does this mean?)
12.00 GB Free RAM
8.26 GB Used RAM (4.46 GB Cached)
0 B Swap Used
Diagnostics Information: (What does this mean?)
Oct 5, 2015, 02:51:17 PM ~/Library/Logs/DiagnosticReports/AppAS_2015-10-05-145117_[redacted].crash
Oct 5, 2015, 02:51:17 PM ~/Library/Logs/DiagnosticReports/AppEH_2015-10-05-145117_[redacted].crash
Oct 5, 2015, 02:41:05 PM /Library/Logs/DiagnosticReports/AddressBookSourceSync_2015-10-05-144105_[redacted].cpu_resource.diag [Click for details]
Oct 5, 2015, 11:00:50 AM /Library/Logs/DiagnosticReports/AddressBookSourceSync_2015-10-05-110050_[redacted].cpu_resource.diag [Click for details]
Oct 5, 2015, 07:06:30 AM ~/Library/Logs/DiagnosticReports/AppAS_2015-10-05-070630_[redacted].crash
Oct 5, 2015, 07:06:30 AM ~/Library/Logs/DiagnosticReports/AppEH_2015-10-05-070630_[redacted].crash
Oct 5, 2015, 06:28:06 AM /Library/Logs/DiagnosticReports/AddressBookSourceSync_2015-10-05-062806_[redacted].cpu_resource.diag [Click for details]
Oct 5, 2015, 05:28:34 AM /Library/Logs/DiagnosticReports/AddressBookSourceSync_2015-10-05-052834_[redacted].cpu_resource.diag [Click for details]
Oct 5, 2015, 05:23:50 AM Self test - passed
Oct 5, 2015, 04:39:57 AM /Library/Logs/DiagnosticReports/AddressBookSourceSync_2015-10-05-043957_[redacted].cpu_resource.diag [Click for details]
Oct 4, 2015, 11:03:48 PM /Library/Logs/DiagnosticReports/AddressBookSourceSync_2015-10-04-230348_[redacted].cpu_resource.diag [Click for details]
Oct 4, 2015, 02:42:24 PM /Library/Logs/DiagnosticReports/AddressBookSourceSync_2015-10-04-144224_[redacted].cpu_resource.diag [Click for details]
Oct 4, 2015, 01:59:04 PM ~/Library/Logs/DiagnosticReports/AppAS_2015-10-04-135904_[redacted].crash
Oct 4, 2015, 01:59:04 PM ~/Library/Logs/DiagnosticReports/AppEH_2015-10-04-135904_[redacted].crash
Oct 4, 2015, 01:23:52 PM ~/Library/Logs/DiagnosticReports/AppAS_2015-10-04-132352_[redacted].crash
Oct 4, 2015, 01:23:52 PM ~/Library/Logs/DiagnosticReports/AppEH_2015-10-04-132352_[redacted].crash
Oct 4, 2015, 01:18:41 PM /Library/Logs/DiagnosticReports/gimp-2.8_2015-10-04-131841_[redacted].cpu_resource.diag [Click for details]
Oct 4, 2015, 01:12:12 PM /Library/Logs/DiagnosticReports/AddressBookSourceSync_2015-10-04-131212_[redacted].cpu_resource.diag [Click for details]
Oct 4, 2015, 12:06:50 PM ~/Library/Logs/DiagnosticReports/AppAS_2015-10-04-120650_[redacted].crash
Oct 4, 2015, 12:06:50 PM ~/Library/Logs/DiagnosticReports/AppEH_2015-10-04-120650_[redacted].crash
Oct 4, 2015, 12:05:51 PM ~/Library/Logs/DiagnosticReports/AppAS_2015-10-04-120551_[redacted].crash
Oct 4, 2015, 12:05:51 PM ~/Library/Logs/DiagnosticReports/AppEH_2015-10-04-120551_[redacted].crash
Oct 4, 2015, 11:42:03 AM /Library/Logs/DiagnosticReports/AddressBookSourceSync_2015-10-04-114203_[redacted].cpu_resource.diag [Click for details]
Oct 4, 2015, 11:08:32 AM ~/Library/Logs/DiagnosticReports/AppAS_2015-10-04-110832_[redacted].crash
Oct 4, 2015, 11:08:32 AM ~/Library/Logs/DiagnosticReports/AppEH_2015-10-04-110832_[redacted].crash
Oct 4, 2015, 10:46:48 AM ~/Library/Logs/DiagnosticReports/AppEH_2015-10-04-104648_[redacted].crash
Oct 4, 2015, 10:46:15 AM ~/Library/Logs/DiagnosticReports/AppAS_2015-10-04-104615_[redacted].crash
Oct 4, 2015, 10:46:15 AM ~/Library/Logs/DiagnosticReports/AppEH_2015-10-04-104615_[redacted].crash
Oct 4, 2015, 10:38:53 AM ~/Library/Logs/DiagnosticReports/AppAS_2015-10-04-103853_[redacted].crash
Oct 4, 2015, 10:38:53 AM ~/Library/Logs/DiagnosticReports/AppEH_2015-10-04-103853_[redacted].crash
Oct 4, 2015, 10:31:35 AM ~/Library/Logs/DiagnosticReports/AppAS_2015-10-04-103135_[redacted].crash
Oct 4, 2015, 10:11:52 AM /Library/Logs/DiagnosticReports/AddressBookSourceSync_2015-10-04-101152_[redacted].cpu_resource.diag [Click for details]
Oct 4, 2015, 10:08:07 AM ~/Library/Logs/DiagnosticReports/AppEH_2015-10-04-100807_[redacted].crash
Oct 4, 2015, 10:08:07 AM ~/Library/Logs/DiagnosticReports/AppAS_2015-10-04-100807_[redacted].crash
Oct 4, 2015, 09:58:50 AM ~/Library/Logs/DiagnosticReports/AppAS_2015-10-04-095850_[redacted].crash
Oct 4, 2015, 09:58:50 AM ~/Library/Logs/DiagnosticReports/AppEH_2015-10-04-095850_[redacted].crash
Oct 4, 2015, 09:11:25 AM ~/Library/Logs/DiagnosticReports/AppAS_2015-10-04-091125_[redacted].crash
Oct 4, 2015, 09:11:25 AM ~/Library/Logs/DiagnosticReports/AppEH_2015-10-04-091125_[redacted].crash
Bonnie3
E te credo che si blocca! C'è tanta spazzatura che rallenta!
Elimina com.pctools.iantivirus.kfs , MacBooster e CleanMyMac all'istante ed elimina i residui cercando con le parole chiave tipo "iobit" "CleanMyMac" "MacPaw" "pctools" "iantivirus" "Macbooster" con EasyFind http://www.devontechnologies.com/download/products.html" onclick="window.open(this.href);return false;
Ricorda che sui Mac gli antivirus non servono, anzi sono loro a creare i problemi ;)
Vai anche su preferenze di sistema > utenti e gruppi > elementi login > seleziona tutte le app che non ti servono all'avvio cliccandoci sopra una volta e poi clicca sull'iconcina col simbolo "-" .
Per il log del riavvio vado a memoria che non ho il Mac davanti:
Clicca su spotlight (lente di ingrandimento in alto a destra) scrivi console e clicca sul risultato.
Una volta in console sulla sinistra ci dovrebbe essere scritto qualcosa come syslog o System log da qualche parte. Ti segni l'ora precisa su un foglio, riavvii e una volta avviato riapri console e copi il log dall'ora che ti sei segnato sul foglio fino all'arrivo sul desktop e lo copi qui come risposta anche in più post. Ricordati di togliere i dati personali ;)
Edit: Vedo che la rubrica indirizzi (o almeno credo sia quella) ti va spesso in crash ma non so perché...prova a leggere qui viewtopic.php?f=20&t=19387" onclick="window.open(this.href);return false;
paraffo
Con appena un po' di ritardo (cosa sono 5 mesi, in fondo? Un battito di ciglia a fronte dell' eternità), rieccomi con il solito problema che mi perseguita da quando sono passato a El Capitan, malgrado mi sia - nel frattempo - deciso ad effettuare una re-installazione pulita.
Il Mac mi si inchioda, molto spesso, solo quando evidenzio porzioni di testo, sia in mail, che in Skype (come stamattina), che in Safari ecc. Non riesco ad uscire dalla evidenziazione, il mouse si muove, ma non funziona più' niente. Per uscire devo fare la forzata (cmd+alt+esc), usando il tasto Return della tastiera ....
Sperando che sia sufficiente, posto qui un pezzo di system.log. Grazie in anticipo ... :lol:
Feb 13 10:40:19 iMac-di-paolo UserEventAgent[45]: Captive: Removing SSID registrations for 3127
Feb 13 10:40:19 iMac-di-paolo com.apple.xpc.launchd[1] (com.skype.skype.237472[3127]): Service exited due to signal: Terminated: 15
Feb 13 10:40:46 iMac-di-paolo lsd[294]: LaunchServices: Could not store lsd-identifiers file at /private/var/db/lsd/com.apple.lsdschemes.plist
Feb 13 10:40:46 --- last message repeated 1 time ---
Feb 13 10:40:46 iMac-di-paolo Console[3465]: Failed to connect (_consoleX) outlet from (NSApplication) to (ConsoleX): missing setter or instance variable
Feb 13 10:40:46 iMac-di-paolo bird[307]: LaunchServices: Failed to create bundleProxy for bundle com.apple.Console
Feb 13 10:41:41 iMac-di-paolo Skype[3466]: ### Failed to load Addressbook class CNContactNameFormatter
Feb 13 10:41:53 iMac-di-paolo syslogd[44]: ASL Sender Statistics
Feb 13 10:41:53 iMac-di-paolo com.apple.AddressBook.ContactsAccountsService[319]: [Accounts] Current connection, <NSXPCConnection: 0x7fa62a5093f0> connection from pid 3466, doesn't have account access.
Feb 13 10:41:53 iMac-di-paolo Skype[3466]: [Accounts] Failed to update account with identifier F21BB0F4-644E-4001-A461-C5FCC85C8BC1, error: Error Domain=ABAddressBookErrorDomain Code=1002 "(null)"
Feb 13 10:41:53 iMac-di-paolo com.apple.WebKit.WebContent[1274]: [10:41:53.518] FigAgglomeratorSetObjectForKey signalled err=-16020 (kFigStringConformerError_ParamErr) (NULL key) at /Library/Caches/com.apple.xbs/Sources/CoreMedia/CoreMedia-1731.15.33/Prototypes/LegibleOutput/FigAgglomerator.c line 92
Feb 13 10:42:00 --- last message repeated 1 time ---
Feb 13 10:42:00 iMac-di-paolo Safari[1612]: KeychainGetICDPStatus: keychain: -25300
Feb 13 10:42:00 iMac-di-paolo Safari[1612]: KeychainGetICDPStatus: status: off
Feb 13 10:43:11 iMac-di-paolo Skype[3466]: Failed to get contents of directory "/Users/paologrenga/Library/Logs/Skype". Impossibile aprire il file “Skype” perché non esiste.
Feb 13 10:43:23 iMac-di-paolo UserEventAgent[45]: Captive: Removing SSID registrations for 3466
Feb 13 10:43:23 iMac-di-paolo com.apple.xpc.launchd[1] (com.skype.skype.237472[3466]): Service exited due to signal: Terminated: 15
Feb 13 10:44:56 iMac-di-paolo Safari[1612]: tcp_connection_tls_session_error_callback_imp 409 __tcp_connection_tls_session_callback_write_block_invoke.434 error 22
Feb 13 10:45:07 iMac-di-paolo netbiosd[2553]: findReachableAddress: Using port 139 family = 33
Feb 13 10:45:07 iMac-di-paolo kernel[0]: smb1_smb_negotiate: Support for the server ALICEGATE has been deprecated (PreXP), disconnecting
Feb 13 10:46:14 iMac-di-paolo BezelServices 255.10[95]: ASSERTION FAILED: dvcAddrRef != ((void *)0) -[DriverServices getDeviceAddress:] line: 2789
Bonnie3
Per questo tipo di log c'è bisogno di Faxus che sicuramente leggerà. :D
Lascia perdere il log di un riavvio, per carità.
Con El Capitan si usa solo in casi disperati.
Va ben quel che hai mandato.
Aspetta la risposta di Bonnie.
Poi semmai la studieranno altri utenti.
Leggo adesso la risposta di Bonnie.
A più tardi
cicciopasticcio
paraffo ha scritto:Con appena un po' di ritardo (cosa sono 5 mesi, in fondo? Un battito di ciglia a fronte dell' eternità), rieccomi con il solito problema che mi perseguita da quando sono passato a El Capitan, malgrado mi sia - nel frattempo - deciso ad effettuare una re-installazione pulita.
Pensavo che ci fossero voluti 5 mesi per cavarsi da quel ginepraio che era il tuo Mac... :D
Ottima mossa, l'installazione pulita. Chiaramente, avrai prima INIZIALIZZATO il tuo HD e poi installato OS X, SENZA ripristinare Sistema nè Applicazioni. E' così, vero?
E hai trascorso qualche settimana in compagnia del Mac "come mamma Apple l'ha fatto", senza utility, skype vari, e gadget non-indispensabili? E funzionava bene?
Io temo che il primo da sospettare sia un problema di software, magari qualche strana utility di scrivania...
Esci da iCloud, dopo essere uscito da Contatti ed aver escluso Contatti da iCloud.
Vai nella tua Libreria utente, Finder, premi il tasto alt e trovala sotto il menù Vai.
Cancella il file > Application Support/AddressBook/Metadata
È la prima cosa da provare.
È un guasto difficile...
La prima volta era un problema di un guasto da un raro malware, risolto con la reinstallazione.
Forse adesso il problema è una sua conseguenza del danno fatto
paraffo
faxus ha scritto:Esci da iCloud, dopo essere uscito da Contatti ed aver escluso Contatti da iCloud.
Grazie a tutti, per l'interessamento.
Ho eseguito le tue istruzioni, caro Faxus. Spero di averle ben interpretate, togliendo la spunta a iCloud, in Preferenze di sistema e cancellando i file presenti nella cartella Metadata (ma non la cartella stessa).
Vi terrò aggiornati ....
paraffo
cicciopasticcio ha scritto:Pensavo che ci fossero voluti 5 mesi per cavarsi da quel ginepraio che era il tuo Mac... :D
Si, caro Cicciopasticcio, ho fatto, per la re-installazione, tutto quanto dici (senza alcun ripristino) ma NO, nessuna luna di miele, il problema si é ripresentato subito!
Il lato positivo é che prima, quando il mio mac era incasinato, non avevo capito che fosse l' evidenziazione che provocava il blocco ....
Ultima modifica di paraffo il dom, 14 feb 2016 08:47, modificato 1 volta in totale.
ratava
paraffo ha scritto:Saluti a tutti!
Grazie! :lol:
Ciao, guarda che non sei mica il solo a cui manca una rotella in questo forum! :D :)
 Hic manebimus optime
