Zen ha scritto:Prova allora così: Preferenze di sistema->Risparmio energia->Clicca sul pulsante "ripristina default".
Poi magari prova anche con un reset del SMC:
http://support.apple.com/kb/HT3964?viewlocale=it_IT" onclick="window.open(this.href);return false;
Se non risolve indaghiamo
Allora adesso rimane da capire lo stop lento,resettato la SMC ci impiega ancora 20 secondi prima che si fermi il tutto vi allego lob dopo stop
Nov 1 17:47:18 imacdimnturoli4.homenet.telecomitalia.it WindowServer[237]: device_generate_lock_screen_screenshot: authw 0x0(0), shield 0x7fa769d79050(2001)
Nov 1 17:47:23 imacdimnturoli4.homenet.telecomitalia.it SystemUIServer[293]: FIXME: IOUnserialize has detected a string that is not valid UTF-8, "{ÿþý".
Nov 1 17:47:23 --- last message repeated 5 times ---
Nov 1 17:47:23 imacdimnturoli4.homenet.telecomitalia.it digest-service[698]: label: default
Nov 1 17:47:23 imacdimnturoli4.homenet.telecomitalia.it digest-service[698]: dbname: od:/Local/Default
Nov 1 17:47:23 imacdimnturoli4.homenet.telecomitalia.it digest-service[698]: mkey_file: /var/db/krb5kdc/m-key
Nov 1 17:47:23 imacdimnturoli4.homenet.telecomitalia.it digest-service[698]: acl_file: /var/db/krb5kdc/kadmind.acl
Nov 1 17:47:23 imacdimnturoli4.homenet.telecomitalia.it digest-service[698]: digest-request: uid=0
Nov 1 17:47:23 imacdimnturoli4.homenet.telecomitalia.it digest-service[698]: digest-request: netr probe 0
Nov 1 17:47:23 imacdimnturoli4.homenet.telecomitalia.it digest-service[698]: digest-request: init request
Nov 1 17:47:23 imacdimnturoli4.homenet.telecomitalia.it digest-service[698]: digest-request: init return domain: IMAC-2C9E35 server: IMACDIMNTUROLI4 indomain was: <NULL>
Nov 1 17:47:23 imacdimnturoli4.homenet.telecomitalia.it digest-service[698]: digest-request: init return domain: IMACDIMNTUROLI4 server: IMACDIMNTUROLI4 indomain was: <NULL>
Nov 1 17:47:44 imacdimnturoli4 kernel[0]: AppleBCM5701Ethernet [en0]: Link down (womp disabled, proxy idle)
Nov 1 17:47:44 imacdimnturoli4.homenet.telecomitalia.it SystemUIServer[293]: FIXME: IOUnserialize has detected a string that is not valid UTF-8, "{ÿþý".
Nov 1 17:47:44 --- last message repeated 7 times ---
Nov 1 17:47:44 imacdimnturoli4 kernel[0]: **** [IOBluetoothHostControllerUSBTransport][SuspendDevice] -- Suspend -- suspendDeviceCallResult = 0x0000 (kIOReturnSuccess) -- 0xb000 ****
Nov 1 17:48:59 imacdimnturoli4 kernel[0]: Wake reason: EHC2
Nov 1 17:48:59 imacdimnturoli4 kernel[0]: Previous Sleep Cause: 5
Nov 1 17:48:59 imacdimnturoli4 kernel[0]: The USB device HubDevice (Port 1 of Hub at 0xfa000000) may have caused a wake by issuing a remote wakeup (2)
Nov 1 17:48:59 imacdimnturoli4 kernel[0]: 3244.572921: setDISASSOC from ATH_INTERFACE_CLASS disconnectVap
Nov 1 17:48:59 imacdimnturoli4 kernel[0]: 3244.572937: switchVap from 1 to 1
Nov 1 17:48:59 imacdimnturoli4 kernel[0]: The USB device BRCM2046 Hub (Port 1 of Hub at 0xfa100000) may have caused a wake by issuing a remote wakeup (3)
Nov 1 17:48:59 imacdimnturoli4 kernel[0]: The USB device Bluetooth USB Host Controller (Port 1 of Hub at 0xfa110000) may have caused a wake by issuing a remote wakeup (3)
Nov 1 17:48:59 imacdimnturoli4 kernel[0]: **** [IOBluetoothHostControllerUSBTransport][SuspendDevice] -- Resume -- suspendDeviceCallResult = 0x0000 (kIOReturnSuccess) -- 0xb000 ****
Nov 1 17:48:59 imacdimnturoli4 kernel[0]: full wake (reason 1) 177 ms
Nov 1 17:48:59 imacdimnturoli4 kernel[0]: **** [IOBluetoothHCIController][ProcessEventDataWL] -- calling mDisplayManager->activityTickle() to wake up the display
Nov 1 17:48:59 imacdimnturoli4.homenet.telecomitalia.it WindowServer[237]: CGXDisplayDidWakeNotification [3244927430905]: posting kCGSDisplayDidWake
Nov 1 17:48:59 imacdimnturoli4.homenet.telecomitalia.it WindowServer[237]: handle_will_sleep_auth_and_shield_windows: NULL shield_window (lock state: 1)
Nov 1 17:49:00 imacdimnturoli4.homenet.telecomitalia.it hidd[62]: MultitouchHID: device bootloaded
Nov 1 17:49:03 imacdimnturoli4 kernel[0]: Ethernet [AppleBCM5701Ethernet]: Link up on en0, 100-Megabit, Full-duplex, Symmetric flow-control, Debug [796d,0301,0de1,0300,4de1,0000]
Nov 1 17:49:03 imacdimnturoli4.homenet.telecomitalia.it configd[17]: LINKLOCAL en0: parent has no IP
Nov 1 17:49:03 imacdimnturoli4.homenet.telecomitalia.it SystemUIServer[293]: FIXME: IOUnserialize has detected a string that is not valid UTF-8, "{ÿþý".
Nov 1 17:49:03 --- last message repeated 1 time ---
Nov 1 17:49:03 iMac-di-manuel-venturoli-4.local configd[17]: setting hostname to "iMac-di-manuel-venturoli-4.local"
Nov 1 17:49:03 iMac-di-manuel-venturoli-4.local SystemUIServer[293]: FIXME: IOUnserialize has detected a string that is not valid UTF-8, "{ÿþý".
Nov 1 17:49:03 iMac-di-manuel-venturoli-4.local configd[17]: network changed: v4(en0-:192.168.1.110) DNS- Proxy-
Nov 1 17:49:03 --- last message repeated 3 times ---
Nov 1 17:49:03 iMac-di-manuel-venturoli-4.local netbiosd[600]: network_reachability_changed : network is not reachable, netbiosd is shutting down
Nov 1 17:49:07 iMac-di-manuel-venturoli-4.local pppd[710]: publish_entry SCDSet() failed: Success!
Nov 1 17:49:07 --- last message repeated 1 time ---
Nov 1 17:49:07 iMac-di-manuel-venturoli-4.local pppd[710]: pppd 2.4.2 (Apple version 727.1.15) started by root, uid 0
Nov 1 17:49:07 iMac-di-manuel-venturoli-4.local configd[17]: network changed.
Nov 1 17:49:07 iMac-di-manuel-venturoli-4.local pppd[710]: local IP address 10.64.64.64
Nov 1 17:49:07 iMac-di-manuel-venturoli-4.local pppd[710]: remote IP address 10.112.112.112
Nov 1 17:49:07 iMac-di-manuel-venturoli-4.local configd[17]: network changed: v4(ppp0+:10.64.64.64) DNS+ Proxy+ SMB
Nov 1 17:49:07 iMac-di-manuel-venturoli-4.local pppd[710]: PPPoE connecting to service '' [access concentrator '']...
Nov 1 17:49:07 iMac-di-manuel-venturoli-4.local pppd[710]: PPPoE connection established.
Nov 1 17:49:07 iMac-di-manuel-venturoli-4.local pppd[710]: Connect: ppp0 <--> socket[34:16]
Nov 1 17:49:07 --- last message repeated 3 times ---
Nov 1 17:49:07 iMac-di-manuel-venturoli-4.local pppd[710]: PAP authentication succeeded
Nov 1 17:49:08 iMac-di-manuel-venturoli-4.local pppd[710]: Local IP address changed to 87.15.26.164
Nov 1 17:49:08 iMac-di-manuel-venturoli-4.local pppd[710]: Remote IP address changed to 192.168.100.1
Nov 1 17:49:08 iMac-di-manuel-venturoli-4.local configd[17]: network changed: v4(ppp0:10.64.64.64) DNS! Proxy SMB
Nov 1 17:49:08 iMac-di-manuel-venturoli-4.local configd[17]: network changed: v4(ppp0!:87.15.26.164) DNS* Proxy SMB
Nov 1 17:49:10 iMac-di-manuel-venturoli-4.local configd[17]: network changed: v4(ppp0:87.15.26.164, en0+:192.168.1.110) DNS* Proxy SMB
Nov 1 17:49:11 iMac-di-manuel-venturoli-4.local Console[713]: setPresentationOptions called with NSApplicationPresentationFullScreen when there is no visible fullscreen window; this call will be ignored.
Nov 1 17:49:12 iMac-di-manuel-venturoli-4.local SystemUIServer[293]: FIXME: IOUnserialize has detected a string that is not valid UTF-8, "{ÿþý".
Nov 1 17:49:12 --- last message repeated 6 times ---
Nov 1 17:49:12 host164-26-dynamic.15-87-r.retail.telecomitalia.it configd[17]: setting hostname to "host164-26-dynamic.15-87-r.retail.telecomitalia.it"
Nov 1 17:49:15 host164-26-dynamic.15-87-r.retail.telecomitalia.it configd[17]: FIXME: IOUnserialize has detected a string that is not valid UTF-8, "{ÿþý".
Nov 1 17:49:15 host164-26-dynamic.15-87-r.retail.telecomitalia.it digest-service[698]: digest-request: uid=0
Nov 1 17:49:15 host164-26-dynamic.15-87-r.retail.telecomitalia.it digest-service[698]: digest-request: init request
Nov 1 17:49:15 host164-26-dynamic.15-87-r.retail.telecomitalia.it digest-service[698]: digest-request: init return domain: IMACDIMNTUROLI4 server: HOST164-26-DYNAMIC indomain was: <NULL>
Nov 1 17:49:15 host164-26-dynamic.15-87-r.retail.telecomitalia.it digest-service[698]: digest-request: init return domain: IMAC-2C9E35 server: HOST164-26-DYNAMIC indomain was: <NULL>
Nov 1 17:49:26 host164-26-dynamic.15-87-r.retail.telecomitalia.it ntpd[227]: ntpd: time set -0.199649 s
Nov 1 17:49:26 host164-26-dynamic.15-87-r.retail.telecomitalia.it com.apple.time[285]: Interval maximum value is 946100000 seconds (specified value: 9223372036854775807).
Nov 1 17:49:56 --- last message repeated 1 time ---
Speriamo sia chiaro il problema altrimenti vorrà dire che è così Mavericks
