cambiare icona disco ntfs in boot camp
gman
Oggetto del messaggio: cambiare icona disco ntfs in boot camp
Messaggio da gman »
Un pò di tempo fà ho trovato questa guida per cambiare la icona alla partizone ntfs di win http://wiki.onmac.net/index.php/Persona ... bootloader che ho seguito alla lettera ma naturalmente non ho concluso nulla ':shock:' .
ciunque abbia voglia di provare e poi spiegarmi ':idea:' come a fatto può seguire qesto estratto del tutoria originale ':?:'
- Replacing the XP Partition's icon
If you use a NTFS file system, you will not be able to modify the XP Partition's icon by the "Get Info" procedure. Follow this instructions to see how you can change your XP Partition's icon
1.- Format a USB stick with a FAT file system (you can use any volume really, but it needs to be FAT).
2.- In Mac OS X, set a custom volume icon using the Finder's "More info" window or any tool of your choice.
3.- Open a Terminal window, enter
cd /Volumes
ls -la
You'll see a file listed that has the same name as the FAT volume, but with a "._" prepended. For example, "._USBSTICK".
4.-Copy that file to the equivalent name for the Windows XP NTFS partition by typing in the terminal
cp ._USBSTICK ._WinXP
5.- Transfer the ".VolumeIcon.icns" file created on the FAT file system to the root of the NTFS partition, using Windows.
6.- Open a Command Prompt and Enter in "attrib +H +S .VolumeIcon.icns" from the root of your NTFS partition. This will make the file a Hidden, System file, which hides it from curious passers by and even if you have the show hidden and systems files it will not show up in your NTFS partition.
Congratulations! Now your XP partition has a new icon
In effetti è un modo ingegnoso per dare al Finder le informazioni che servono a visualizzare l'icona del disco.
Spero solo che qualcuno con la "capa fresca" possa aiutarti a risolvere il "problema".
:wink:
