Autocad per Mac: non installare Mountain Lion
mauripucci
Oggetto del messaggio: Autocad per Mac: non installare Mountain Lion
Messaggio da mauripucci »
AutoCAD and AutoCAD LT support on Mac OS X 10.8 (Mountain Lion)
You want to know if AutoCAD for Mac and AutoCAD LT for Mac can be run on the new Mac OS X 10.8 (Mountain Lion) operating system.
Solution
The following products are currently NOT supported on the Mac OS X 10.8 (Mountain Lion) operating system:
AutoCAD 2013 for Mac
AutoCAD 2012 for Mac
AutoCAD LT 2013 for Mac
AutoCAD LT 2012 for Mac
If any of these products are installed on Mountain Lion, undesirable side effects can occur, including issues with Installer re-start, resetting applications, cursor missing when printing to PDF, and more. Our engineers are working round the clock to support Mountain Lion for these products, however no support is currently available.
Until such time as a service pack is available, we highly recommend NOT installing Mac OS X 10.8 (Mountain Lion) on any machines where AutoCAD 2013 for Mac, AutoCAD 2012 for Mac, AutoCAD LT 2013 for Mac, or AutoCAD LT 2012 for Mac is required.
http://usa.autodesk.com/adsk/servlet/ps ... D=15839490" onclick="window.open(this.href);return false;
francescolupo7
Lupus in fabula
Lupus in fabula
Oggetto del messaggio: Re: Autocad per Mac: non installare Mountain Lion
Messaggio da francescolupo7 »
Grande Autodesk.
Presenta giusto un mese fa (o poco più) la versione 2013 e non è compatibile a Mountain Lion. Grande davvero.
_____________________________
Zingaro
Messaggio da Zingaro »
non ho veramente parole...stavo per aggiornare.
solito discorso, fino a ieri avevo snow.
Zingaro
francescolupo7
Lupus in fabula
Lupus in fabula
Vai tranquillo. Basta reinstallare AutoCAD e funziona perfettamente.
http://roaringapps.com/app:5141
Zingaro
francescolupo7 ha scritto:Vai tranquillo. Basta reinstallare AutoCAD e funziona perfettamente.
io da Zingaraccio ho piccole pare in più... ovvero se non mi funziona una cosetta di mia conoscenza sarei veramente nella cacca ... non so se rischiare.
Zingaro
francescolupo7
Lupus in fabula
Lupus in fabula
A me funziona su ML. Ed ho una macchina del 2009.
Zingaro
francescolupo7 ha scritto:A me funziona su ML. Ed ho una macchina del 2009.
hai la licenza studenti o quella normale ?
Zingaro
francescolupo7
Lupus in fabula
Lupus in fabula
licenza normale. :)
mauripucci
da AutoCAD for Mac Services & Support: http://usa.autodesk.com/adsk/servlet/ps ... D=15839490" onclick="window.open(this.href);return false;
Attualmente i seguenti prodotti non sono supportati dal sistema operativo Mac OS X 10,8 (Leone di montagna):
2013 Di AutoCAD per Mac
AutoCAD 2012 per Mac
AutoCAD LT 2013 per Mac
AutoCAD LT 2012 per Mac
Supporto AutoCAD e AutoCAD LT su Mac OS X 10,8 (Leone di montagna)
Problema
Volete sapere se AutoCAD per Mac e AutoCAD LT per Mac può essere eseguito sul nuovo sistema operativo Mac OS X 10,8 (Leone di montagna).
Soluzione
Se uno qualsiasi di questi prodotti sono installato su Leone di montagna, possono verificarsi effetti collaterali indesiderati, comprese le questioni con il riavvio del programma di installazione, ripristino applicazioni, cursore mancanti quando si stampa in PDF e di più. I nostri ingegneri stanno lavorando ventiquattro per supportare il Leone di montagna per questi prodotti, tuttavia nessun supporto è attualmente disponibile.
Finché un service pack è disponibile, si consiglia non installare Mac OS X 10,8 (Leone di montagna) su tutte le macchine dove 2013 di AutoCAD per Mac, AutoCAD 2012 per Mac, AutoCAD LT 2013 per Mac o AutoCAD LT 2012 per Mac è richiesto.
2013 Di AutoCAD per Mac Beta programma
Un programma di beta sarà annunciato nel prossimo futuro per un service pack che aggiunge supporto per Leone di montagna al 2013 di AutoCAD per Mac. Questa soluzione sarà aggiornata per includere ulteriori informazioni sul programma beta quando diventa disponibile.
AutoCAD 2012 per Mac Beta programma
Un programma beta è ora disponibile per un service pack che aggiunge il supporto per Leone di montagna per AutoCAD 2012 per Mac. Questo service pack è ancora in versione beta e non è consigliato in un ambiente di produzione, tuttavia esso hanno migliorato il supporto per Leone di montagna e apprezziamo il vostro feedback. Per iscriversi a questa beta programma si prega di utilizzare il seguente link: ...
Zingaro
mauripucci ha scritto:da AutoCAD for Mac Services & Support: http://usa.autodesk.com/adsk/servlet/ps ... D=15839490" onclick="window.open(this.href);return false;
Problema
Soluzione
in pratica 2012 si e 2013 ancora no ?
Zingaro
mauripucci
veramente Autocad dice di non installare ML con qualsiasi Autocad:
Solution
al contrario App Compatibility Table dice: vedi immagine più sotto
PS: comunque faccio presente che io non utilizzo personalmente Autocad; sono solo il "prof responsabile" -assieme al tecnico- dell' "aula informatica mac" (non dell' "aula microsoft") del liceo dove lavoro e non ho ancora fatto installare ML negli iMac in dotazione (che hanno SL e funzionano benissimo)... dopo la comunicazione di Autocad.
Zingaro
mauripucci ha scritto:veramente Autocad dice di non installare ML con qualsiasi Autocad:
Solution
Sfondi un portone aperto, io stò scrivendo dal mio macbookpro con Snow ..... ho Lion nell'air ma solo per costrizione.
questo autunno dopo che avrò consegnato un pò di lavori arretrati faccio esperimenti ! =D
cmq ti posso dire che il 2013 sul mio Air con Lion va benone..a parte qualche spasmo del monitor quando apro l'applicazione.
Zingaro
kOoLiNuS
Messaggio da kOoLiNuS »
Quasi quasi provo a fare una installazione di test ... più che altro mi preoccupa la marcia di aggiornamenti intrapresa per ML (a giorni il .2) mentre per Lion non si dice nulla.
Inoltre iCloud e i meccanismi di aggiornamento e dell'AppStore stanno cambiando e non vorrei che a meno di 10 mesi dall'acquisto i due Lion presi allo studio di mia moglie diano incompatibilità ... Insomma per 15€ vorrei metterli up-2-date.
Che dite ?
-user dal giugno 2006
il mio blog: https://koolinus.net — il mio sito professionale: https://nicolalosito.it
francescolupo7
Lupus in fabula
Lupus in fabula
Ripeto che a me è bastato reinstallare AutoCAD 2013 dopo il passaggio a ML. E tutto ha funzionato alla perfezione. Solo i soliti crash a cui ci ha abituato Autodesk. ;)
kOoLiNuS
francescolupo7 ha scritto:Ripeto che a me è bastato reinstallare AutoCAD 2013 dopo il passaggio a ML. E tutto ha funzionato alla perfezione. Solo i soliti crash a cui ci ha abituato Autodesk. ;)
Grazie ... a me la cosa che preoccupa di più che è ho la netta percezione che Autodesk non abbia avuto il ritorno che si aspettava della piattaforma Mac e stia rallentando fortemente gli investimenti su tale piattaforma. Su iOS, invece, il mercato pare florido visto il numero ma sopratutto la qualità media delle loro proposte.
Speriamo di sbagliare ...
