aggiornamento Gimp
Oggetto del messaggio: Re: aggiornamento Gimp
Gimp - 2.8.10
Maintenance release
Some small fixes, no new features.
http://gimp.lisanet.de/Website/Download.html" onclick="window.open(this.href);return false;
Messaggio da faxus »
Gimp 2.8.14
Per Mavericks e Yosemite
http://sourceforge.net/projects/gimpono ... p_redirect" onclick="window.open(this.href);return false;
Oppure sul sito del produttore
Overview of Changes from GIMP 2.8.12 to GIMP 2.8.14
General:
- Fix libtool versioning (forgot to bump gimp_interface_age)
Overview of Changes from GIMP 2.8.10 to GIMP 2.8.12
Core:
- OSX: Fix migration code for old GIMP directories
- Fix brush sizes when used from plug-ins
- Windows: Allow to Explorer-open files with UTF-8 characters in the filename
- Make XCF loading more robust against broken files
GUI:
- Make sure the widget direction matches the GUI language
- Remove the option to disable the warning when closing a modified image
- Fix canvas overlay widgets (like the text options) for tablets
- Make DND work between images in one dockable
Libgimp:
- Make gimp_image_get_name() return the string used for the image title
Plug-ins:
- Make script-fu-server more secure by listening to 127.0.0.1 by
default and add a warning about changing that IP. This breaks the
procedure's API, but for security reasons.
- Bring back proper script-fu translations
General:
- Massively clean up and fix the OSX build and bundle
- Add Jenkins tutorial
- Documentation updates
- Bug fixes
- Translation updates
Per eseguire questa versione di GIMP è necessario
OS X 10.9.x Mavericks
Funziona già sul prossimo
OS X 10.9.x Yosemite
La prima volta che si riavvia GIMP dopo l'aggiornamento ci vorrà un po 'di tempo, perché ricarica i font.
A causa di alcune differenze nelle funzioni di salvataggio/esportazione si dovranno leggere le seguenti istruzioni:
Since the 2.8.6 build, the GIMP on OS X packages uses a more smart way of the "save / export" function than it was introduced in GIMP 2.8. The GIMP on OS X build tries to prevent data loss as far as possible while still giving you as much as possible of the the old behavior of GIMP 2.6 back, without restricting you too much.
Now:
1) non-XCF images with 1 layer:
- can be saved via "File - Save" as in GIMP 2.6
- are marked "clean" after saving, so no more dialogs about unsaved changes
2) non-XCF images with 2 or more layers:
- nothing has been changed. Works as in 'plain' GIMP 2.8
3) XCF images and newly created images:
"Save as / Export / Export to / Overwrite" work as in 'plain' GIMP 2.8
And, it’s completely configurable:
Go to GIMP's Preferences -> Environment -> Saving Images -> "Force to save only in XCF image format".
The default is unchecked, which will give you the above mentioned behavior, so that you can save non-XCF images.
If you want to use the new GIMP 2.8 behavior to only save in XCF, just mark this option checked.
Patch 1 per l'aggiornamento di ieri
Gimp 2.8.14p1
Si erano dimenticati di aggiungere la lingua inglese.
Per cui chi sceglieva la lingua inglese si trovava il programma in un altro linguaggio
Questo il messaggio del produttore nelle news del sito:
As you might have noticed, the english localization got messed up and showed menu items in other languages. The english language file was simply missing. I’ve build a new package which fixes this.
So please download the new build 2.814p1. If you don’t use the english localization, you aren’t affected by this bug.
Sorry for the inconvenience.
Nevertheless, happy GIMPing ...
Simone Karin
Phate
Messaggio da Phate »
Grazie, scarico
:wink:
Nas DiskStation DS1513+
Apc Smart-Ups 1000Va Lcd 230V
canale y o u t u b e
j u z a photo
[/i]
Phate
Smettere GIMP
:roll:
j u z a photo
[/i]
Phate ha scritto:Smettere GIMP ...
È come una droga...
Chi non ce la fa ricorre all'Uscita Forzata
Messaggio da mauropasha »
"Smetti" era la traduzione italiana per cmd+q di un vecchio Mac OS pre X, dei primi anni 90, ma non ricordo più quale :(
kato
Messaggio da kato »
mauropasha ha scritto:"Smetti" era la traduzione italiana per cmd+q di un vecchio Mac OS pre X, dei primi anni 90, ma non ricordo più quale :(
Giusto: 6 o 7 o entrambi.
a-mac
Messaggio da a-mac »
che burloni... l'hanno fatto apposta! troppo simpatici ;-)
“è complicato, ma semplice”
UNIX: Live Free or Die
With great power comes great responsibility
You may say, I'm a dreamer, but I'm not the only one, I hope some day you'll join us, And the world will live as one!
Gimp 2.8.14p2
2.8.14p2 del 09.01.2015
* lots of bug fixed:
* UFRaw now works again and can open RAW files
* fixed a bug, where using the context menu (right-click on the canvas) has totally scrambled the main menubar
* switching images with ALT + number now works as expected
* fixed a bug with fonts (rectangles were shown instead of characters if you've installed GIMP as admin and run as user)
* added a missing localization of the application menu (random languages might have been shown in the GIMP menu)
* folder icons are shown throughout the file open / file save dialog.
Giobatta
Messaggio da Giobatta »
La versione che scarico è uguale a quella del 14 settembre scorso...
Giovanni
PowerBook 2005 15" 1,67 GHz, MacPro 2006 3 GHz, Mac Mini 2011 2,5 GHz, iMac 27" 2013 3,5 GHz, MacBook Pro 16" 2,3 GHz 2019
Giobatta ha scritto:La versione che scarico è uguale a quella del 14 settembre scorso...
Sul sito di Simone Karin Lehmann non è stato ancora aggiornato.
Scarica da Sourceforge
Gimp 2.8.16
Gira su El Capitan
https://www.gimp.org/downloads/" onclick="window.open(this.href);return false;
Su http://sourceforge.net/projects/gimpono ... p_redirect" onclick="window.open(this.href);return false;
oppure sul sito del produttore
è presente ancora la 2.8.14p2
Intanto è in via di rilascio la 2.9.2, di cui non sono riuscito a trovare le beta
giginx
Comics Expert
Comics Expert
Messaggio da giginx »
Se non l'hai già trovato (ma ne dubito)
https://download.gimp.org/mirror/pub/gimp/v2.9/" onclick="window.open(this.href);return false;
giginx ha scritto:Se non l'hai già trovato (ma ne dubito)...
Grazie del credito... In effetti lo avevo visto.
Credo siano i sorgenti e non mi attira l'idea di compilarlo.
Come sai, sono per la praticità...
Torna a “Novità Apple”
