Sono a casa di un amico per impegni politici (registrare podcast e rifare il sito che fa pena www.azionegiovanipompei.it ) quando, all'improvviso...... Kernel Panic!!!!
è la prima volta che mi capita.... che significa??? Mi devo preoccupare??? Può portare problemi????
Ora vi posto il resoconto che mi è apparso automaticamente:
Dettagli problema
Sat Jul 5 22:09:39 2008
Machine-check capabilities (cpu 0) 0x0000000000000806:
family: 6 model: 15 stepping: 11 microcode revision 179
Intel(R) Core(TM)2 Duo CPU T7500 @ 2.20GHz
6 error-reporting banks
threshold-based error status present
Machine-check status 0x0000000000000005
restart IP valid
machine-check in progress
MCA error-reporting registers:
IA32_MC0_STATUS(0x401): 0x1000000000000000 invalid
IA32_MC1_STATUS(0x405): 0x0000000000000000 invalid
IA32_MC2_STATUS(0x409): 0x0000000000000000 invalid
IA32_MC3_STATUS(0x40d): 0x0020000000000000 invalid
IA32_MC4_STATUS(0x411): 0x0000000000000011 invalid
IA32_MC5_STATUS(0x415): 0xb200001806000e0f valid
MCA error code : 0x0e0f
Model specific error code: 0x0600
Other information : 0x00000018
Threshold-based status : Undefined
Status bits:
Processor context corrupt
Error enabled
Uncorrected error
panic(cpu 0 caller 0x001A8656): Machine Check at 0x0019c4ea, thread:0x4c3b5d0, trapno:0x12, err:0x0, registers:
CR0: 0x8001003b, CR2: 0x50f2a774, CR3: 0x0108d000, CR4: 0x00000660
EAX: 0x0000006f, EBX: 0x00464f66, ECX: 0x00468416, EDX: 0x0000006f
ESP: 0x5320b47c, EBP: 0x5320b488, ESI: 0x00000014, EDI: 0x00468429
EFL: 0x00000246, EIP: 0x0019c4ea
Backtrace, Format - Frame : Return Address (4 potential args on stack)
0x4ece28 : 0x12b0fa (0x4592a4 0x4ece5c 0x133243 0x0)
0x4ece78 : 0x1a8656 (0x462504 0x19c4ea 0x4c3b5d0 0x12)
0x4ecf58 : 0x19fd93 (0x4ecf70 0x0 0x0 0x0)
0x5320b488 : 0x344537 (0x468414 0x464f64 0x15 0x5320b498)
0x5320b548 : 0x1f459e (0x5320b560 0x5320b550 0x5320b558 0x5320b558)
0x5320b598 : 0x1f0890 (0x49a9d90 0x468414 0x0 0x5320b63c)
0x5320b5e8 : 0x1f2839 (0x49a9d90 0x468414 0x0 0x5320b63c)
0x5320b658 : 0x1f555a (0x49a9d90 0x5320b810 0x49d9964 0x5320b668)
0x5320b6b8 : 0x1dc7a9 (0x49a9d90 0x5320b810 0x49d9964 0x5320b6c8)
0x5320b958 : 0x358c52 (0x3dcd3b8 0x0 0x8 0x49d9964)
0x5320b998 : 0x1d8c06 (0x3e0f104 0x3dcd3b8 0x8 0x49d9964)
0x5320b9e8 : 0x1d496c (0x49a9d90 0x0 0x8 0x49d9964)
0x5320ba78 : 0x1d5739 (0x5320bddc 0x100 0x5320bdfc 0x0)
0x5320bb38 : 0x1e434d (0x5320bddc 0x5358a4 0x2a05be10 0xab9)
0x5320bd88 : 0x1e497c (0xb0523e98 0x0 0x0 0x0)
0x5320bf48 : 0x1e4a15 (0xb0523e98 0x0 0x0 0x0)
Backtrace continues...
BSD process name corresponding to current thread: fseventsd
Mac OS version:
9E17
Kernel version:
Darwin Kernel Version 9.4.0: Mon Jun 9 19:30:53 PDT 2008; root:xnu-1228.5.20~1/RELEASE_I386
System model name: MacBook3,1 (Mac-F22788C8)
Configurazione di sistema
Model: MacBook3,1, BootROM MB31.008E.B02, 2 processors, Intel Core 2 Duo, 2.2 GHz, 2 GB
Graphics: kHW_IntelGMA965Item, GMA X3100, spdisplays_builtin, 144 MB
Memory Module: BANK 0/DIMM0, 1 GB, DDR2 SDRAM, 667 MHz
Memory Module: BANK 1/DIMM1, 1 GB, DDR2 SDRAM, 667 MHz
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x88), Broadcom BCM43xx 1.0 (4.170.46.9)
Bluetooth: Version 2.1.0f17, 2 service, 1 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: Hitachi HTS542516K9SA00, 149,05 GB
Parallel ATA Device: HL-DT-ST DVDRW GSA-S10N
USB Device: Built-in iSight, Micron, high_speed, 500 mA
USB Device: Apple Internal Keyboard / Trackpad, Apple Computer, full_speed, 500 mA
USB Device: IR Receiver, Apple Computer, Inc., low_speed, 500 mA
USB Device: Bluetooth USB Host Controller, Apple, Inc., full_speed, 500 mA
Vi prego di aiutarmi..... c'è qualcosa che posso fare?? C'è qualche errore?? Ho combinato qualcosa io?? Bisogna eliminare qualche file o fare qualcosa???
Grazie mille, questa volta è seria la cosa.....
