altro crash imac da 20 aiutatemi!
danzyc
Oggetto del messaggio: altro crash imac da 20 aiutatemi!
Messaggio da danzyc »
ecco il report generale: mi si spegne da solo! 1 giorno si ed uno
no!...2 giorni si ed uno no....che strano..io ho installato wmware e tutto è successo mi pare....dopo avrlo installato....(potrei sbagliarmi) ecco di seguito il report :
03/04/08 13:45:44 /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow[22] Login Window Application Started
03/04/08 13:45:51 kernel AppleYukon2 - en0 link active, 10-Mbit, half duplex port 0
03/04/08 13:45:44 com.apple.SecurityServer[18] Entering service
03/04/08 13:45:51 kernel vmnet: VNetUserIf_Create: created userIf at 0x74acc00.
03/04/08 13:45:51 kernel vmnet: VMNetConnect: returning port 0x74acc00
03/04/08 13:45:44 mDNSResponder mDNSResponder-170 (Jan 4 2008 18:04:07)[21] starting
03/04/08 13:45:51 kernel vmnet: Hub 0 does not exist, allocating memory.
03/04/08 13:45:45 /usr/sbin/ocspd[56] starting
03/04/08 13:45:51 kernel vmnet: Allocated hub 0x7465000 for hubNum 0.
03/04/08 13:45:51 kernel vmnet: VMNET_SO_BINDTOHUB: port: paddr 00:50:56:ea:5a:5c
03/04/08 13:45:51 kernel vmnet: Port 0
03/04/08 13:45:51 kernel vmnet: bridge-en0: got dev 0x6f54404
03/04/08 13:45:51 kernel vmnet: bridge-en0: up
03/04/08 13:45:51 kernel vmnet: bridge-en0: attached
03/04/08 13:45:51 kernel vmnet: VNetUserIfFree: freeing userIf at 0x74acc00.
03/04/08 13:45:47 configd[33] setting hostname to "imac-di-daniele.local"
03/04/08 13:45:48 mDNSResponder[21] getifaddrs ifa_netmask for vmnet8(7) Flags 8863 Family 2 192.168.245.1 has different family: 0
03/04/08 13:45:48 mDNSResponder[21] getifaddrs ifa_netmask for vmnet1(8) Flags 8863 Family 2 192.168.96.1 has different family: 0
03/04/08 13:45:50 mDNSResponder[21] getifaddrs ifa_netmask for vmnet8(7) Flags 8863 Family 2 192.168.245.1 has different family: 0
03/04/08 13:45:50 mDNSResponder[21] getifaddrs ifa_netmask for vmnet1(8) Flags 8863 Family 2 192.168.96.1 has different family: 0
03/04/08 13:45:51 mDNSResponder[21] getifaddrs ifa_netmask for vmnet8(7) Flags 8863 Family 2 192.168.245.1 has different family: 0
03/04/08 13:45:51 mDNSResponder[21] getifaddrs ifa_netmask for vmnet1(8) Flags 8863 Family 2 192.168.96.1 has different family: 0
03/04/08 13:45:53 kernel jnl: disk0s3: replay_journal: from: 36864 to: 594432 (joffset 0x71c000)
03/04/08 13:45:54 kextd[10] writing kernel link data to /var/run/mach.sym
03/04/08 13:45:55 kernel jnl: disk0s3: journal replay done.
03/04/08 13:45:55 fseventsd[26] event logs in /Volumes/Arcadia 2/.fseventsd out of sync with volume. destroying old logs. (42465 2 42732)
03/04/08 13:45:55 fseventsd[26] log dir: /Volumes/Arcadia 2/.fseventsd getting new uuid: 3924CE30-0396-4ADB-B5E8-F86695CE1898
03/04/08 13:45:55 fseventsd[26] event logs in /Volumes/Arcadia 3/.fseventsd out of sync with volume. destroying old logs. (41695 0 42732)
03/04/08 13:45:55 fseventsd[26] log dir: /Volumes/Arcadia 3/.fseventsd getting new uuid: EC3F4A18-E3D8-44E5-B782-9913CBA96EAA
03/04/08 13:45:55 mds[20] (/Volumes/Arcadia 2/.Spotlight-V100/Store-V1/Stores/7A410548-5BD0-4D3C-9F1A-614D76EE345A)(Error) IndexCI in ContentIndexOpenBulk:Unclean shutdown of /Volumes/Arcadia 2/.Spotlight-V100/Store-V1/Stores/7A410548-5BD0-4D3C-9F1A-614D76EE345A/live.2.; needs recovery
03/04/08 13:46:03 kernel disk0s2: memory allocation error.
03/04/08 13:46:04 kernel disk0s2: memory allocation error.
03/04/08 13:46:06 kernel disk0s2: memory allocation error.
03/04/08 13:46:08 loginwindow[22] Login Window Started Security Agent
