aggiornamento Gimp
Dovrò dargli un'occhiata, prima o poi...
Gimp 2.10.8
dmg 154MB
449MB su disco
OS X Snow Leopard 10.6+
Versioni precedenti sul sito
https://www.gimp.org
https://www.gimp.org/downloads/
brew e brew cask
brew tap caskroom/cask && brew cask install gimp
Novità in 2.10.8:
Core:
Use adaptive chunk size in GimpProjection when rendering the projection asynchronously, rather than using a fixed chunk size. This provides a better trade-off between throughput and responsiveness dynamically, based on how fast the processing is.
Tools:
In all selection tools, show error on attempt to subtract-from/intersect-with empty selection.
Fix text along path not working with vertical text.
Fix Text tool's frame position when undoing a move operation.
Streamline Text tool's drawing blocking/unblocking logic.
When moving a text layer using the text tool (through alt+drag), don't change the layer's box mode to "fixed", which is unnecessary, since the layer's size isn't affected.
Transform and deformation operations now maintain color for fully transparent pixels, making unerase and curves manipulation of alpha channel more reliable.
All transform tools now apply changes when you save or export/overwrite an image without pressing Enter first to confirm changes.
Heal, Dodge/Burn, Smudge, and Convolve tools now adjust the processed buffer and mask_buffer regions according to the changes made to the application region, as calculated by intersecting it with the drawable and mask extents. This fixes wrong application position when painting on a drawable whose origin is above/to the left of the image's origin, and there's a selection active.
Plug-ins:
Port all plug-ins to the new iterator API in GEGL.
Improve automatic detection of HEIC/HEIF files.
Improve RawTherapee discovery by looking up registry key (should become useful with RawTherapee 5.5 and more).
Usability:
Compatibility information in the Save dialog is now more understandable. The minimum GIMP version for the XCF file is always written down when it is GIMP 2.8 or over. The list of features warranting the minimum version is now listed in an expander container rather than as tooltip, which makes it more discoverable. The warning on compression is now displayed as its own text under the checkbox and not as additional text to the minimum GIMP version label.
CLI:
New self-explanatory --enable-win32-debug-console CLI option
Debugging:
New GimpBacktrace API provides an interface for creating and traversing multi-threaded backtraces, as well as querying symbol information. Backends are available for Linux and Windows.
Performance log recording now available in the Dashboard dock. The log contains a series of samples of the dashboard variables, as well as the full program backtrace, when available. As such, it essentially acts as a built-in profiler, which allows us to correlate program execution with the information available through the Dashboard.
New performance-log-expand.py tool decodes a delta-encoded performance log by expanding the deltas, producing a log where each sample (and other relevant elements) contain complete information. The structure of expanded logs is identical to that of delta-encoded logs, the expanded log simply has no deltas.
New performance-log-resolve.py tool resolves symbol information in backtraces. The logs produced by GIMP only specify the program counter at each stack frame, providing an address-map to map program-counter addresses to actual symbols separately. This tool looks up each program-counter address in the address map, incorporating the relevant symbol information directly into the backtrace.
New performance-log-deduce.py tool that statistically deduces the correct thread states based on backtrace address frequency, fixing local inaccuracies.
New performance-log-viewer.py tool that is a viewer for GIMP performance logs, with a sample-selection area at the top and an information area at the bottom. The sample-selection area visualizes the sampled variables and markers using a simultaneous set of plots, and displays the currently selected samples. The information area shows global information stored in the log, as well as information specific to the currently selected samples, including variable listing and statistics, full backtrace, and profile/call-graph information.
Translations:
Updated translations: Danish, Dutch, Finnish, German, Hungarian, Italian, Polish, Portuguese (Brazil), Spanish, Swedish, Ukrainian
Impossibile leggere una pagina che fa impennare la CPU con Safari.
Come le volte precedenti, dati cercati e copiati altrove.
Attenzione, sia col Gatekeeper libero o bloccato sull'impostazione predefinita Apple, non cliccare sull'installer.
Va messo in Applicazioni, sostituendo l'applicazione precedente.
Poi lanciata col tasto ⌃ per l'installazione offline
Ultima modifica di faxus il sab, 10 nov 2018 19:06, modificato 1 volta in totale.
faxus ha scritto:
sab, 10 nov 2018 12:54
Gimp 2.10.6
L'ultima release è la 2.10.6 o la 2.10.8 ? :?:
Impossibile leggere una pagina che fa impennare la CPU con Safari.....
Ti riferisci alla pagina delle note di rilascio?
Eh... non ha preso la correzione sulla citazione.
Ovviamente è la 2.10.8, come scritto bene sulle note di versione, grazie
Non, infatti, la pagina del changelog è impossibile da aprire con Safari TP
Kernel Panic ha scritto:
sab, 10 nov 2018 21:18
... https://www.gimp.org/release-notes/...
Questa sì
Questa fa bloccare Safari TP.
Non da adesso, da due edizioni
Prima ero su High Sierra, ora sono su Mojave, e riesco ugualmente ad aprire - provato più volte - quelle due pagine con entrambi i Safari (anche quella incriminata) .....
Boh.
Niente da fare.
Con Yandex apre https://www.gimp.org/release-notes/gimp-2.10.html senza problemi.
Safari TP no, si blocca il browser e neanche mostra la pagina.
È un episodio circoscritto praticamente solo a quella pagina.
Non attrae il mio interesse, quindi.
Non me ne importa molto, l'ho solo segnalato
Non uso browser non avanzati.
Uso Safari Technology Preview per tutti gli usi.
Poi per lo streaming Yandex Beta, per lo specifico Firefox Quantum Developer Edition, Opera Developer e Tor.
Un po' più di rado Blisk, Maxthon e Roccat
charlie
Open Office Expert
Open Office Expert
McGimp di Partha's Place 2.10.8 è disponibile : https://www.partha.com/downloads/McGimp-2.10.8.app.zip
Schermata 2018-11-22 alle 18.17.15.png (40.72 KiB) Visto 5212 volte
Charlie
iMac 24 M1 - 1 TB - 16 GB ram - macOS 14.4.1 Sonoma
ex iMac 27" metà 2011- SSD 525 GB - 12 GB RAM - macOS 10.13.6 High Sierra
non funziona più.
http://www.charlieopenoffice.altervista.org"
charlie
Open Office Expert
Open Office Expert
La nuova versione di McGimp uguaglia pari pari quella ufficiale di Gimp 2.10.8
NUFRaw è l'editor raw predefinito, ma sei libero di usare qualsiasi editor raw per modificare le immagini della camera raw.
G'MIC è stato aggiornato all'ultima versione.
Charlie
non funziona più.
charlie
Open Office Expert
Open Office Expert
Rilasciato Gimp 2.10.10 https://www.gimp.org/downloads/
Schermata 2019-04-09 alle 08.25.35.png (140.12 KiB) Visto 4434 volte
Charlie
non funziona più.
charlie
Open Office Expert
Open Office Expert
Charlie
non funziona più.
Torna a “Novità Apple”
Visitano il forum: Apple [Bot] e 9 ospiti
cron
