se avessi un cubo, te lo potrei dire per conoscenza diretta
non avendolo mi baso su mactracker che dice
- Immagine 8.jpg (66.81 KiB) Visto 476 volte
e ho anche trovato questo
How do you upgrade the RAM in the Power Mac G4 Cube? How much RAM of what type does the Power Mac G4 Cube support?
The Power Macintosh G4 Cube models -- the Power Mac G4/450 Cube and G4/500 Cube -- have three memory slots and support up to 1.5 GB of memory running either MacOS 9 or MacOS X (MacOS 9 is limited to 1 GB of memory allocated to any single application).
Officially, the Power Mac G4 Cube uses 100 MHz PC100 SDRAM (3.3v, unbuffered, 64-bit-wide, 168-pin) modules, but PC133 is backwards compatible with the earlier PC100 standard and may be easier to find.
ma, nelle info, cosa ti appare di quella già montata?
