- Software Expert Gold
Cocktail -
11.6
Cocktail 11.6 (High Sierra Edition) for users running macOS High Sierra has been released. Here are the release notes for this version:
Added ability to enforce critical (XProtect and Gatekeeper) security updates
Added compatibility with macOS High Sierra 10.13.5
Improvements on the "Perform essential system maintenance" procedure
Improvements on the "Clear Internet caches" procedure
Various improvements to Pilot
New "Enforce Critical Security Updates" Automator action
Other small enhancements.
http://www.maintain.se/cocktail/
Cocktail -
11.6.1
Cocktail 11.6.1 (High Sierra Edition) for users running macOS High Sierra has been released. Here are the release notes for this version:
Addresses minor compatibility issues with Apple File System (APFS) volumes
Improvements on the "Clear kernel caches" procedure
Improvements on the "Clear QuickLook caches" procedure
Fixed compatibility issues between AirPlay 2 and the "Clear audio components caches" procedure
Fixed compatibility issues with Safari 12
Fixed compatibility issues with upcoming Cocktail (Mojave Edition)
Addresses an issue in which "Enforce Critical Security Updates" action may not appear in Automator
Added macOS High Sierra 10.13.6 compatibility
Updated Automator actions.
Cocktail -
11.6.2
Cocktail 11.6.2 (High Sierra Edition) for users running macOS High Sierra has been released. Here are the release notes for this version:
Added support for more localizations (.lproj language codes)
Improvements on the “Clear WebKit caches" procedure
Improvements on the "Clear the hibernate (sleepimage) file" procedure
Addresses an issue in which some zero-length preference files were reported as corrupted
Addresses an issue in which rebuilding of the Launch Services database may cause Share menu in Safari to report “No Service” error
Cocktail -
11.6.3
Cocktail 11.6.3 (High Sierra Edition) for users running macOS High Sierra has been released. Here are the release notes for this version:
Improvements on the "Rebuild XPC Helper Agent caches" procedure
Addresses compatibility issues with Sophos Home
Updated uninstaller and Automator actions.
Cocktail -
12.0
We are pleased to inform you that Cocktail 12.0 (Mojave Edition) has been released!
Cocktail is a general purpose utility for macOS that lets you clean, repair and optimize your Mac. It is a powerful digital toolset that helps hundreds of thousands of Mac users around the world get the most out of their computers every day. When unregistered, Cocktail runs in demo mode and will expire after the tenth launch.
Please notice that Cocktail (Mojave Edition) requires macOS Mojave 10.14 to run. If you are running macOS High Sierra 10.13, please continue to use Cocktail (HighSierra Edition).
Cocktail -
12.0.1
Cocktail 12.0.1 (Mojave Edition) for users running macOS Mojave has been released. Here are the release notes for this version:
Addresses an issue in which Cocktail may cause Mail to crash
Improvements on the "Clear font caches" procedure
Miscellaneous minor bug
Cocktail -
12.0.2
Addresses compatibility issues with macOS Server
Addresses an issue in which VoiceOver may stop working after clearing audio components cache
Addresses compatibility issues with Radeon graphics drivers
Added macOS Mojave 10.14.1 compatibility
Resolves a number of other issues discovered in the previous release.
Cocktail -
12.2
Cocktail -
12.2.1
Cocktail 12.2.1 (Mojave Edition) for users running macOS Mojave has been released. Here are the release notes for this version:
• Improvements on the "Verify boot volume at startup" procedure
• Improvements on the "Check S.M.A.R.T. status at startup" procedure
• Addresses minor compatibility issues with macOS Mojave 10.14.4
• Fixes for few other customer reported issues
• Updated Help files
Cocktail -
12.3
Cocktail 12.3 (Mojave Edition) for users running macOS Mojave has been released. Here are the release notes for this version:
Added ability to repair user permissions at startup (Preferences - General)
Addresses an issue in which Cocktail may cause kernel extensions not to load properly on macOS 10.14.5
Added "Repair User Permissions" Automator action
Added macOS 10.14.5 compatibility
Cocktail -
12.4
Cocktail 12.4 (Mojave Edition) for users running macOS Mojave has been released. Here are the release notes for this version:
Addresses an issue in which kernel cache could not be rebuilt, "Can't create kext cache under / - owner not root" error
Fixed compatibility of the feature to remove localization files with applications that use incorrectly sealed symbolic links to simulate multiple language packages
Fixed a compatibility problem with the automatic restart feature when the application was renamed
Fixed compatibility issues with QuarkXPress 2018
Fixed a bug in which some items in /private/tmp folder were not deleted during clearing of the temporary files
Fixed a problem where specific log files could not be displayed if they contained invalid characters
Improvements on the "Search for corrupted preference files" procedure (it now searches for corrupted Launch Daemons and Launch Agents)
Resolves an issue in which the uninstaller may fail to reset UDP settings to their default values
The distribution package now uses the latest Gatekeeper security features
Many under-the-hood optimizations for faster and more reliable performance
Please notice that Cocktail (Mojave Edition) requires macOS Mojave 10.14 to run. Cocktail (High Sierra Edition) for macOS 10.13 and Cocktail (Sierra Edition) for macOS 10.12 are available for download from our website.
Cocktail -
12.4.1
Cocktail 12.4.1 (Mojave Edition) for users running macOS Mojave has been released. Here are the release notes for this version:
Addresses compatibility with upcoming Cocktail (Catalina Edition)
Improvements on the "Clear applications caches" procedure
Fixed Developer ID certificate issues
Added macOS Mojave 10.14.6 compatibility
Resolves a number of other customer reported issues discovered in the previous release
Cocktail -
12.4.2
Cocktail 12.4.2 (Mojave Edition) for users running macOS Mojave has been released. Here are the release notes for this version:
Addresses compatibility issues with Boot Camp partitions on macOS 10.14.6 or later
Addresses compatibility issues with sleep settings and macOS 10.14.6 Supplemental Update
Cocktail -
13.2
Cocktail 13.2 (Catalina Edition) for users running macOS Catalina has been released.
Cocktail is now code signed and notarized by Apple
Improvements on the "Delete local Time Machine snapshots" procedure
Fixed compatibility issues with Carbon Copy Cloner
Minor interface improvements
Updated Help files.
Download it from http://cocktail.maintain.se or launch Cocktail and choose "Check for Update" from the Cocktail application menu.
