EtreCheckPro version: 6.8.4 (68040)
Report generated: 2024-04-20 12:32:05
Download EtreCheckPro from https://etrecheck.com
Runtime: 3:60
Performance: Good
Problem: Other problem
Description:
Computer is shutting down randomly
Major Issues: None
Minor Issues:
These issues do not need immediate attention but they may indicate future problems or opportunities for improvement.
Clean up - There are orphan files that could be removed.
Unsigned files - There are unsigned software files installed. These files could be old, incompatible, and cause problems. They should be reviewed.
Vintage hardware - This computer may be considered vintage.
Limited permissions - More information may be available with Full Disk Access.
Hardware Information:
iMac (21.5-inch, Late 2015)
Status: Vintage
iMac Model: iMac16,1
1,6 GHz Dual-Core Intel Core i5 (i5-5250U) CPU: 2-core
8 GB RAM - Not upgradeable
BANK 0/DIMM0 - 4 GB DDR3 1867
BANK 1/DIMM0 - 4 GB DDR3 1867
Video Information:
Intel HD Graphics 6000 - VRAM: 1536 MB
iMac 1920 x 1080
Drives:
disk0 - CT1000BX500SSD1 1.00 TB (Solid State - TRIM: Yes)
Internal SATA 6 Gigabit Serial ATA
disk0s1 - EFI (MS-DOS FAT32) [EFI] 210 MB
disk0s2 [APFS Container] 1000.00 GB
disk1 [APFS Virtual drive] 1000.00 GB (Shared by 6 volumes)
disk1s1 - S****i (APFS) [APFS Virtual drive] (107.86 GB used)
disk1s2 - Preboot (APFS) [APFS Preboot] (355 MB used)
disk1s3 - Recovery (APFS) [Recovery] (1.12 GB used)
disk1s4 - VM (APFS) [APFS VM] (1 MB used)
disk1s5 (APFS) [APFS Container] (15.41 GB used)
disk1s5s1 - SSD (APFS) [APFS Snapshot] (15.41 GB used)
disk1s6 - Update (APFS) (3 MB used)
Mounted Volumes:
disk1s1 - S****i [APFS Virtual drive]
Filesystem: APFS
Mount point: /System/Volumes/Data
Used: 107.86 GB
Shared values
Free: 875.04 GB
Available: 876.37 GB
disk1s2 - Preboot [APFS Preboot]
Filesystem: APFS
Mount point: /System/Volumes/Preboot
Used: 355 MB
Shared values
Free: 875.04 GB
disk1s4 - VM [APFS VM]
Filesystem: APFS
Mount point: /System/Volumes/VM
Used: 1 MB
Shared values
Free: 875.04 GB
disk1s5s1 - SSD [APFS Snapshot]
Filesystem: APFS
Mount point: /
Read-only: Yes
Used: 15.41 GB
Shared values
Free: 875.04 GB
disk1s6 - Update
Filesystem: APFS
Mount point: /System/Volumes/Update
Used: 3 MB
Shared values
Free: 875.04 GB
USB:
USB30Bus
Broadcom Corp. - Bluetooth USB Host Controller
Apple Inc. - FaceTime HD Camera (Built-in)
Apple Inc. - Magic Keyboard
Network:
Interface en0: Ethernet
Interface en1: Wi-Fi
802.11 a/b/g/n/ac
Interface en5: iPhone
Interface bridge0: Thunderbolt Bridge
System Software:
macOS Monterey 12.6.8 (21G725)
Time since boot: Less than an hour
Security:
Gatekeeper: App Store and identified developers
System Integrity Protection: Enabled
Antivirus software: Apple
Unsigned Files:
Launchd: /Library/LaunchDaemons/com.wdc.WDPrivilegedHelper.plist
Executable: /Library/PrivilegedHelperTools/com.wdc.WDPrivilegedHelper
Details: Exact match found in the legitimate list - probably OK
Launchd: /Library/LaunchDaemons/com.microsoft.OneDriveStandaloneUpdaterDaemon.plist
Executable: /Applications/OneDrive.app/Contents/StandaloneUpdaterDaemon.xpc/Contents/MacOS/StandaloneUpdaterDaemon
Launchd: /Library/LaunchDaemons/com.microsoft.OneDriveUpdaterDaemon.plist
Executable: /Applications/OneDrive.app/Contents/OneDriveUpdaterDaemon.xpc/Contents/MacOS/OneDriveUpdaterDaemon
Launchd: /Library/LaunchDaemons/com.microsoft.teams.TeamsUpdaterDaemon.plist
Executable: /Applications/Microsoft Teams.app/Contents/TeamsUpdaterDaemon.xpc/Contents/MacOS/TeamsUpdaterDaemon
Details: Restrictive config permissions - possibly malware
System Launch Daemons:
[Not Loaded] 39 Apple tasks
[Loaded] 210 Apple tasks
[Running] 132 Apple tasks
[Other] One Apple task
System Launch Agents:
[Not Loaded] 19 Apple tasks
[Loaded] 208 Apple tasks
[Running] 130 Apple tasks
Launch Daemons:
[Not Loaded] com.apple.installer.cleanupinstaller.plist (Not signed - installed 2023-01-21)
Executable: /macOS Install Data/Locked Files/cleanup_installer
[Loaded] com.microsoft.OneDriveStandaloneUpdaterDaemon.plist (Not signed - installed 2023-01-21)
[Loaded] com.microsoft.OneDriveUpdaterDaemon.plist (Not signed - installed 2023-01-21)
[Loaded] com.microsoft.autoupdate.helper.plist (Microsoft Corporation - installed 2023-01-21)
Executable: /Library/PrivilegedHelperTools/com.microsoft.autoupdate.helper
[Loaded] com.microsoft.office.licensingV2.helper.plist (Microsoft Corporation - installed 2023-01-22)
Executable: /Library/PrivilegedHelperTools/com.microsoft.office.licensingV2.helper
[Loaded] com.microsoft.teams.TeamsUpdaterDaemon.plist (Not signed - installed 2023-01-21)
[Loaded] com.wdc.WDPrivilegedHelper.plist (Not signed - installed 2023-01-26)
Launch Agents:
[Other] com.microsoft.OneDriveStandaloneUpdater.plist (Not signed - installed 2023-01-21)
Executable: /Applications/OneDrive.app/Contents/StandaloneUpdater.app/Contents/MacOS/OneDriveStandaloneUpdater
[Other] com.microsoft.update.agent.plist (Not signed - installed 2023-01-21)
Command: /Library/Application Support/Microsoft/MAU2.0/Microsoft AutoUpdate.app/Contents/MacOS/Microsoft Update Assistant.app/Contents/MacOS/Microsoft Update Assistant --launchByAgent
Applications:
364 apps
20 x86-only apps
2 unsigned apps
App Extensions:
Share services:
OneNote - /Applications/Microsoft OneNote.app
Internet Plug-ins:
AdobePDFViewer: 20.006.20034 (Adobe Systems, Inc. - installed 2020-02-04)
AdobePDFViewerNPAPI: 17.012.20098 (Adobe Systems, Inc. - installed 2020-02-04)
Backup:
Time Machine information is limited without Full Disk Access
Performance:
System Load: 10.55 (1 min ago) 12.38 (5 min ago) 6.03 (15 min ago)
Nominal I/O usage: 12.66 MB/s
File system: 31.15 seconds
Write speed: 473 MB/s
Read speed: 517 MB/s
CPU Usage Snapshot:
Type Overall
System: 5 %
User: 14 %
Idle: 81 %
Top Processes Snapshot by CPU:
Process (count) CPU (Source - Location)
photoanalysisd 48.58 % (Apple)
CalendarAgent 20.54 % (Apple)
firefox 17.66 % (Mozilla Corporation)
plugin-container (8) 12.44 % (Mozilla Corporation)
mobileassetd 12.32 % (Apple)
Top Processes Snapshot by Memory:
Process (count) RAM usage (Source - Location)
plugin-container (8) 1.16 GB (Mozilla Corporation)
EtreCheckPro 635 MB (Etresoft, Inc.)
firefox 431 MB (Mozilla Corporation)
kernel_task 235 MB (Apple)
mdworker_shared (16) 168 MB (Apple)
Top Processes Snapshot by Network Use:
Process (count) Input / Output (Source - Location)
firefox 3 MB / 254 KB (Mozilla Corporation)
mDNSResponder 45 KB / 29 KB (Apple)
trustd 48 KB / 7 KB (Apple)
AddressBookSourceSync 34 KB / 15 KB (Apple)
nsurlsessiond 17 KB / 8 KB (Apple)
Top Processes Snapshot by Energy Use:
Process (count) Energy (0-100) (Source - Location)
plugin-container (8) 12 (Mozilla Corporation)
WindowServer 4 (Apple)
suggestd 3 (Apple)
AddressBookSourceSync 2 (Apple)
CalendarAgent 2 (Apple)
Virtual Memory Information:
Physical RAM: 8 GB
Free RAM: 725 MB
Used RAM: 4.08 GB
Cached files: 3.21 GB
Available RAM: 3.92 GB
Swap Used: 0 B
Clean up:
/Library/LaunchAgents/com.microsoft.update.agent.plist
Executable not found
/Library/LaunchDaemons/com.apple.installer.cleanupinstaller.plist
/Library/LaunchAgents/com.microsoft.OneDriveStandaloneUpdater.plist
Diagnostics Information (past 60 days):
End of report
Questo capita anche al mio iMac late 2015, ma non così frequentemente come a te, senza che abbia mai apportato modifiche alla macchina.
Essenzialmente questa cosa l'ho fatta senza volerlo, magari cerco qualche guida e ci provo.
Purtroppo non ho foto ma non penso di aver avuto allucinazioni: l'avviso per installare un nuovo sistema l'ho ricevuto (non sono i semplici aggiornamenti di versione). Dato che Monterey è uscito nel 2021 quello lo tenevo al 100%.fragrua ha scritto: ↑mar, 21 mag 2024 10:12Prova un avvio con utilizzo normale da disco esterno per escludere problemi all'SSD o al cavo SATA.
Resta il fatto che l'installazione di Ventura è inspiegabile. Quasi quasi lo tratterei con OpenCore Legacy Patcher come fosse un Mac non supportato.
R-Store applica tariffe ufficiali… capisci a me.
Reimpostare l'SMC del Mac ...in fondo alla pagina.
Considerato che anche altre persone qui e sul forum hanno lo stesso problema forse è semplicemente qualcosa che si è rotto e non ha a che fare con la sostituzione dell'HDD.spegahsheen ha scritto: ↑mar, 21 mag 2024 11:04Questo capita anche al mio iMac late 2015, ma non così frequentemente come a te, senza che abbia mai apportato modifiche alla macchina.
