faxus ha scritto: ↑mer, 22 gen 2020 21:51
Pacotom, per favore, collabora...
scusate, ma alle 21 viene la badante a mettermi a letto, ecco l'ultimo report
EtreCheck version: 3.4.7 (461)
Report generated 2020-01-23 09:44:20
Download EtreCheck from
https://etrecheck.com
Runtime: 3:29
Performance: Good
Click the [Remove/Report] links to remove adware or update the whitelist of legitimate software.
Problem: Computer is restarting
Hardware Information: ⓘ
iMac (Retina 5K, 27-inch, 2019)
iMac - model: iMac19,1
1 3 GHz Intel Core i5 (i5-8500) CPU: 6-core
64 GB RAM Upgradeable - [Instructions]
BANK 0/ChannelA-DIMM0
16 GB DDR4 2667 MHz ok
BANK 1/ChannelA-DIMM1
BANK 2/ChannelB-DIMM0
BANK 3/ChannelB-DIMM1
Handoff/Airdrop2: supported
Wireless: en1: Unknown
iCloud Quota: 4.81 GB available
iCloud Status: One pending file
Video Information: ⓘ
Radeon Pro 570X - VRAM: 4 GB
iMac
Disk Information: ⓘ
TS256GSSD230S disk1: (256,06 GB) (Solid State - TRIM: No)
[Show SMART report]
EFI (disk1s1 - MS-DOS FAT32) <not mounted> [EFI]: 210 MB
(disk1s2) <not mounted> [APFS Container]: 255.85 GB
APPLE SSD SM0032L disk0: (28 GB) (Solid State - TRIM: Yes)
(disk0s1) <not mounted> [EFI]: 315 MB
(disk0s2) <not mounted> [APFS Container]: 27.55 GB
USB Information: ⓘ
USB31Bus
Generic 4-Port USB 3.0 Hub
Seagate M3 Portable
M3 Portable disk4: (2 TB)
SEAGATE 2 T (disk4s1 - Journaled HFS+) /Volumes/SEAGATE 2 T : 2.00 TB (610.81 GB free)
TOSHIBA External USB 3.0
External USB 3.0 disk5: (4 TB)
EFI (disk5s1 - MS-DOS FAT32) <not mounted> [EFI]: 210 MB
TOSHIBA 4 T (disk5s2 - Journaled HFS+) /Volumes/TOSHIBA 4 T : 4.00 TB (2.71 TB free)
Elgato EyeTV Diversity
Generic 4-Port USB 2.0 Hub
Sennheiser Communications Sennheiser USB headset
Apple Inc. Magic Keyboard
Logitech USB Optical Mouse
USB31Bus
Thunderbolt Information: ⓘ
Apple Inc. thunderbolt_bus
Virtual disks: ⓘ
Macintosh HD (disk2s1 - APFS) / [Startup]: 255.85 GB (120.50 GB free)
Physical disk: disk1s2 255.85 GB (120.50 GB free)
(disk2s2) <not mounted> [Preboot]: 255.85 GB
(disk2s3) <not mounted> [Recovery]: 255.85 GB
(disk2s4) /private/var/vm [VM]: 255.85 GB
System Software: ⓘ
macOS 10.14.6 (18G2022) - Time since boot: about one hour
Configuration files: ⓘ
System Integrity Protection status: enabled (Custom Configuration)
Gatekeeper: ⓘ
Possible adware: ⓘ
Unknown file: ~/Library/LaunchAgents/com.LaterAgent.silhouette.plist
~/Library/Application Support/.nfcd/seld
Unknown file: ~/Library/LaunchAgents/com.nuendo.plist
~/Library/Application Support/.max/mixxx
Unknown file: ~/Library/LaunchAgents/com.reason.plist
~/Library/Application Support/.reaper/sibelius
3 possible adware files found. [Remove/Report]
Clean up: ⓘ
/Library/LaunchAgents/com.microsoft.OneDriveStandaloneUpdater.plist
/Applications/OneDrive.app/Contents/StandaloneUpdater.app/Contents/MacOS/OneDriveStandaloneUpdater
Executable not found!
/Library/LaunchDaemons/com.microsoft.OneDriveStandaloneUpdaterDaemon.plist
/Applications/OneDrive.app/Contents/StandaloneUpdaterDaemon.xpc/Contents/MacOS/StandaloneUpdaterDaemon
/Library/LaunchDaemons/com.microsoft.OneDriveUpdaterDaemon.plist
/Applications/OneDrive.app/Contents/OneDriveUpdaterDaemon.xpc/Contents/MacOS/OneDriveUpdaterDaemon
/Library/LaunchDaemons/jp.co.canon.MasterInstaller.plist
/Library/PrivilegedHelperTools/jp.co.canon.MasterInstaller
~/Library/LaunchAgents/com.nchsoftware.videopadit.schedule.CacheDeleteAll.plist
/Volumes/VideoPad/VideoPad.app/Contents/MacOS/VideoPad -scheduled_launch -bgtask delcache
5 orphan files found. [Clean up]
Kernel Extensions: ⓘ
/Applications/Wondershare Video Converter Ultimate.app
[not loaded] com.Perfect.Driver.SystemAudioRecorder (1.1.0 - SDK 10.6) [Lookup]
/Library/Application Support/Roxio
[not loaded] com.roxio.TDIXController (1.6) [Lookup]
/Library/Application Support/VirtualBox
[loaded] org.virtualbox.kext.VBoxDrv (6.0.10) [Lookup]
[loaded] org.virtualbox.kext.VBoxNetAdp (6.0.10) [Lookup]
[loaded] org.virtualbox.kext.VBoxNetFlt (6.0.10) [Lookup]
[loaded] org.virtualbox.kext.VBoxUSB (6.0.10) [Lookup]
/System/Library/Extensions
[not loaded] com.elgato.driver.DontMatchAfaTech (1.1) [Lookup]
[not loaded] com.elgato.driver.DontMatchCinergy450 (1.1) [Lookup]
[not loaded] com.elgato.driver.DontMatchCinergyXS (1.1) [Lookup]
[not loaded] com.elgato.driver.DontMatchEmpia (1.1) [Lookup]
[not loaded] com.elgato.driver.DontMatchVoyager (1.1) [Lookup]
[not loaded] org.defyne.driver.ConexantCX2388X (0.2) [Lookup]
[not loaded] org.defyne.driver.MMInputFamily (0.6.0) [Lookup]
[not loaded] org.defyne.driver.PhilipsSAA7146 (0.5.5) [Lookup]
[not loaded] org.defyne.driver.PrincipalMMInputs (0.7.4) [Lookup]
[not loaded] org.defyne.driver.TypicalDVBFrontends (0.7.4) [Lookup]
[not loaded] org.defyne.driver.UDMUtils (0.1.0) [Lookup]
/Users/[redacted]/Apowersoft/Mac Online Launcher/Mac Online Launcher.app
[loaded] com.Apowersoft.driver.AudioDevice (1.6.7 - SDK 10.11) [Lookup]
[not loaded] com.Cycling74.driver.Soundflower (1.0.0 - SDK 10.
[Lookup]
Startup Items: ⓘ
udmarket: Path: /Library/StartupItems/udmarket
Startup items no longer function in OS X Yosemite or later
System Launch Agents: ⓘ
[not loaded] 9 Apple tasks
[loaded] 179 Apple tasks
[running] 112 Apple tasks
System Launch Daemons: ⓘ
[not loaded] 36 Apple tasks
[loaded] 177 Apple tasks
[running] 120 Apple tasks
Launch Agents: ⓘ
[not loaded] com.adobe.AAM.Updater-1.0.plist (? ffb65062 ba46f95b - installed 2018-04-29) [Lookup]
[loaded] com.adobe.ElementsAutoCreator-18.0.plist (Adobe Systems, Inc. - installed 2020-01-18) [Lookup]
[running] com.adobe.GC.AGM.plist (Adobe Systems, Inc. - installed 2020-01-18) [Lookup]
[not loaded] com.adobe.GC.Invoker-1.0.plist (Adobe Systems, Inc. - installed 2020-01-18) [Lookup]
[failed] com.microsoft.OneDriveStandaloneUpdater.plist (? b97e8726 0 - installed 2019-12-07) [Lookup] - /Applications/OneDrive.app/Contents/StandaloneUpdater.app/Contents/MacOS/OneDriveStandaloneUpdater: Executable not found!
[loaded] com.microsoft.update.agent.plist (Microsoft Corporation - installed 2019-12-07) [Lookup]
Launch Daemons: ⓘ
[loaded] com.adobe.acc.installer.v2.plist (Adobe Systems, Inc. - installed 2020-01-18) [Lookup]
[loaded] com.adobe.agsservice.plist (Adobe Systems, Inc. - installed 2020-01-18) [Lookup]
[loaded] com.adobe.fpsaud.plist (Adobe Systems, Inc. - installed 2020-01-13) [Lookup]
[loaded] com.apple.installer.osmessagetracing.plist (Apple, Inc. - installed 2019-12-04)
[loaded] com.binarynights.ForkLiftHelper.plist (BinaryNights LLC - installed 2018-04-28) [Lookup]
[running] com.bombich.ccchelper.plist (Bombich Software, Inc. - installed 2019-12-07) [Lookup]
[running] com.crystalidea.macsfancontrol.smcwrite.plist (Ilya Parniuk - installed 2019-12-27) [Lookup]
[running] com.memeo.WDMemeod.plist (? d0fcb9dc 2b12012e - installed 2009-09-30) [Lookup]
[failed] com.microsoft.OneDriveStandaloneUpdaterDaemon.plist (? 1a4f628 0 - installed 2020-01-14) [Lookup] - /Applications/OneDrive.app/Contents/StandaloneUpdaterDaemon.xpc/Contents/MacOS/StandaloneUpdaterDaemon: Executable not found!
[loaded] com.microsoft.OneDriveUpdaterDaemon.plist (? a510a00 0 - installed 2019-12-07) [Lookup] - /Applications/OneDrive.app/Contents/OneDriveUpdaterDaemon.xpc/Contents/MacOS/OneDriveUpdaterDaemon: Executable not found!
[loaded] com.microsoft.autoupdate.helper.plist (Microsoft Corporation - installed 2019-12-07) [Lookup]
[loaded] com.microsoft.office.licensingV2.helper.plist (Microsoft Corporation - installed 2019-11-11) [Lookup]
[loaded] jp.co.canon.MasterInstaller.plist (? d0637166 0 - installed 2020-01-10) [Lookup] - /Library/PrivilegedHelperTools/jp.co.canon.MasterInstaller: Executable not found!
[not loaded] org.virtualbox.startup.plist (Shell Script 700b9385 - installed 2019-10-01) [Lookup]
User Launch Agents: ⓘ
[running] com.LaterAgent.silhouette.plist (? 69136dce 10be6241 - installed 2020-01-13) [Lookup]
[loaded] com.adobe.AAM.Updater-1.0.plist (? 6a3cceca ba46f95b - installed 2018-04-29) [Lookup]
[loaded] com.adobe.GC.Invoker-1.0.plist (Adobe Systems, Inc. - installed 2020-01-19) [Lookup]
[loaded] com.google.keystone.agent.plist (Google, Inc. - installed 2019-12-07) [Lookup]
[loaded] com.google.keystone.xpcservice.plist (Google, Inc. - installed 2019-12-07) [Lookup]
[loaded] com.nchsoftware.videopadit.schedule.CacheDeleteAll.plist (? 3dbd1ae 0 - installed 2020-01-14) [Lookup] - /Volumes/VideoPad/VideoPad.app/Contents/MacOS/VideoPad: Executable not found!
[running] com.nuendo.plist (? fc47c0ee 3064553d - installed 2019-10-28) [Lookup]
[loaded] com.reason.plist (? fee43be2 b128766c - installed 2019-10-28) [Lookup]
[not loaded] org.virtualbox.vboxwebsrv.plist (Oracle America, Inc. - installed 2019-10-01) [Lookup]
User Login Items: ⓘ
EyeTV Helper Applicazione
(/Library/Application Support/EyeTV/EyeTV Helper.app)
SilentStartHelper SMLoginItem - Hidden (Apple, Inc. - installed 2019-10-15)
(/Applications/Silent Start.app/Contents/Library/LoginItems/SilentStartHelper.app)
ForkLiftMini SMLoginItem - Hidden (BinaryNights LLC - installed 2018-04-28)
(/Applications/ForkLift.app/Contents/Library/LoginItems/ForkLiftMini.app)
ForkLiftMini SMLoginItem - Hidden (BinaryNights LLC - installed 2019-11-28)
(/Volumes/TOSHIBA 4 T/Install Mac/Programmi/ForkLift/ForkLift 2.app/Contents/Library/LoginItems/ForkLiftMini.app)
(/Volumes/SEAGATE 2 T/Install Mac/Programmi/ForkLift/ForkLift 2.app/Contents/Library/LoginItems/ForkLiftMini.app)
CanonIJExtendedSurveyLaunchAgent SMLoginItem - Hidden (Canon Inc. - installed 2020-01-10)
(/Applications/Canon Utilities/Inkjet Extended Survey Program/Inkjet Extended Survey Program.app/Contents/MacOS/ESPController.app/Contents/Library/LoginItems/CanonIJExtendedSurveyLaunchAgent.app)
Internet Plug-ins: ⓘ
FlashPlayer-10.6: 32.0.0.321 (installed 2020-01-21) [Lookup]
Flash Player: 32.0.0.321 (installed 2020-01-21) [Lookup]
QuickTime Plugin: 7.7.3 (installed 2020-01-21)
PepperFlashPlayer: 32.0.0.321 (installed 2020-01-21) [Lookup]
EPPEX Plugin: 10.0 (installed 2018-09-20) [Lookup]
Safari Extensions: ⓘ
[enabled] Open in Internet Explorer - Parallels -
http://www.parallels.com (installed 2018-04-28)
3rd Party Preference Panes: ⓘ
Flash Player (installed 2020-01-13) [Lookup]
Time Machine: ⓘ
Skip System Files: NO
Auto backup: YES
Volumes being backed up:
Macintosh HD: Disk size: 255.85 GB Disk used: 135.35 GB
Destinations:
SAMSUNG 1 T [Local]
Total size: 999.85 GB
Total number of backups: 35
Oldest backup: 19/10/2019, 11:05
Last backup: 23/01/2020, 09:13
Backup size 999.85 GB > (Disk size 255.85 GB X 3)
Top Processes by CPU: ⓘ
6% Console
3% Google Chrome Helper (Renderer)
3% diagnosticd
3% Google Chrome
2% com.apple.SpeechRecognitionCore.speechrecognitiond
Top Processes by Memory: ⓘ
721 MB com.apple.SpeechRecognitionCore.speechrecognitiond
573 MB Google Chrome
384 MB Microsoft Word
351 MB Microsoft Excel
295 MB mds_stores
Input Output Process name
6 MB 1 KB systemmigrationd
157 KB 127 KB mDNSResponder
23 KB 6 KB netbiosd
16 KB 7 KB AddressBookSourceSync
5 KB 8 KB apsd
99.72 iconservicesagent
53.98 diagnosticd
42.88 Console
38.26 systemmigrationd
34.28 System Information
Virtual Memory Information: ⓘ
49.71 GB Available RAM
44.51 GB Free RAM
14.29 GB Used RAM
5.20 GB Cached files
0 B Swap Used
ApolloOne: 2.4.1 (installed 2020-01-07)
Speedtest: 1.9 (installed 2020-01-09)
Inkjet Extended Survey Program: (null) (installed 2020-01-10)
Driver della stampante Canon IJ: (null) (installed 2020-01-10)
Canon IJScanner16f: (null) (installed 2020-01-10)
Canon IJ Scan Utility2: (null) (installed 2020-01-10)
Canon IJ Scan Utility Lite: (null) (installed 2020-01-10)
UserRegistration: (null) (installed 2020-01-10)
Manuale a video: (null) (installed 2020-01-10)
My Image Garden V364: (null) (installed 2020-01-10)
Quick Menu: (null) (installed 2020-01-10)
Adobe Flash Player: (null) (installed 2020-01-14)
Adobe Pepper Flash Player: (null) (installed 2020-01-14)
Paint S: 5.7.8 (installed 2020-01-17)
Adobe Flash Player: (null) (installed 2020-01-21)
Adobe Pepper Flash Player: (null) (installed 2020-01-21)
Speedtest: 1.10 (installed 2020-01-23)
2020-01-22 18:46:47 Microsoft Word.app High CPU use [Open] [Details]
2020-01-22 15:19:19 backupd High CPU use [Open] [Details]
2020-01-20 14:08:46 ReportCrash Crash [Open]
Cause: dyld3 mode
Analyzing process: EtreCheckPro[3590], path: ???; parent process: [1], path: /sbin/launchd
2020-01-20 13:57:17 DetectX Swift.app Crash [Open]
Cause: *** Terminating app due to uncaught exception 'NSInternalInconsistencyException', reason: 'NSWindow drag regions should only be invalidated on the Main Thread!'
terminating with uncaught exception of type NSException
abort() called
2020-01-18 20:18:44 Kernel Panic [Open] [Details]
3rd Party Kernel Extensions:
org.virtualbox.kext.VBoxUSB 6.0.10
org.virtualbox.kext.VBoxNetAdp 6.0.10
org.virtualbox.kext.VBoxNetFlt 6.0.10
org.virtualbox.kext.VBoxDrv 6.0.10
com.Apowersoft.driver.AudioDevice 1.6.7
