EtreCheck version: 6.1.4 (6B028)
Report generated: 2019-11-15 10:02:25
Runtime: 3:15
Performance: Good
Major Issues:
Anything that appears on this list needs immediate attention.
Gatekeeper disabled - Gatekeeper security protection is disabled. This computer is at risk of malware infection.
Obsolete hardware - This machine may be considered obsolete.
Minor Issues:
These issues do not need immediate attention but they may indicate future problems or opportunities for improvement.
Heavy RAM usage - Apps are using a large amount of RAM.
Apps with heavy CPU usage - There have been numerous cases of apps with heavy CPU usage.
Clean up - There are orphan files that could be removed.
Unsigned files - There are unsigned software files installed. They appear to be legitimate but should be reviewed.
System modifications - There are a large number of system modifications running in the background.
Hardware Information:
Mac Pro (Early 2008) - Obsolete!
Mac Pro Model: MacPro3,1
2 2,8 GHz Quad-Core Intel Xeon (Xeon(R)) CPU: 8-core
12 RAM - Upgradeable
DIMM Riser B/DIMM 1 - 1 GB DDR2 FB-DIMM 800
DIMM Riser B/DIMM 2 - 1 GB DDR2 FB-DIMM 800
DIMM Riser A/DIMM 1 - 1 GB DDR2 FB-DIMM 800
DIMM Riser A/DIMM 2 - 1 GB DDR2 FB-DIMM 800
DIMM Riser B/DIMM 3 - Empty
DIMM Riser B/DIMM 4 - Empty
DIMM Riser A/DIMM 3 - 4 GB DDR2 FB-DIMM 800
DIMM Riser A/DIMM 4 - 4 GB DDR2 FB-DIMM 800
Video Information:
ATI Radeon HD 5770 - VRAM: 1024 MB
EA274WMi 2560 x 1440
Drives:
disk0 - WDC WD10EZRX-00L4HB0 1.00 TB (Mechanical)
Internal SATA 3 Gigabit Serial ATA
disk0s1 - EFI (MS-DOS FAT32) [EFI] 210 MB
disk0s2 - m*******s (Journaled HFS+) 999.35 GB (314.34 GB used)
disk0s3 - Recovery HD (Journaled HFS+) [Recovery] 650 MB
disk1 - WDC WD10EZRX-00L4HB0 1.00 TB (Mechanical)
disk1s1 - EFI (MS-DOS FAT32) [EFI] 210 MB
disk1s2 - H****B (Journaled HFS+) 999.86 GB (966.93 GB used)
Mounted Volumes:
disk0s2 - m*******s
999.35 GB (314.34 GB used - 684.75 GB free)
Journaled HFS+
Mount point: /
disk1s2 - H****B
999.86 GB (966.93 GB used - 32.93 GB free)
Journaled HFS+
Mount point: /Volumes/H****B
Network:
Interface en2: Bluetooth PAN
Interface en1: Ethernet 2
Interface en0: Ethernet 1
Interface fw0: FireWire
System Software:
OS X El Capitan 10.11.6 (15G22010)
Time since boot: Less than an hour
Configuration Files:
File /etc/sysctl.conf exists but not expected
/etc/hosts - Count: 17
Security:
System Status
Gatekeeper: Anywhere
System Integrity Protection: Enabled
Antivirus software: None!
Unsigned Files:
Launchd: /Library/LaunchDaemons/com.quark.quarkupdate.plist
Executable: /Library/PrivilegedHelperTools/com.quark.quarkupdate
Details: Exact match found in the whitelist - probably OK
Launchd: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/com.oracle.java.Helper-Tool.plist
Executable: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/Helper-Tool
Launchd: /Library/LaunchDaemons/com.efi.ofasq.plist
Executable: /Applications/Fiery/OFASQ/ofaApp
Launchd: ~/Library/LaunchAgents/com.wondershare.mobilegodaemon.plist
Executable: ~/Library/Application Support/wondershare_mobilego/MobileGoDaemon.app/Contents/MacOS/MobileGoDaemon
Launchd: /Library/LaunchDaemons/com.oracle.java.Helper-Tool.plist
Launchd: /Library/LaunchAgents/com.oracle.java.Java-Updater.plist
Executable: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/Java Updater.app/Contents/MacOS/Java Updater -bgcheck
Launchd: /Library/LaunchDaemons/com.efi.FDCDaemon.plist
Executable: /Applications/Fiery/Command WorkStation 5/FDC.app/Contents/MacOS/FDC
Launchd: /Library/LaunchDaemons/com.adobe.fpsaud.plist
Executable: /Library/Application Support/Adobe/Flash Player Install Manager/fpsaud
Launchd: /Library/LaunchAgents/com.microsoft.update.agent.plist
Executable: /Library/Application Support/Microsoft/MAU2.0/Microsoft AutoUpdate.app/Contents/MacOS/Microsoft AU Daemon.app/Contents/MacOS/Microsoft AU Daemon -checkForUpdates
Launchd: /Library/LaunchAgents/com.epson.ews.launcher.plist
Executable: /Applications/Epson Software/Epson Web Support.app/Contents/MacOS/Epson Web Support -NAV:AGNT
Launchd: /Library/LaunchDaemons/com.efi.es1000service.plist
Executable: /Library/Application Support/EFI/ES1000Service/ES1000Server
Launchd: /Library/LaunchAgents/com.efi.cws.analytics.plist
Executable: /Library/Application Support/efiLINQ/efiLINQ -n=CWSServer
Launchd: ~/Library/LaunchAgents/com.zimbra.desktop.plist
Executable: ~/Library/Zimbra Desktop/bin/zdesktop start -w
Launchd: /Library/LaunchDaemons/com.microsoft.office.licensing.helper.plist
Executable: /Library/PrivilegedHelperTools/com.microsoft.office.licensing.helper
Launchd: /Library/LaunchAgents/com.efi.analytic.wxwidgets.plist
Executable: /Library/Application Support/efiLINQ/efiLINQ -n=wxWidgets
Launchd: /Library/LaunchDaemons/com.adobe.SwitchBoard.plist
Executable: /Library/Application Support/Adobe/SwitchBoard/SwitchBoard.app/Contents/MacOS/launch.switchboard
Launchd: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/com.oracle.java.Java-Updater.plist
Launchd: /Library/LaunchDaemons/com.efi.lmgr.plist
Executable: /Applications/EFI/EFILM/lmgrd_wrapper.sh /Applications/EFI/EFILM
Login Item: /Applications/Adobe InDesign CC/Adobe InDesign CC.app
Login Item: /Applications/Adobe Illustrator CC/Adobe Illustrator.app
Login Item: /etc/mach_init_per_user.d/com.adobe.SwitchBoard.monitor.plist
Login Item: /Applications/GoPro Studio.app/Contents/Library/LoginItems/GoPro Importer.app
Kernel Extensions:
/Library/Application Support/HASP/kexts
[Not Loaded] aksfridge.signed.kext (1.0.16332)
/Library/Application Support/Roxio
[Not Loaded] TDIXController.kext (2.0)
/System/Library/Extensions
[Loaded] Terminus.kext (4)
[Not Loaded] RoxioBluRaySupport.kext (1.1.6)
Startup Items:
ProTec6b Path: /Library/StartupItems/ProTec6b
System Launch Agents:
[Not Loaded] 9 Apple tasks
[Loaded] 158 Apple tasks
[Running] 73 Apple tasks
System Launch Daemons:
[Not Loaded] 46 Apple tasks
[Loaded] 160 Apple tasks
[Running] 84 Apple tasks
[Other] 2 Apple tasks
Launch Agents:
[Not Loaded] com.adobe.AAM.Updater-1.0.plist (? ffb65062 - installed 2019-10-07)
[Other] com.adobe.ARMDCHelper.cc24aef4a1b90ed56a725c38014c95072f92651fb65e1bf9c8e43c37a23d420d.plist (Adobe Systems, Inc. - installed 2019-08-27)
[Running] com.efi.FSMAgent.plist (? 40a12309 - installed 2019-11-05)
[Loaded] com.efi.analytic.wxwidgets.plist (? 514c7800 - installed 2019-11-05)
[Loaded] com.efi.cws.analytics.plist (? 2fcc88bf - installed 2019-11-05)
[Loaded] com.epson.ews.launcher.plist (? d9ab2448 - installed 2011-11-14)
[Other] com.google.keystone.agent.plist (Google, Inc. - installed 2019-11-08)
[Loaded] com.google.keystone.xpcservice.plist (Google, Inc. - installed 2019-11-08)
[Running] com.microsoft.update.agent.plist (? 5cdbb3ff - installed 2019-08-30)
[Not Loaded] com.oracle.java.Java-Updater.plist (? 409089cd - installed 2019-07-04)
[Loaded] com.quark.quarkupdate.agent.plist (Quark - installed 2019-10-31)
[Other] jp.buffalo.NASPower.plist (? ea5706c7 - installed 2017-01-12)
[Not Loaded] jp.buffalo.NASPower_pla.plist (? 238a9afd - installed 2017-01-12)
Launch Daemons:
[Loaded] com.adobe.ARMDC.Communicator.plist (Adobe Systems, Inc. - installed 2019-08-27)
[Loaded] com.adobe.ARMDC.SMJobBlessHelper.plist (Adobe Systems, Inc. - installed 2019-08-27)
[Not Loaded] com.adobe.SwitchBoard.plist (? 856489a3 - installed 2015-01-20)
[Loaded] com.adobe.fpsaud.plist (? 2afb3af7 - installed 2016-04-16)
[Running] com.aladdin.aksusbd.plist (SFNT Germany GmbH - installed 2015-08-26)
[Running] com.efi.FDCDaemon.plist (? 29a4a0ef - installed 2016-10-26)
[Running] com.efi.es1000service.plist (? e7eea73a - installed 2015-04-14)
[Running] com.efi.lmgr.plist (? 8d2637a0 - installed 2019-11-05)
[Running] com.efi.ofasq.plist (? 48bb5a0a - installed 2019-11-05)
[Loaded] com.google.keystone.daemon.plist (Google, Inc. - installed 2019-11-08)
[Loaded] com.microsoft.OneDriveUpdaterDaemon.plist (Microsoft Corporation - installed 2019-08-30)
[Loaded] com.microsoft.autoupdate.helper.plist (Microsoft Corporation - installed 2019-08-30)
[Loaded] com.microsoft.office.licensing.helper.plist (? 6d8cb30e - installed 2010-09-23)
[Loaded] com.microsoft.office.licensingV2.helper.plist (Microsoft Corporation - installed 2019-08-30)
[Not Loaded] com.oracle.java.Helper-Tool.plist (? e3fefdd2 - installed 2019-07-04)
[Loaded] com.quark.QXPHelper.plist (? e42a157f - installed 2015-11-10)
[Not Loaded] com.quark.quarkupdate.plist (? b5d626e1 - installed 2015-11-10)
[Loaded] com.quark.quarkupdate.quhelper.plist (Quark - installed 2019-11-05)
User Launch Agents:
[Loaded] com.adobe.AAM.Updater-1.0.plist (? 0 - installed 2019-10-07)
[Loaded] com.adobe.ARM.***.plist (? 0 - installed 2015-09-24)
[Other] com.adobe.ARM.***.plist (? 0 - installed 2015-09-18)
[Loaded] com.dropbox.DropboxMacUpdate.agent.plist (Dropbox, Inc. - installed 2019-08-26)
[Loaded] com.logmein.GoToMeeting.G2MUpdate.plist (LogMeIn, Inc. - installed 2019-09-18)
[Running] com.wondershare.mobilegodaemon.plist (? 0 - installed 2019-04-02)
[Loaded] com.zimbra.desktop.plist (? 0 - installed 2018-03-07)
User Login Items:
Adobe Illustrator CC (? - installed 2015-09-22)
(Application - /Applications/Adobe Illustrator CC/Adobe Illustrator.app)
Adobe Illustrator.app (? - installed 2015-09-22)
Adobe InDesign CC (? - installed 2015-07-07)
(Application - /Applications/Adobe InDesign CC/Adobe InDesign CC.app)
Adobe InDesign CC.app (? - installed 2015-07-07)
Dropbox.app (Dropbox, Inc. - installed 2019-11-15)
(Application - /Applications/Dropbox.app)
GoPro Importer (? - installed 2015-06-29)
(Modern Login Item - /Applications/GoPro Studio.app/Contents/Library/LoginItems/GoPro Importer.app)
Mail.app (Apple - installed 2019-08-27)
(Application - /Applications/Mail.app)
Mail (Apple - installed 2019-08-27)
com.adobe.SwitchBoard.monitor.plist (?)
(MachInit - /etc/mach_init_per_user.d/com.adobe.SwitchBoard.monitor.plist)
Internet Plug-ins:
AdobeAAMDetect: AdobeAAMDetect 1.0.0.0 (? - installed 2019-10-07)
FlashPlayer-10.6: 21.0.0.226 (? - installed 2016-04-22)
Default Browser: 601 (Apple - installed 2017-08-09)
AdobePDFViewerNPAPI: 17.012.20098 (Adobe Systems, Inc. - installed 2019-08-27)
AdobePDFViewer: 19.010.20099 (Adobe Systems, Inc. - installed 2019-08-27)
Flash Player: 21.0.0.226 (? - installed 2016-04-22)
JavaAppletPlugin: Java 8 Update 221 build 11 (? - installed 2019-09-03)
SharePointBrowserPlugin: 14.5.2 (? - installed 2015-07-02)
iPhotoPhotocast: 7.0 (Apple - installed 2015-02-02)
User Internet Plug-ins:
BlueStacks Install Detector: (?)
WebEx64: 1.1.0 (? - installed 2017-05-22)
Audio Plug-ins:
BluetoothAudioPlugIn: 4.4.6 (Apple - installed 2019-08-27)
AirPlay: 2.0 (Apple - installed 2019-08-27)
AppleAVBAudio: 406.1 (Apple - installed 2019-08-27)
iSightAudio: 7.7.3 (Apple - installed 2019-08-27)
3rd Party Preference Panes:
Flash Player (installed 2016-04-16)
FUSE for OS X (OSXFUSE) (installed 2015-10-25)
Java (installed 2019-09-03)
Quark Update Preferences (installed 2019-10-31)
Time Machine:
Auto backup: Yes
Volumes being backed up:
m*******s: Disk size: 999.35 GB - Disk used: 314.60 GB
Destinations:
H****B [Local] (Last used)
Total size: 999.86 GB
Total number of backups: 79
Oldest backup: 2018-09-03 09:58:36
Last backup: 2019-11-15 09:58:15
Performance:
System Load: 2.50 (1 min ago) 2.58 (5 min ago) 2.57 (15 min ago)
Nominal I/O speed: 5.13 MB/s
File system: 28.25 seconds
Write speed: 117 MB/s
Read speed: 116 MB/s
CPU Usage Snapshot:
Type Overall
System 1 %
User 4 %
Idle 95 %
Top Processes Snapshot by CPU:
Process (count) CPU (Source - Location)
EtreCheckPro 16.10 % (Etresoft, Inc.)
Google Chrome Helper (Renderer) (30) 6.36 % (Google, Inc.)
WindowServer 4.42 % (Apple)
kernel_task 1.02 % (Apple)
Google Chrome Helper (GPU) 0.82 % (Google, Inc.)
Top Processes Snapshot by Memory:
Process (count) RAM usage (Source - Location)
Google Chrome Helper (Renderer) (30) 2.44 GB (Google, Inc.)
kernel_task 944 MB (Apple)
Adobe (4) 762 MB (? - /Applications)
EtreCheckPro 677 MB (Etresoft, Inc.)
Dropbox Web Helper (4) 528 MB (Dropbox, Inc.)
Top Processes Snapshot by Energy Use:
Process (count) Energy (0-100) (Source - Location)
Google Chrome Helper (Renderer) (30) 17 (Google, Inc.)
WindowServer 5 (Apple)
Google Chrome Helper (2) 1 (Google, Inc.)
coreaudiod 1 (Apple)
launchd 1 (Apple)
Virtual Memory Information:
Physical RAM: 12 GB
Free RAM: 1.42 GB
Used RAM: 6.65 GB
Cached files: 3.93 GB
Available RAM: 5.35 GB
Swap Used: 0 B
Software Installs (past 30 days):
Install Date Name (Version)
2019-10-22 DaVinci Resolve Panels Installer v1.1.2 (1.1.2)
2019-10-22 DaVinci Resolve (14.3)
2019-11-05 QuarkUpdate (1.0)
2019-11-05 Image Enhance Visual Editor (1.4.0.25b)
2019-11-05 ES1000 installer (4.7.2.08a)
2019-11-05 efiLINQ (0.1.06.01)
2019-11-05 hasp_driver (7.40.000.1)
2019-11-05 EFILM (11.13.1.0)
2019-11-05 EFI License Activation (1.3.0.8)
2019-11-05 CWS5 (5.8.0.100)
2019-11-14 XProtectPlistConfigData (2108)
Clean up:
~/Library/LaunchAgents/com.adobe.ARM.***.plist
/Volumes/H****B/A**********s/A*****************o/A*******************p/C******s/M***S/U*****r/A******************************p/C******s/M***S/A**************************r
Executable not found
/Library/LaunchAgents/jp.buffalo.NASPower_pla.plist
/Library/PrivilegedHelperTools/NasNavigator2.app/Contents/MacOS/NasNavigator2
/Library/LaunchAgents/jp.buffalo.NASPower.plist
Diagnostics Information (past 7 days):
2019-11-14 14:40:29 Command WorkStation.app High CPU Use
Executable: /Applications/Fiery/*/Command WorkStation.app
2019-11-12 17:13:47 Adobe Photoshop CC 2015.app High CPU Use
Executable: /Applications/Adobe Photoshop CC 2015/Adobe Photoshop CC 2015.app
2019-11-12 10:44:17 mdworker Crash
Executable: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Details:
import fstype:hfs fsflag:480D000 flags:40000005E diag:0 isXCode:0 uti:
public.truetype-ttf-font plugin:/Library/Spotlight/Font.mdimporter - f
ind suspect file using: sudo mdutil -t 901445
ATSFontTestCreateReport: Font file "cairo_tt.ttf", font identifier "E7
A942DE|FontMonger:Cairo Medium", font PostScript name "Cairo"
2019-11-11 08:58:55 DesktopServicesHelper High CPU Use
Executable: /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Resources/DesktopServicesHelper
End of report
/code]
Non molto, in pratica mentre sto lavorando, navigando, inviando posta, senza nessun motivo si blocca, schermo nero e poi ventole al max, nessuna combinazione di tasti o altro lo fanno risvegliare, l'unica soluzione è spegnerlo e riaccenderlo.
Un insieme di piccoli problemi che sommati portano ad un rallentamento del tutto?Minor Issues:
Mounted Volumes:
disk0s2 - m*******s
Journaled HFS+
Mount point: /
disk1s2 - H****B
Journaled HFS+
Una volta riacceso riparte come sempre, il secondo disco è per il backup, il disco di avvio è del 2015iMaurizio ha scritto: ↑mar, 19 nov 2019 19:41Non sono un esperto di Etrecheck, ma ad un primo sguardo non mi pare sia in grado di individuare un unica causa.
Quanti anni hanno i due dischi meccanici che hai dentro ?
Usare le app che vedo che usi con soli 12 Gb di RAM e senza neanche un SSD di avvio certamente non aiuta.
Spero tu abbia un backup, altrimenti fallo subito.
Quando si blocca riparte subito e funziona normalmente poi ?
A mio parere i problemi possono trovarsi, in ordine di probabilità:
- nel disco di avvio
- nel disco non di avvio ma che diventa di uso frequente quando lavori con un app grafica o di video
- non escluderei un po' di stanchezza nella scheda grafica
Come posso vedere quali app consumano ram? trovare i file orfani?Kundalini ha scritto: ↑mar, 19 nov 2019 20:58Un insieme di piccoli problemi che sommati portano ad un rallentamento del tutto?Minor Issues:
Mounted Volumes:
disk0s2 - m*******s
Journaled HFS+
Mount point: /
disk1s2 - H****B
Journaled HFS+
Alto uso di RAM; alto uso del processore; qualche file orfano da eliminare; modifiche al sistema che girano in background (vai a sapere quali sono); 2 dischi meccanici, il secondo dei quali pressoché pieno; oltre a più di 10 anni di onorata carriera della macchina.
Un adeguamento hardware potrebbe prolungargliela. Se la macchina è questa https://everymac.com/systems/apple/mac_ ... specs.html non potrà inoltre mai installare un sistema più avanzato di 10.11 ElCapitan. Non combacia solo il tipo di Radeon, per caso è stata già sostituita?
Di più non saprei dirti.
