Installare programma da pacchetto tar.gz
charlie
Open Office Expert
Open Office Expert
mmhh .... :)
iMac-di-mac:~ mac$  wget -O - http://apt.llvm.org/llvm-snapshot.gpg.key
--2019-05-06 08:45:22--  http://apt.llvm.org/llvm-snapshot.gpg.key
Risoluzione di apt.llvm.org (apt.llvm.org)... 151.101.242.49, 2a04:4e42:39::561
Connessione a apt.llvm.org (apt.llvm.org)|151.101.242.49|:80... connesso.
Richiesta HTTP inviata, in attesa di risposta... 200 OK
Lunghezza: 3145 (3,1K) [application/octet-stream]
Salvataggio in: "STDOUT"
-                     0%[                    ]       0  --.-KB/s               -----BEGIN PGP PUBLIC KEY BLOCK-----
Version: GnuPG v1.4.12 (GNU/Linux)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=j+4q
-----END PGP PUBLIC KEY BLOCK-----
-                   100%[===================>]   3,07K  --.-KB/s    in 0s
2019-05-06 08:45:22 (111 MB/s) - scritto su stdout [3145/3145]
iMac-di-mac:~ mac$ sudo ssh-add -K /Users/Mac/Downloads/llvm-snapshot.gpg.key
Password:
Enter passphrase for /Users/Mac/Downloads/llvm-snapshot.gpg.key:
a me continua a chiedere la passphrase.
Charlie
non funziona più.
utente eliminato
per cambiare o reimpostare una passphrase occorre questo comando
ssh-keygen -t rsa -f percorsofile.key
quindi il comando sarà
ssh-keygen -t rsa -f /Users/mac/Desktop/llvm-snapshot.gpg.key
dopo questo comando ripeterai l'operazione ssh-add con la passphrase da te impostata
sudo ssh-add -K /Users/mac/Desktop/llvm-snapshot.gpg.key
per favore, dopo posta il risultato di
clang --version
charlie
Open Office Expert
Open Office Expert
Tutto bene ora.
iMac-di-mac:~ mac$ clang --version
Apple LLVM version 9.0.0 (clang-900.0.39.2)
Target: x86_64-apple-darwin16.7.0
Thread model: posix
InstalledDir: /Library/Developer/CommandLineTools/usr/bin
iMac-di-mac:~ mac$
Charlie
non funziona più.
utente eliminato
Perfetto, procedi con l'installazione di darktable 2.7.0 seguendo le pagine precedenti
charlie
Open Office Expert
Open Office Expert
Tutto bene, tranne all'ultimo comando:
iMac-di-mac:darktable-release-2.7.0 mac$ sudo bash build.sh
Darktable build script
Building directory:  /Users/mac/Downloads/darktable-release-2.7.0/build
Installation prefix: /opt/darktable
Build type:          RelWithDebInfo
Build generator:     Unix Makefiles
Build tasks:         4
CMake Deprecation Warning at CMakeLists.txt:5 (cmake_policy):
  The OLD behavior for policy CMP0048 will be removed from a future version
  of CMake.
  The cmake-policies(7) manual explains that the OLD behaviors of all
  policies are deprecated and that a policy should be set to OLD only under
  specific short-term circumstances.  Projects should be ported to the NEW
  behavior and not rely on setting a policy to OLD.
-- Building SSE2-optimized codepaths: ON
-- Found little endian system. Good.
-- Is the target platform supported: 1
-- Mac OS X build detected, setting default features
-- Performing Test C_COMPILER_UNDERSTANDS_-Wno-error=varargs
-- Performing Test C_COMPILER_UNDERSTANDS_-Wno-error=varargs - Success
-- Performing Test CXX_COMPILER_UNDERSTANDS_-Wno-error=varargs
-- Performing Test CXX_COMPILER_UNDERSTANDS_-Wno-error=varargs - Success
-- Performing Test C_COMPILER_UNDERSTANDS_-Wno-error=address-of-packed-member
-- Performing Test C_COMPILER_UNDERSTANDS_-Wno-error=address-of-packed-member - Success
-- Performing Test CXX_COMPILER_UNDERSTANDS_-Wno-error=address-of-packed-member
-- Performing Test CXX_COMPILER_UNDERSTANDS_-Wno-error=address-of-packed-member - Success
-- Performing Test C_COMPILER_UNDERSTANDS_-Wframe-larger-than=32768
-- Performing Test C_COMPILER_UNDERSTANDS_-Wframe-larger-than=32768 - Success
-- Performing Test CXX_COMPILER_UNDERSTANDS_-Wframe-larger-than=32768
-- Performing Test CXX_COMPILER_UNDERSTANDS_-Wframe-larger-than=32768 - Success
-- Performing Test C_COMPILER_UNDERSTANDS_-Wstack-usage=32768
-- Performing Test C_COMPILER_UNDERSTANDS_-Wstack-usage=32768 - Failed
-- Performing Test CXX_COMPILER_UNDERSTANDS_-Wstack-usage=32768
-- Performing Test CXX_COMPILER_UNDERSTANDS_-Wstack-usage=32768 - Failed
-- Performing Test C_COMPILER_UNDERSTANDS_-Wlarger-than=524288
-- Performing Test C_COMPILER_UNDERSTANDS_-Wlarger-than=524288 - Success
-- Performing Test CXX_COMPILER_UNDERSTANDS_-Wlarger-than=524288
-- Performing Test CXX_COMPILER_UNDERSTANDS_-Wlarger-than=524288 - Success
-- Looking for external programs
-- Found perl
-- Missing intltool-merge
-- Missing desktop-file-validate, problems in darktable.desktop might go unnoticed
-- Could NOT find LLVM (missing: LLVM_DIR)
CMake Warning at CMakeLists.txt:375 (message):
  Could not find LLVM 3.9+
CMake Warning at CMakeLists.txt:376 (message):
  Test-compilation of OpenCL programs can not be done.
-- Test-compilation of OpenCL programs is disabled.
-- Missing jsonschema, problems in noiseprofiles.json might go unnoticed
-- Found xsltproc
-- Found xmllint
CMake Error at CMakeLists.txt:425 (message):
  Some external programs couldn't be found
-- Configuring incomplete, errors occurred!
See also "/Users/mac/Downloads/darktable-release-2.7.0/build/CMakeFiles/CMakeOutput.log".
See also "/Users/mac/Downloads/darktable-release-2.7.0/build/CMakeFiles/CMakeError.log".
Charlie
non funziona più.
utente eliminato
Credevo fosse troppo avanti la versione di LLVM cosi ho trovato in rete la versione LLVM 3.9 e una volta installata il terminale dopo il comando cmake ha risposto nuovamente inesistente.
Devo studiare bene la situazione, ti aggiorno presto, se qualcuno vuole farsi avanti è il benvenuto :)
charlie
Open Office Expert
Open Office Expert
Schermata 2019-05-07 alle 10.02.54.png (14 KiB) Visto 500 volte
Grazie, ma non vorrei che trascurassi il sonno :shock:
Charlie
non funziona più.
charlie
Open Office Expert
Open Office Expert
Quel + può voler comprendere tutte le versioni successive alla 3.9?
Edit:
Quindi LLVM c'è ma non lo trova?
Thread model: posix
iMac-di-mac:~ mac$
Charlie
non funziona più.
charlie
Open Office Expert
Open Office Expert
Vedo che potrebbe c'entrare intltool e, andando indietro vedo questi errori, forse trascurati:
test -z "/usr/bin" || ./install-sh -c -d "/usr/bin"
 /usr/bin/install -c intltool-extract intltool-merge intltool-update intltoolize intltool-prepare '/usr/bin'
install: /usr/bin/intltool-extract: Operation not permitted
make[2]: *** [install-binSCRIPTS] Error 71
make[1]: *** [install-am] Error 2
make: *** [install-recursive] Error 1
Charlie
non funziona più.
utente eliminato
charlie ha scritto:
mar, 07 mag 2019 10:05
Ti ringrazio per esserti preoccupato ma amo studiare informatica di notte :)
Risolveremo una cosa per volta, intanto ti invito a rimuovere llvm con questo comando.
Andando ad installare una doppia versione di llvm (datata tra l'altro) potrebbero verificarsi dei conflitti.
brew remove -f llvm
poi
brew remove -f clang
installa la versione 3.9.0 di llvm, scarica il pacchetto da qui
https://cdn-02.anonfile.com/h6V3p0o8n8/ ... src.tar.xz
charlie
Open Office Expert
Open Office Expert
Ho seguito le tue indicazioni scaricando il file
Schermata 2019-05-08 alle 08.20.46.png (57.15 KiB) Visto 446 volte
Charlie
non funziona più.
charlie
Open Office Expert
Open Office Expert
Mi sono trovato, inaspettatamente, un file DMG anziché TAR.GZ, ma non ci ho fato caso e l'ho installato :oops: :
Schermata 2019-05-08 alle 08.16.22.png (181.92 KiB) Visto 445 volte
non accorgendomi che era un'altra cosa.
Charlie
non funziona più.
charlie
Open Office Expert
Open Office Expert
Ora mi trovo con FLASH PLAYER installato sul Desktop:
Schermata 2019-05-08 alle 08.20.11.png (82.47 KiB) Visto 445 volte
Non mi sarò mica beccato Shlayer ? https://www.imaccanici.org/shlayer-e-va ... per-macos/
Charlie
non funziona più.
Che criminale!
charlie
Open Office Expert
Open Office Expert
Sono sicuro che Chappy sia a sua volta una vittima, forse del sito scelto per caricare il file.
Sto ripristinando il mio s.o. ma poi lo aspetto per proseguire il percorso cominciato ...
Charlie
non funziona più.
Visitano il forum: trendiction [Bot] e 8 ospiti
