brew install git
git clone https://github.com/darktable-org/darktable.git
ls
cd darktable
ls
git submodule init
git submodule update
brew install gcc
brew install cmake
brew install json-c
brew install llvm
brew install libjpeg
brew install pugixml
ls
cd Downloads
cd Scaricati
ls
cd intltool-0.50.2
./configure --prefix=/usr &&
sudo make install
brew update && brew upgrade
mkdir build/
cd build/
cmake -DCMAKE_INSTALL_PREFIX=/opt/darktable/ ..
Ti sono grato, anche se non ricordo di averti aiutato. Difficile sia potuto accadere qui, forse altrove?
Ottimo.
Dopo quello che Faxus sta passando (nella vita reale, e un po' anche qui) permettiamogli un refuso.Kernel Panic ha scritto: ↑ven, 03 mag 2019 21:06Davvero lo chiedetti?
Non me lo ricordo proprio .....
Hah, chissà come mi volevo esprimere, poi il correttore avrà messo del suo...
Scusami, non ho avuto pazienza.
sudo make install
iMac-di-mac:intltool-0.50.2 mac$ ./configure --prefix=/usr &&
> sudo make install
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... ./install-sh -c -d
checking for gawk... no
checking for mawk... no
checking for nawk... no
checking for awk... awk
checking whether make sets $(MAKE)... yes
checking for perl... /usr/bin/perl
checking for perl >= 5.8.1... 5.18.2
checking for XML::Parser... ok
checking for bzr... no
configure: creating ./config.status
config.status: creating Makefile
config.status: creating doc/Makefile
config.status: creating intltoolize
config.status: creating tests/Makefile
config.status: creating tests/cases/Makefile
config.status: creating tests/results/Makefile
config.status: creating tests/selftest.pl
Password:
Making install in tests
Making install in cases
make[3]: Nothing to be done for `install-exec-am'.
make[3]: Nothing to be done for `install-data-am'.
Making install in results
Making install in doc
make[2]: Nothing to be done for `install-exec-am'.
test -z "/usr/share/man/man8" || .././install-sh -c -d "/usr/share/man/man8"
/usr/bin/install -c -m 644 intltoolize.8 intltool-extract.8 intltool-merge.8 intltool-prepare.8 intltool-update.8 '/usr/share/man/man8'
sed -e 's|[@]PACKAGE@|intltool|g' -e 's|[@]VERSION@|0.50.2|g' -e "s|[@]INTLTOOL_PERL@|/usr/bin/perl|g" -e "s|[@]INTLTOOL_LIBDIR@|/usr/lib|g" < intltool-extract.in > intltool-extract
chmod +x intltool-extract
sed -e 's|[@]PACKAGE@|intltool|g' -e 's|[@]VERSION@|0.50.2|g' -e "s|[@]INTLTOOL_PERL@|/usr/bin/perl|g" -e "s|[@]INTLTOOL_LIBDIR@|/usr/lib|g" < intltool-merge.in > intltool-merge
chmod +x intltool-merge
sed -e 's|[@]PACKAGE@|intltool|g' -e 's|[@]VERSION@|0.50.2|g' -e "s|[@]INTLTOOL_PERL@|/usr/bin/perl|g" -e "s|[@]INTLTOOL_LIBDIR@|/usr/lib|g" < intltool-update.in > intltool-update
chmod +x intltool-update
sed -e 's|[@]PACKAGE@|intltool|g' -e 's|[@]VERSION@|0.50.2|g' -e "s|[@]INTLTOOL_PERL@|/usr/bin/perl|g" -e "s|[@]INTLTOOL_LIBDIR@|/usr/lib|g" < intltool-prepare.in > intltool-prepare
chmod +x intltool-prepare
test -z "/usr/bin" || ./install-sh -c -d "/usr/bin"
/usr/bin/install -c intltool-extract intltool-merge intltool-update intltoolize intltool-prepare '/usr/bin'
install: /usr/bin/intltool-extract: Operation not permitted
make[2]: *** [install-binSCRIPTS] Error 71
make[1]: *** [install-am] Error 2
make: *** [install-recursive] Error 1
iMac-di-mac:intltool-0.50.2 mac$ brew update && brew upgrade
Already up-to-date.
iMac-di-mac:intltool-0.50.2 mac$ mkdir build/
iMac-di-mac:intltool-0.50.2 mac$ cd build/
iMac-di-mac:build mac$
iMac-di-mac:build mac$ cmake -DCMAKE_INSTALL_PREFIX=/opt/darktable/ ..
CMake Error: The source directory "/Users/mac/downloads/intltool-0.50.2" does not appear to contain CMakeLists.txt.
Specify --help for usage, or press the help button on the CMake GUI.
wget -O - http://apt.llvm.org/llvm-snapshot.gpg.key
sudo ssh-add -K percorsodicharlie/llvm-snapshot.gpg.key
@ WARNING: UNPROTECTED PRIVATE KEY FILE! @
Permissions 0644 for '/Users/Casper/Desktop/llvm-snapshot.gpg.key' are too open.
It is required that your private key files are NOT accessible by others.
This private key will be ignored.
sudo ssh-add
brew install llvm
brew unlink isl
Error: An exception occurred within a child process:
RuntimeError: /usr/local/opt/autoconf not present or broken
Please reinstall autoconf. Sorry :(
brew reinstall autoconf
brew reinstall
brew reinstall automake
brew reinstall
brew reinstall libtool
brew reinstall
brew install isl --HEAD
curl -s http://php-osx.liip.ch/install.sh | bash -s 7.2
curl -s https://php-osx.liip.ch/install.sh | bash -s force 7.2
brew install composer
clang --version
Apple LLVM version 10.0.1 (clang-1001.0.46.4)
Target: x86_64-apple-darwin18.5.0
Thread model: posix
InstalledDir: /Library/Developer/CommandLineTools/usr/bin
cd Downloads
cd Scaricati
ls
tar -zxvf darktable-release-2.7.0.tar.gz
cd darktable-release-2.7.0
ls
sudo bash build.sh
Visitano il forum: SemrushBot [Bot] e 22 ospiti
