<?php /** * * @package Cookie and server settings tool * @copyright (c) 2008 ktuk.net * @copyright (c) 2011 phpbb.com * @license GPL * */ // Standard definitions/includes $page_title = 'phpBB3 Cookies'; define('IN_PHPBB', true); $phpbb_root_path = (defined('PHPBB_ROOT_PATH')) ? PHPBB_ROOT_PATH : './'; $phpEx = substr(strrchr(__FILE__, '.'), 1); include($phpbb_root_path . 'common.' . $phpEx); $script_name = (isset($request) && ($request instanceof \phpbb\request\request_interface)) ? $request->server('SCRIPT_NAME', '') : $_SERVER['SCRIPT_NAME']; $cookie_data = array(); $server_data = array(); $sent = request_var('sent', ''); // Gather cookie settings from config array $cookie_data[] = $config['cookie_domain']; $cookie_data[] = $config['cookie_name']; $cookie_data[] = $config['cookie_path']; $cookie_data[] = $config['cookie_secure']; $server_data[] = $config['force_server_vars']; $server_data[] = $config['script_path']; $server_data[] = $config['server_name']; $server_data[] = $config['server_port']; $server_data[] = $config['server_protocol']; $cookie_checked = ($cookie_data[3]) ? "checked = \"checked\"" : ''; $force_checked = ($server_data[0]) ? "checked = \"checked\"" : ''; if (!$sent) { print "<html> <head><title>$page_title</title></head> <body> <form action=\"" . $script_name . "\" method=\"post\" <fieldset> <table> <tr><h2>Cookie Settings</h2></tr> <tr><td>Cookie Domain:</td><td><input type=\"text\" name=\"cookie_domain\" value=\"" . $cookie_data[0] . "\"></td></tr> <tr><td>Cookie Name:</td><td><input type=\"text\" name=\"cookie_name\" value=\"" . $cookie_data[1] . "\"></td></tr> <tr><td>Cookie Path:</td><td><input type=\"text\" name=\"cookie_path\" value=\"" . $cookie_data[2] . "\"></td></tr> <tr><td>Cookie Secure:</td><td><input type=\"checkbox\" name=\"cookie_secure\" value=\"1\" $cookie_checked ></td></tr> </table> <table> <tr><h2>Server Settings</h2></tr> <tr><td>Force Server Vars:</td><td><input type=\"checkbox\" name=\"force_server_vars\" value=\"1\" $force_checked ></td></tr> <tr><td>Script Path:</td><td><input type=\"text\" name=\"script_path\" value=\"" . $server_data[1] . "\"></td></tr> <tr><td>Server Name:</td><td><input type=\"text\" name=\"server_name\" value=\"" . $server_data[2] . "\"></td></tr> <tr><td>Server Port:</td><td><input type=\"text\" name=\"server_port\" value=\"" . $server_data[3] . "\"></td></tr> <tr><td>Server Protocol:</td><td><input type=\"text\" name=\"server_protocol\" value=\"" . $server_data[4] . "\"></td></tr> <tr><td>Submit:</td><td><input type=\"submit\" name=\"sent\" value=\"submit\"></td></tr> </table> </fieldset> </body> <html> "; } if ($sent) { $cookie_domain = request_var('cookie_domain', ''); $cookie_name = request_var('cookie_name', ''); $cookie_path = request_var('cookie_path', ''); $cookie_secure = request_var('cookie_secure', 0); $force_server_vars = request_var('force_server_vars', 0); $script_path = request_var('script_path', ''); $server_name = request_var('server_name', ''); $server_port = request_var('server_port', 80); $server_protocol = request_var('server_protocol', 'http://'); $sql_ary = array( 'cookie_domain' => $cookie_domain, 'cookie_name' => $cookie_name, 'cookie_path' => $cookie_path, 'cookie_secure' => $cookie_secure, 'force_server_vars' => $force_server_vars, 'script_path' => $script_path, 'server_name' => $server_name, 'server_port' => $server_port, 'server_protocol' => $server_protocol ); foreach ($sql_ary as $config_name => $config_value) { set_config($config_name, $config_value); } print "Settings are updated!"; print "<meta http-equiv=\"refresh\" content=\"4;./cookie.php\">"; }
UPDATE phpbb_config SET config_value = 'YOUR COOKIE DOMAIN HERE' WHERE config_name = 'cookie_domain'; UPDATE phpbb_config SET config_value = 'YOUR COOKIE NAME HERE' WHERE config_name = 'cookie_name'; UPDATE phpbb_config SET config_value = 'YOUR COOKIE PATH HERE' WHERE config_name = 'cookie_path'; UPDATE phpbb_config SET config_value = '0' WHERE config_name = 'cookie_secure';
