Questo processo, al nome che riporti, non corrisponde a qualcosa di conosciuto.
ps xuwww -p PID
USER PID %CPU %MEM VSZ RSS TT STAT STARTED TIME COMMAND
root 65 100,0 27,3 6562868 2291812 ?? Rs 11:05am 3:07.63 /Library/cuiyTgoP/cuiyTgoP.app/Contents/MacOS/cuiyTgoP
sudo rm -rf /Applications/Mackeeper.app ~/Library/Application\ Support/MacKeeper Helper ~/Library/Caches/com.zeobit.MacKeeper ~/Library/Caches/com.zeobit.MacKeeper.Helper ~/Library/Caches/com.mackeeper.MacKeeper ~/Library/Caches/com.mackeeper.MacKeeper.Helper ~/Library/Caches/LaunchAgents/com.zeobit.MacKeeper.Helper.plist ~/Library/LaunchAgents/com.zeobit.MacKeeper.plugin.Backup.agent.plist ~/Library/LaunchAgents/com.mackeeper.MacKeeper.Helper.plist ~/Library/Logs/MacKeeper.log ~/Library/Logs/MacKeeper.log.signed ~/Library/Preferences/com.zeobit.MacKeeper.plist ~/Library/Preferences/com.zeobit.MacKeeper.Helper.plist ~/Library/Preferences/com.mackeeper.MacKeeper.plist ~/Library/Preferences/com.mackeeper.MacKeeper.Helper.plist /Library/Application\ Support/MacKeeper /Library/LaunchDaemons/com.zeobit.MacKeeper.AntiVirus.plist /Library/LaunchDaemon/com.zeobit.MacKeeper.plugin.AntiTheft.daemon.plist /private/tmp/com.mackeeper.MacKeeper.Installer.config /private/var/db/receipts/com.mackeeper.MacKeeper.affid.pkg.plist /private/var/db/receipts/com.mackeeper.MacKeeper.affid.pkg.bom /private/var/db/receipts/com.mackeeper.MacKeeper.pkg.plist /private/var/db/receipts/com.mackeeper.MacKeeper.pkg.bom /Library/Preferences/.3FAD0F65-FC6E-4889-B975-B96CBF807B78
Bene, è decisamente normale...
Non è consumo, è impegno.
Giusto.
Visitano il forum: SemrushBot [Bot] e 14 ospiti
