ciao a tutti,
ho un macBook 12" del gennaio 2017 - quando apro Chrome invece di vedere la pagina di Google scelta come predefinita, si apre SMART SEARCH e una finestra di MacKeeper ... qualcuno mi può aiutare ?
grazie !!
qui sotto incollo il report di EtreCheck :
EtreCheck version: 3.4.7 (461)
Report generated 2019-01-07 14:24:54
Download EtreCheck from
https://etrecheck.com
Runtime: 2:41
Performance: Excellent
Click the [Remove/Report] links to remove adware or update the whitelist of legitimate software.
Problem: Other problem
Description:
smart search
Hardware Information: ⓘ
MacBook (Retina, 12-inch, Early 2016)
MacBook - model: MacBook9,1
1 1,2 GHz Intel Core m5 (m5-6Y54) CPU: 2-core
8 GB RAM Not upgradeable
BANK 0/DIMM0
4 GB LPDDR3 1867 MHz ok
BANK 1/DIMM0
Handoff/Airdrop2: supported
Wireless: en0: 802.11 a/b/g/n/ac
Battery: Health = Normal - Cycle count = 295
iCloud Quota: 10.66 GB available
Video Information: ⓘ
Intel HD Graphics 515 - VRAM: 1536 MB
Color LCD
Disk Information: ⓘ
APPLE SSD AP0512J disk0: (500,28 GB) (Solid State - TRIM: Yes)
(disk0s1) <not mounted> [EFI]: 315 MB
(disk0s2) <not mounted> [APFS Container]: 499.96 GB
USB Information: ⓘ
USB30Bus
Virtual disks: ⓘ
Macintosh HD (disk1s1 - APFS) / [Startup]: 499.96 GB (93.24 GB free)
Physical disk: disk0s2 499.96 GB (93.24 GB free)
(disk1s2) <not mounted> [Preboot]: 499.96 GB
(disk1s3) <not mounted> [Recovery]: 499.96 GB
(disk1s4) /private/var/vm [VM]: 499.96 GB
System Software: ⓘ
macOS High Sierra 10.13.6 (17G65) - Time since boot: about 11 hours
Gatekeeper: ⓘ
Possible adware: ⓘ
Adware: ~/Library/LaunchAgents/com.MyMacUpdater.agent.plist
Unknown file: ~/Library/LaunchAgents/com.cisco.videoguard10.plist
sh -c $HOME/Library/Cisco/VideoGuardPlayer/VideoGuard10/VideoGuard10.bundle/Contents/Resources/setupServer.sh
Unknown file: ~/Library/LaunchAgents/com.cisco.videoguard10.uninstall.plist
sh ~/.cisco/VideoGuard/uninstall/cisco_videoguard10/condUninstall.sh
3 possible adware files found. [Remove/Report]
Clean up: ⓘ
/System/Library/LaunchAgents/com.apple.corespeechd.plist
/System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd
Executable not found!
~/Applications/MyMacUpdater/MyMacUpdater -guid 48807305586966977 -source adst-1852 -url http:/request.macmymacupdater.com/macCheckForUpdates -brand MyMacUpdater -current_version 1000
~/Library/LaunchAgents/com.MyShopcoupon.agent.plist
~/Applications/MyShopcoupon/MyShopcoupon
~/Library/LaunchAgents/com.iobit.MacBoosterMini6.plist
/Applications/MacBooster 6.app/Contents/Resources/MacboosterMini.app/Contents/MacOS/MacboosterMini
4 orphan files found. [Clean up]
Kernel Extensions: ⓘ
/System/Library/Extensions
[not loaded] com.BlackBerry.driver.USBCDCNCM (1.0.10 - SDK 10.7) [Lookup]
[not loaded] com.rim.driver.BlackBerryUSBDriverInt (2.2.7 - SDK 10.7) [Lookup]
[not loaded] com.rim.driver.BlackBerryUSBDriverVSP (0.0.74) [Lookup]
[loaded] com.rim.driver.BlackBerryVirtualPrivateNetwork (1.0.18 - SDK 10.
[Lookup]
System Launch Agents: ⓘ
[failed] com.apple.corespeechd.plist (? ? ? - installed 2018-04-27) - /System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd: Executable not found!
[not loaded] 9 Apple tasks
[loaded] 180 Apple tasks
[running] 103 Apple tasks
System Launch Daemons: ⓘ
[not loaded] 37 Apple tasks
[loaded] 194 Apple tasks
[running] 104 Apple tasks
Launch Agents: ⓘ
[not loaded] com.adobe.AAM.Updater-1.0.plist (Adobe Systems, Inc. - installed 2018-02-11) [Lookup]
[failed] com.adobe.ARMDCHelper.cc24aef4a1b90ed56a725c38014c95072f92651fb65e1bf9c8e43c37a23d420d.plist (Adobe Systems, Inc. - installed 2018-02-14) [Lookup]
[running] com.adobe.AdobeCreativeCloud.plist (Adobe Systems, Inc. - installed 2017-12-31) [Lookup]
[running] com.adobe.GC.AGM.plist (Adobe Systems, Inc. - installed 2018-12-23) [Lookup]
[not loaded] com.adobe.GC.Invoker-1.0.plist (Adobe Systems, Inc. - installed 2018-12-23) [Lookup]
[loaded] com.divx.dms.agent.plist (? 90291e60 ebd1b8a6 - installed 2013-01-27) [Lookup]
[failed] com.divx.update.agent.plist (? 4a2d5ecc 9a387dac - installed 2013-01-27) [Lookup]
[running] com.rim.BBAlbumArtCacher.plist (Research in Motion Limited - installed 2012-07-17) [Lookup]
[running] com.rim.BBLaunchAgent.plist (? c583fbf8 3bdc9b31 - installed 2014-09-03) [Lookup]
[running] com.rim.PeerManager.plist (Research in Motion Limited - installed 2014-06-24) [Lookup]
[running] com.rim.blackberrylink.BlackBerry-Link-Helper-Agent.plist (? 85f34458 f53a3198 - installed 2017-01-18) [Lookup]
[running] uk.co.canimaansoftware.ClamXAV.UI-Helper.plist (Mark Allan - installed 2019-01-06) [Lookup]
[loaded] uk.co.canimaansoftware.ClamXAV.UninstallWatcher.plist (Mark Allan - installed 2018-12-30) [Lookup]
Launch Daemons: ⓘ
[loaded] com.adobe.ARMDC.Communicator.plist (Adobe Systems, Inc. - installed 2018-02-14) [Lookup]
[loaded] com.adobe.ARMDC.SMJobBlessHelper.plist (Adobe Systems, Inc. - installed 2018-02-14) [Lookup]
[loaded] com.adobe.acc.installer.plist (Adobe Systems, Inc. - installed 2017-12-31) [Lookup]
[running] com.adobe.agsservice.plist (Adobe Systems, Inc. - installed 2018-12-23) [Lookup]
[loaded] com.adobe.fpsaud.plist (Adobe Systems, Inc. - installed 2018-11-29) [Lookup]
[running] com.bombich.ccchelper.plist (Bombich Software, Inc. - installed 2015-01-20) [Lookup]
[running] com.rim.BBDaemon.plist (? 9f895e8a 50e66787 - installed 2014-06-24) [Lookup]
[not loaded] com.rim.nkehelper.plist (Apple, Inc. - installed 2018-07-04)
[running] com.rim.tunmgr.plist (Research in Motion Limited - installed 2014-06-24) [Lookup]
[running] uk.co.canimaansoftware.ClamXAV.Engine.plist (Mark Allan - installed 2018-12-30) [Lookup]
[running] uk.co.canimaansoftware.ClamXAV.HelperTool.plist (Mark Allan - installed 2018-12-30) [Lookup]
[loaded] uk.co.canimaansoftware.ClamXAV.HelperToolUpdater.plist (Mark Allan - installed 2018-12-30) [Lookup]
User Launch Agents: ⓘ
[failed] com.MyMacUpdater.agent.plist (? 4738f66a 0 - installed 2018-12-27) Adware! [Remove/Report]
[failed] com.MyShopcoupon.agent.plist (? bf9485b 0 - installed 2018-12-27) [Lookup] - ~/Applications/MyShopcoupon/MyShopcoupon: Executable not found!
[loaded] com.adobe.AAM.Updater-1.0.plist (Adobe Systems, Inc. - installed 2017-12-31) [Lookup]
[loaded] com.adobe.GC.Invoker-1.0.plist (Adobe Systems, Inc. - installed 2018-12-23) [Lookup]
[loaded] com.cisco.videoguard10.plist (Shell Script 42dd7412 - installed 2018-10-04)
[loaded] com.cisco.videoguard10.uninstall.plist (Shell Script b3285c54 - installed 2018-10-04)
[running] com.cisco.videoguardmonitor.plist (Shell Script 1993d3c - installed 2018-10-04)
[loaded] com.divx.agent.postinstall.plist (? e4878fa f8208157 - installed 2013-01-27) [Lookup]
[loaded] com.google.keystone.agent.plist (Google, Inc. - installed 2018-07-20) [Lookup]
[failed] com.iobit.MacBoosterMini6.plist (? 273899ce 0 - installed 2018-12-27) [Lookup] - /Applications/MacBooster 6.app/Contents/Resources/MacboosterMini.app/Contents/MacOS/MacboosterMini: Executable not found!
User Login Items: ⓘ
iTunesHelper Applicazione - Hidden (Apple, Inc. - installed 2018-04-15)
(/Applications/iTunes.app/Contents/MacOS/iTunesHelper.app)
Internet Plug-ins: ⓘ
AdobeAAMDetect: 3.0.0.0 (installed 2017-12-31) [Lookup]
FlashPlayer-10.6: 32.0.0.101 (installed 2018-12-10) [Lookup]
QuickTime Plugin: 7.7.3 (installed 2019-01-06)
OVSHelper: 1.1 (installed 2017-01-18) [Lookup]
AdobePDFViewer: 19.010.20064 (installed 2019-01-02) [Lookup]
DivXBrowserPlugin: 2.2 (installed 2017-01-18) [Lookup]
AdobePDFViewerNPAPI: 17.012.20098 (installed 2019-01-02) [Lookup]
Flash Player: 32.0.0.101 (installed 2018-12-10) [Lookup]
Silverlight: 4.1.10329.0 (installed 2017-01-18) [Lookup]
iPhotoPhotocast: 7.0 (installed 2017-01-18)
Safari Extensions: ⓘ
None
3rd Party Preference Panes: ⓘ
DivX (installed 2012-12-11) [Lookup]
Flash Player (installed 2018-11-29) [Lookup]
Time Machine: ⓘ
Skip System Files: NO
Mobile backups: ON
Auto backup: YES
Volumes being backed up:
Destinations:
SENZA TITOL [Local]
Total size: 499.76 GB
Total number of backups: 4
Oldest backup: 21/11/12, 08:26
Last backup: 08/12/16, 02:15
Backup size 499.76 GB > (Disk size 0 B X 3)
Top Processes by CPU: ⓘ
11% Google Chrome
11% WindowServer
11% Google Chrome Helper
10% kernel_task
5% hidd
Top Processes by Memory: ⓘ
705 MB kernel_task
201 MB Google Chrome
139 MB Google Chrome Helper
96 MB opendirectoryd
79 MB Google Chrome Helper
Input Output Process name
293 KB 256 KB mDNSResponder
50 KB 21 KB netbiosd
12 KB 2 KB cloudd
4 KB 6 KB apsd
0 B 416 B SystemUIServer
15.68 Google Chrome Helper
12.90 WindowServer
9.56 Google Chrome
5.66 Google Chrome Helper
Virtual Memory Information: ⓘ
4.83 GB Available RAM
3.28 GB Free RAM
3.17 GB Used RAM
1.55 GB Cached files
396 MB Swap Used
Adobe Flash Player: (installed 2018-12-10)
Adobe Acrobat Reader DC (19.010.20064): (installed 2019-01-02)
ClamXAV v3.0.9: (installed 2019-01-06)
2019-01-06 17:01:55 opendirectoryd Crash [Open]
Cause: API MISUSE: Over-release of an object
