Etcher 1.4.5
OS X 10.9 Mavericks+
Dmg 93.5MB
257.8MB su disco
https://etcher.io
https://github.com/resin-io/etcher
Etcher è una semplice applicazione multipiattaforma per creare una chiavetta usb o scheda SD con un'installazione avviabile di Linux.
Sarà possibile così usare una ISO di una distribuzione Linux senza installarla sul disco o virtualizzarla.
Pur essendo multipiattaforma, qui presento la versione per OS X/macOS.
Il funzionamento è elementare, come si vede nella gif:
C'è anche una versione sperimentale CLI dell'utilità
https://etcher.io/cli/
Istallazione macOS o GNU/Linux:
Extract the .tar.gz package by running:
tar fvx path/to/cli.tar.gz
Add /opt/etcher-cli to the PATH. For example, add the following to .bashrc or .zshrc:
export PATH="$PATH:/opt/etcher-cli"
Novità nella 1.4.5:
Center content independent to window resolution.
Add electron-native file-picker component.
Hide unsafe mode option toggle with an env var.
Use new design background color and drive step size ordering.
Add a convenience Storage class on top of localStorage.
Introduce env var to toggle autoselection of all drives.
Add font-awesome.
Add support for configuration files
Use GTK-3 darkTheme mode.
Add environment variable to toggle fullscreen.
Allow blacklisting of drives through and environment variable ETCHER_BLACKLISTED_DRIVES.
Show selected drives below drive selection step.
Add a button to cancel the flash process.
Download usbboot drivers installer when clicking a driverless usbboot device on Windows.
Allow disabling links and hiding help link with an env var.
Fixes
Add "make webpack" to travis-ci build script
Makefile: Don't use tilde in rpm versions
Change Spectron port so not to overlap with other builds
Fix multi-writes analytics by reusing existing logic in multi-write events.
Load usbboot adapter on start on GNU/Linux if running as root.
Misc
Update drivelist to v6.4.2
Add instructions for installing and uninstalling on Solus
