EtreCheck version: 3.4.7 (461)
Report generated 2018-08-10 09:44:39
Runtime: 2:46
Performance: Excellent
Problem: Computer is restarting
Hardware Information: ⓘ
Mac mini (Late 2012)
Mac mini - model: Macmini6,2
1 2.6 GHz Intel Core i7 (i7-3720QM) CPU: 4-core
16 GB RAM Upgradeable - [Instructions]
BANK 0/DIMM0
8 GB DDR3 1600 MHz ok
BANK 1/DIMM0
Handoff/Airdrop2: supported
Wireless: en1: 802.11 a/b/g/n
Video Information: ⓘ
Intel HD Graphics 4000 - VRAM: 1024 MB
G247HL 1920 x 1080
Disk Information: ⓘ
APPLE SSD SM128E disk1: (121,33 GB) (Solid State - TRIM: Yes)
[Show SMART report]
(disk1s1) <not mounted> [EFI]: 210 MB
(disk1s2) <not mounted> [CoreStorage Container]: 120.99 GB
(disk1s3) <not mounted> [Boot]: 134 MB
APPLE HDD HTS541010A9E662 disk0: (1 TB) (Rotational)
[Show SMART report]
(disk0s1) <not mounted> [EFI]: 210 MB
(disk0s2) <not mounted> [CoreStorage Container]: 999.35 GB
(disk0s3) <not mounted> [Recovery]: 650 MB
USB Information: ⓘ
XHCI Root Hub SS Simulation
EHCI Root Hub Simulation
hub_device
Apple, Inc. Keyboard Hub
composite_device
Apple Inc. Apple Keyboard
hub_device
4,05 GB
JMicron Samsung M3 Portable 1 TB
hub_device
Apple, Inc. IR Receiver
Apple Inc. BRCM20702 Hub
XHCI Root Hub USB 2.0 Simulation
Thunderbolt Information: ⓘ
Apple Inc. thunderbolt_bus
Virtual disks: ⓘ
Macintosh HD (disk2 - Journaled HFS+) / [Startup]: 1.12 TB (731.47 GB free)
Physical disk: disk1s2 120.99 GB Online
Physical disk: disk0s2 999.35 GB Online
SAMSUNG Time Machine (disk4s2 - Case-sensitive Journaled HFS+) /Volumes/SAMSUNG Time Machine : 999.85 GB (576.84 GB free)
Physical disk: (null) 999.85 GB (576.84 GB free)
System Software: ⓘ
OS X Yosemite 10.10.5 (14F2511) - Time since boot: less than an hour
Configuration files: ⓘ
/etc/sysctl.conf - File exists but not expected
Gatekeeper: ⓘ
Clean up: ⓘ
/System/Library/LaunchAgents/com.apple.CalendarAgentLauncher.plist
/System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgentLauncher
Executable not found!
~/Library/LaunchAgents/MaxSecure.MaxMacSec.plist
/Applications/MaxSecureAntivirus.app/Contents/MacOS/MaxSecureAntivirus
2 orphan files found. [Clean up]
Kernel Extensions: ⓘ
/Library/Application Support/Avast/components/fileshield/signed
[not loaded] com.avast.FileShield (4.0.0 - SDK 10.12) [Lookup]
/Library/Application Support/Avast/components/proxy/signed
[not loaded] com.avast.PacketForwarder (2.1 - SDK 10.12) [Lookup]
/Library/Extensions
[loaded] com.malwarebytes.mbam.rtprotection (3.1 - SDK 10.12) [Lookup]
/System/Library/Extensions
[not loaded] com.avira.kext.FileAccessControl (1.0.0d1 - SDK 10.9) [Lookup]
[not loaded] net.telestream.driver.TelestreamAudio (1.1.0 - SDK 10.8) [Lookup]
System Launch Agents: ⓘ
[loaded] com.apple.CalendarAgentLauncher.plist (? ? ? - installed 2014-03-21) - /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgentLauncher: Executable not found!
[not loaded] 7 Apple tasks
[loaded] 145 Apple tasks
[running] 61 Apple tasks
System Launch Daemons: ⓘ
[failed] com.apple.watchdogd.plist (Apple, Inc. - installed 2017-06-05)
[not loaded] 45 Apple tasks
[loaded] 143 Apple tasks
[running] 74 Apple tasks
Launch Agents: ⓘ
[not loaded] com.avast.osx.secureline.update-agent.plist (AVAST Software a.s. - installed 2018-06-10) [Lookup]
[not loaded] com.avast.osx.secureline.userinit.plist (Shell Script 2fc1004f - installed 2018-06-10) [Lookup]
[not loaded] com.avast.userinit.plist (Shell Script bb25154c - installed 2018-06-10) [Lookup]
[not loaded] com.malwarebytes.mbam.frontend.agent.plist (Malwarebytes Corporation - installed 2017-11-27) [Lookup]
Launch Daemons: ⓘ
[not loaded] com.adobe.fpsaud.plist (Adobe Systems, Inc. - installed 2018-06-26) [Lookup]
[not loaded] com.apple.installer.cleanupinstaller.plist (? ? ? - installed 2017-10-14)
[loaded] com.apple.installer.osmessagetracing.plist (Apple, Inc. - installed 2017-10-02)
[not loaded] com.avast.init.plist (Shell Script fc55b6fa - installed 2018-06-10) [Lookup]
[not loaded] com.avast.osx.secureline.init.plist (Shell Script 1bda83b1 - installed 2018-06-10) [Lookup]
[not loaded] com.avast.osx.secureline.uninstall.plist (Shell Script ba7a0061 - installed 2018-06-10) [Lookup]
[not loaded] com.avast.osx.secureline.update.plist (Shell Script f50a649c - installed 2018-06-10) [Lookup]
[not loaded] com.avast.uninstall.plist (Shell Script 22f94791 - installed 2018-06-10) [Lookup]
[not loaded] com.avast.update.plist (Shell Script 5c6ac355 - installed 2018-06-10) [Lookup]
[not loaded] com.malwarebytes.MBAMHelperTool.plist (Malwarebytes Corporation - installed 2015-11-07) [Lookup]
[not loaded] com.malwarebytes.mbam.rtprotection.daemon.plist (Malwarebytes Corporation - installed 2017-11-27) [Lookup]
[not loaded] com.malwarebytes.mbam.settings.daemon.plist (Malwarebytes Corporation - installed 2017-11-27) [Lookup]
User Launch Agents: ⓘ
[not loaded] MaxSecure.MaxMacSec.plist (? 83dec26a 0 - installed 2015-02-06) [Lookup] - /Applications/MaxSecureAntivirus.app/Contents/MacOS/MaxSecureAntivirus: Executable not found!
[not loaded] com.avast.osx.secureline.home.userinit.plist (Shell Script a3a599fe - installed 2018-06-10) [Lookup]
[not loaded] com.google.keystone.agent.plist (Google, Inc. - installed 2018-07-18) [Lookup]
[not loaded] com.macpaw.CleanMyMac2Helper.diskSpaceWatcher.plist (MacPaw Inc. - installed 2014-09-13) [Lookup]
[not loaded] com.macpaw.CleanMyMac2Helper.scheduledScan.plist (MacPaw Inc. - installed 2014-09-13) [Lookup]
[not loaded] com.macpaw.CleanMyMac2Helper.trashWatcher.plist (MacPaw Inc. - installed 2014-09-13) [Lookup]
User Login Items: ⓘ
iTunesHelper Applicazione (Apple, Inc. - installed 2018-07-10)
(/Applications/iTunes.app/Contents/MacOS/iTunesHelper.app)
Android File Transfer Agent Applicazione
(~/Library/Application Support/Google/Android File Transfer/Android File Transfer Agent.app)
SpeechSynthesisServer Applicazione
(/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesisServer.app)
Internet Plug-ins: ⓘ
Silverlight: 5.1.41212.0 (installed 2016-04-24) [Lookup]
FlashPlayer-10.6: 30.0.0.134 (installed 2018-07-11) [Lookup]
QuickTime Plugin: 7.7.3 (installed 2017-10-13)
Flash Player: 30.0.0.134 (installed 2018-07-11) [Lookup]
Flip4Mac WMV Plugin: 3.2.0.16 (installed 2013-11-09) [Lookup]
Default Browser: 600 (installed 2015-08-25)
Safari Extensions: ⓘ
Avast Online Security - AVAST Software - http://www.avast.com (installed 2014-12-06)
3rd Party Preference Panes: ⓘ
Flash Player (installed 2018-06-26) [Lookup]
Flip4Mac WMV (installed 2013-03-29) [Lookup]
Time Machine: ⓘ
Mobile backups: OFF
Auto backup: NO - Auto backup turned off
Volumes being backed up:
Macintosh HD: Disk size: 1.12 TB Disk used: 383.73 GB
Destinations:
SAMSUNG Time Machine [Local]
Total size: 999.85 GB
Total number of backups: 21
Oldest backup: 02/10/13 21:06
Last backup: 13/10/17 21:55
Size of backup disk: Too small
Backup size 999.85 GB < (Disk used 383.73 GB X 3)
Top Processes by CPU: ⓘ
3% WindowServer
1% kernel_task
0% fontd
0% notifyd
0% launchd
Top Processes by Memory: ⓘ
816 MB kernel_task
277 MB com.apple.WebKit.WebContent
270 MB com.apple.WebKit.WebContent
213 MB com.apple.WebKit.WebContent
212 MB Safari
2.98 WindowServer
0.08 AppleSpell
0.02 locationd
0.02 SystemUIServer
Virtual Memory Information: ⓘ
11.08 GB Available RAM
9.17 GB Free RAM
4.92 GB Used RAM
1.91 GB Cached files
0 B Swap Used
Adobe Flash Player: (installed 2018-07-11)
2018-08-10 09:09:45 cleanup_installer Crash [Open]
2018-08-09 23:41:52 Kernel Panic [Open] [Details]
3rd Party Kernel Extensions:
com.avast.PacketForwarder 2.1
com.avast.PacketForwarder 2.1 (addr 0xffffff7f8a7fb000, size 20480)
com.avast.FileShield 4.0.0
net.telestream.driver.TelestreamAudio 1.1.0
com.malwarebytes.mbam.rtprotection 3.1.1
Come detto sarà difficile.
Visitano il forum: Ahrefs [Bot], Google [Bot], SemrushBot [Bot] e 12 ospiti
