Ciao a tutti, piacere di conoscervi e di far parte di questa comunità. In pratica non ho un vero e proprio problema col mio Mac ma vorrei sapere come poter ottimizzare le prestazioni del mio Mac e se al suo interno funziona tutto alla normalità, oppure c'e qualcosa che non va ed io non sono in grado di capirlo in quanto inesperto in materia. Spero possiate aiutarmi. Grazie infinite
EtreCheck version: 3.4.7 (461)
Report generated 2018-07-05 16:53:48
Download EtreCheck from
https://etrecheck.com
Runtime: 1:56
Performance: Excellent
Hardware Information: ⓘ
MacBook Pro (Retina, 15-inch, Mid 2015)
MacBook Pro - model: MacBookPro11,4
1 2,2 GHz Intel Core i7 (i7-4770HQ) CPU: 4-core
16 GB RAM Not upgradeable
BANK 0/DIMM0
8 GB DDR3 1600 MHz ok
BANK 1/DIMM0
Handoff/Airdrop2: supported
Wireless: en0: 802.11 a/b/g/n/ac
Battery: Health = Normal - Cycle count = 534
iCloud Quota: 4.24 GB available
Video Information: ⓘ
Intel Iris Pro - VRAM: 1536 MB
Color LCD
Disk Information: ⓘ
APPLE SSD SM0256G disk0: (251 GB) (Solid State - TRIM: Yes)
[Show SMART report]
(disk0s2) <not mounted> [APFS Container]: 250.79 GB
USB Information: ⓘ
USB30Bus
Broadcom Corp. Bluetooth USB Host Controller
Thunderbolt Information: ⓘ
Apple Inc. thunderbolt_bus
Virtual disks: ⓘ
Macintosh HD (disk1s1 - APFS) / [Startup]: 250.79 GB (67.06 GB free)
Encrypted: Yes (Unlocked)
Physical disk: disk0s2 250.79 GB (67.06 GB free)
(disk1s2) <not mounted> [Preboot]: 250.79 GB
(disk1s3) <not mounted> [Recovery]: 250.79 GB
(disk1s4) /private/var/vm [VM]: 250.79 GB
System Software: ⓘ
macOS High Sierra 10.13.5 (17F77) - Time since boot: less than an hour
Gatekeeper: ⓘ
Clean up: ⓘ
/System/Library/LaunchAgents/com.apple.corespeechd.plist
/System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd
Executable not found!
One orphan file found. [Clean up]
Kernel Extensions: ⓘ
/Library/Extensions
[loaded] com.malwarebytes.mbam.rtprotection (3.1 - SDK 10.12) [Lookup]
System Launch Agents: ⓘ
[failed] com.apple.corespeechd.plist (? ? ? - installed 2017-11-01) - /System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd: Executable not found!
[not loaded] 8 Apple tasks
[loaded] 177 Apple tasks
[running] 107 Apple tasks
System Launch Daemons: ⓘ
[not loaded] 37 Apple tasks
[loaded] 187 Apple tasks
[running] 109 Apple tasks
Launch Agents: ⓘ
[not loaded] com.adobe.AAM.Updater-1.0.plist (Adobe Systems, Inc. - installed 2018-01-16) [Lookup]
[running] com.adobe.AdobeCreativeCloud.plist (Adobe Systems, Inc. - installed 2018-07-01) [Lookup]
[not loaded] com.adobe.GC.Invoker-1.0.plist (Adobe Systems, Inc. - installed 2018-05-31) [Lookup]
[running] com.malwarebytes.mbam.frontend.agent.plist (Malwarebytes Corporation - installed 2018-01-17) [Lookup]
Launch Daemons: ⓘ
[loaded] com.adobe.acc.installer.v2.plist (Adobe Systems, Inc. - installed 2018-07-01) [Lookup]
[running] com.adobe.agmservice.plist (Adobe Systems, Inc. - installed 2018-05-31) [Lookup]
[running] com.adobe.agsservice.plist (Adobe Systems, Inc. - installed 2018-05-31) [Lookup]
[loaded] com.adobe.fpsaud.plist (Adobe Systems, Inc. - installed 2018-06-02) [Lookup]
[loaded] com.apple.installer.osmessagetracing.plist (Apple, Inc. - installed 2018-05-30)
[loaded] com.macpaw.CleanMyMac3.Agent.plist (MacPaw Inc. - installed 2018-05-22) [Lookup]
[loaded] com.malwarebytes.HelperTool.plist (Malwarebytes Corporation - installed 2018-01-17) [Lookup]
[running] com.malwarebytes.mbam.rtprotection.daemon.plist (Malwarebytes Corporation - installed 2018-01-17) [Lookup]
[running] com.malwarebytes.mbam.settings.daemon.plist (Malwarebytes Corporation - installed 2018-01-17) [Lookup]
User Launch Agents: ⓘ
[loaded] com.adobe.AAM.Updater-1.0.plist (Adobe Systems, Inc. - installed 2018-01-16) [Lookup]
[loaded] com.adobe.GC.Invoker-1.0.plist (Adobe Systems, Inc. - installed 2018-05-31) [Lookup]
[not loaded] com.google.keystone.agent.plist (Google, Inc. - installed 2017-11-08) [Lookup]
[loaded] com.macpaw.CleanMyMac3.Scheduler.plist (MacPaw Inc. - installed 2017-03-07) [Lookup]
[running] com.spotify.webhelper.plist (Spotify - installed 2018-07-05) [Lookup]
User Login Items: ⓘ
StartUpHelper SMLoginItem - Hidden (Spotify - installed 2018-07-01)
(/Applications/Spotify.app/Contents/Library/LoginItems/StartUpHelper.app)
Internet Plug-ins: ⓘ
Silverlight: 5.1.20125.0 (installed 2017-05-12) [Lookup]
FlashPlayer-10.6: 30.0.0.113 (installed 2018-06-07) [Lookup]
QuickTime Plugin: 7.7.3 (installed 2018-06-12)
Flash Player: 30.0.0.113 (installed 2018-06-07) [Lookup]
AdobeAAMDetect: 3.0.0.0 (installed 2018-07-01) [Lookup]
3rd Party Preference Panes: ⓘ
Flash Player (installed 2018-06-02) [Lookup]
Time Machine: ⓘ
Time Machine not configured!
Top Processes by CPU: ⓘ
9% WindowServer
2% kernel_task
2% mdworker
2% mdworker
2% com.apple.WebKit.WebContent
Top Processes by Memory: ⓘ
931 MB kernel_task
311 MB Finder
179 MB Spotify Helper
156 MB Safari
155 MB Adobe Desktop Service
Input Output Process name
715 KB 177 KB Spotify
20 KB 17 KB mDNSResponder
8 KB 6 KB apsd
7 KB 2 KB cloudd
3 KB 1 KB netbiosd
11.56 WindowServer
2.24 com.apple.WebKit.WebContent
0.98 Spotify
0.90 Adobe CEF Helper
Virtual Memory Information: ⓘ
11.24 GB Available RAM
8.22 GB Free RAM
4.76 GB Used RAM
3.02 GB Cached files
0 B Swap Used
Adobe Flash Player: (installed 2018-06-07)
The Unarchiver: 4.0.0 (installed 2018-06-16)
Memory Clean 2: 1.7 (installed 2018-06-19)
AdBlock: 1.0.7 (installed 2018-07-02)
2018-07-04 23:29:56 ~/Library/Logs/DiagnosticReports/cloudd_2018-07-04-232956_[redacted].crash Crash [Open]
2018-07-04 09:37:49 ~/Library/Logs/DiagnosticReports/AdBlock-Safari-Menu_2018-07-04-093749_[redacted].crash Crash [Open]
