Ecco L'etrecheck.
EtreCheck version: 3.4.7 (461)
Report generated 2018-05-10 23:27:33
Download EtreCheck from
https://etrecheck.com" onclick="window.open(this.href);return false;
Runtime: 4:16
Performance: Good
Problem: Computer is too slow
Hardware Information: ⓘ
iMac (27-inch, Late 2013)
iMac - model: iMac14,2
1 3,5 GHz Intel Core i7 (i7-4771) CPU: 4-core
24 GB RAM Upgradeable - [Instructions]
BANK 0/DIMM0
4 GB DDR3 1600 MHz ok
BANK 1/DIMM0
BANK 0/DIMM1
8 GB DDR3 1600 MHz ok
BANK 1/DIMM1
Handoff/Airdrop2: supported
Wireless: en1: Unknown
Video Information: ⓘ
NVIDIA GeForce GTX 775M - VRAM: 2048 MB
iMac 2560 x 1440
Disk Information: ⓘ
APPLE SSD SD0128F disk1: (121,33 GB) (Solid State - TRIM: Yes)
[Show SMART report]
EFI (disk1s1 - MS-DOS FAT32) <not mounted> [EFI]: 210 MB
(disk1s2) <not mounted> [CoreStorage Container]: 120.99 GB
(disk1s3) <not mounted> [Boot]: 134 MB
APPLE HDD ST3000DM001 disk0: (3 TB) (Rotational)
[Show SMART report]
(disk0s2) <not mounted> [CoreStorage Container]: 3.00 TB
Recovery HD (disk0s3 - HFS+) <not mounted> [Recovery]: 650 MB
USB Information: ⓘ
USB30Bus
Samsung D3 Station
D3 Station disk3: (3 TB)
(disk3s1) <not mounted> [EFI]: 315 MB
GENESI (disk3s2 - Journaled HFS+) /Volumes/GENESI : 3.00 TB (162.10 GB free)
Apple Inc. BRCM20702 Hub
Apple, Inc. Keyboard Hub
Apple Inc. Apple Keyboard
Thunderbolt Information: ⓘ
Apple Inc. thunderbolt_bus
Virtual disks: ⓘ
SKYNET (disk2 - Journaled HFS+) / [Startup]: 3.11 TB (602.45 GB free)
Physical disk: disk1s2 120.99 GB Online
Physical disk: disk0s2 3.00 TB Online
System Software: ⓘ
macOS High Sierra 10.13.4 (17E199) - Time since boot: less than an hour
Gatekeeper: ⓘ
Clean up: ⓘ
/System/Library/LaunchAgents/com.apple.corespeechd.plist
/System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd
Executable not found!
One orphan file found. [Clean up]
Kernel Extensions: ⓘ
/Applications/CodeMeter.app
[not loaded] com.wibu.codemeter.CmUSBMassStorage (1.0.7) [Lookup]
/Applications/MacX Video Converter Pro.app
[not loaded] com.macxdvd.driver.goodSysAudioCapture (1.0 - SDK 10.10) [Lookup]
/Applications/Toast 8 Titanium/Toast 8 Titanium/Toast Titanium.app
[not loaded] com.roxio.BluRaySupport (1.1.3) [Lookup]
[not loaded] com.roxio.TDIXController (1.6) [Lookup]
/Library/Extensions
[not loaded] com.lge.driver.LGAndroidmdmcontrol (4.5 - SDK 10.9) [Lookup]
[not loaded] com.lge.driver.LGAndroidmdmdata (4.5 - SDK 10.9) [Lookup]
[not loaded] com.lge.driver.LGAndroidndiscontrol (4.5 - SDK 10.9) [Lookup]
[not loaded] com.lge.driver.LGAndroidndisdata (4.5 - SDK 10.9) [Lookup]
[not loaded] com.lge.driver.LGAndroidserial (4.5 - SDK 10.9) [Lookup]
[not loaded] com.lge.driver.LGAndroidusbbus (4.5 - SDK 10.9) [Lookup]
/System/Library/Extensions
[not loaded] com.Maxtor.driver.PowSecDriver (4.3.16) [Lookup]
[not loaded] com.cy.iokit.Morpheus (1.4.0) [Lookup]
[not loaded] com.digidesign.iokit.DigiDal (7.3) [Lookup]
[not loaded] com.digidesign.iokit.DigiIO (7.3) [Lookup]
[not loaded] com.maxtor.iokit.IOFireWireMxBt (4.2.6) [Lookup]
[not loaded] com.mice.driver.Xbox360Controller (1.0.0d13 - SDK 10.
[Lookup]
[not loaded] com.paceap.kext.PACESupport (5.4.1) [Lookup]
[not loaded] com.paceap.kext.PACESupport2 (5.4.1) [Lookup]
/System/Library/Extensions/360Controller.kext/Contents/PlugIns
[not loaded] com.mice.driver.Wireless360Controller (1.0.0d13 - SDK 10.
[Lookup]
[not loaded] com.mice.driver.WirelessGamingReceiver (1.0.0d13 - SDK 10.
[Lookup]
Startup Items: ⓘ
DigidesignLoader: Path: /Library/StartupItems/DigidesignLoader
PACESupport: Path: /Library/StartupItems/PACESupport
Qmaster: Path: /Library/StartupItems/Qmaster
Startup items no longer function in OS X Yosemite or later
System Launch Agents: ⓘ
[failed] com.apple.corespeechd.plist (? ? ? - installed 2018-02-27) - /System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd: Executable not found!
[not loaded] 8 Apple tasks
[loaded] 184 Apple tasks
[running] 100 Apple tasks
System Launch Daemons: ⓘ
[not loaded] 38 Apple tasks
[running] 112 Apple tasks
Launch Agents: ⓘ
[loaded] com.gog.galaxy.commservice.plist (GOG Sp. z o.o. - installed 2018-04-23) [Lookup]
[failed] com.google.keystone.agent.plist (Google, Inc. - installed 2018-02-04) [Lookup]
[loaded] com.oracle.java.Java-Updater.plist (? 86462284 1a4bf56e - installed 2018-02-23) [Lookup]
[loaded] org.macosforge.xquartz.startx.plist (Apple Inc. - XQuartz - installed 2013-11-11) [Lookup]
Launch Daemons: ⓘ
[failed] PACESupport.plist (Apple, Inc. - installed 2018-03-28)
[loaded] com.adobe.fpsaud.plist (Adobe Systems, Inc. - installed 2018-04-29) [Lookup]
[loaded] com.gog.galaxy.ClientService.plist (GOG Sp. z o.o. - installed 2018-04-23) [Lookup]
[loaded] com.google.keystone.daemon.plist (Google, Inc. - installed 2018-03-06) [Lookup]
[loaded] com.malwarebytes.HelperTool.plist (Malwarebytes Corporation - installed 2017-03-19) [Lookup]
[running] com.mice.360Daemon.plist (? 6ea3b505 ef303aff - installed 2013-10-11) [Lookup]
[loaded] com.oracle.java.Helper-Tool.plist (Shell Script e3fefdd2 - installed 2017-12-20) [Lookup]
[loaded] org.macosforge.xquartz.privileged_startx.plist (Apple Inc. - XQuartz - installed 2013-11-11) [Lookup]
User Launch Agents: ⓘ
[loaded] com.google.xupdater.plist (? 7cbabf7e 916a4824 - installed 2013-05-16) [Lookup]
[loaded] com.valvesoftware.steamclean.plist (? 9190ca9a cf421285 - installed 2018-04-21) [Lookup]
User Login Items: ⓘ
Memory Scope Applicazione
(/Applications/Memory Scope.app)
Android File Transfer Agent Applicazione
(~/Library/Application Support/Google/Android File Transfer/Android File Transfer Agent.app)
Internet Plug-ins: ⓘ
DirectorShockwave: 11.5.1r601 (installed 2009-08-03) [Lookup]
GameFacePlugin: GameFacePlugin 1.3.1.1 (installed 2013-05-07) [Lookup]
Google Earth Web Plug-in: 6.2 (installed 2012-04-14) [Lookup]
Unity Web Player: UnityPlayer version 5.3.8f1 (installed 2017-05-07) [Lookup]
Flip4Mac WMV Plugin: 3.2.0.16 (installed 2013-11-21) [Lookup]
Silverlight: 5.1.30514.0 (installed 2014-12-18) [Lookup]
FlashPlayer-10.6: 29.0.0.171 (installed 2018-05-08) [Lookup]
QuickTime Plugin: 7.7.3 (installed 2018-03-28)
Flash Player: 29.0.0.171 (installed 2018-05-08) [Lookup]
PepperFlashPlayer: 29.0.0.171 (installed 2018-05-08) [Lookup]
iPhotoPhotocast: 7.0 (installed 2013-05-07)
AdobePDFViewer: Unknown (installed 2008-12-20)
JavaAppletPlugin: Java 8 Update 161 build 12 (installed 2018-02-23) Check version
Safari Extensions: ⓘ
[enabled] AdBlock - BetaFish, Inc. -
https://getadblock.com" onclick="window.open(this.href);return false; (installed 2017-12-21)
Audio Plug-ins: ⓘ
DVCPROHDAudio: 1.2 (installed 2005-04-05)
3rd Party Preference Panes: ⓘ
Connect360 (installed 2013-05-07) [Lookup]
Déjà Vu (installed 2008-04-23) [Lookup]
Flash Player (installed 2018-04-29) [Lookup]
Flip4Mac WMV (installed 2013-03-29) [Lookup]
Java (installed 2018-02-23) [Lookup]
MacFUSE (installed 2013-05-07) [Lookup]
NTFS-3G (installed 2009-04-05) [Lookup]
XBox 360 Controllers (installed 2013-10-11) [Lookup]
Time Machine: ⓘ
Skip System Files: NO
Mobile backups: OFF
Auto backup: YES
Volumes being backed up:
SKYNET: Disk size: 3.11 TB Disk used: 2.50 TB
Destinations:
GENESI [Local]
Total size: 3.00 TB
Total number of backups: 64
Oldest backup: 14/06/17, 02:01
Last backup: 10/05/18, 23:19
Size of backup disk: Too small
Backup size 3.00 TB < (Disk used 2.50 TB X 3)
Top Processes by CPU: ⓘ
9% Google Chrome Helper
6% kernel_task
3% Google Chrome
1% coreaudiod
0% Memory Scope
Top Processes by Memory: ⓘ
1.24 GB kernel_task
383 MB Google Chrome Helper
321 MB Google Chrome Helper
308 MB Google Chrome
292 MB Google Chrome Helper
Input Output Process name
16 KB 14 KB mDNSResponder
5 KB 4 KB apsd
2 KB 578 B netbiosd
263 B 289 B kernel_task
9.74 Google Chrome Helper
5.70 Google Chrome
2.18 coreaudiod
1.48 Google Chrome Helper
0.68 launchd
Virtual Memory Information: ⓘ
18.88 GB Available RAM
16.35 GB Free RAM
5.12 GB Used RAM
2.53 GB Cached files
0 B Swap Used
Adobe Flash Player: (installed 2018-04-12)
Adobe Pepper Flash Player: (installed 2018-04-12)
GOG.com Galaxy Redists: (installed 2018-04-23)
GOG.com Galaxy Client: (installed 2018-04-23)
Adobe Flash Player: (installed 2018-05-08)
Adobe Pepper Flash Player: (installed 2018-05-08)
2018-05-10 23:16:39 Last shutdown cause: 0 - Power loss
