diskutil cs list
diskutil cs list
Last login: Sat Jan 20 17:10:55 on ttys001
Mac-Pro-di-satisa:~ satisa$ diskutil list
/dev/disk0
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme *160.0 GB disk0
1: EFI EFI 209.7 MB disk0s1
2: Apple_HFS Seagate Barracuda 160 159.7 GB disk0s2
/dev/disk1
0: GUID_partition_scheme *2.0 TB disk1
1: EFI EFI 209.7 MB disk1s1
2: Apple_HFS Hitachi 2T 2.0 TB disk1s2
/dev/disk2
0: GUID_partition_scheme *320.1 GB disk2
1: EFI EFI 209.7 MB disk2s1
2: Apple_HFS MacPro Maxtor 320 319.7 GB disk2s2
/dev/disk3
0: GUID_partition_scheme *4.0 TB disk3
1: EFI EFI 209.7 MB disk3s1
2: Apple_CoreStorage 3.8 TB disk3s2
3: Apple_HFS Blank 134.2 MB disk3s6
4: Apple_CoreStorage 214.1 GB disk3s3
5: Apple_HFS Blank 650.0 MB disk3s4
/dev/disk5
0: GUID_partition_scheme *256.1 GB disk5
1: EFI EFI 209.7 MB disk5s1
2: Apple_HFS SSD Samsung 255.1 GB disk5s2
3: Apple_Boot Recovery HD 784.2 MB disk5s3
/dev/disk6
0: Apple_HFS Hitachi 4T *3.8 TB disk6
Logical Volume on disk3s2
276018FF-FA37-46AD-9070-374DCF932B91
Unencrypted
diskutil cs list
giginx ha scritto:devi ripetere il comandopare che ci sia ancora un fusion drive.Codice: Seleziona tutto
diskutil cs list
Last login: Sat Jan 20 17:41:24 on console
Mac-Pro-di-satisa:~ satisa$ diskutil cs list
CoreStorage logical volume groups (2 found)
+-- Logical Volume Group C4AEBF97-5989-4641-91A7-5967550A6416
| Name: Hitachi 4T Yosemite
| Status: Online
| Size: 214087790592 B (214.1 GB)
| Free Space: 213735464960 B (213.7 GB)
| +-< Physical Volume 29EAEE0A-2291-4181-BFCD-403340DF3698
| Index: 0
| Disk: disk3s3
| Status: Online
+-- Logical Volume Group B07A7BDD-F3A5-4C30-8450-0789402A359D
Status: Online
Size: 3785705263104 B (3.8 TB)
Free Space: 10354688 B (10.4 MB)
+-< Physical Volume 256ABE5F-4305-49AA-A32A-C3275564729A
| Index: 0
| Disk: disk3s2
| Status: Online
+-> Logical Volume Family C6B58274-0D6A-4671-8F91-7AE736BB2783
Encryption Status: Unlocked
Encryption Type: None
Conversion Status: NoConversion
Conversion Direction: -none-
Has Encrypted Extents: No
Fully Secure: No
Passphrase Required: No
+-> Logical Volume 276018FF-FA37-46AD-9070-374DCF932B91
Disk: disk4
Status: Online
Size (Total): 3785342582784 B (3.8 TB)
Conversion Progress: -none-
Revertible: No
LV Name: Hitachi 4T
Volume Name: Hitachi 4T
Content Hint: Apple_HFS
Last login: Sat Jan 20 18:24:52 on console
| Status: Online
| | Index: 0
| | Disk: disk3s2
| | Status: Online
| Fully Secure: No
| Disk: disk4
| Status: Online
| Revertible: No
| LV Name: Hitachi 4T
Status: Online
Index: 0
Disk: disk3s3
Status: Online
Last login: Sat Jan 20 18:28:13 on ttys000
/dev/disk0
/dev/disk1
/dev/disk2
/dev/disk3
3: Apple_CoreStorage 214.1 GB disk3s3
/dev/disk4
0: Apple_HFS Hitachi 4T *3.8 TB disk4
Unencrypted
/dev/disk5
diskutil cs delete B07A7BDD-F3A5-4C30-8450-0789402A359D
diskutil cs list
Scusami...e se la situazione attuale fosse questa qui sotto? I comandi che mi consigli vanno lo stesso bene?giginx ha scritto:Allo stato attuale ci sono ancora 2 Logical Volume Group e vanno eliminati. Inizia con il primo
finita la prima operazione ridai il comandoCodice: Seleziona tutto
diskutil cs list
Last login: Sat Jan 20 22:14:32 on ttys001
/dev/disk0
0: GUID_partition_scheme *4.0 TB disk0
2: Apple_CoreStorage 3.8 TB disk0s2
/dev/disk1
0: GUID_partition_scheme *160.0 GB disk1
2: Apple_HFS Seagate Barracuda 160 159.7 GB disk1s2
/dev/disk2
0: GUID_partition_scheme *2.0 TB disk2
2: Apple_HFS Hitachi 2T 2.0 TB disk2s2
/dev/disk3
0: GUID_partition_scheme *320.1 GB disk3
2: Apple_HFS MacPro Maxtor 320 319.7 GB disk3s2
/dev/disk4
Logical Volume on disk0s2
688E75F3-B18D-4D47-AC05-AE9B0EA176FD
Unencrypted
/dev/disk5
Last login: Sat Jan 20 22:18:56 on ttys000
CoreStorage logical volume groups (1 found)
Status: Online
| Index: 0
| Disk: disk0s2
| Status: Online
+-> Logical Volume Family AC0A5D7B-FBF1-41DB-A644-BBE8D77C143A
Fully Secure: No
+-> Logical Volume 688E75F3-B18D-4D47-AC05-AE9B0EA176FD
Disk: disk4
Status: Online
Revertible: No
LV Name: Hitachi 4T
Last login: Sat Jan 20 22:39:34 on ttys000
No CoreStorage logical volume groups found
Last login: Sat Jan 20 22:39:56 on ttys001
/dev/disk0
2: Apple_HFS Untitled 3.8 TB disk0s2
/dev/disk1
/dev/disk2
/dev/disk3
/dev/disk5
Last login: Sat Jan 20 22:53:32 on ttys001
Voglio dire che,giginx ha scritto:la prima voce è il disco, il suo nome di fabbrica. Untitled è tutto lo spazio di quel disco, lo inizializzi secondo le tue esigenze dandogli un nome e assegnandogli, se vuoi, altre partizioni. È tutto normale.
Grazie...ora sembra che core storage non ce ne sianogiginx ha scritto:Non devi inizializzare né rinominare il disco dopo che hai eliminato di nuovo il core storage, lascia quello che gli dà il sistema.
Ora avrai un UNTITLED giusto sotto, è quello che devi inizializzare dandogli il nome che preferisci.
Last login: Sun Jan 21 13:10:09 on console
prato06 ha scritto:[Se partiziono il Volume 4TB HGST HDS724040ALE640 Media in una sola partizione (nominandola per esempio Hitachi 4T)....allora OK...
Visitano il forum: Nessuno e 29 ospiti
