-bash-3.2# diskutil list
/dev/disk0 (internal, physical):
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme *250.1 GB disk0
1: EFI EFI 209.7 MB disk0s1
2: Apple_HFS Macintosh SDD 189.2 GB disk0s2
3: Apple_Boot Recovery HD 650.0 MB disk0s3
4: Apple_APFS Container disk2 59.3 GB disk0s4
5: Apple_KernelCoreDump 655.4 MB disk0s5
/dev/disk1 (disk image):
0: GUID_partition_scheme +2.1 GB disk1
1: Apple_HFS OS X Base System 2.0 GB disk1s1
/dev/disk2 (synthesized):
0: APFS Container Scheme - +59.3 GB disk2
Physical Store disk0s4
1: APFS Volume HSierra 12.0 GB disk2s1
2: APFS Volume Preboot 20.1 MB disk2s2
3: APFS Volume Recovery 518.9 MB disk2s3
4: APFS Volume VM 4.3 GB disk2s4
/dev/disk3 (disk image):
0: untitled +5.2 MB disk3
/dev/disk4 (disk image):
0: untitled +524.3 KB disk4
/dev/disk5 (disk image):
0: untitled +524.3 KB disk5
/dev/disk6 (disk image):
0: untitled +524.3 KB disk6
/dev/disk7 (disk image):
0: untitled +2.1 MB disk7
/dev/disk8 (disk image):
0: untitled +524.3 KB disk8
/dev/disk9 (disk image):
0: untitled +524.3 KB disk9
/dev/disk10 (disk image):
0: untitled +12.6 MB disk10
/dev/disk11 (disk image):
0: untitled +2.1 MB disk11
/dev/disk12 (disk image):
0: untitled +1.0 MB disk12
/dev/disk13 (disk image):
0: untitled +2.1 MB disk13
/dev/disk14 (disk image):
0: untitled +524.3 KB disk14
/dev/disk15 (disk image):
0: untitled +524.3 KB disk15
/dev/disk16 (disk image):
0: untitled +1.0 MB disk16
/dev/disk17 (disk image):
0: untitled +6.3 MB disk17
/dev/disk18 (disk image):
0: untitled +6.3 MB disk18
/dev/disk19 (disk image):
0: untitled +524.3 KB disk19
/dev/disk20 (disk image):
0: untitled +2.1 MB disk20
-bash-3.2#
Mi stavo chiedendo la stessa cosa. Quest'anno non voglio sporcare l'iMac fino alla versione finale. Ho un nuovo mbp 13 late 2016, che però mi serve per lavoro. Se potessi partizionarlo e installare High Sierra su una sola partizione, convertendo solo questa in apfs, potrei sbizzarrirmi senza timore di nulla. In fondo, se si può fare con ntfs (Boot Camp) sarà possibile anche in questo caso. O no?faxus ha scritto:C'è già una discussione in proposito, sul Forum.Uno_qualunque ha scritto:Vorrei capire bene le novità relative a APFS... qualcuno ha già chiaro cosa cambia rispetto a HFS+? La scelta di adottare un nuovo filesystem deve essere spinta da motivazioni forti, cosa c'è di nuovo e particolarmente vantaggioso rispetto al passato?
viewtopic.php?f=9&t=40638" onclick="window.open(this.href);return false;
Per il resto sto ancora armeggiando per installare con sicurezza.
Per adesso mi sembra di aver capito che posso usare anche due filesystem.
Sto per fare la prova pratica, poi ti dico
Sì. Sto facendo questo, esattamente.Catalambano ha scritto:... Se potessi partizionarlo e installare High Sierra su una sola partizione, convertendo solo questa in apfs, potrei sbizzarrirmi senza timore di nulla... O no?
https://support.apple.com/en-us/HT204899" onclick="window.open(this.href);return false;fenix ha scritto:cosa e il sip?
si vabbe è una protezione per non farmi fare troppi guasti e per questo motivo che ogni volta devo autorizzare alcunev cartelle e dischi per poterci scrivere che rottura ft gestione non funziona più sui nuovi osfaxus ha scritto:https://support.apple.com/en-us/HT204899" onclick="window.open(this.href);return false;fenix ha scritto:cosa e il sip?
https://en.wikipedia.org/wiki/System_In ... Protection" onclick="window.open(this.href);return false;
Indimenticabile Fenix.fenix ha scritto:lo ricorda anche franz quello che combinavo sui dish
Perché allora non procurarsi un SSD esterno con interfaccia Thunderbolt e installare lì ......faxus ha scritto:Sì. Sto facendo questo, esattamente. .....Catalambano ha scritto:... Se potessi partizionarlo e installare High Sierra su una sola partizione, convertendo solo questa in apfs, potrei sbizzarrirmi senza timore di nulla... O no?
Se ce lo mandassi come pensi che la prenderebbe?faxus ha scritto: Siri... Hahaha, prende per il cu_o.
...... Gli chiedo di aprire la mia cartella utente:
Stai svegliando la scimmia, il mio Apple Pay comincia a preoccuparsi...Kernel Panic ha scritto:Perché allora non procurarsi un SSD esterno con interfaccia Thunderbolt e installare lì ......faxus ha scritto:Sì. Sto facendo questo, esattamente. .....Catalambano ha scritto:... Se potessi partizionarlo e installare High Sierra su una sola partizione, convertendo solo questa in apfs, potrei sbizzarrirmi senza timore di nulla... O no?
