Homebrew su OS X - Diamo la birra al Mac
Oggetto del messaggio: Re: Homebrew su OS X - Diamo la birra al Mac
Messaggio da iStefano »
Stato: Connesso
Messaggio da faxus »
Eliminalo del tutto, MacPorts.
Ormai serve solo ad alcuni iperspecialisti.
Brew è di gran lunga più maneggevole e semplice
Stato: Connesso
Upgrade (un bel po' di roba... Binutils soprattutto), update e doctor
Mmmm... Ventole al massimo, temperature alte...
I soliti errori per la mia discutibile impostazione dell'ora e data non automatica da Apple...
Nuove formule
MacBook-Pro-di-Fabio:~ faxus$ brew update
Updated Homebrew from 1455aa3 to ffd71d0.
Updated 2 taps (caskroom/cask, homebrew/core).
==> New Formulae
alot                lego                osm-gps-map         rclone
git-remote-hg       libbdplus           pdftoedn            wireguard-tools
gitversion          m-cli               presto              zstd
grafana             minio-mc            rancher-cli
==> Updated Formulae
binutils
smartmontools
==> Renamed Formulae
racket -> minimal-racket
==> Deleted Formulae
avidemux            icmake              luyten              sqlitebrowser
folly               kdiff3              quassel             ucspi-tools
gimp                libdbusmenu-qt      samba
Un po' di lavoro con doctor
MacBook-Pro-di-Fabio:~ faxus$ brew doctor
Please note that these warnings are just used to help the Homebrew maintainers
with debugging if you file an issue. If everything you use Homebrew for is
working fine: please don't worry and just ignore them. Thanks!
Warning: A newer Command Line Tools release is available.
Update them from Software Update in the App Store.
Warning: You are using OS X 10.12.
We do not provide support for this pre-release version.
You may encounter build failures or other breakages.
Please create pull-requests instead of filing issues.
Warning: Broken symlinks were found. Remove them with `brew prune`:
/usr/local/bin/macdown
Stato: Connesso
Un po' di aggiornamento.
E un up per I nuovi utenti del Forum...
To restore the stashed changes to /usr/local/Homebrew/Library/Taps/caskroom/homebrew-cask run:
  'cd /usr/local/Homebrew/Library/Taps/caskroom/homebrew-cask && git stash pop'
==> New Formulae
archi-steam-farm    hesiod              pyinvoke            terragrunt
consul-backinator   libsquish           questdb             ttyd
csvtomd             nvc                 rmlint              typescript
dbhash              osrm-backend        sql-translator      yarn
hana                piknik              svgcleaner
==> Updated Formulae...
automoc4                   frescobaldi                shiboken
cuty_capt                  pyside                     sqliteman
elementary                 pyside-tools               valkyrie
evas-generic-loaders       qwtpolar
ezlupdate                  rcssserver
MacBook-Pro-di-Fabio:~ faxus$ brew upgrade
==> Upgrading 1 outdated package, with result:
glib 2.50.1
==> Upgrading glib
==> Downloading https://homebrew.bintray.com/bottles/glib-2.50.1.sierra.bottle.t
######################################################################## 100,0%
==> Pouring glib-2.50.1.sierra.bottle.tar.gz
==> Using the sandbox
** /usr/local/Cellar/glib/2.50.1: 427 files, 22.3M
Your system is ready to brew.
poi
viewtopic.php?f=5&t=32846&start=105#p423128" onclick="window.open(this.href);return false;
MacBook-Pro-di-Fabio:~ faxus$ brew cask info bitbar
bitbar: 1.9.2
https://github.com/matryer/bitbar/
/usr/local/Caskroom/bitbar/1.9.1 (68B)
From: https://github.com/caskroom/homebrew-cask/blob/master/Casks/bitbar.rb
==> Name
BitBar
==> Artifacts
BitBar.app (app)
MacBook-Pro-di-Fabio:~ faxus$ brew cask install --force bitbar
==> Downloading https://github.com/matryer/bitbar/releases/download/v1.9.2/BitBa
==> Verifying checksum for Cask bitbar
==> It seems there is already an App at '/Applications/BitBar.app'; overwriting.
==> Removing App: '/Applications/BitBar.app'
==> Moving App 'BitBar.app' to '/Applications/BitBar.app'
**  bitbar was successfully installed!
MacBook-Pro-di-Fabio:~ faxus$ brew cask cleanup
==> Removing cached downloads
/Users/faxus/Library/Caches/Homebrew/Cask/bitbar--1.9.2.zip
==> This operation has freed approximately 2.3M of disk space.
Stato: Connesso
Addio Fraise, ormai non verrà aggiornata per Sierra, peccato...
MacBook-Pro-di-Fabio:~ faxus$ brew cask uninstall fraise
Poi ho eliminato anche l'alias, ormai orfano, in /Applicazioni
Messaggio da Scialla »
Ecco, io neanche ci pensavo più....
Ovviamente non funziona più niente dopo avere aggiornato a Sierra
Vabbé, intanto comincio a clonarmi il disco poi inizierò a ammanettare per cercare di sistemare..... uffa che 2 balls
Stato: Connesso
Scialla ha scritto:... Ovviamente non funziona più niente dopo avere aggiornato a Sierra...
Devo dire che solo la prima volta è stato noioso, come tempo.
Poi è veloce.
Ma devi rifare daccapo la sistemazione di brew e considera che cambia la cartella di cask.
Se vai un po' indietro trovi tutto annotato.
Ovviamente devi anche aggiornare i Command Line Tool
Stato: Connesso
faxus ha scritto:Addio Fraise, ormai non verrà aggiornata per Sierra, peccato...
Devo dire che, pur sapendolo, ho rilevato nuovamente che la disinstallazione di cask fa schifo...
Una passata con EasyFind è obbligatoria...
Stato: Connesso
Ho aggiornato Cyberduck.
viewtopic.php?f=5&t=4710&p=423892#p423892" onclick="window.open(this.href);return false;
Stato: Connesso
Ho aggiornato Gimp
Guarda un po'...
Stato: Connesso
Dovevo aggiornare Wesnoth..
Ho scoperto che c'è anche su cask...
Stato: Connesso
Manutenzione settimanale
==> Auto-updated Homebrew!
Updated 1 tap (homebrew/core).
==> New Formulae
gitless         jumanpp         loc             pacparser       ssh-audit
aha                        isc-dhcp                   peco
apache-geode               jenkins                    pick
archi-steam-farm           keybase                    pngcrush
gtk+3                      passenger                  zsh-syntax-highlighting
harfbuzz ✔                 passpie
hh                         pcap_dnsproxy
stash-cli -> atlassian-cli
puddletag           qbzr                sonar-runner        treeline
continuando in
indi una regolazione e doctor rassicurante
Stato: Connesso
Annuncio che è stata creata una app per la gestione di brew grafica.
Una beta ben fatta e funzionante, arrivata alla versione 1.2.3.
Qui uno sguardo d'insieme:
viewtopic.php?f=33&t=39371&p=425991#p425991" onclick="window.open(this.href);return false;
Per scaricare l'applicazione
brew cask install cakebrew
Qualche utente che segue questo topic ma si annoia ad usare Terminale avrà la possibilità di usarlo convenientemente
Messaggio da kext »
Ci uscirebbe proprio un articolo bello!
ImmagineImmagine
Stato: Connesso
Vado ad aprire Xquartz come servizio per Inkscape.
Saltella nel Dock e poi si eclissa.
Ripeto altre due volte, idem, leggo nei log praticamente nulla.
Vabbè, sarà il solito casino dopo gli aggiornamenti.
Decido di fare piazza pulita e reinstallare.
Apro EasyFind, non mi fido di come disinstalla Cask, e App Cleaner.
Metto Xquartz nel cestino, cancello le dipendenze nelle librerie varie.
Poi nei private trovo dei file che fanno resistenza.
Via, via! Terminale, sudo e spazzo tutto, vuoto il cestino e addio Xquartz.
Vado su Terminale a reinstallare e a brew cask install xquartz mi risponde a parolacce…
Un casino, messaggi all’impazzata, poco ci manca che si mette a strillare.
Ripeto ma idem.
Boh sarà qualche bizza di brew, però il sospetto di aver fatto una cazzata c’è…
Intanto sistemiamo il dovuto, sono giorni che non ci metto le mani.
Diamogli il suo con l’upgrade, forse si calma
Lo fa, ma compare quel messaggio:
To restore the stashed changes to /usr/loal /Homebrew run:
cd /usr/local Homebrew && git stash pop
Lo sapevo ho fatto casino, ho cancellato qualcosa che sottintendeva qualcos’altro, non solo Xquartz.
Probabilmente ho cancellato qualche archivio o libreria di brew con dei contenuti di Xquartz e non sono stato a separare il contenuto dal contenete…
Terminato l’upgrade eseguo
Bah, no, forse era solo un residuo conflittuale…
... Continua
