Questione di personalità differenti, io preferirei sempre la beta, che (solo in questo strano caso) in effetti sarebbe l'ultima versione testata su Tiger, quindi paradossalmente la più collaudata.Mickie ha scritto:È logico (credo) che è meglio l'ultima "definitiva" piuttosto che la prima beta, no?
PS: anche Leopard, se uno è bravo e lo sa alleggerire, gira su G4, ma il mio Tiger gira su Intel Core 2 Duo e ancora non ha finito di stupirmi!
http://www.transmissionbt.com/64-bit compatibility
Queuing system will not exclude transfers with tracker warnings
Links to original torrent files are no longer maintained
Better data recovery in the case of an OS or Transmission crash
If a data file is moved, stop the torrent instead of redownloading it
Fix bug that didn't list some peers in the resume file and in PEX
Fix bug where changing the global per-torrent peer connection limit did not affect the current session
Fix bug where changing settings through RPC would result in wrong values being saved for three fields
More helpful torrent error messages
Update to a newer snapshot of miniupnpc
Richiede Mac OS X 10.5 o successivi:All Platforms
Don't wait so long on unresponsive trackers if there are other trackers to try
Adding corrupt/invalid torrents could crash Transmission
Fix 1.74 bug that caused a high CPU load on startup
Fix 1.74 bug that stopped multitracker if a single tracker sent an error message
Fix bug in converting other charsets to UTF-8
Handle HTTP redirects more gracefully
Faster verification of local data for torrents with small piece size
Fix 1.74 build error when compiling without DHT
Mac
Fix libcurl build issue that caused tracker connectivity problems on Snow Leopard
Fix error when creating a torrent file while still changing the announce address
Visitano il forum: Ahrefs [Bot] e 20 ospiti
