Aggiornamenti VMware Fusion
Anche a me il 4.1 non funzionava più su M-Lion (funziona su Lion)
Ho dovuto installare il 5.0.1
– Io scrivo su iMaccanici con iPhone e Tapatalk –
VMware Fusion - 5.0.2
USB 3.0 stability improvements.
Graphics improvements when running the Microsoft Office 2013 preview.
Fixed an issue that caused the library and the Fusion start menu contents to get out of sync.
Fixed an issue that caused Mac OS X (Mountain Lion) guests to see stale directory information when using HGFS.
Fixed a multi-monitor behavior on Mac OS X (Mountain Lion) when Use All Displays in Full Screen is selected.
Fixed an issue that caused the full screen short-cut key to intermittently fail when Caps Lock was on.
Easy Install improvements for Microsoft Windows 8.
Fixed key repeat behavior (typematic) on certain versions of Mac OS X (Mountain Lion).
Fixed an intermittent problem that caused Fusion to quit when the network editor was opened.
Fixed cancelling of the import of OVF virtual machines.
Addressed graphics issues with Autodesk Inventor, Altium Designer, and Solidworks.
Fixed an issue installing on Macs with a user or group named "0".
Fixed error compiling HGFS on Linux 3.6 kernels.
Changed the selection color in the library icon view.
Renamed the Pause key menu item to aid with accessibility and automation.
Fixed an issue importing a Parallels virtual machine that has no network devices.
Resolved an issue that caused the PC Migration Assistant to not complete when migrating a Windows PC.
Intanto è stato rilasciato VMware Fusion 5.0.3.
http://www.vmware.com/products/fusion/overview.html" onclick="window.open(this.href);return false;
Rilasciato VMware Fusion 6.0.2.
http://www.vmware.com/products/fusion/" onclick="window.open(this.href);return false;
Note: VMware Fusion 6.0.2 is a maintenance release that resolves some known issues.
• Resolved an issue that causes virtual machines to fail to power on due to insufficient memory.
• Easy Install support for final versions of Windows 8.1 and Windows Server 2012 R2.
• Improved performance when opening VMware Fusion.
• Resolved an issue that caused the HGFS kernel module to fail to build on certain versions of Linux.
Improved support for OS X Mavericks:
◦ Finder tags.
◦ Improved drag-and-drop to OS X guests.
◦ Improved menu-bar handling.
◦ Improving handling of multiple displays in Unity mode.
◦ Improved support for Recovery Partition with a OS X Mavericks guest.
◦ Fixed an issue with boot device selection with a OS X guest.
◦ Improved handling of virtual machine window restoration after a restart.
◦ Improved the "Migrate a PC" feature to be more compatible with Mavericks file sharing.
• Improved detection of Parallels Desktop 8 when importing virtual machines.
• Improved message when no boot device is found.
• Prevent disk layout changes on an encrypted virtual machine.
• Fixed an issue that prevented auto-start virtual machine from powering on.
• FileVault can be activated in a Mac OS guest installed on a SATA virtual disk.
• Resolved the isse where a virtual machine ceases to function (hang) while powering off, particularly if the guest OS was in the middle of a BSOD or kernel panic.
• Resolved an issue building the shared folders kernel module on Ubuntu 13.10.
Link diretto:
https://download3.vmware.com/software/f ... 398658.dmg" onclick="window.open(this.href);return false;
fragrua ha scritto:Rilasciato VMware Fusion 6.0.2.
Che bello non sapevo si potesse installare Mavericks così, senza problemi e dalla chiavetta USB!
Schermata 2013-11-05 alle 22.23.16.png (69.34 KiB) Visto 2995 volte
joni71
aggiornato a vmware 6.0.2 su mavericks ma non riconosce le porte USB e non si connette ad internet...ho cancellato le preferenze ma non va ....mah !
A me si. Boh.
joni71
non è che devo creare una macchina virtuale nuova da zero?? :cry:
Rilasciato VMware Fusion 6.0.3.
Link diretto:
https://download3.vmware.com/software/f ... 747349.dmg" onclick="window.open(this.href);return false;
Amici emulatori, virtualizzatori…vi segnalo l'aggiornamento VMware Fusion 6.0.4.
Link diretto:
https://download3.vmware.com/software/f ... 887983.dmg" onclick="window.open(this.href);return false;
Rilasciato VMware Fusion 7.0.0 aggiornato soprattutto per OS X Yosemite.
http://www.vmware.com" onclick="window.open(this.href);return false;
Disponibile VMware Fusion 8.5.8
We took the time to make some enhancements to existing technology such as our command line ‘vmrun‘ utility with many additional commands, while still working on brand new features like our new REST API.
We’ve made many enhancements to the UI to modernize the look and feel, and added support for TouchBar as well as automated background cleanup tasks.
There’s also a new 3D Rendering engine that leverages Apple’s ‘Metal‘ technology instead of OpenGL on the Host. This has given us improved battery life and more performance in many areas. There are some performance hits as well, so we’re eager to hear about your experiences with both performance and ‘correctness’ of rendering.
On the Networking side of things, we’ve been working on a highly-requested feature of the UI to modify the NAT port forwarding rules, so users can do that now without having to modify text files on the command line. You can also rename networks to be whatever you like so you can easily tell your ‘storage-net’ from ‘vmnet5’.
For folks working with vSphere, check out the new features for interacting with ESXi Hosts. Users can now control host power operations remotely, so you can easily shutdown or reboot a remote ESXi host.
Anche in versione valutazione, poi basterà acquistare il seriale.
https://www.vmware.com/products/fusion/ ... ation.html" onclick="window.open(this.href);return false;
Torna a “Aggiornamenti”
