Aggiornamento XLD (X Lossless Decoder)
francescolupo7
Lupus in fabula
Lupus in fabula
Utilissimo software per la conversione dei vari formati audio.
Developer site: http://tmkk.undo.jp/xld/index_e.html
http://www.macupdate.com/app/mac/23430/ ... ss-decoder
_____________________________
francescolupo7
Lupus in fabula
Lupus in fabula
Kernel Panic ha scritto:L'autoaggiornamento non va a buon fine.
Scaricata l'ultima versione da MacUpdate.
Ho messo per questo motivo il link a MacUpdate.
Prega!
mauropasha
Geniale
Geniale
https://www.imaccanici.org/article.php/xld" onclick="window.open(this.href);return false;
mauro
goodiewina
Si può perfer per questo utile programma: …
[Edit by admin] Sono uno spammer ed ho fatto la fine che merito!
Il link che hai pubblicato è per quella merdaccia di zozz.
Non è che sei un trollone?
Noi abbiamo a disposizione XLD e a nulla ci servono le fetenzie made in macroschiff. :puke: :puke: :puke:
X Lossless Decoder - 20160920
A maintenance release to fix compatibility with macOS Sierra
Fixed a problem that save log button was not working when a disc was ejected
Supported opus encoding in CLI
Updated WavPack to version 4.80.0
Updated Opus to version 1.1.3
http://tmkk.undo.jp/xld/index_e.html" onclick="window.open(this.href);return false;
X Lossless Decoder - 20161007
Fixed a problem that automatic update was not working on macOS 10.12 Sierra
X Lossless Decoder - 20170710
Cover-image scaling works properly in Retina environments
"No Image" is shown in an image placeholder properly on recent macOS
Added an option to verify encoding result in FLAC encoder
Fixed a problem with XLD's failure to detect Audio CD with a long volume name
Fixed a problem with XLD's failure to read some .cue files
Fixed a crash when finishing playback
Fixed a problem where tags were ignored on some ALAC files
Prevent swiching to dGPU
Updated FLAC to version 1.3.2
Updated WavPack to version 5.10.0
Updated Opus to version 1.2.1
Releasing PSF and SPC decoder plugins, currently not included in XLD app.
X Lossless Decoder - 20181001
XLD has become 64-bit app
Supported dark mode appearance in macOS Mojave (Experimental)
Disabled by default, but you can enable by choosing "Enable Dark Mode Support" under XLD menu.
Supported EBU R128 for gain analysis
Supported reading CD-Text
Fixed a problem when opening audio CDs with long volume name
Made TAK decoder compatible with an official Wine app bundle
Updated LAME to version 3.100
Various small bug fixes.
>>> https://tmkk.undo.jp/xld/index_e.html
mar, 02 ott 2018 13:44
Giusto una mia curiosità:
Qualcuno che ha installato questa nuova versione mi può dire se fra i formati di destinazione gli compare "LAME MP3", come da screenshot allegato.
dom, 07 ott 2018 21:09
Pare di sì.
Uhm... grazie per il riscontro.
Hai installato anche i plug-in oppure solo aggiornato il programma? E lo hai aggiornato dal menù "controlla aggiornamenti" oppure scaricando la nuova versione? Io ho provato scaricando la nuova versione e mi mancano diversi formati, fra cui quello indicato (Lame mp3).
** EDIT Ok, come non detto... ho riprovato ad installarlo e funziona bene, e i formati ci sono tutti. Non so cosa fosse successo la prima volta, ma direi che non importa. Grazie di nuovo. :)
L'autoaggiornamento non funziona anche se l'applicazione segnala correttamente la disponibilità di una nuova versione.
È necessario scaricare l'applicazione aggiornata direttamente dal sito.
X Lossless Decoder - 20181019
Fixed:
A potential cause for random crash when active task exists in a task window
A graphical glitch when switching between dark and light mode
A problem that prevented CLI from running on zsh
A problem that -o option in CLI did not work properly under some conditions
Updated:
Opus to version 1.3.
Note: Do not try to load plugins built only for incompatible CPU architecture anymore.
Torna a “Aggiornamenti”
