Già fatto, copiandoli a manina. Il menù rimane nella versione "potata".fragrua ha scritto:Proverei a spostare i servizi dalla libreria utente alla libreria principale, tanto per sfizio.
Cosa può avvenire al login, o al logout, che ricrea la lista dei Servizi disponibili nel Finder??8/24/11 10:12:36 AM com.apple.loginwindow[531] 2011-08-24 10:12:36.112 ManagedClient[34265:803] MCX.initializeDirectoryServices:[ODNode nodeWithSession: type:kODNodeTypeLocalNodes ] == 1002 (Unable to open Directory node of type 8704.)
8/24/11 10:12:36 AM com.apple.loginwindow[531] 2011-08-24 10:12:36.113 ManagedClient[34265:803] MCX.initializeDirectoryServices:[ODNode nodeWithSession: type:kODNodeTypeLocalNodes ] == 1002 (Unable to open Directory node of type 8704.)
8/24/11 10:12:36 AM com.apple.loginwindow[531] 2011-08-24 10:12:36.132 ManagedClient[34265:803] MCX.initializeDirectoryServices:[ODNode nodeWithSession: type:kODNodeTypeLocalNodes ] == 1002 (Unable to open Directory node of type 8704.)
8/24/11 10:15:11 AM com.apple.loginwindow[531] 2011-08-24 10:15:11.531 ManagedClient[34282:803] MCX.initializeDirectoryServices:[ODNode nodeWithSession: type:kODNodeTypeLocalNodes ] == 1002 (Unable to open Directory node of type 8704.)
8/24/11 10:15:11 AM com.apple.loginwindow[531] 2011-08-24 10:15:11.533 ManagedClient[34282:803] MCX.initializeDirectoryServices:[ODNode nodeWithSession: type:kODNodeTypeLocalNodes ] == 1002 (Unable to open Directory node of type 8704.)
8/24/11 10:15:11 AM com.apple.loginwindow[531] 2011-08-24 10:15:11.537 ManagedClient[34282:803] MCX.initializeDirectoryServices:[ODNode nodeWithSession: type:kODNodeTypeLocalNodes ] == 1002 (Unable to open Directory node of type 8704.)
8/24/11 11:05:11 AM com.apple.loginwindow[531] 2011-08-24 11:05:11.410 ManagedClient[34904:803] MCX.initializeDirectoryServices:[ODNode nodeWithSession: type:kODNodeTypeLocalNodes ] == 1002 (Unable to open Directory node of type 8704.)
8/24/11 11:05:11 AM com.apple.loginwindow[531] 2011-08-24 11:05:11.412 ManagedClient[34904:803] MCX.initializeDirectoryServices:[ODNode nodeWithSession: type:kODNodeTypeLocalNodes ] == 1002 (Unable to open Directory node of type 8704.)
8/24/11 11:05:11 AM com.apple.loginwindow[531] 2011-08-24 11:05:11.437 ManagedClient[34904:803] MCX.initializeDirectoryServices:[ODNode nodeWithSession: type:kODNodeTypeLocalNodes ] == 1002 (Unable to open Directory node of type 8704.)
8/24/11 11:16:19 AM com.apple.loginwindow[531] 2011-08-24 11:16:19.558 ManagedClient[34952:803] MCX.initializeDirectoryServices:[ODNode nodeWithSession: type:kODNodeTypeLocalNodes ] == 1002 (Unable to open Directory node of type 8704.)
8/24/11 11:16:19 AM com.apple.loginwindow[531] 2011-08-24 11:16:19.559 ManagedClient[34952:803] MCX.initializeDirectoryServices:[ODNode nodeWithSession: type:kODNodeTypeLocalNodes ] == 1002 (Unable to open Directory node of type 8704.)
8/24/11 11:16:19 AM com.apple.loginwindow[531] 2011-08-24 11:16:19.564 ManagedClient[34952:803] MCX.initializeDirectoryServices:[ODNode nodeWithSession: type:kODNodeTypeLocalNodes ] == 1002 (Unable to open Directory node of type 8704.)
Esatto! Io vorrei sapere con che criterio qui intorno la gente viene fatta expert!fragrua ha scritto:kato, ci vorrebbe un Expert!
Il problema continua a manifestarsi in maniera assolutamente casuale (controllo il menù Servizi in continuazione ed "ad un certo punto" me lo trovo dimagrito ). Sto guardando con sospetto Safari ma senza prove o motivi evidenti.Io sono buono e chero ma quando mi inchezzo divento un animele...
Argh!NAME
pbs -- general helper tool
SYNOPSIS
pbs
DESCRIPTION
pbs is a helper tool for the Cocoa frameworks.
There are no configuration options to pbs. Users should not run pbs manually.
Già, quella è la teoria. Poi, quando passa la strega malvagia ed invisibile, il menù si trasforma dalla prima delle immagini inserite sopra alla seconda... Ma quel pbs dovrebbe riportare tutto alla norma!fragrua ha scritto:Quel POCHISSIMO che ho capito sui Servizi è che se clicchi su un cartella ti mostra quelli "compatibili" con la cartella, se clicchi su una immagine ti mostra quelli compatibili con le immagini, se clicchi su un file di testo ti mostra quelli compatibili con i file di testo… e così via.
sudo chown root:admin /
sudo kextcache -system-prelinked-kernel
sudo kextcache -system-caches
sudo ls -al /
e ora invecedrwxr-xr-x 36 [mio utente] 501 1292 29 Ago 18:49 .
con uno spengimento a dir poco fulminante.drwxr-xr-x 36 root admin 1292 29 Ago 18:49 .
Visitano il forum: Google [Bot] e 34 ospiti
