Dal Finder fai Mela+Maiuscole+G e incolla questo /private/var/vm/trezzit ha scritto:Non sono riuscito a trovare il file sleepimage, porca miseria..!
Prova a disinstallare per bene "Tao Effect".walrus87 ha scritto:scusate ma io invece che posso fare?
anche lo smile..??fragrua ha scritto: Dal Finder fai Mela+Maiuscole+G e incolla questo /private/var/vm/
Mi sembra che siano tutti relativi a quell'applicazione che non hai disinstallato per bene.walrus87 ha scritto:niente
è normale che nei messaggi della console mi dia un sacco di errors e warnings?
30/06/11 20.25.16 com.apple.launchd.peruser.501[100] ([0x0-0x24024].com.apple.Console[199]) Exited: Killed
30/06/11 20.25.16 com.apple.launchd.peruser.501[100] (com.apple.AirPortBaseStationAgent[128]) Exited: Killed
30/06/11 20.25.16 com.apple.launchd.peruser.501[100] (com.apple.FolderActions.enabled[137]) Exited: Killed
30/06/11 20.25.16 loginwindow[31] DEAD_PROCESS: 31 console
30/06/11 20.25.16 shutdown[216] reboot by Paolo:
30/06/11 20.25.16 shutdown[216] SHUTDOWN_TIME: 1309458316 580592
30/06/11 20.25.16 mDNSResponder[30] mDNSResponder mDNSResponder-258.18 (Jan 18 2011 20:25:03) stopping
30/06/11 20.25.16 DirectoryService[15] BUG in libdispatch: 10J869 - 1960 - 0x10004004
30/06/11 20.25.16 WindowServer[64] hidd died. Reestablishing connection.
30/06/11 20.25.16 WindowServer[64] Unable to create event queue via hidd: (0x10000003)
30/06/11 20.25.16 com.apple.SecurityServer[26] Session 0x231ff5 dead
30/06/11 20.25.16 com.apple.SecurityServer[26] Killing auth hosts
30/06/11 20.25.16 com.apple.SecurityServer[26] Session 0x231ff5 destroyed
30/06/11 20.25.16 kernel systemShutdown true
30/06/11 20.25.16 kernel Kext loading now disabled.
30/06/11 20.25.16 kernel Kext unloading now disabled.
30/06/11 20.25.16 kernel Kext autounloading now disabled.
30/06/11 20.25.16 kernel Kernel requests now disabled.
30/06/11 20.25.16 kernel Kext unloading is disabled (com.taoeffect.ispy.kext).
30/06/11 20.25.30 kernel npvhash=4095
30/06/11 20.25.30 kernel PAE enabled
30/06/11 20.25.30 kernel 64 bit mode enabled
30/06/11 20.25.30 kernel Darwin Kernel Version 10.7.0: Sat Jan 29 15:17:16 PST 2011; root:xnu-1504.9.37~1/RELEASE_I386
30/06/11 20.25.30 kernel vm_page_bootstrap: 950324 free pages and 24524 wired pages
30/06/11 20.25.30 kernel standard timeslicing quantum is 10000 us
30/06/11 20.25.30 kernel mig_table_max_displ = 73
30/06/11 20.25.30 kernel AppleACPICPU: ProcessorId=0 LocalApicId=0 Enabled
30/06/11 20.25.30 kernel AppleACPICPU: ProcessorId=1 LocalApicId=1 Enabled
30/06/11 20.25.30 kernel calling mpo_policy_init for TMSafetyNet
30/06/11 20.25.30 kernel Security policy loaded: Safety net for Time Machine (TMSafetyNet)
30/06/11 20.25.30 kernel calling mpo_policy_init for Quarantine
30/06/11 20.25.30 kernel Security policy loaded: Quarantine policy (Quarantine)
30/06/11 20.25.30 kernel calling mpo_policy_init for Sandbox
30/06/11 20.25.30 kernel Security policy loaded: Seatbelt sandbox policy (Sandbox)
30/06/11 20.25.30 kernel Copyright (c) 1982, 1986, 1989, 1991, 1993
30/06/11 20.25.30 kernel The Regents of the University of California. All rights reserved.
30/06/11 20.25.30 kernel MAC Framework successfully initialized
30/06/11 20.25.30 kernel using 16384 buffer headers and 4096 cluster IO buffer headers
30/06/11 20.25.30 kernel IOAPIC: Version 0x11 Vectors 64:87
30/06/11 20.25.30 kernel ACPI: System State [S0 S3 S4 S5] (S3)
30/06/11 20.25.30 kernel AppleIntelCPUPowerManagement: initialization complete
30/06/11 20.25.30 kernel mbinit: done (64 MB memory set for mbuf pool)
30/06/11 20.25.30 kernel rooting via boot-uuid from /chosen: 66848580-7A89-3FB1-BA89-83039C3833CB
30/06/11 20.25.30 kernel Waiting on <dict ID="0"><key>IOProviderClass</key><string ID="1">IOResources</string><key>IOResourceMatch</key><string ID="2">boot-uuid-media</string></dict>
30/06/11 20.25.30 kernel com.apple.AppleFSCompressionTypeZlib kmod start
30/06/11 20.25.30 kernel com.apple.AppleFSCompressionTypeZlib load succeeded
30/06/11 20.25.30 kernel AppleIntelCPUPowerManagementClient: ready
30/06/11 20.25.30 kernel BTCOEXIST off
30/06/11 20.25.30 kernel wl0: Broadcom BCM4353 802.11 Wireless Controller
30/06/11 20.25.30 kernel 5.10.131.36
30/06/11 20.25.30 kernel Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@B/AppleMCP79AHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/TOSHIBA MK2555GSXF Media/IOGUIDPartitionScheme/Customer@2
30/06/11 20.25.30 kernel BSD root: disk0s2, major 14, minor 2
30/06/11 20.25.25 com.apple.launchd[1] *** launchd[1] has started up. ***
30/06/11 20.25.32 kernel Previous Shutdown Cause: 5
30/06/11 20.25.32 kernel NVDANV50HAL loaded and registered.
30/06/11 20.25.32 kernel DSMOS has arrived
30/06/11 20.25.41 kernel NVEthernet: Ethernet address 34:15:***********
30/06/11 20.25.41 kernel AirPort_Brcm43224: Ethernet address 58:b0:*******
30/06/11 20.25.41 kernel IO80211Controller::dataLinkLayerAttachComplete(): adding AppleEFINVRAM notification
30/06/11 20.25.41 kernel IO80211Interface::efiNVRAMPublished():
30/06/11 20.25.43 kernel systemShutdown false
30/06/11 20.25.43 mDNSResponder[30] mDNSResponder mDNSResponder-258.18 (Jan 18 2011 20:25:03) starting
30/06/11 20.25.43 bootlog[42] BOOT_TIME: 1309458325 0
30/06/11 20.25.47 com.apple.SecurityServer[26] Session 0x5fbff962 created
30/06/11 20.25.48 /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow[31] Login Window Application Started
30/06/11 20.25.48 blued[43] Apple Bluetooth daemon started
30/06/11 20.25.48 cupsd[60] sandbox cache error: database is locked
30/06/11 20.25.48 cupsd[61] sandbox cache error: database is locked
30/06/11 20.25.49 kernel [iSpy.kext] INFO: loaded successfully!
30/06/11 20.25.49 com.apple.SecurityServer[26] Entering service
30/06/11 20.25.49 mds[29] sandbox cache error: database is locked
30/06/11 20.25.49 cupsd[59] sandbox cache error: database is locked
30/06/11 20.25.50 com.apple.launchd[1] (com.apple.xprotectupdater[21]) Exited with exit code: 255
30/06/11 20.25.51 kernel AirPort: Link Down on en1. Reason 8 (Disassociated because station leaving).
30/06/11 20.25.51 com.apple.usbmuxd[23] usbmuxd-211 built on Feb 8 2011 at 13:49:43 on Feb 8 2011 at 13:49:43, running 64 bit
30/06/11 20.25.52 sandboxd[82] pdftopdf2(58) deny file-write* /private/var/spool/cups/Library
30/06/11 20.25.52 sandboxd[82] cgpdftoraster(59) deny file-write* /private/var/spool/cups/Library
30/06/11 20.25.53 com.apple.SecurityServer[26] Session 0x307bd1 created
30/06/11 20.25.53 com.apple.SecurityServer[26] Session 0x307bd1 attributes 0x30
30/06/11 20.25.54 kernel NVEthernet::setLinkStatus - Valid but not Active
30/06/11 20.25.54 configd[13] bootp_session_transmit: bpf_write(en1) failed: Network is down (50)
30/06/11 20.25.54 configd[13] DHCP en1: INIT-REBOOT transmit failed
30/06/11 20.25.54 configd[13] network configuration changed.
30/06/11 20.25.54 configd[13] setting hostname to "PauLBook.local"
30/06/11 20.25.54 loginwindow[31] Login Window Started Security Agent
30/06/11 20.25.54 SecurityAgent[96] User info context values set for Paolo
30/06/11 20.25.54 SecurityAgent[96] Login Window login proceeding
30/06/11 20.25.54 SecurityAgent[96] Login Window done
30/06/11 20.25.54 loginwindow[31] Login Window - Returned from Security Agent
30/06/11 20.25.54 loginwindow[31] USER_PROCESS: 31 console
30/06/11 20.25.54 com.apple.launchctl.Aqua[99] launchctl: Please convert the following to launchd: /etc/mach_init_per_user.d/com.adobe.SwitchBoard.monitor.plist
30/06/11 20.25.54 com.apple.launchd.peruser.501[97] (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
30/06/11 20.25.55 kernel en1: 802.11d country code set to 'GB'.
30/06/11 20.25.55 kernel en1: Supported channels 1 2 3 4 5 6 7 8 9 10 11 12 13 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140
30/06/11 20.25.55 kernel Auth result for: 1c:bd:b9:af:bd:f8 MAC AUTH succeeded
30/06/11 20.25.55 kernel AirPort: Link Up on en1
30/06/11 20.25.56 kernel AirPort: RSN handshake complete on en1
30/06/11 20.25.57 configd[13] network configuration changed.
30/06/11 20.25.57 com.epson.Epusp[128] Epusp: Terminate..
30/06/11 20.25.58 com.apple.launchd.peruser.501[97] (com.apple.Kerberos.renew.plist[123]) Exited with exit code: 1
30/06/11 20.25.58 com.apple.launchd.peruser.501[97] (0x1001013a0.mach_init.switchboard.sh) Failed to check-in!
30/06/11 20.25.58 com.apple.usbmuxd[23] HandleUSBMuxDictionary client 0x100303760-iTunesHelper/com.apple.iTunesHelper using library usbmuxd-211 built on Jan 13 2011 at 04:19:31, running usbmuxd-211 built on Feb 8 2011 at 13:49:43
30/06/11 20.25.58 [0x0-0xa00a].com.rim.blackberrydevicemanager[138] (138) 2011-06-30 20:25:58.303 INFO default [RimQNXAutoMounterAppDelegate:418] logger ------------ Starting BlackBerry® Device Manager
30/06/11 20.25.58 [0x0-0xa00a].com.rim.blackberrydevicemanager[138] (138) 2011-06-30 20:25:58.990 INFO default [RimQNXAutoMounterAppDelegate:427] logger ------------ BlackBerry® Device Manager: Version 2.0.1 (build 14) (200.01.14)
30/06/11 20.25.58 [0x0-0xa00a].com.rim.blackberrydevicemanager[138] (138) 2011-06-30 20:25:58.990 INFO default [RimQNXAutoMounterAppDelegate:438] logger ------------ USB Driver: Version 0.0.64 (build 0.0.64)
30/06/11 20.25.58 [0x0-0xa00a].com.rim.blackberrydevicemanager[138] (138) 2011-06-30 20:25:58.990 INFO default [RimQNXAutoMounterAppDelegate:445] logger ------------ USB Framework: Version 2.0.1 (build 0.0.64)
30/06/11 20.25.58 [0x0-0xa00a].com.rim.blackberrydevicemanager[138] (138) 2011-06-30 20:25:58.990 INFO default [RimQNXAutoMounterAppDelegate:452] logger ------------ Desktop: Version 2.0.1 (build 200.01.14)
30/06/11 20.25.58 [0x0-0xa00a].com.rim.blackberrydevicemanager[138] (138) 2011-06-30 20:25:58.993 INFO default [BDRimLogger.m:893] logger ------------ Mac OS Version 10.6.7 (Build 10J869) (kern.version Darwin Kernel Version 10.7.0: Sat Jan 29 15:17:16 PST 2011; root:xnu-1504.9.37~1/RELEASE_I386)
30/06/11 20.25.58 [0x0-0xa00a].com.rim.blackberrydevicemanager[138] (138) 2011-06-30 20:25:58.993 INFO default [BDRimLogger.m:938] logger ------------ Starting BlackBerry Device Manager Logger
30/06/11 20.25.58 [0x0-0xa00a].com.rim.blackberrydevicemanager[138] (138) 2011-06-30 20:25:58.282 DEBUG default [RimQNXAutoMounterAppDelegate.:67] 0x30a6e0 Registering for USB device events...
30/06/11 20.25.59 [0x0-0xa00a].com.rim.blackberrydevicemanager[138] (138) 2011-06-30 20:25:59.604 WARNING default [RimQNXAutoMounterAppDelegate:104] 0x30a6e0 Found Process... BlackBerry Device Manager (138) -- [(
30/06/11 20.25.59 [0x0-0xa00a].com.rim.blackberrydevicemanager[138] (138) 2011-06-30 20:25:59.604 WARNING default [RimQNXAutoMounterAppDelegate:104] 0x30a6e0 -->> "-psn_0_40970"
30/06/11 20.25.59 [0x0-0xa00a].com.rim.blackberrydevicemanager[138] (138) 2011-06-30 20:25:59.604 WARNING default [RimQNXAutoMounterAppDelegate:104] 0x30a6e0 -->>)]
30/06/11 20.26.00 [0x0-0xa00a].com.rim.blackberrydevicemanager[138] (138) 2011-06-30 20:26:00.224 INFO default [RimQNXAutoMounterAppDelegate:157] 0x30a6e0 Launched With Arguments:
30/06/11 20.26.00 [0x0-0xa00a].com.rim.blackberrydevicemanager[138] (138) 2011-06-30 20:26:00.227 INFO default [RimQNXAutoMounterAppDelegate:160] 0x30a6e0 Argument 0: /Library/Application Support/BlackBerry/BlackBerry Device Manager.app/Contents/MacOS/BlackBerry Device Manager
30/06/11 20.26.00 [0x0-0xa00a].com.rim.blackberrydevicemanager[138] (138) 2011-06-30 20:26:00.227 INFO default [RimQNXAutoMounterAppDelegate:160] 0x30a6e0 Argument 1: -psn_0_40970
30/06/11 20.26.00 [0x0-0xa00a].com.rim.blackberrydevicemanager[138] (138) 2011-06-30 20:26:00.227 WARNING default [RimQNXAutoMounterAppDelegate:162] 0x30a6e0 Skipping Argument: -psn_0_40970
30/06/11 20.26.00 [0x0-0xa00a].com.rim.blackberrydevicemanager[138] (138) 2011-06-30 20:26:00.228 WARNING default [RimQNXAutoMounterAppDelegate:185] 0x30a6e0 No argument provided... will connect all available device
30/06/11 20.26.00 [0x0-0xa00a].com.rim.blackberrydevicemanager[138] (138) 2011-06-30 20:26:00.233 INFO default [RimQNXAutoMounterAppDelegate:275] 0x30a6e0 Application will terminate ...
30/06/11 20.26.00 [0x0-0xa00a].com.rim.blackberrydevicemanager[138] (138) 2011-06-30 20:26:00.309 INFO default [RimQNXAutoMounterAppDelegate:461] logger ------------ Quitting BlackBerry® Device Manager
30/06/11 20.26.00 iPiece[147] CGImageSourceCreateWithData: data parameter is nil
30/06/11 20.26.00 [0x0-0x15015].com.oldjewel.iPiece[147] Thu Jun 30 20:26:00 PauLBook.local iPiece[147] <Error>: CGImageSourceCreateWithData: data parameter is nil
30/06/11 20.26.00 BBDaemon[48] IOBSDNameMatching returned a NULL dictionary.
30/06/11 20.26.01 iPiece[147] *** WARNING: Method selectRow:byExtendingSelection: in class NSTableView is deprecated. It will be removed in a future release and should no longer be used.
30/06/11 20.26.02 Finder[103] TotalFinderInjector: got init request
30/06/11 20.26.02 Finder[103] TotalFinderInjector: Installing TotalFinder ...
30/06/11 20.26.02 Finder[103] Warning: Finder has unknown version 10.6.8. TotalFinder has not been tested with this Finder version.
30/06/11 20.26.02 Finder[103] Unable to compute valid address for AppleShowAllFiles symbol in Finder's image. Show Hidden Files toggle won't be effective until you restart Finder.
30/06/11 20.26.03 kernel Finder (map: 0x8cde70c) triggered DYLD shared region unnest for map: 0x8cde70c, region 0x7fff88c00000->0x7fff88e00000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
30/06/11 20.26.15 ntpd[19] time reset +0.153848 s
01/07/11 21.20.51 Dock[102] kCGErrorIllegalArgument: CGSSetWindowTransformsAtPlacement: Singular matrix at index 1: [0.000 0.000 0.000 0.000]
01/07/11 21.20.51 com.apple.Dock.agent[102] Fri Jul 1 21:20:51 PauLBook.local Dock[102] <Error>: kCGErrorIllegalArgument: CGSSetWindowTransformsAtPlacement: Singular matrix at index 1: [0.000 0.000 0.000 0.000]
01/07/11 21.20.51 Dock[102] kCGErrorIllegalArgument: CGSSetWindowTransformAtPlacement: Singular matrix [0.000 0.000 0.000 0.000]
01/07/11 21.20.51 com.apple.Dock.agent[102] Fri Jul 1 21:20:51 PauLBook.local Dock[102] <Error>: kCGErrorIllegalArgument: CGSSetWindowTransformAtPlacement: Singular matrix [0.000 0.000 0.000 0.000]
Visitano il forum: Nessuno e 54 ospiti
