Si apre Console (sta in Applicazioni/Utility) e si legge cosa succede nell'orario preciso dell'anomalia. Logicamente devi mettere "tutti i messaggi" nell'apposito menù.walrus87 ha scritto:ehm no...come si fa?
28/06/11 16.44.11 com.apple.launchd.peruser.501[97] (com.taoeffect.EspionageHelper[885]) posix_spawn("/Users/Paolo/Library/Application Support/Espionage/EspionageHelper.app/Contents/MacOS/EspionageHelper", ...): No such file or directory
28/06/11 16.44.11 com.apple.launchd.peruser.501[97] (com.taoeffect.EspionageHelper[885]) Exited with exit code: 1
28/06/11 16.44.11 com.apple.launchd.peruser.501[97] (com.taoeffect.EspionageHelper) Throttling respawn: Will start in 10 seconds
28/06/11 16.44.21 com.apple.launchd.peruser.501[97] (com.taoeffect.EspionageHelper[886]) posix_spawn("/Users/Paolo/Library/Application Support/Espionage/EspionageHelper.app/Contents/MacOS/EspionageHelper", ...): No such file or directory
28/06/11 16.44.21 com.apple.launchd.peruser.501[97] (com.taoeffect.EspionageHelper[886]) Exited with exit code: 1
28/06/11 16.44.21 com.apple.launchd.peruser.501[97] (com.taoeffect.EspionageHelper) Throttling respawn: Will start in 10 seconds
28/06/11 16.44.31 com.apple.launchd.peruser.501[97] (com.taoeffect.EspionageHelper[887]) posix_spawn("/Users/Paolo/Library/Application Support/Espionage/EspionageHelper.app/Contents/MacOS/EspionageHelper", ...): No such file or directory
28/06/11 16.44.31 com.apple.launchd.peruser.501[97] (com.taoeffect.EspionageHelper[887]) Exited with exit code: 1
28/06/11 16.44.31 com.apple.launchd.peruser.501[97] (com.taoeffect.EspionageHelper) Throttling respawn: Will start in 10 seconds
28/06/11 16.44.41 com.apple.launchd.peruser.501[97] (com.taoeffect.EspionageHelper[888]) posix_spawn("/Users/Paolo/Library/Application Support/Espionage/EspionageHelper.app/Contents/MacOS/EspionageHelper", ...): No such file or directory
28/06/11 16.44.41 com.apple.launchd.peruser.501[97] (com.taoeffect.EspionageHelper[888]) Exited with exit code: 1
28/06/11 16.44.41 com.apple.launchd.peruser.501[97] (com.taoeffect.EspionageHelper) Throttling respawn: Will start in 10 seconds
28/06/11 16.44.51 com.apple.launchd.peruser.501[97] (com.taoeffect.EspionageHelper[889]) posix_spawn("/Users/Paolo/Library/Application Support/Espionage/EspionageHelper.app/Contents/MacOS/EspionageHelper", ...): No such file or directory
28/06/11 16.44.51 com.apple.launchd.peruser.501[97] (com.taoeffect.EspionageHelper[889]) Exited with exit code: 1
28/06/11 16.44.51 com.apple.launchd.peruser.501[97] (com.taoeffect.EspionageHelper) Throttling respawn: Will start in 10 seconds
..scaricati Find Any File o EasyFind che e' gratis e metti il nome o il processo del programma,poi cercalo e buttalo!!walrus87 ha scritto:stessa cosa, non va in stop e continua ogni 10 secondi a fare sto processo che io non riesco a stoppare...
Ho eliminato nelle preferenze di little snitch la parte riguardante espionage ma continua a ripetere il processo..dove lo trovo?
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>com.adobe.AAM.Scheduler-1.0</key>
<dict>
<key>Disabled</key>
<true/>
</dict>
<key>com.apple.FolderActions.enabled</key>
<dict>
<key>Disabled</key>
<false/>
</dict>
<key>com.apple.FolderActions.folders</key>
<dict>
<key>Disabled</key>
<false/>
</dict>
<key>com.taoeffect.EspionageHelper</key>
<dict>
<key>Disabled</key>
<false/>
</dict>
</dict>
</plist>
Prova a disabilitare la funziona Iberna viewtopic.php?t=13145 oppure ad eliminare (spostare nel cestino e riavviare) il file sleepimage che trovi in /private/var/vm/.trezzit ha scritto:Anch'io è molto tempo che navigo con questo problema e nonostante abbia applicato alla lettera i suggerimenti anche di questo topic
