E qui mi dai da pensare...non ho due MAC, ma ogni volta che dissocio tutti i dispositivi da iCloud e cambio la password torna a funzionare tutto bene...cosa mi consigliate.
Fare una pulizia del Mac aiuterebbe...controllare i servizi o i processi che vanno in background e succhiano MB dalla rete?
- Immagine 29-12-20 alle 14.58.jpg (161.37 KiB) Visto 287 volte
Vi allego anche un report dello stato software attuale (ci sono elencate app che ho già rimosso, come mi avevate consigliato, ma sono rimasti dei file orfani che non so come eliminare)
EtreCheck version: 5.6.4 (5222)
Report generated: 2020-12-29 15:02:07
Download EtreCheck from
https://etrecheck.com
Runtime: 1:26
Performance: Excellent
Sandbox: Enabled
Full drive access: Disabled
Problem: Other problem
Major Issues: None
Minor Issues:
These issues do not need immediate attention but they may indicate future problems or opportunities for improvement.
Clean up - There are orphan files that could be removed.
Unsigned files - There are unsigned software files installed. Apple has said that unsigned software will not run by default in a future version of the operating system.
32-bit Apps - This computer has 32-bits apps will not work on current versions of the operating system.
Limited drive access - More information may be available with Full Drive Access.
Kernel extensions present - This computer has kernel extensions that may not work in the future.
Sharing enabled - This computer has sharing services enabled that could be a security risk.
Hardware Information:
MacBook Pro (16-inch, 2019)
MacBook Pro Model: MacBookPro16,1
2,3 GHz 8-Core Intel Core i9 (i9-9880H) CPU: 8-core
16 GB RAM - Not upgradeable
BANK 0/ChannelA-DIMM0 - 8 GB DDR4 2667
BANK 2/ChannelB-DIMM0 - 8 GB DDR4 2667
Battery: Health = Normal - Cycle count = 18
Video Information:
Intel UHD Graphics 630 - VRAM: 1536 MB
AMD Radeon Pro 5500M - VRAM: 4 GB
Color LCD (built-in) 3584 x 2240
DELL ST2210 1920 x 1080
Drives:
disk0 - APPLE SSD AP1024N 1.00 TB (Solid State - TRIM: Yes)
Internal PCI-Express 8.0 GT/s x4 NVM Express
disk0s1 - EFI [EFI] 315 MB
disk0s2 [APFS Container] 1.00 TB
disk1 [Fusion Drive] 1.00 TB
disk1s1 - M*****************i (APFS) [APFS Virtual drive] (Shared - 51.18 GB used)
disk1s2 - Macintosh HD (APFS) [Fusion Drive] (Shared)
disk1s2s1 - Macintosh HD (APFS) (Shared - 15.05 GB used)
disk1s3 - Preboot (APFS) [APFS Preboot] (Shared - 323 MB used)
disk1s4 - Recovery (APFS) [Recovery] (Shared)
disk1s5 - VM (APFS) [APFS VM] (Shared - 20 KB used)
disk1s6 - U****e (APFS) (Shared - 2 MB used)
Mounted Volumes:
disk1s1 - M*****************i [APFS Virtual drive]
1.00 TB (Shared - 51.18 GB used, 938.23 GB available, 932.87 GB free)
APFS
Mount point: /System/Volumes/Data
Encrypted
1.00 TB (Shared - 15.05 GB used, 938.23 GB available, 932.87 GB free)
APFS
Mount point: /
Read-only: Yes
disk1s3 - Preboot [APFS Preboot]
1.00 TB (Shared - 323 MB used, 932.87 GB free)
APFS
Mount point: /System/Volumes/Preboot
disk1s5 - VM [APFS VM]
1.00 TB (Shared - 20 KB used, 932.87 GB free)
APFS
Mount point: /System/Volumes/VM
disk1s6 - U****e
1.00 TB (Shared - 2 MB used, 932.87 GB free)
APFS
Mount point: /System/Volumes/U****e
Network:
Interface en5: USB 10/100/1000 LAN
Interface en0: Wi-Fi
802.11 a/b/g/n/ac
Interface en7: Bluetooth PAN
Interface bridge0: Thunderbolt Bridge
Printer sharing: Enabled
System Software:
macOS Big Sur 11.1 (20C69)
Time since boot: Less than an hour
Notifications:
Notifications not available without Full Drive Access.
Security:
Gatekeeper: Enabled
System Integrity Protection: Enabled
Antivirus software: Apple
Unsigned Files:
Launchd: /Library/LaunchDaemons/com.malwarebytes.mbam.settings.daemon.plist
Executable: /Library/Application Support/Malwarebytes/MBAM/Engine.bundle/Contents/PlugIns/SettingsDaemon.app/Contents/MacOS/SettingsDaemon
Details: Exact match found in the legitimate list - probably OK
Launchd: ~/Library/LaunchAgents/com.google.keystone.agent.plist
Executable: ~/Library/Google/GoogleSoftwareUpdate/GoogleSoftwareUpdate.bundle/Contents/Resources/GoogleSoftwareUpdateAgent.app/Contents/MacOS/GoogleSoftwareUpdateAgent -runMode ifneeded
Launchd: ~/Library/LaunchAgents/com.google.keystone.xpcservice.plist
Executable: ~/Library/Google/GoogleSoftwareUpdate/GoogleSoftwareUpdate.bundle/Contents/Resources/GoogleSoftwareUpdateAgent.app/Contents/MacOS/GoogleSoftwareUpdateAgent -runMode xpchost
32-bit Applications:
2 32-bit apps
Kernel Extensions:
/Applications/Parallels Desktop.app
prl_hypervisor.kext (Parallels International GmbH, 16.1.1 49141 - SDK 10.11)
prl_netbridge.kext (Parallels International GmbH, 16.1.1 49141 - SDK 10.9)
prl_usb_connect.kext (Parallels International GmbH, 16.1.1 49141 - SDK 10.9)
prl_vnic.kext (Parallels International GmbH, 16.1.1 49141 - SDK 10.9)
/Library/Extensions
ufsd_NTFS.kext (Paragon Software GmbH, 15.8.105 - SDK 10.10)
System Launch Agents:
[Not Loaded] 17 Apple tasks
[Loaded] 185 Apple tasks
[Running] 129 Apple tasks
System Launch Daemons:
[Not Loaded] 35 Apple tasks
[Loaded] 187 Apple tasks
[Running] 137 Apple tasks
[Other] One Apple task
Launch Agents:
[Other] com.malwarebytes.mbam.frontend.agent.plist (? 1b555a92 - installed 2020-12-07)
[Other] com.paragon-software.ntfs.notification-agent.plist (Paragon Software GmbH - installed 2020-12-08)
Launch Daemons:
[Other] com.malwarebytes.mbam.rtprotection.daemon.plist (? d5730461 - installed 2020-12-19)
[Loaded] com.malwarebytes.mbam.settings.daemon.plist (? a40d558f - installed 2020-12-07)
User Launch Agents:
[Loaded] com.google.keystone.agent.plist (? 0 - installed 2020-12-20)
[Loaded] com.google.keystone.xpcservice.plist (? 0 - installed 2020-12-20)
User Login Items:
[Not Loaded] AppCleaner SmartDelete (Julien Ramseier - installed 2020-12-25)
Modern Login Item
/Applications/AppCleaner.app/Contents/Library/LoginItems/AppCleaner SmartDelete.app
[Not Loaded] LaunchHelper (App Store - installed 2020-12-17)
Modern Login Item
/Applications/Battery Monitor.app/Contents/Library/LoginItems/LaunchHelper.app
[Loaded] FSMenuAppLoginItemHelper (Paragon Software GmbH - installed 2020-12-17)
Modern Login Item
/Applications/NTFS for Mac.app/Contents/Library/LoginItems/FSMenuAppLoginItemHelper.app
[Not Loaded] Launcher Disabler (App Store - installed 2020-12-20)
Modern Login Item
/Applications/OneDrive.app/Contents/Library/LoginItems/Launcher Disabler.app
[Loaded] OneDrive Launcher (App Store - installed 2020-12-20)
Modern Login Item
/Applications/OneDrive.app/Contents/Library/LoginItems/OneDrive Launcher.app
[Not Loaded] WhatsApp Login Helper (App Store - installed 2020-12-18)
Modern Login Item
/Applications/WhatsApp.app/Contents/Library/LoginItems/WhatsApp Login Helper.app
User Internet Plug-ins:
User Internet Plug-ins need Full Drive Access
User Audio Plug-ins:
User Audio Plug-ins need Full Drive Access
User iTunes Plug-ins:
User iTunes Plug-ins need Full Drive Access
Safari Extensions:
"Open In" button for Internet Explorer (Parallels International GmbH - installed 2020-11-06)
3rd Party Preference Panes:
ParagonNTFS (Paragon Software GmbH - installed 2020-12-08)
Backup:
Time Machine information not available without Full Drive Access.
3 local snapshots
Oldest local snapshot: 2020-12-29 11:09:02
Last local snapshot: 2020-12-29 13:03:47
Performance:
System Load: 1.62 (1 min ago) 1.42 (5 min ago) 1.15 (15 min ago)
Nominal I/O speed: 8.36 MB/s
File system: 20.34 seconds
Write speed: 3033 MB/s
Read speed: 3116 MB/s
CPU Usage Snapshot:
Type Overall
System: 1 %
User: 2 %
Idle: 97 %
Top Processes Snapshot by CPU:
Process (count) CPU (Source - Location)
Other processes 26.92 % (?)
EtreCheck 13.80 % (App Store)
Safari 0.70 % (Apple)
Spotlight 0.24 % (Apple)
sharingd 0.08 % (Apple)
Top Processes Snapshot by Memory:
Process (count) RAM usage (Source - Location)
EtreCheck 555 MB (App Store)
Spotlight 179 MB (Apple)
corespotlightd 172 MB (Apple)
Safari 129 MB (Apple)
AppleSpell 117 MB (Apple)
Top Processes Snapshot by Network Use:
Process Input / Output (Source - Location)
Other processes 695 KB / 7 MB (?)
com.apple.WebKit.Networking.xpc 8 KB / 166 KB (Apple)
FinderSync.appex 7 KB / 1 KB (App Store)
backgroundtaskmanagementagent 0 B / 0 B (Apple)
UsageTrackingAgent 0 B / 0 B (Apple)
Virtual Memory Information:
Physical RAM: 16 GB
Free RAM: 5.15 GB
Used RAM: 4.51 GB
Cached files: 6.34 GB
Available RAM: 11.49 GB
Swap Used: 0 B
Software Installs (past 30 days):
Install Date Name (Version)
2020-12-08 macOS 11.0.1 (11.0.1)
2020-12-08 Numbers (10.0)
2020-12-08 Pages (10.0)
2020-12-08 Keynote (10.0)
2020-12-08 Battery Monitor (2.4.4)
2020-12-08 The Unarchiver (4.2.4)
2020-12-08 PDF Toolkit+ (2.4). CANCELLATO
2020-12-08 Magnet (2.5.0)
2020-12-08 NETGEAR Genie. CANCELLATO
2020-12-08 product
2020-12-11 Foxit PhantomPDF. CANCELLATO
2020-12-15 GoodNotes (5.6.30)
2020-12-15 macOS 11.1 (11.1)
2020-12-15 MRTConfigData (1.72)
2020-12-18 XProtectPlistConfigData (2137)
2020-12-18 WhatsApp (2.2049.10)
2020-12-18 CocoaPacketAnalyzer (1.51). CANCELLATO
2020-12-18 ChmodBPF (1.1). CANCELLATO
2020-12-18 Ghostery Lite (1.1.0). CANCELLATO
2020-12-19 Microsoft OneDrive
2020-12-19 Malwarebytes for Mac. CANCELLATO
2020-12-19 EtreCheck (5.6.4)
2020-12-20 OneDrive (20.169.0823)
Clean up:
/Library/LaunchDaemons/com.malwarebytes.mbam.rtprotection.daemon.plist
/Library/Application Support/Malwarebytes/MBAM/Engine.bundle/Contents/PlugIns/RTProtectionDaemon.app/Contents/MacOS/RTProtectionDaemon
Executable not found
/Library/LaunchAgents/com.malwarebytes.mbam.frontend.agent.plist
/Library/Application Support/Malwarebytes/MBAM/Engine.bundle/Contents/PlugIns/FrontendAgent.app/Contents/MacOS/FrontendAgent
Diagnostics Information (past 7-30 days):
Directory /Library/Logs/DiagnosticReports is not accessible.
Enable Full Drive Access to see more information.
End of report
