ciao a tutti...ultimamente accendendo il mac mi partono le ventole a mille per un attimo, circa 20 secondi, e poi torna tutto alla normalità.
Ho controllato i processi e mi trovo il processo denominato RT Pretection Deamon che occupa il 99,9 % della cpu.
Ho guardato e penso sia collagato a Malware bytes....
Ho fatto fatto un controllo con etrecheck, questo è quello che mi è uscito?
cosa ne pensate? come posso togliere questo processo che all'accensione mi ammazza il mac?
EtreCheck version: 5.5.4 (5106)
Report generated: 2020-04-27 14:13:12
Download EtreCheck from
https://etrecheck.com
Runtime: 4:30
Performance: Poor
Sandbox: Enabled
Full drive access: Disabled
Major Issues:
Anything that appears on this list needs immediate attention.
Runaway process - A process is using a large percentage of your CPU.
Poor performance - EtreCheck report shows poor performance. This is unusual.
Software/hardware problems - Software is causing performance problems.
Minor Issues:
These issues do not need immediate attention but they may indicate future problems or opportunities for improvement.
Configuration profiles present - This machine has configuration profiles. These are sometimes used by adware and malware.
High battery cycle count - Your battery may be losing capacity.
Clean up - There are orphan files that could be removed.
Unsigned files - There are unsigned software files installed. Apple has said that unsigned software will not run by default in a future version of the operating system.
System modifications - There are a large number of system modifications running in the background.
Vintage hardware - This machine may be considered vintage.
32-bit Apps - This machine has 32-bits apps will not work on macOS 10.15 "Catalina".
Limited drive access - More information may be available with Full Drive Access.
Kernel extensions present - This machine has kernel extensions that may not work in the future.
Sharing enabled - This machine has sharing services enabled that could be a security risk.
Hardware Information:
MacBook Pro (13-inch, Early 2011) - Vintage!
MacBook Pro Model: MacBookPro8,1
2,3 GHz Intel Core i5 (i5-2415M) CPU: 2-core
4 RAM - Upgradeable
BANK 0/DIMM0 - 2 GB DDR3 1333
BANK 1/DIMM0 - 2 GB DDR3 1333
Battery: Health = Normal - Cycle count = 873
Drives:
disk0 - Samsung SSD 860 EVO 500GB 500.11 GB (Solid State - TRIM: Yes)
Internal SATA 6 Gigabit Serial ATA
disk0s1 - EFI (MS-DOS FAT32) [EFI] 210 MB
disk0s2 [Core Storage Container] 499.25 GB
disk1 - M***********D (Journaled HFS+) 498.88 GB (200.10 GB used)
disk0s3 - Recovery HD (Journaled HFS+) [Recovery] 650 MB
Mounted Volumes:
498.88 GB (200.10 GB used, 329.73 GB available, 298.51 GB free)
Journaled HFS+
Mount point: /
System Software:
macOS High Sierra 10.13.6 (17G12034)
Time since boot: Less than an hour
Configuration Profiles:
This computer has configuration profiles installed.
Notifications:
Notifications not available without Full Drive Access.
Security:
System Status
Gatekeeper: Enabled
System Integrity Protection: Enabled
Antivirus software: Apple and Malwarebytes
Unsigned Files:
Launchd: /Library/LaunchAgents/com.microsoft.update.agent.plist
Executable: /Library/Application Support/Microsoft/MAU2.0/Microsoft AutoUpdate.app/Contents/MacOS/Microsoft Update Assistant.app/Contents/MacOS/Microsoft Update Assistant -checkForUpdates
Details: Exact match found in the whitelist - probably OK
Launchd: /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
Executable: /Library/Application Support/Adobe/OOBE/PDApp/UWA/UpdaterStartupUtility -mode=logon
Launchd: /Library/LaunchDaemons/com.oracle.java.Helper-Tool.plist
Executable:
Launchd: /Library/LaunchDaemons/com.microsoft.office.licensing.helper.plist
Executable: /Library/PrivilegedHelperTools/com.microsoft.office.licensing.helper
Launchd: /Library/LaunchDaemons/org.macosforge.xquartz.privileged_startx.plist
Executable: /opt/X11/lib/X11/xinit/privileged_startx -d /opt/X11/lib/X11/xinit/privileged_startx.d
Launchd: ~/Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
Launchd: /Library/LaunchDaemons/com.adobe.SwitchBoard.plist
Executable: /Library/Application Support/Adobe/SwitchBoard/SwitchBoard.app/Contents/MacOS/launch.switchboard
Launchd: /Library/LaunchAgents/org.macosforge.xquartz.startx.plist
Executable: /opt/X11/lib/X11/xinit/launchd_startx /opt/X11/bin/startx -- /opt/X11/bin/Xquartz
Launchd: /Library/LaunchDaemons/org.virtualbox.startup.plist
Executable:
Running app: com.google.Chrome.framework.service_process/Users/danieletraetta/Library/Application_Support/Google/Chrome
Safari Extension: "Open In" button for Internet Explorer
Plugin: /Library/Internet Plug-Ins/AdobeExManDetect.plugin
Plugin: /Library/Internet Plug-Ins/AdobeAAMDetect.plugin
Plugin: /Library/Internet Plug-Ins/Default Browser.plugin
Plugin: /Library/Internet Plug-Ins/Flip4Mac WMV Plugin.plugin
Plugin: /Library/Internet Plug-Ins/SharePointBrowserPlugin.plugin
Plugin: /Library/Internet Plug-Ins/Silverlight.plugin
Preference Pane: /Library/PreferencePanes/Flip4Mac WMV.prefPane
Preference Pane: /Library/PreferencePanes/MacFUSE.prefPane
Apps: 90
32-bit Applications:
58 32-bit apps
Kernel Extensions:
/Applications/Parallels Desktop.app
prl_hypervisor.kext (15.1.3 47255 - SDK 10.9)
prl_netbridge.kext (15.1.3 47255 - SDK 10.9)
prl_usb_connect.kext (15.1.3 47255 - SDK 10.9)
prl_vnic.kext (15.1.3 47255 - SDK 10.9)
/Applications/Recoverit.app
WondershareDriver.kext (2.1.3 - SDK 10.14)
/Applications/VMware Horizon Client.app
vmioplug.kext (19.2.0)
/Library/Extensions
com.malwarebytes.mbam.rtprotection.kext (3.2 - SDK 10.13)
/System/Library/Extensions
ezcap VideoGrabber.kext (1.4.1)
ManyCamDriver.kext (0.0.9 - SDK 10.5)
UsbEthernetGadget.kext (1.0.0d1)
System Launch Agents:
[Not Loaded] 16 Apple tasks
[Loaded] 170 Apple tasks
[Running] 108 Apple tasks
System Launch Daemons:
[Not Loaded] 36 Apple tasks
[Loaded] 193 Apple tasks
Launch Agents:
[Not Loaded] com.adobe.AAM.Updater-1.0.plist (? ffb65062 - installed 2016-01-20)
[Other] com.adobe.ARMDCHelper.cc24aef4a1b90ed56a725c38014c95072f92651fb65e1bf9c8e43c37a23d420d.plist (Adobe Systems, Inc. - installed 2020-02-10)
[Running] com.adobe.GC.AGM.plist (Adobe Systems, Inc. - installed 2020-04-22)
[Not Loaded] com.adobe.GC.Invoker-1.0.plist (Adobe Systems, Inc. - installed 2020-04-22)
[Running] com.bjango.istatmenus.agent.plist (Bjango Pty Ltd - installed 2020-04-12)
[Running] com.bjango.istatmenus.status.plist (Bjango Pty Ltd - installed 2020-04-12)
[Loaded] com.google.keystone.agent.plist (Google, Inc. - installed 2020-03-12)
[Loaded] com.google.keystone.xpcservice.plist (Google, Inc. - installed 2020-03-12)
[Loaded] com.hp.messagecenter.launcher.plist (Apple - installed 2020-03-19)
[Running] com.malwarebytes.mbam.frontend.agent.plist (Malwarebytes Corporation - installed 2018-02-14)
[Loaded] com.microsoft.OneDriveStandaloneUpdater.plist (Microsoft Corporation - installed 2020-04-27)
[Other] com.microsoft.update.agent.plist (? fcc9aea5 - installed 2020-04-27)
[Not Loaded] com.teamviewer.teamviewer.plist (TeamViewer GmbH - installed 2020-02-14)
[Not Loaded] com.teamviewer.teamviewer_desktop.plist (TeamViewer GmbH - installed 2020-02-14)
[Running] org.chromium.chromoting.plist (Google, Inc. - installed 2020-04-03)
[Loaded] org.macosforge.xquartz.startx.plist (? 2748570a - installed 2012-09-28)
Launch Daemons:
[Loaded] com.adobe.ARMDC.Communicator.plist (Adobe Systems, Inc. - installed 2020-02-07)
[Loaded] com.adobe.ARMDC.SMJobBlessHelper.plist (Adobe Systems, Inc. - installed 2020-02-07)
[Loaded] com.adobe.SwitchBoard.plist (? 68cad67 - installed 2014-02-05)
[Running] com.adobe.agsservice.plist (Adobe Systems, Inc. - installed 2020-04-22)
[Loaded] com.adobe.fpsaud.plist (Adobe Systems, Inc. - installed 2020-03-27)
[Running] com.bjango.istatmenus.daemon.plist (Bjango Pty Ltd - installed 2020-04-12)
[Running] com.bjango.istatmenus.fans.plist (Bjango Pty Ltd - installed 2020-04-12)
[Loaded] com.bjango.istatmenus.installerhelper.plist (Bjango Pty Ltd - installed 2020-04-12)
[Loaded] com.google.keystone.daemon.plist (Google, Inc. - installed 2020-03-12)
[Loaded] com.malwarebytes.HelperTool.plist (Malwarebytes Corporation - installed 2018-05-27)
[Running] com.malwarebytes.mbam.rtprotection.daemon.plist (Malwarebytes Corporation - installed 2018-02-14)
[Running] com.malwarebytes.mbam.settings.daemon.plist (Malwarebytes Corporation - installed 2018-02-14)
[Loaded] com.microsoft.OneDriveStandaloneUpdaterDaemon.plist (Microsoft Corporation - installed 2020-04-27)
[Loaded] com.microsoft.OneDriveUpdaterDaemon.plist (Microsoft Corporation - installed 2020-04-27)
[Loaded] com.microsoft.autoupdate.helper.plist (Microsoft Corporation - installed 2020-04-27)
[Loaded] com.microsoft.office.licensing.helper.plist (? 6d8cb30e - installed 2010-09-23)
[Loaded] com.microsoft.office.licensingV2.helper.plist (Microsoft Corporation - installed 2018-08-04)
[Not Loaded] com.oracle.java.Helper-Tool.plist (? 0 - installed )
[Loaded] com.teamviewer.Helper.plist (TeamViewer GmbH - installed 2020-02-14)
[Not Loaded] com.teamviewer.teamviewer_service.plist (TeamViewer GmbH - installed 2020-02-14)
[Loaded] com.transcend.RxRecoveryHelper.plist (Transcend Information, Inc. - installed 2019-08-09)
[Loaded] com.vmware.CDSHelper.plist (VMware, Inc. - installed 2020-04-07)
[Loaded] org.macosforge.xquartz.privileged_startx.plist (? 77ab826e - installed 2012-09-28)
[Not Loaded] org.virtualbox.startup.plist (? 0 - installed )
[Loaded] org.wireshark.ChmodBPF.plist (Wireshark Foundation, Inc. - installed 2020-02-26)
User Launch Agents:
[Loaded] com.adobe.AAM.Updater-1.0.plist (? 0 - installed 2014-02-05)
[Loaded] com.dropbox.DropboxMacUpdate.agent.plist (Dropbox, Inc. - installed 2019-08-23)
[Other] com.wondershare.TunesGoHelper.plist (YZC2T44ZDX - installed 2017-03-16)
User Login Items:
[Not Loaded] AppCleaner SmartDelete (Julien Ramseier - installed 2019-05-13)
Modern Login Item
/Applications/AppCleaner.app/Contents/Library/LoginItems/AppCleaner SmartDelete.app
[Not Loaded] LPLaunchAtLoginHelperApp (App Store - installed 2019-07-08)
Modern Login Item
/Applications/LastPass.app/Contents/Library/LoginItems/LPLaunchAtLoginHelperApp.app
[Not Loaded] Launcher Disabler (Microsoft Corporation - installed 2020-04-27)
Modern Login Item
/Applications/OneDrive.app/Contents/Library/LoginItems/Launcher Disabler.app
[Not Loaded] OneDrive Launcher (Microsoft Corporation - installed 2020-04-27)
Modern Login Item
/Applications/OneDrive.app/Contents/Library/LoginItems/OneDrive Launcher.app
[Not Loaded] SSDReporterLaunchHelper (CoreCode Limited - installed 2020-02-19)
Modern Login Item
/Applications/SSDReporter.app/Contents/Library/LoginItems/SSDReporterLaunchHelper.app
[Not Loaded] LaunchHelper (App Store - installed 2020-04-06)
Modern Login Item
/Applications/Turbo VPN.app/Contents/Library/LoginItems/LaunchHelper.app
[Not Loaded] WhatsApp Login Helper (WhatsApp Inc. - installed 2020-04-01)
Modern Login Item
/Applications/WhatsApp.app/Contents/Library/LoginItems/WhatsApp Login Helper.app
[Not Loaded] PhotoStreamAgent (App Store - installed 2015-03-19)
Modern Login Item
/Applications/iPhoto.app/Contents/Library/LoginItems/PhotoStreamAgent.app
Internet Plug-ins:
AdobeExManDetect: AdobeExManDetect 1.1.0.0 (? - installed 2014-02-07)
FlashPlayer-10.6: 32.0.0.363 (Adobe Systems, Inc. - installed 2020-04-14)
AdobeAAMDetect: AdobeAAMDetect 1.0.0.0 (? - installed 2016-01-20)
AdobePDFViewerNPAPI: 17.012.20098 (Adobe Systems, Inc. - installed 2020-03-19)
AdobePDFViewer: 20.006.20042 (Adobe Systems, Inc. - installed 2020-03-19)
Flash Player: 32.0.0.363 (Adobe Systems, Inc. - installed 2020-04-14)
Default Browser: (? - installed 2019-10-18)
Flip4Mac WMV Plugin: 3.2.0.16 (? - installed 2013-11-06)
SharePointBrowserPlugin: 14.7.7 (? - installed 2018-01-28)
Silverlight: 5.1.40728.0 (? - installed 2015-10-18)
iPhotoPhotocast: 7.0 (Apple - installed 2013-04-25)
User Internet Plug-ins:
User Internet Plug-ins need Full Drive Access
User Audio Plug-ins:
User Audio Plug-ins need Full Drive Access
User iTunes Plug-ins:
User iTunes Plug-ins need Full Drive Access
Safari Extensions:
"Open In" button for Internet Explorer (? - installed 2019-03-02)
3rd Party Preference Panes:
Flash Player (Adobe Systems, Inc. - installed 2020-03-27)
Flip4Mac WMV (? - installed 2013-03-29)
MacFUSE (? - installed 2008-12-19)
Performance:
System Load: 1.84 (1 min ago) 1.61 (5 min ago) 1.71 (15 min ago)
Nominal I/O speed: 6.10 MB/s
File system: 119.40 seconds
Write speed: 455 MB/s
Read speed: 517 MB/s
CPU Usage Snapshot:
Type Overall
System: 5 %
User: 26 %
Idle: 69 %
Top Processes Snapshot by CPU:
Process (count) CPU (Source - Location)
Other processes 114.10 % (?)
EtreCheck 10.25 % (App Store)
iStat Menus Status 0.37 % (Bjango Pty Ltd)
cloudd 0.31 % (Apple)
SystemUIServer 0.15 % (Apple)
Top Processes Snapshot by Memory:
Process (count) RAM usage (Source - Location)
EtreCheck 443 MB (App Store)
AppleSpell 97 MB (Apple)
Mail 87 MB (Apple)
Safari 68 MB (Apple)
suggestd 57 MB (Apple)
Top Processes Snapshot by Network Use:
Process (count) Input / Output (Source - Location)
Other processes 194 KB / 80 MB (?)
Mail 245 KB / 73 KB (Apple)
remoting_me2me_host 25 KB / 6 KB (Google, Inc.)
spindump_agent 0 B / 0 B (Apple)
backgroundtaskmanagementagent 0 B / 0 B (Apple)
Virtual Memory Information:
Physical RAM: 4 GB
Free RAM: 17 MB
Used RAM: 2.56 GB
Cached files: 1.42 GB
Available RAM: 1.44 GB
Swap Used: 102 MB
Clean up:
Executable not found
Diagnostics Information (past 7-30 days):
Directory /Library/Logs/DiagnosticReports is not accessible.
Enable Full Drive Access to see more information.
End of report
