Buongiorno a tutti!
Come da titolo ho problemi con SuperDuper! (versione 3.3.1 ma anche precedenti)
Vorrei fare copia Hd del mio iMac 27 mid 2010 sistema operativo Mac OS High Sierra 10.13.6
Dimensione disco disco da copiare 1TB (disponibile 626,36 GB Utilizzato 379,17 GB su disco)
dimensione disco di destinazione 1Tb disponibile 999,36 GB (490 KB cancellabili)
il messaggio di errore che mi dà è il seguente:
SDCopy can not be used without SuperDuper!
Come posso fare?
Ringrazio anticipatamente chiunque possa darmi una mano
qui di seguito riporto tutta la descrizione che mi da il programma.
| 04:35:18 PM | Info | SuperDuper! Version 3.3.1 (121-a5db222), path: /Applications/SuperDuper!.app, load address: 0x10f45d000
| 04:35:18 PM | Info | Started on Mon, Feb 10, 2020 at 4:35 PM
| 04:35:18 PM | Info | Source Volume: "Macintosh HD" mount: '/' device: disk1s1 file system: 'APFS' protocol: SATA OS: 10.13.6 capacity: 1 TB available: 619,85 GB files: 1.267.869 directories: 476.579
| 04:35:18 PM | Info | Target Volume: "Backup" mount: '/Volumes/Backup' device: disk2s2 file system: 'Mac OS Extended (Journaled)' protocol: USB capacity: 1 TB available: 999,36 GB files: 66 directories: 19
| 04:35:18 PM | Info | Copy Mode : Erase, then copy files
| 04:35:18 PM | Info | Copy Script : Backup - all files.dset
| 04:35:18 PM | Info | Transcript : BuildTranscript.plist
| 04:35:18 PM | Info | PHASE: 1. Prepare to Copy Files
| 04:35:18 PM | Info | ...ACTION: Preparing Macintosh HD
| 04:35:18 PM | Info | ......COMMAND => Enabling permissions on Macintosh HD
| 04:35:18 PM | Info | ...ACTION: Preparing Macintosh HD snapshot
| 04:35:18 PM | Info | ......COMMAND => Creating Snapshot of Macintosh HD
| 04:36:06 PM | Info | ......COMMAND => Mounting Snapshot for Macintosh HD
| 04:36:06 PM | Info | ...ACTION: Erasing Backup
| 04:36:06 PM | Info | ......COMMAND => Erasing Backup
| 04:36:07 PM | Info | Erasing standalone volume
| 04:36:07 PM | Info | Unmounting /dev/disk2s2 mounted on /Volumes/Backup
| 04:36:09 PM | Info | Volume Backup on disk2s2 unmounted
| 04:36:09 PM | Info | Started erase on disk2s2 Backup
| 04:36:09 PM | Info | Unmounting disk
| 04:36:09 PM | Info | Erasing
| 04:36:36 PM | Info | Initialized /dev/rdisk2s2 as a 931 GB case-insensitive HFS Plus volume with a 81920k journal
| 04:36:36 PM | Info | Mounting disk
| 04:36:39 PM | Info | Finished erase on disk2s2 Backup
| 04:36:39 PM | Info | ...ACTION: Preparing Backup
| 04:36:39 PM | Info | ......COMMAND => Checking APFS Preboot partition for Backup
| 04:36:39 PM | Info | ......COMMAND => Checking APFS Recovery partition for Backup
| 04:36:39 PM | Info | ......COMMAND => Checking APFS Virtual Memory partition for Backup
| 04:36:39 PM | Info | ......COMMAND => Checking APFS Volume Group for Backup
| 04:36:39 PM | Info | ......COMMAND => Enabling permissions on Backup
| 04:36:39 PM | Info | /dev/disk1s1 on / (apfs, local, journaled)
| 04:36:39 PM | Info | devfs on /dev (devfs, local, nobrowse)
| 04:36:39 PM | Info | /dev/disk1s4 on /private/var/vm (apfs, local, noexec, journaled, noatime, nobrowse)
| 04:36:39 PM | Info | map -hosts on /net (autofs, nosuid, automounted, nobrowse)
| 04:36:39 PM | Info | map auto_home on /home (autofs, automounted, nobrowse)
| 04:36:39 PM | Info | //iMac%20ADI@AirPort%20Time%20Capsule%20iMac._afpovertcp._tcp.local./Backup%20iMac on /Volumes/Backup iMac (afpfs, nobrowse)
| 04:36:39 PM | Info | /dev/disk2s3 on /Volumes/iMac Backup (hfs, local, nodev, nosuid, journaled, noowners)
| 04:36:39 PM | Info | /dev/disk3s2 on /Volumes/Backup di Time Machine (hfs, local, nodev, nosuid, journaled, nobrowse)
| 04:36:39 PM | Info | com.apple.TimeMachine.2020-02-10-163606@/dev/disk1s1 on /private/var/folders/9k/k7ggxvbx0fjcr8bts1snnbxm0000gn/T/com.blacey.SuperDuper/C936F1B7-52C1-4FD9-910B-0F2B7E8E3878/snapshot (apfs, local, read-only, journaled, nobrowse)
| 04:36:39 PM | Info | com.apple.TimeMachine.2020-02-10-163615@/dev/disk1s1 on /Volumes/com.apple.TimeMachine.localsnapshots/Backups.backupdb/iMac di iMac/2020-02-10-163615/Macintosh HD (apfs, local, read-only, journaled, nobrowse)
| 04:36:39 PM | Info | com.apple.TimeMachine.2020-02-10-152750@/dev/disk1s1 on /Volumes/com.apple.TimeMachine.localsnapshots/Backups.backupdb/iMac di iMac/2020-02-10-152750/Macintosh HD (apfs, local, read-only, journaled, nobrowse)
| 04:36:39 PM | Info | /dev/disk2s2 on /Volumes/Backup (hfs, local, nodev, nosuid, journaled, noowners)
| 04:36:40 PM | Info | Enabling permissions on device /dev/disk2s2
| 04:36:40 PM | Info | File system user/group ownership enabled
| 04:36:40 PM | Info | Permissions are enabled on /Volumes/Backup
| 04:36:40 PM | Info | ......COMMAND => Verifying that Backup ACL support matches Macintosh HD
| 04:36:40 PM | Info | ......COMMAND => Pausing Spotlight indexing for Backup
| 04:36:40 PM | Info | PHASE: 2. Copy Files
| 04:36:40 PM | Info | ...ACTION: Copying files from Macintosh HD to Backup
| 04:36:40 PM | Info | ......COMMAND => Cloning Macintosh HD to Backup
| 04:36:40 PM | Info | Copying all files using script: /Users/imacadi/Library/Application Support/SuperDuper!/Copy Scripts/Standard Scripts/Backup - all files.dset
| 04:36:40 PM | Error | SDCopy can not be used without SuperDuper!
| 04:36:40 PM | Info | Will ignore error codes 1,13 encountered while copying files and directories
