Shleyer? Finder desidera apportare delle modifiche per svuotare il cestino
Zacksit
Expert Translator
Expert Translator
Sarebbe possibile copiare e incollare il seguente comando di Terminale da /Library/F-Secure/XFENCE (libreria di sistema) a Terminale in modalità Recovery? Avevo provato a copiarlo a mano, ma gli accapo non erano puliti e non sapevo come fare per rispettare tutti quegli spazi. Ma forse gli spazi interlinei non sono importanti? se copiassi tutto di seguito senza accapo funzionerebbe?
#!/bin/bash
PARTIAL=false
while getopts uc opt
do
    case "$opt" in
	u) PARTIAL=true
	\?) echo "Usage: $0"
            exit 1
    esac
done
#Checking if integrated
echo "Checking if integrated"
if [ -d /Library/F-Secure/XFENCE/F-Secure\ XFENCE\ Configuration.app ] ; then
       echo "/Library/F-Secure/XFENCE/F-Secure\ XFENCE\ Configuration.app exists"
	if [ -f /usr/local/f-secure/signal/xfence-disabled-by-uninstaller ] ; then
    	    rm -rf /usr/local/f-secure/signal/xfence-disabled-by-uninstaller
	fi
	touch /usr/local/f-secure/signal/xfence-uninstall
        notifyutil -1 com.f-secure.xfence-uninstall-proceed && touch /usr/local/f-secure/signal/xfence-disabled-by-uninstaller &
        notifyutil -p com.f-secure.xfence-uninstall
        SECONDS=0
	while [ $SECONDS -lt 10 ] && [ ! -f /usr/local/f-secure/signal/xfence-disabled-by-uninstaller ]; do
  	    sleep 1
	done
	isKextLoaded=$(kextstat |grep com.fsecure.XFENCE)
	if [ -n "$isKextLoaded" ] && [ ! -f /usr/local/f-secure/signal/xfence-disabled-by-uninstaller ] ; then
	    exit 1
	fi
else
    echo "/Library/F-Secure/XFENCE/F-Secure\ XFENCE\ Configuration.app does not exist"
    launchctl unload /Library/LaunchAgents/com.fsecure.XFENCEUserAgent.plist
    sudo rm -f /Library/LaunchAgents/com.fsecure.XFENCEUserAgent.plist
    sudo killall "F-Secure XFENCE"
fi
echo "Unloading com.fsecure.XFENCEDaemon.plist"
sudo launchctl unload /Library/LaunchDaemons/com.fsecure.XFENCEDaemon.plist
echo "Removing app files"
sudo rm -rf /Library/Extensions/XFENCE.kext
sudo rm -rf /Library/Application\ Support/XFENCE
sudo rm -rf /Applications/F-Secure\ XFENCE\ Configuration.app
sudo rm -f /Library/LaunchDaemons/com.fsecure.XFENCE.plist
sudo rm -f /Library/LaunchDaemons/com.fsecure.XFENCEDaemon.plist
sudo rm -f /Library/LaunchAgents/com.fsecure.XFENCEUpdater.plist
sudo rm -rf /Library/F-Secure/XFENCE
sudo rm -rf /Users/Shared/F-Secure\ XFENCE\ Extras
if ! $PARTIAL ; then
fi
echo "Killing XFENCEDaemon"
sudo killall XFENCEDaemon
exit 0
# Do not force unload, allow kext to be unloaded on next reboot
# sudo touch /System/Library/Extensions
# sleep 5
# sudo kextcache -u /
# sync
# sudo kextunload -b com.fsecure.XFENCE
Kundalini
Da F-Secure XFENCE User Guide.pdf (che si recupera dall'interno dell'applicazione stessa Menu > Help > ), mi par di capire tuttavia che a seguito del tentativo di disinstallazione poco ortodosso l'applicazione stessa non ti risponda più nella sua interezza.
"Uninstalling F-Secure XFENCE
To uninstall F-Secure XFENCE, first disable it from the menu bar, and then run the following command:
sudo bash /Library/F-Secure/XFENCE/uninstall.sh
Once you’ve run this, reboot the computer. Note that you cannot perform this operation unless F-Secure XFENCE has been disabled, for obvious reasons. You may also wish to delete your rules on the system, which can be found in /Users/Shared/F-Secure XFENCE/.
When Things Go Wrong
Problems with F-Secure XFENCE are very rare, but if something does go wrong and you are unable to uninstall using the above methods, you can also uninstall F-Secure XFENCE from safe boot or recovery mode. In the unlikely chance that you find your system hung and will not boot, or other irrecoverable situations, perform the following steps to forcefully disable F-Secure XFENCE:
From Safe Boot
1. Boot into safe mode by holding in shift when you hear the boot chime
2. Verify that your menu bar reads Safe Mode in bold red text after logging in
3. Execute the following command:
4. Reboot the computer, and F-Secure XFENCE will no longer appear
From Recovery Mode
1. Boot into recovery mode using Command-R when you hear the boot chime
2. If your disk is File Vault protected, launch Disk Utility; select your disk and then select
File > Mount. You'll be prompted for your account password to unlock the volume. Once unlocked, quit Disk Utility and return to the main recovery screen.
3. Select Utilities > Terminal to launch a terminal session
4. Run the following commands to delete the F-Secure XFENCE kernel extension and
rebuild the cache:
rm -rf "/Volumes/Macintosh HD/Library/Extensions/XFENCE.kext” kextcache –u /Volumes/Macintosh\ HD
5. Reboot the computer, and then run the F-Secure XFENCE uninstall script to clean up"
Siccome non sono un mago da Terminale resto sempre un po' dubbioso.
Sembra interessante il comando da eseguire dopo l'avvio in safe mode.
Anche perché con l'avvio da Recovery al punto 5 dice di lanciare lo script di disinstallazione e da quel che ho capito tu non lo hai più, avendo eliminato parzialmente F-Secure con AppCleaner.
P.S.: Ma come mai quando ho premuto Invia non mi è apparso il solito avviso "Nel frattempo é stata aggiunta una risposta ecc."
Non ho letto ancora completamente le risposte precedenti :)
Se funziona, non aggiustarlo.
Zacksit
Expert Translator
Expert Translator
Grazie di cuore Kundalini, lo provo!
Zacksit
Expert Translator
Expert Translator
La cosa strana che sia in modalità sicura, sia in modalità Recupero, dopo che ho inserito i comandi citati, Terminale mi dava che non li trovava. Ma poi riavviando ora sembra risolto. La cartella F-Secure c'è ancora nella Libreria di sistema, ma per fortuna è vuota! :D
Grazie Kundalini e ƒaxus! :occasion5:
Uno_qualunque
Senza voler dare addosso a Zacksit, perché casini del genere li abbiamo fatti e li faremo (spero poco!) tutti, ancora una volta si dimostra che il peggior virus/malware è quell'attrezzo tutto ossa, peli e ciccia che sta al di là della tastiera.
Complimenti ai soliti, che non si danno mai per persi, per me è sempre un divertimento leggere questi post, si impara un sacco!
Zacksit
Expert Translator
Expert Translator
Uno_qualunque ha scritto:
sab, 04 lug 2020 10:56
Hai assolutamente ragione, avrei voluto esprimerlo così chiaramente.
Dopo che non riuscivo a trovare il disinstallatore, per la fretta ho pensato (male) di usare App Cleaner & Uninstaller, poi AppCleaner. Invece avrei dovuto eseguire un ulteriore ricerca in primis sull'app (non so perché non ci ho pensato prima) e poi su Google.
Infatti c'è sempre da imparare... in fondo questi forum esistono anche per questo.
Uno_qualunque
Temevo che avrei potuto essere preso "male" invece sono contento che tu abbia colto esattamente il senso :-)
Zacksit
Expert Translator
Expert Translator
sab, 04 lug 2020 15:58
Figurati, e poi non ho mai paure di ammettere quando faccio 'azzate anche se a volte m'imbarazza di essere stato così scemo :D
Pingus
Che bella gente in questo posto...
Pingus ha scritto:
lun, 06 lug 2020 11:40
Che gente in questo bel posto!
spegahsheen
Che bel quesito ha posto la gente
Per un'insolita congiunzione astrale si manifestò alla mia mente la VERITÀ: trascendente, profonda, rivelata con parole illuminanti. Solo che adesso... non me la ricordo più!
Zacksit
Expert Translator
Expert Translator
Davvero, che bel posto ha questa gente.
Visitano il forum: Google [Bot] e 58 ospiti
cron
