Certo che EtreCheck è veramente scaduto. Questa versione 5.2 (PRO? Ma occorre pure pagare?) non fornisce più nessuna informazione valida. Un resoconto di dati che sono reperibili direttamente da applicazioni del SO o di terze parti completamente gratuite. Grande delusione.
farci girare Mojave diventa arduo.Drives:
disk0 - APPLE HDD HTS541010A9E662 1.00 TB (Mechanical- 5400 RPM)
Internal SATA 3 Gigabit Serial ATA
disk0s1 - EFI (MS-DOS FAT32) [EFI] 210 MB
disk0s2 [APFS Container] 1000.00 GB
disk1 [APFS Virtual drive] 1000.00 GB (Shared by 4 volumes)
disk1s1 - M*****X (APFS) (Shared - 12.62 GB used)
disk1s2 - Preboot (APFS) [APFS Preboot] (Shared - 46 MB used)
disk1s3 - Recovery (APFS) [Recovery] (Shared - 523 MB used)
disk1s4 - VM (APFS) [APFS VM] (Shared - 4.29 GB used)
Timestamp (3): Sun Apr 21 21:13:37 2019
DetectX Swift v1.086
macOS: Version 10.14.4 (Build 18E227)
File System: apfs
Temp: Critical: The thermal state is significantly impacting the performance of the system and the device needs to cool down. Reduce usage of the CPU, GPU, and any I/O to the minimum level required for user interaction. Stop using any peripherals such as the camera.
Boot time: Sun Apr 21 21:00:50 2019
Uptime: 13 mins, 1 user
Spotlight status for /:
Indexing enabled.
FileVault is Off.
Internet: Reachable
Hardware Overview:
Model Name: iMac
Model Identifier: iMac14,1
Processor Name: Intel Core i5
Processor Speed: 2,7 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 4 MB
Memory: 8 GB
Boot ROM Version: 135.0.0.0.0
SMC Version (system): 2.14f24
Sharing Preferences:
File Sharing: Off
Screen Sharing: Off
Remote Management: Off
Back To My Mac: Off
Remote Login: Off
Remote Apple Events: Off
3rd Party Kexts (loaded):
$PATH:
/etc/paths:
/usr/local/bin
/usr/bin
/bin
/usr/sbin
/sbin
/etc/paths.d/:
~/.bash_profile:
~/.bashrc:
~/.bash_login:
~/.profile:
~/.bash_logout:
PID Status Label
- 0 com.openssh.ssh-agent
759 0 com.sqwarq.DetectX-Swift.1668
- 0 com.sqwarq.DetectX-Swift.observer
System Launchd processes:
0 - com.vix.cron
0 0 org.cups.cupsd
User Login Items:
nil
/Library/LaunchDaemons:
/Library/LaunchAgents:
~/Library/LaunchAgents:
com.sqwarq.DetectX-Swift.observer.plist
--> Program Arguments: /Applications/DetectX Swift.app/Contents/MacOS/DetectX Swift
--> Program Arguments: -observer
User Crontab:
No cron jobs
/etc:
rc.common
bashrc_Apple_Terminal
bashrc
zshrc
rc.netboot
aliases
zprofile
/ $Root:
.HFS+ Private Directory Data
/ .. children: 0
installer.failurerequests
.file
~/ $Home:
Music / .. children: 1
.CFUserTextEncoding
Pictures / .. children: 2
Desktop / .. children: 2
Library / .. children: 60
.cups / .. children: 1
Public / .. children: 2
Movies / .. children: 2
.Trash / .. children: 0
Documents / .. children: 1
Downloads / .. children: 3
~/Library:
studentd / .. children: 4
HomeKit / .. children: 7
Family / .. children: 1
PersonalizationPortrait / .. children: 1
com.apple.sbd / .. children: 1
com.apple.touristd / .. children: 3
DiskImages / .. children: 1
dmd / .. children: 0
CEF / .. children: 1
NVIDIA / .. children: 3
com.sqwarq.DetectX-Swift / .. children: 2
DetectX Swift / .. children: 3
DriveDx / .. children: 6
~/Library/Safari/Extensions:
~/Library/Internet Plug-Ins:
/Users/Shared:
adi / .. children: 0
/Applications:
Books.app
Home.app
News.app
DetectX Swift.app
GeForceNOW.app
Stocks.app
VoiceMemos.app
/Library:
/Library/Extensions:
Disabled Plug-Ins / .. children: 2
/Library/Managed Preferences:
/Library/ScriptingAdditions:
/Library/StartupItems:
/Library/Updates:
ProductMetadata.plist
Top Processes:
%CPU PID COMMAND
16.0 130 WindowServer
13.4 92 sandboxd
11.6 272 callservicesd
11.4 302 soagent
4.9 421 Safari
4.0 759 DetectX Swift
2.7 0 kernel_task
2.0 431 com.apple.WebKit
1.0 91 hidd
0.7 370 Dock
Running Processes:
PPID PID %CPU USER COMMAND
0 1 0.1 root /sbin/launchd
1 36 0.0 root /usr/sbin/syslogd
1 37 0.0 root /usr/libexec/UserEventAgent (System)
1 40 0.0 root /System/Library/PrivateFrameworks/Uninstall.framework/Resources/uninstalld
1 41 0.0 root /usr/libexec/kextd
1 42 0.0 root /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/Support/fseventsd
1 44 0.0 root /System/Library/PrivateFrameworks/MediaRemote.framework/Support/mediaremoted
1 47 0.0 _appleevents /System/Library/CoreServices/appleeventsd --server
1 48 0.0 root /usr/sbin/systemstats --daemon
1 50 0.0 root /usr/libexec/configd
1 51 0.0 root /System/Library/CoreServices/powerd.bundle/powerd
1 54 0.0 root /usr/libexec/logd
1 55 0.0 root /usr/libexec/keybagd -t 15
1 60 0.0 root /usr/libexec/warmd
1 61 0.0 root /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Support/mds
1 62 0.0 _iconservices /System/Library/CoreServices/iconservicesd
1 63 0.0 root /usr/libexec/diskarbitrationd
1 66 0.0 root /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd-helper -launchd
1 67 0.0 root /usr/libexec/coreduetd
1 70 0.1 root /usr/libexec/opendirectoryd
1 71 0.0 root /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
1 72 0.0 root /System/Library/PrivateFrameworks/Noticeboard.framework/Versions/A/Resources/nbstated
1 73 0.0 root /System/Library/CoreServices/launchservicesd
1 74 0.0 _timed /usr/libexec/timed
1 75 0.0 root /usr/sbin/securityd -i
1 76 0.0 _usbmuxd /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/Resources/usbmuxd -launchd
1 78 0.0 _locationd /usr/libexec/locationd
1 80 0.0 root autofsd
1 81 0.0 _displaypolicyd /usr/libexec/displaypolicyd -k 1
1 82 0.0 root /usr/libexec/dasd
1 85 0.0 [U501] /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow console
1 86 0.0 root /System/Library/CoreServices/logind
1 87 0.0 root /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/Support/revisiond
1 88 0.0 root /usr/sbin/KernelEventAgent
1 90 0.0 root /usr/sbin/bluetoothd
1 91 0.0 _hidd /usr/libexec/hidd
1 92 16.8 root /usr/libexec/sandboxd
1 93 0.0 root /usr/libexec/corebrightnessd --launchd
1 94 0.0 root /usr/libexec/AirPlayXPCHelper
1 95 0.1 root /usr/sbin/notifyd
1 96 0.0 _distnote /usr/sbin/distnoted daemon
1 97 0.0 root /usr/sbin/cfprefsd daemon
1 98 0.0 root /System/Library/CoreServices/coreservicesd
1 99 0.0 root /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/MacOS/authd
1 100 0.0 root aslmanager
1 101 0.0 root /usr/libexec/airportd
1 122 0.0 root /System/Library/PrivateFrameworks/CoreDuetContext.framework/Resources/contextstored
1 126 0.0 _coreaudiod /usr/sbin/coreaudiod
1 127 0.0 root /usr/libexec/nehelper
1 130 11.4 _windowserver /System/Library/PrivateFrameworks/SkyLight.framework/Resources/WindowServer -daemon
1 132 0.0 root /System/Library/Frameworks/PCSC.framework/Versions/A/XPCServices/com.apple.ctkpcscd.xpc/Contents/MacOS/com.apple.ctkpcscd
1 133 0.0 root /usr/libexec/trustd
1 136 0.0 _ctkd /System/Library/Frameworks/CryptoTokenKit.framework/ctkd -s
1 144 0.0 _coreaudiod /System/Library/Frameworks/CoreAudio.framework/Versions/A/XPCServices/com.apple.audio.DriverHelper.xpc/Contents/MacOS/com.apple.audio.DriverHelper
1 145 0.0 _networkd /usr/libexec/symptomsd
1 146 0.0 root /usr/libexec/mobileassetd
1 147 0.0 _nsurlsessiond /usr/libexec/nsurlsessiond --privileged
1 148 0.0 root /System/Library/PrivateFrameworks/CoreSymbolication.framework/coresymbolicationd
1 149 0.0 root /usr/sbin/ocspd
1 160 0.0 root /usr/libexec/lsd runAsRoot
1 165 0.0 root /usr/libexec/smd
1 168 0.0 _nsurlstoraged /usr/libexec/nsurlstoraged --privileged
1 169 0.0 root /System/Library/CryptoTokenKit/com.apple.ifdreader.slotd/Contents/MacOS/com.apple.ifdreader
1 170 0.0 root /usr/libexec/apfsd
1 172 0.0 root /usr/libexec/usbd
1 173 0.0 root /usr/libexec/firmwarecheckers/ethcheck/ethcheck --integrity-check-daemon
1 174 0.0 _cmiodalassistants /System/Library/Frameworks/CoreMediaIO.framework/Resources/VDC.plugin/Contents/Resources/VDCAssistant
1 175 0.0 root /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Support/awdd
1 176 0.0 _mdnsresponder /usr/sbin/mDNSResponder
1 177 0.0 root /usr/libexec/syspolicyd
1 178 0.0 root /usr/sbin/mDNSResponderHelper
1 180 0.0 root /usr/libexec/watchdogd
1 181 0.0 root /System/Library/PrivateFrameworks/TCC.framework/Resources/tccd system
1 183 0.0 root /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mds_stores
1 184 0.0 root /usr/libexec/thermald
1 186 0.0 root /usr/libexec/secinitd
1 192 0.0 root /usr/libexec/findmydeviced
1 193 0.0 root /System/Library/Frameworks/AudioToolbox.framework/AudioComponentRegistrar -daemon
1 194 0.0 _netbios /usr/sbin/netbiosd
1 195 0.0 _coreaudiod /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
1 197 0.0 root /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
1 199 0.0 root /usr/libexec/colorsync.displayservices
1 200 0.0 root /usr/libexec/colorsyncd
1 208 0.0 root /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/com.apple.CodeSigningHelper.xpc/Contents/MacOS/com.apple.CodeSigningHelper
1 209 0.0 root /usr/libexec/bootinstalld
1 211 0.0 root /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/XPCServices/ViewBridgeAuxiliary.xpc/Contents/MacOS/ViewBridgeAuxiliary
1 214 0.0 root /usr/sbin/distnoted agent
1 217 0.0 root /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/XPCServices/com.apple.PerformanceAnalysis.animationperfd.xpc/Contents/MacOS/com.apple.PerformanceAnalysis.animationperfd
1 219 0.0 root /usr/libexec/sysmond
1 221 0.0 _assetcache /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/XPCServices/AssetCacheLocatorService.xpc/Contents/MacOS/AssetCacheLocatorService -d
1 222 0.0 root /System/Library/PrivateFrameworks/AmbientDisplay.framework/Versions/A/XPCServices/com.apple.AmbientDisplayAgent.xpc/Contents/MacOS/com.apple.AmbientDisplayAgent
48 223 0.0 root /usr/sbin/systemstats --logger-helper /private/var/db/systemstats
1 224 0.0 root /usr/sbin/spindump
1 225 0.0 root /System/Library/CoreServices/SubmitDiagInfo server-init
1 226 0.0 root /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/XPCServices/com.apple.cmio.registerassistantservice.xpc/Contents/MacOS/com.apple.cmio.registerassistantservice
1 227 0.0 _assetcache /usr/libexec/AssetCache/AssetCache
1 229 0.0 root /System/Library/CoreServices/sharedfilelistd
1 231 0.0 root /usr/sbin/systemsoundserverd
1 232 0.0 root /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd
1 233 0.0 root /System/Library/PrivateFrameworks/AccountPolicy.framework/XPCServices/com.apple.AccountPolicyHelper.xpc/Contents/MacOS/com.apple.AccountPolicyHelper
1 234 0.0 root /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp -d
1 244 0.0 [U501] /usr/sbin/cfprefsd agent
1 245 0.0 [U501] /usr/sbin/distnoted agent
1 246 0.0 _spotlight /usr/sbin/distnoted agent
1 247 0.0 [U501] /usr/libexec/lsd
1 256 0.0 root /System/Library/Frameworks/GSS.framework/Helpers/GSSCred
1 259 0.0 [U501] /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd
1 260 0.0 root /usr/libexec/securityd_service
1 262 0.0 [U501] /usr/libexec/UserEventAgent (Aqua)
1 264 0.0 [U501] /usr/sbin/universalaccessd launchd -s
1 265 0.0 [U501] /System/Library/Frameworks/CoreTelephony.framework/Support/CommCenter -L
1 266 0.0 [U501] /usr/libexec/trustd --agent
1 267 0.0 [U501] /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support/fontd
1 269 0.0 [U501] /System/Library/CoreServices/backgroundtaskmanagementagent
1 270 0.0 [U501] /usr/libexec/secd
1 271 0.0 root /usr/sbin/WirelessRadioManagerd
1 272 16.5 [U501] /System/Library/PrivateFrameworks/TelephonyUtilities.framework/callservicesd
1 274 0.0 [U501] /System/Library/PrivateFrameworks/IDS.framework/identityservicesd.app/Contents/MacOS/identityservicesd
1 275 0.0 [U501] /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
1 276 0.0 [U501] /System/Library/CoreServices/iconservicesagent
1 277 0.0 [U501] /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent
1 278 0.0 root /System/Library/Frameworks/VideoToolbox.framework/Versions/A/XPCServices/VTDecoderXPCService.xpc/Contents/MacOS/VTDecoderXPCService
1 279 0.0 [U501] /System/Library/PrivateFrameworks/TCC.framework/Resources/tccd
1 280 0.0 [U501] /System/Library/PrivateFrameworks/IMDPersistence.framework/XPCServices/IMDPersistenceAgent.xpc/Contents/MacOS/IMDPersistenceAgent
1 281 0.0 [U501] /usr/libexec/spindump_agent
1 282 0.0 [U501] /System/Library/Frameworks/AddressBook.framework/Executables/ContactsAccountsService
1 283 0.0 [U501] /usr/libexec/secinitd
1 284 0.0 root /usr/sbin/wirelessproxd
1 285 0.0 [U501] /usr/libexec/rapportd
1 286 0.0 [U501] /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd
1 287 0.0 [U501] /usr/libexec/routined LAUNCHED_BY_LAUNCHD
1 288 0.0 [U501] /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Support/cloudd
1 289 0.0 _analyticsd /System/Library/PrivateFrameworks/CoreAnalytics.framework/Support/analyticsd
1 290 0.0 [U501] /usr/libexec/nsurlstoraged
1 292 0.0 [U501] /usr/sbin/usernoted
1 293 0.0 [U501] /System/Library/Frameworks/Security.framework/Versions/A/Resources/CloudKeychainProxy.bundle/Contents/MacOS/CloudKeychainProxy
1 294 0.0 [U501] /System/Library/Image Capture/Support/icdd
1 296 0.0 [U501] /usr/libexec/nsurlsessiond
1 297 0.0 root /System/Library/CoreServices/CrashReporterSupportHelper server-init
1 299 0.0 [U501] /System/Library/CoreServices/NotificationCenter.app/Contents/MacOS/NotificationCenter
1 301 0.0 [U501] /usr/libexec/pboard
1 302 16.9 [U501] /System/Library/PrivateFrameworks/MessagesKit.framework/Resources/soagent.app/Contents/MacOS/soagent
1 303 0.0 [U501] /System/Library/PrivateFrameworks/UserActivity.framework/Agents/useractivityd
1 304 0.0 [U501] /usr/libexec/sharingd
1 305 0.0 [U501] /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/XPCServices/ViewBridgeAuxiliary.xpc/Contents/MacOS/ViewBridgeAuxiliary
1 306 0.0 [U501] /System/Library/CoreServices/talagent
1 307 0.0 [U501] /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
1 308 0.0 [U501] /System/Library/PrivateFrameworks/PrintingPrivate.framework/Versions/A/PrintUITool
1 310 0.0 [U501] /usr/libexec/fmfd
1 311 0.0 [U501] /System/Library/CoreServices/sharedfilelistd
1 312 0.0 [U501] /usr/libexec/pkd
1 313 0.0 [U501] /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeaccountd
1 314 0.0 [U501] /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iCloudHelper.xpc/Contents/MacOS/com.apple.iCloudHelper
1 316 0.0 [U501] /usr/libexec/networkserviceproxy
1 317 0.0 [U501] /System/Library/CoreServices/APFSUserAgent
1 320 0.0 [U501] /System/Library/CoreServices/CoreLocationAgent.app/Contents/MacOS/CoreLocationAgent
1 321 0.0 [U501] /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
1 322 0.0 [U501] /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/Resources/familycircled
1 323 0.0 [U501] /System/Library/CoreServices/WiFiAgent.app/Contents/MacOS/WiFiAgent
1 324 0.0 [U501] /System/Library/PrivateFrameworks/CalendarNotification.framework/Versions/A/XPCServices/CalNCService.xpc/Contents/MacOS/CalNCService
1 325 0.0 [U501] /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/commerce
1 326 0.0 _fpsd /System/Library/PrivateFrameworks/CoreADI.framework/adid
1 327 0.0 root /System/Library/Frameworks/ApplicationServices.framework/Frameworks/PrintCore.framework/Versions/A/printtool daemon
1 329 0.0 [U501] /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/XPCServices/AssetCacheLocatorService.xpc/Contents/MacOS/AssetCacheLocatorService -a
1 330 0.0 [U501] /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Helpers/ProtectedCloudKeySyncing
1 331 0.0 [U501] /System/Library/Frameworks/ApplicationServices.framework/Frameworks/PrintCore.framework/Versions/A/printtool agent
1 333 0.0 [U501] /System/Library/PrivateFrameworks/CommunicationsFilter.framework/CMFSyncAgent
1 334 0.0 [U501] /System/Library/Frameworks/ColorSync.framework/Support/colorsync.useragent
1 337 0.0 [U501] /usr/libexec/swcd
1 338 0.0 [U501] /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/Support/assistantd
1 339 0.0 [U501] /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/Versions/A/Support/bird
1 342 0.0 root /usr/sbin/filecoordinationd
1 343 0.0 [U501] /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/XPCServices/ContainerMetadataExtractor.xpc/Contents/MacOS/ContainerMetadataExtractor
1 344 0.0 [U501] /System/Library/PrivateFrameworks/CacheDelete.framework/deleted
1 345 0.0 [U501] /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/XPCServices/media-indexer.xpc/Contents/MacOS/media-indexer
1 346 0.0 [U501] /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod
1 347 0.0 [U501] /System/Library/Frameworks/iTunesLibrary.framework/Versions/A/XPCServices/com.apple.iTunesLibraryService.xpc/Contents/MacOS/com.apple.iTunesLibraryService
1 352 0.0 [U501] /System/Library/CoreServices/SafariSupport.bundle/Contents/MacOS/SafariBookmarksSyncAgent
1 353 0.0 root /System/Library/CoreServices/iconservicesagent runAsRoot
1 354 0.0 [U501] /System/Library/CoreServices/pbs
1 355 0.0 [U501] /System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd
1 357 0.0 [U501] /System/Library/CoreServices/SocialPushAgent.app/Contents/MacOS/SocialPushAgent
1 359 0.0 [U501] /usr/libexec/dmd
1 360 0.0 [U501] /System/Library/Frameworks/InputMethodKit.framework/Resources/imklaunchagent
1 361 0.0 [U501] /System/Library/CoreServices/Siri.app/Contents/MacOS/Siri launchd
1 363 0.0 [U501] /System/Library/CoreServices/AirPlayUIAgent.app/Contents/MacOS/AirPlayUIAgent --launchd
1 364 0.0 [U501] /usr/libexec/knowledge-agent
1 365 0.0 [U501] /System/Library/CoreServices/cloudpaird
1 366 0.0 [U501] /System/Library/PrivateFrameworks/Noticeboard.framework/Versions/A/Resources/nbagent.app/Contents/MacOS/nbagent
1 367 0.0 [U501] /System/Library/CoreServices/diagnostics_agent
1 368 0.0 [U501] /usr/libexec/adprivacyd
1 370 0.0 [U501] /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
1 371 0.0 [U501] /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp
1 372 0.0 [U501] /System/Library/CoreServices/SystemUIServer.app/Contents/MacOS/SystemUIServer
1 373 0.0 [U501] /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
1 376 0.0 [U501] /System/Library/Frameworks/CryptoTokenKit.framework/ctkd -tw
1 382 0.0 [U501] /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Contents/MacOS/com.apple.dock.extra
1 387 0.0 [U501] /System/Library/CoreServices/Spotlight.app/Contents/MacOS/Spotlight
1 388 0.0 [U501] /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistoryPluginHelper
1 389 0.0 [U501] /System/Library/PrivateFrameworks/CoreParsec.framework/parsecd
1 390 0.0 [U501] /System/Library/PrivateFrameworks/CoreWLANKit.framework/Versions/A/XPCServices/WiFiProxy.xpc/Contents/MacOS/WiFiProxy
1 392 0.0 [U501] /usr/libexec/videosubscriptionsd
1 394 0.0 [U501] /System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdate_notify_agent
1 396 0.0 _softwareupdate /System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdated
1 397 0.0 root /System/Library/CoreServices/Software Update.app/Contents/Resources/suhelperd
1 398 0.0 [U501] SafeEjectGPUAgent
1 399 0.0 _atsserver /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support/fontd
1 400 0.0 [U501] /System/Library/CoreServices/Menu Extras/SafeEjectGPUExtra.menu/Contents/XPCServices/SafeEjectGPUService.xpc/Contents/MacOS/SafeEjectGPUService
1 408 0.0 [U501] /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storelegacy
1 415 0.0 [U501] /System/Library/CoreServices/CoreServicesUIAgent.app/Contents/MacOS/CoreServicesUIAgent
1 417 0.0 [U501] /System/Library/PrivateFrameworks/FileProvider.framework/Support/fileproviderd
1 421 0.3 [U501] /Applications/Safari.app/Contents/MacOS/Safari
1 422 0.0 [U501] /System/Library/PrivateFrameworks/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.History.xpc/Contents/MacOS/com.apple.Safari.History
1 424 0.0 [U501] /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
1 426 0.0 [U501] /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc/Contents/MacOS/com.apple.hiservices-xpcservice
1 429 0.0 [U501] /usr/libexec/SafariCloudHistoryPushAgent
1 431 0.1 [U501] /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
1 432 0.0 [U501] /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeassetd
1 433 0.0 root /usr/libexec/dmd
1 434 0.0 _spotlight /usr/libexec/trustd --agent
1 435 0.0 [U501] /System/Library/PrivateFrameworks/ContactsAgent.framework/Executables/ContactsAgent
1 438 0.0 [U501] /System/Library/PrivateFrameworks/CommerceKit.framework/Resources/LaterAgent.app/Contents/MacOS/LaterAgent
1 440 0.0 [U501] /System/Library/PrivateFrameworks/CloudServices.framework/Versions/A/XPCServices/com.apple.sbd.xpc/Contents/MacOS/com.apple.sbd
1 444 0.0 [U501] /System/Library/PrivateFrameworks/ClassKit.framework/Versions/A/progressd
1 445 0.0 [U501] /System/Library/PrivateFrameworks/HomeKitDaemon.framework/Support/homed
1 446 0.0 [U501] /System/Library/PrivateFrameworks/PassKitCore.framework/passd
1 447 0.0 [U501] /System/Library/CoreServices/Siri.app/Contents/XPCServices/SiriNCService.xpc/Contents/MacOS/SiriNCService
1 449 0.0 [U501] /System/Library/PrivateFrameworks/CoreFollowUp.framework/Versions/A/Support/followupd
1 453 0.0 _applepay /usr/libexec/nfcd
1 457 0.0 [U501] /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
1 458 0.0 [U501] /System/Library/PrivateFrameworks/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.SearchHelper.xpc/Contents/MacOS/com.apple.Safari.SearchHelper
1 459 0.0 [U501] /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/com.apple.Safari.SafeBrowsing.Service
1 464 0.0 root /usr/libexec/dprivacyd
1 465 0.0 [U501] /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
1 466 0.0 [U501] /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
1 467 0.0 [U501] /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMCompiler 2
1 470 0.0 [U501] /usr/libexec/keyboardservicesd
1 471 0.0 [U501] /System/Library/PrivateFrameworks/CoreSuggestions.framework/Versions/A/Support/suggestd
1 472 0.0 [U501] /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 474 0.0 [U501] /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 476 0.0 [U501] /System/Library/PrivateFrameworks/ContextKit.framework/Versions/A/XPCServices/ContextService.xpc/Contents/MacOS/ContextService
1 477 0.0 [U501] /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/corespotlightd
1 491 0.0 [U501] /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Support/fontworker
1 493 0.0 [U501] /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 494 0.0 [U501] /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 497 0.0 [U501] /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
1 498 0.0 [U501] /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/XPCServices/com.apple.accessibility.mediaaccessibilityd.xpc/Contents/MacOS/com.apple.accessibility.mediaaccessibilityd
1 500 0.0 [U501] /System/Library/Frameworks/AudioToolbox.framework/AudioComponentRegistrar
1 501 0.0 [U501] /System/Library/CoreServices/cloudphotosd.app/Contents/MacOS/cloudphotosd
1 502 0.0 [U501] /System/Library/PrivateFrameworks/AppStoreDaemon.framework/Support/appstoreagent
1 503 0.0 [U501] /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
1 504 0.0 [U501] /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 505 0.0 [U501] /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 508 0.0 [U501] /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
1 509 0.0 [U501] /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/Frameworks/CloudPhotosConfigurationXPC.framework/Versions/A/XPCServices/com.apple.CloudPhotosConfiguration.xpc/Contents/MacOS/com.apple.CloudPhotosConfiguration
1 512 0.0 [U501] /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storedownloadd
1 517 0.0 [U501] /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Support/photolibraryd
1 520 0.0 [U501] /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Frameworks/PhotoLibraryServices.framework/Versions/A/XPCServices/com.apple.photomoments.xpc/Contents/MacOS/com.apple.photomoments
1 521 0.0 [U501] /System/Library/CoreServices/ScopedBookmarkAgent
1 522 0.0 [U501] /System/Library/PrivateFrameworks/PhotoLibrary.framework/Versions/A/XPCServices/com.apple.PhotoIngestService.xpc/Contents/MacOS/com.apple.PhotoIngestService
1 523 0.0 [U501] /Applications/Safari.app/Contents/XPCServices/com.apple.Safari.SandboxBroker.xpc/Contents/MacOS/com.apple.Safari.SandboxBroker
1 524 0.0 [U501] /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdwrite
1 526 0.0 [U501] /System/Library/PrivateFrameworks/PhotoAnalysis.framework/Versions/A/Support/photoanalysisd
1 527 0.0 [U501] /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support/atsd
1 530 0.0 [U501] /System/Library/PrivateFrameworks/XprotectFramework.framework/Versions/A/XPCServices/XprotectService.xpc/Contents/MacOS/XprotectService
1 566 0.0 [U501] /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/Resources/helpd
1 568 0.0 [U501] /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Support/com.apple.quicklook.ThumbnailsAgent
1 569 0.0 root /usr/bin/sysdiagnose
1 570 0.0 root /System/Library/PrivateFrameworks/PackageKit.framework/Resources/system_installd
1 571 0.0 root /System/Library/PrivateFrameworks/PackageKit.framework/Resources/installd
1 576 0.0 [U501] /System/Library/Frameworks/MediaLibrary.framework/Versions/A/XPCServices/com.apple.MediaLibraryService.xpc/Contents/MacOS/com.apple.MediaLibraryService
1 578 0.0 [U501] /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
1 579 0.0 [U501] /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 580 0.0 [U501] /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 596 0.0 root /usr/libexec/amfid
1 639 0.0 root /System/Library/CoreServices/ReportCrash daemon
1 725 0.0 [U501] /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 726 0.0 [U501] /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 730 0.0 [U501] /System/Library/PrivateFrameworks/KerberosHelper/Helpers/DiskUnmountWatcher
1 757 0.0 [U501] /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 759 5.0 [U501] /Applications/DetectX Swift.app/Contents/MacOS/DetectX Swift
1 766 0.0 [U501] /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 767 0.0 [U501] /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 911 0.0 [U501] /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
1 925 0.0 root /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd
1 926 0.0 [U501] /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 927 0.0 [U501] /System/Library/PrivateFrameworks/SyncedDefaults.framework/Support/syncdefaultsd
1 929 0.0 [U501] /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 932 0.0 [U501] /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 986 0.0 root /usr/libexec/dpd
1 1001 0.0 root /usr/libexec/diskmanagementd
«»EOF»«
Il tuo Mac è teoricamente supportato...
La scheda grafica del mio iMac è una integrata (Intel Iris Pro 1536 MB)
Questo penso sia risolutivo...
Dovrebbe andare bene.
Per caso hai comprato questo iMac di seconda mano? Perché, guardando su https://everymac.com/systems/apple/imac ... specs.html , questa macchina del 2013 usciva di fabbrica con Mountain Lion installato, Yosemite fu disponibile in versione stabile solo dalla fine del 2014, più o meno. Resta pur sempre la possibilità che essendo uscito di produzione a ottobre 2015 si sia verificato il caso che il negozio dove lo hai preso abbia venduto una macchina prodotta nel 2013 con installato l'ultimo sistema disponibile al momento della vendita, cosa che è molto comune. Oppure, come dicevo, lo hai comprato di seconda mano ed era già stato aggiornato a Yosemite.
Visitano il forum: Google [Bot] e 52 ospiti
