paolosuperfast ha scritto: ↑lun, 01 apr 2019 12:35Qui c'è una soluzione possibile.
In inglese. Ma se volete vi traduco la pagina. È semplice, non serve il traduttore.
Make older programs compatible with this version of Windows
https://support.microsoft.com/en-us/hel ... compatible
Most programs created for earlier versions of Windows will work in this version of Windows, but some older programs might run poorly or not at all. Running the Program Compatibility Troubleshooter should automatically detect and fix some of the most common issues. If that doesn’t work, try changing the settings manually. The following table should help you figure out which setting to adjust.
Visitano il forum: Nessuno e 34 ospiti
