diskutil list
sudo systemsetup -liststartupdisks
sudo systemsetup -getstartupdisk
Hai scordato il pulsante "codice".Fritz1984 ha scritto: ↑mar, 19 feb 2019 13:02Spero di aver postato correttamente i risultati!!Codice: Seleziona tutto
diskutil list </dev/disk0 (internal, physical): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *1.0 TB disk0 1: EFI EFI 209.7 MB disk0s1 2: Apple_APFS Container disk1 1000.0 GB disk0s2 /dev/disk1 (synthesized): #: TYPE NAME SIZE IDENTIFIER 0: APFS Container Scheme - +1000.0 GB disk1 Physical Store disk0s2 1: APFS Volume Macintosh HD 736.3 GB disk1s1 2: APFS Volume Preboot 22.6 MB disk1s2 3: APFS Volume Recovery 513.9 MB disk1s3 4: APFS Volume VM 4.3 GB disk1s4 /dev/disk2 (external, physical): #: TYPE NAME SIZE IDENTIFIER 0: Apple_partition_scheme *1.0 TB disk2 1: Apple_partition_map 32.3 KB disk2s1 2: Apple_HFS Wd Elements 1.0 TB disk2s3 /dev/disk3 (external, physical): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *500.1 GB disk3 1: EFI EFI 209.7 MB disk3s1 2: Apple_APFS Container disk4 499.9 GB disk3s2 /dev/disk4 (synthesized): #: TYPE NAME SIZE IDENTIFIER 0: APFS Container Scheme - +499.9 GB disk4 Physical Store disk3s2 1: APFS Volume SSD Samsung 111.7 GB disk4s1 2: APFS Volume Preboot 24.4 MB disk4s2 3: APFS Volume Recovery 513.9 MB disk4s3 4: APFS Volume VM 4.3 GB disk4s4 /dev/disk5 (disk image): #: TYPE NAME SIZE IDENTIFIER 0: Apple_partition_scheme +24.3 MB disk5 1: Apple_partition_map 32.3 KB disk5s1 2: Apple_HFS Flash Player 24.2 MB disk5s2> sudo systemsetup -liststartupdisks </Volumes/com.apple.TimeMachine.localsnapshots/Backups.backupdb/iMac di Patty & Bat/2019-02-19-125535/Macintosh HD/System/Library/CoreServices /Volumes/SSD Samsung/System/Library/CoreServices /System/Library/CoreServices> sudo systemsetup -getstartupdisk </Volumes/SSD Samsung/System/Library/CoreServices>
sudo systemsetup -setstartupdisk /Volumes/SSD\ Samsung
diskutil info /Volumes/SSD\ Samsung | grep 'Volume UUID'
Setting startup disk not allowed while System Integrity Protection is enabled.
Sembrerebbe... Ma non me lo aspettavo.Fritz1984 ha scritto: ↑ven, 22 feb 2019 07:00...E' forse questo il problema?Codice: Seleziona tutto
csrutil disable; reboot
csrutil enable; reboot
