/Library/ScriptingAdditions:
Adobe Unit Types.osax
SASyphonInjector.osax
/Library/StartupItems:
/Library/Updates:
041-30526 / .. children: 3
index.plist
ProductMetadata.plist
zzzz041-30443 / .. children: 7
Top Processes:
%CPU PID COMMAND
9.3 761 firefox
8.5 772 plugin-container
5.4 150 WindowServer
4.3 1454 DetectX Swift
4.2 0 kernel_task
3.5 158 coreaudiod
3.2 762 plugin-container
0.9 287 accountsd
0.9 290 Little Snitch Ag
0.8 423 Little Snitch Ne
Running Processes:
PPID PID %CPU USER COMMAND
0 1 1.0 root /sbin/launchd
1 37 0.0 root /usr/libexec/UserEventAgent (System)
1 38 0.0 root /usr/sbin/syslogd
1 40 0.0 root /System/Library/PrivateFrameworks/Uninstall.framework/Resources/uninstalld
1 41 0.0 root /usr/libexec/kextd
1 42 0.0 root /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/Support/fseventsd
1 44 0.0 root /System/Library/PrivateFrameworks/MediaRemote.framework/Support/mediaremoted
1 45 0.0 root /Applications/EaseUS Data Recovery Wizard.app/Contents/MacOS/EaseUS Data Recovery Wizard.app/Contents/Resources/EUDataDaemon.app/Contents/MacOS/eudataback
1 48 0.0 _appleevents /System/Library/CoreServices/appleeventsd --server
1 49 0.3 root /usr/libexec/configd
1 50 0.0 root /System/Library/CoreServices/powerd.bundle/powerd
1 51 0.0 root /usr/libexec/mobileassetd
1 53 0.0 root /usr/libexec/firmwarecheckers/ethcheck/ethcheck --integrity-check-nonthunderbolt-daemon
1 54 0.0 root /Applications/TeamViewer.app/Contents/MacOS/TeamViewer_Service -Module Full
1 57 0.0 root /usr/libexec/logd
1 61 0.0 root /usr/libexec/airportd
1 63 0.0 root /usr/libexec/warmd
1 64 0.0 root /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Support/mds
1 69 0.0 _iconservices /System/Library/CoreServices/iconservicesd
1 70 0.0 root /System/Library/CoreServices/iconservicesagent
1 72 0.0 root /usr/libexec/diskarbitrationd
1 73 0.0 root /Library/Little Snitch/Little Snitch Daemon.bundle/Contents/_MASReceipt/Hooker
1 75 0.0 root /usr/libexec/coreduetd
1 76 0.0 root /usr/libexec/wdhelper
1 81 0.6 root /usr/libexec/opendirectoryd
1 82 0.0 root /usr/sbin/wirelessproxd
1 84 0.0 root /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
1 85 0.0 root /System/Library/PrivateFrameworks/Noticeboard.framework/Versions/A/Resources/nbstated
1 86 0.0 root /System/Library/CoreServices/launchservicesd
1 87 0.0 _usbmuxd /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/Resources/usbmuxd -launchd
1 88 0.0 root /usr/sbin/securityd -i
1 90 0.0 _locationd /usr/libexec/locationd
1 93 0.0 root /usr/libexec/DuetHeuristic-BM
1 94 0.0 _displaypolicyd /usr/libexec/displaypolicyd -k 1
1 95 0.0 root /usr/sbin/blued
1 96 0.0 root autofsd
1 100 0.0 root /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/Support/revisiond
1 101 0.0 visualdrome /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow console
1 102 0.0 root /System/Library/CoreServices/logind
1 103 0.0 root /usr/sbin/KernelEventAgent
1 105 0.0 _hidd /usr/libexec/hidd
1 106 0.0 root /usr/libexec/corebrightnessd --launchd
1 107 0.0 root /usr/libexec/AirPlayXPCHelper
1 108 0.7 root /usr/sbin/notifyd
1 109 0.0 _distnote /usr/sbin/distnoted daemon
1 110 0.0 root /usr/libexec/taskgated -s
1 111 0.0 root /usr/libexec/amfid
1 115 0.2 root /usr/sbin/cfprefsd daemon
1 116 0.1 root /System/Library/CoreServices/coreservicesd
1 117 0.0 root /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/MacOS/authd
1 122 0.0 root aslmanager
1 127 0.0 root /System/Library/Frameworks/PCSC.framework/Versions/A/XPCServices/com.apple.ctkpcscd.xpc/Contents/MacOS/com.apple.ctkpcscd
1 129 0.0 root /usr/libexec/trustd
1 131 0.0 _ctkd /System/Library/Frameworks/CryptoTokenKit.framework/ctkd -s
1 141 0.0 root /usr/libexec/sandboxd
1 150 5.3 _windowserver /System/Library/PrivateFrameworks/SkyLight.framework/Resources/WindowServer -daemon
1 151 0.0 _mdnsresponder /usr/sbin/mDNSResponder
1 153 0.0 root /usr/sbin/mDNSResponderHelper
1 158 3.4 _coreaudiod /usr/sbin/coreaudiod
1 159 0.0 root /usr/libexec/diskmanagementd
1 160 0.0 _coreaudiod /System/Library/Frameworks/CoreAudio.framework/Versions/A/XPCServices/com.apple.audio.DriverHelper.xpc/Contents/MacOS/com.apple.audio.DriverHelper
1 163 0.0 root /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Support/awdd
73 169 0.0 root /Library/Little Snitch/Little Snitch Daemon.bundle/Contents/MacOS/Little Snitch Daemon
1 170 0.0 root /usr/libexec/lsd runAsRoot
1 186 0.0 root /System/Library/PrivateFrameworks/AmbientDisplay.framework/Versions/A/XPCServices/com.apple.AmbientDisplayAgent.xpc/Contents/MacOS/com.apple.AmbientDisplayAgent
1 187 0.0 root /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mds_stores
1 191 0.0 root /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
1 198 0.0 root /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/com.apple.CodeSigningHelper.xpc/Contents/MacOS/com.apple.CodeSigningHelper
1 215 0.0 root /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp -d
1 216 0.0 root /usr/sbin/systemstats --xpc
1 217 0.0 root /usr/libexec/secinitd
1 218 0.0 root /System/Library/PrivateFrameworks/AccountPolicy.framework/XPCServices/com.apple.AccountPolicyHelper.xpc/Contents/MacOS/com.apple.AccountPolicyHelper
1 223 0.0 root /System/Library/Frameworks/GSS.framework/Helpers/com.apple.GSSCred
1 224 0.0 _networkd /usr/libexec/symptomsd
1 225 0.0 root /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/XPCServices/com.apple.PerformanceAnalysis.animationperfd.xpc/Contents/MacOS/com.apple.PerformanceAnalysis.animationperfd
1 227 0.0 root /System/Library/CoreServices/CrashReporterSupportHelper server-init
1 233 0.0 _nsurlstoraged /usr/libexec/nsurlstoraged
1 243 0.0 root /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd
1 244 0.0 root /usr/libexec/securityd_service
1 246 0.1 visualdrome /usr/sbin/cfprefsd agent
1 255 0.0 _nsurlsessiond /usr/libexec/nsurlsessiond --privileged
1 256 0.0 root /usr/sbin/ntpd -c /private/etc/ntp-restrict.conf -n -g -p /var/run/ntpd.pid -f /var/db/ntp.drift
1 257 0.0 root /usr/sbin/cupsd -l
1 258 0.0 root /usr/libexec/nehelper
1 259 0.0 root /usr/libexec/corestoraged
1 260 0.0 root /usr/libexec/thermald
1 261 0.0 root /usr/libexec/ApplicationFirewall/socketfilterfw
1 267 0.0 root /System/Library/PrivateFrameworks/CoreSymbolication.framework/coresymbolicationd
1 268 0.0 root sysmond
1 269 0.0 visualdrome /usr/libexec/UserEventAgent (Aqua)
1 271 0.2 visualdrome /usr/sbin/distnoted agent
1 273 0.0 visualdrome /System/Library/Frameworks/CoreTelephony.framework/Support/CommCenter -L
1 274 0.0 visualdrome /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
1 276 0.0 visualdrome /System/Library/CoreServices/SystemUIServer.app/Contents/MacOS/SystemUIServer
1 277 0.0 visualdrome /usr/libexec/trustd --agent
1 278 0.0 visualdrome /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
1 279 0.0 visualdrome /usr/libexec/secd
1 280 0.0 visualdrome /usr/libexec/lsd
1 281 0.0 visualdrome /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/Versions/A/Support/bird
1 283 0.0 visualdrome /System/Library/PrivateFrameworks/CacheDelete.framework/deleted
1 285 0.0 visualdrome /usr/libexec/pboard
1 287 3.2 visualdrome /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
1 288 0.0 visualdrome /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support/fontd
1 290 0.6 visualdrome /Library/Little Snitch/Little Snitch Agent.app/Contents/MacOS/Little Snitch Agent
1 292 0.0 visualdrome /System/Library/PrivateFrameworks/TelephonyUtilities.framework/callservicesd
1 293 0.0 visualdrome /System/Library/CoreServices/sharedfilelistd
1 294 0.0 visualdrome /System/Library/PrivateFrameworks/UserActivity.framework/Agents/useractivityd
1 295 0.0 visualdrome /usr/sbin/usernoted
1 296 0.0 visualdrome /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Contents/MacOS/com.apple.dock.extra
1 297 0.0 visualdrome /System/Library/CoreServices/iconservicesagent
1 298 0.0 visualdrome /usr/libexec/sharingd
1 299 0.0 root /usr/sbin/filecoordinationd
1 301 0.0 visualdrome /System/Library/PrivateFrameworks/IDS.framework/identityservicesd.app/Contents/MacOS/identityservicesd
1 302 0.0 visualdrome /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent
1 303 0.1 visualdrome /usr/libexec/nsurlstoraged
1 304 0.1 visualdrome /System/Library/PrivateFrameworks/TCC.framework/Resources/tccd
1 305 0.0 visualdrome /System/Library/PrivateFrameworks/IMDPersistence.framework/XPCServices/IMDPersistenceAgent.xpc/Contents/MacOS/IMDPersistenceAgent
1 307 0.0 visualdrome /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
1 308 0.0 visualdrome /System/Library/CoreServices/mapspushd
1 309 0.0 visualdrome /System/Library/CoreServices/SocialPushAgent.app/Contents/MacOS/SocialPushAgent
1 311 0.0 visualdrome /usr/libexec/secinitd
1 312 1.3 visualdrome /System/Library/Frameworks/AddressBook.framework/Executables/ContactsAccountsService
1 313 0.0 root /usr/sbin/WirelessRadioManagerd
1 314 0.0 root /System/Library/CoreServices/sharedfilelistd --enable-legacy-services
1 315 0.0 visualdrome /System/Library/CoreServices/AppleIDAuthAgent
1 316 0.0 visualdrome /usr/libexec/keyboardservicesd
1 317 0.0 visualdrome /System/Library/PrivateFrameworks/PassKitCore.framework/passd
1 318 0.0 visualdrome /usr/libexec/SafariCloudHistoryPushAgent
1 319 0.0 visualdrome /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistorySyncHelper
1 320 0.0 visualdrome /usr/libexec/fmfd
1 321 0.0 visualdrome /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd
1 322 0.0 visualdrome /System/Library/PrivateFrameworks/GameCenterFoundation.framework/Versions/A/gamed
1 324 0.0 visualdrome /System/Library/PrivateFrameworks/AskPermission.framework/Versions/A/Resources/askpermissiond
1 325 0.0 visualdrome /System/Library/CoreServices/SafariSupport.bundle/Contents/MacOS/SafariBookmarksSyncAgent
1 326 0.0 visualdrome /System/Library/PrivateFrameworks/MessagesKit.framework/Resources/soagent.app/Contents/MacOS/soagent
1 327 0.0 visualdrome /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistoryPluginHelper
1 328 0.0 visualdrome /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Support/cloudd
1 329 0.0 visualdrome /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iCloudHelper.xpc/Contents/MacOS/com.apple.iCloudHelper
1 330 0.0 visualdrome /usr/libexec/nsurlsessiond
1 331 0.0 visualdrome /System/Library/PrivateFrameworks/CalendarNotification.framework/Versions/A/XPCServices/CalNCService.xpc/Contents/MacOS/CalNCService
1 332 0.0 visualdrome /usr/libexec/pkd
1 333 0.0 visualdrome /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Support/com.apple.quicklook.ThumbnailsAgent
1 334 0.0 root /System/Library/CoreServices/backupd.bundle/Contents/Resources/TMCacheDelete
1 335 0.0 root /System/Library/PrivateFrameworks/PackageKit.framework/Resources/installd
1 336 0.0 visualdrome /System/Library/CoreServices/cloudphotosd.app/Contents/MacOS/cloudphotosd
1 337 0.0 visualdrome /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storedownloadd
1 338 0.0 visualdrome /System/Library/PrivateFrameworks/GeoServices.framework/geodMachServiceBridge
1 339 0.0 _assetcache /usr/libexec/AssetCache/AssetCache
1 340 0.0 root /System/Library/PrivateFrameworks/PackageKit.framework/Resources/system_installd
1 351 0.0 visualdrome /System/Library/CoreServices/Spotlight.app/Contents/MacOS/Spotlight
1 352 0.0 visualdrome /Users/visualdrome/Applications/Flux.app/Contents/MacOS/Flux
1 353 0.0 visualdrome /Applications/iTunes.app/Contents/MacOS/iTunesHelper.app/Contents/MacOS/iTunesHelper
1 354 0.4 visualdrome /Applications/Dropbox.app/Contents/MacOS/Dropbox
1 355 0.0 visualdrome /Applications/Backup and Sync.app/Contents/MacOS/Backup and Sync
1 356 0.0 visualdrome /Users/visualdrome/Library/Application Support/Google/Android File Transfer/Android File Transfer Agent.app/Contents/MacOS/Android File Transfer Agent
1 358 0.0 visualdrome /Applications/Dropbox.app/Contents/MacOS/Dropbox -type:crashpad-handler --monitor-self --monitor-self-argument=-type:crashpad-handler --monitor-self-annotation=product_name=desktop_crashpad --monitor-self-annotation=client_session_id=b02d91c0-78ec-4608-b30a-ecba64f72837 --monitor-self-annotation=buildno=Dropbox-mac-66.3.81 --no-upload-gzip --no-rate-limit --capture-python --no-identify-client-via-url --database=/Users/visualdrome/.dropbox/Crashpad --metrics-dir=0 --url=https://d.dropbox.com/report_crashpad_minidump --https-pin=0x23,0xf2,0xed,0xff,0x3e,0xde,0x90,0x25,0x9a,0x9e,0x30,0xf4,0xa,0xf8,0xf9,0x12,0xa5,0xe5,0xb3,0x69,0x4e,0x69,0x38,0x44,0x3,0x41,0xf6,0x6,0xe,0x1,0x4f,0xfa --https-pin=0xaf,0xf9,0x88,0x90,0x6d,0xde,0x12,0x95,0x5d,0x9b,0xeb,0xbf,0x92,0x8f,0xdc,0xc3,0x1c,0xce,0x32,0x8d,0x5b,0x93,0x84,0xf2,0x1c,0x89,0x41,0xca,0x26,0xe2,0x3,0x91 --https-pin=0x5a,0x88,0x96,0x47,0x22,0xe,0x54,0xd6,0xbd,0x8a,0x16,0x81,0x72,0x24,0x52,0xb,0xb5,0xc7,0x8e,0x58,0x98,0x4b,0xd5,0x70,0x50,0x63,0x88,0xb9,0xde,0xf,0x7,0x5f --https-pin=0xfe,0xa2,0xb7,0xd6,0x45,0xfb,0xa7,0x3d,0x75,0x3c,0x1e,0xc9,0xa7,0x87,0xc,0x40,0xe1,0xf7,0xb0,0xc5,0x61,0xe9,0x27,0xb9,0x85,0xbf,0x71,0x18,0x66,0xe3,0x6f,0x22 --https-pin=0x76,0xee,0x85,0x90,0x37,0x4c,0x71,0x54,0x37,0xbb,0xca,0x6b,0xba,0x60,0x28,0xea,0xdd,0xe2,0xdc,0x6d,0xbb,0xb8,0xc3,0xf6,0x10,0xe8,0x51,0xf1,0x1d,0x1a,0xb7,0xf5 --https-pin=0x6d,0xbf,0xae,0x0,0xd3,0x7b,0x9c,0xd7,0x3f,0x8f,0xb4,0x7d,0xe6,0x59,0x17,0xaf,0x0,0xe0,0xdd,0xdf,0x42,0xdb,0xce,0xac,0x20,0xc1,0x7c,0x2,0x75,0xee,0x20,0x95 --https-pin=0x1e,0xa3,0xc5,0xe4,0x3e,0xd6,0x6c,0x2d,0xa2,0x98,0x3a,0x42,0xa4,0xa7,0x9b,0x1e,0x90,0x67,0x86,0xce,0x9f,0x1b,0x58,0x62,0x14,0x19,0xa0,0x4,0x63,0xa8,0x7d,0x38 --https-pin=0x87,0xaf,0x34,0xd6,0x6f,0xb3,0xf2,0xfd,0xf3,0x6e,0x9,0x11,0x1e,0x9a,0xba,0x2f,0x6f,0x44,0xb2,0x7,0xf3,0x86,0x3f,0x3d,0xb,0x54,0xb2,0x50,0x23,0x90,0x9a,0xa5 --https-pin=0xbc,0xfb,0x44,0xaa,0xb9,0xad,0x2,0x10,0x15,0x70,0x6b,0x41,0x21,0xea,0x76,0x1c,0x81,0xc9,0xe8,0x89,0x67,0x59,0xf,0x6f,0x94,0xae,0x74,0x4d,0xc8,0x8b,0x78,0xfb --https-pin=0xab,0x98,0x49,0x52,0x76,0xad,0xf1,0xec,0xaf,0xf2,0x8f,0x35,0xc5,0x30,0x48,0x78,0x1e,0x5c,0x17,0x18,0xda,0xb9,0xc8,0xe6,0x7a,0x50,0x4f,0x4f,0x6a,0x51,0x32,0x8f --https-pin=0x49,0x5,0x46,0x66,0x23,0xab,0x41,0x78,0xbe,0x92,0xac,0x5c,0xbd,0x65,0x84,0xf7,0xa1,0xe1,0x7f,0x27,0x65,0x2d,0x5a,0x85,0xaf,0x89,0x50,0x4e,0xa2,0x39,0xaa,0xaa --https-pin=0x56,0x32,0xd9,0x7b,0xfa,0x77,0x5b,0xf3,0xc9,0x9d,0xde,0xa5,0x2f,0xc2,0x55,0x34,0x10,0x86,0x40,0x16,0x72,0x9c,0x52,0xdd,0x65,0x24,0xc8,0xa9,0xc3,0xb4,0x48,0x9f --https-pin=0x2a,0x8f,0x2d,0x8a,0xf0,0xeb,0x12,0x38,0x98,0xf7,0x4c,0x86,0x6a,0xc3,0xfa,0x66,0x90,0x54,0xe2,0x3c,0x17,0xbc,0x7a,0x95,0xbd,0x2,0x34,0x19,0x2d,0xc6,0x35,0xd0 --https-pin=0x32,0xb6,0x4b,0x66,0x72,0x7a,0x20,0x63,0xe4,0x6,0x6f,0x3b,0x95,0x8c,0xb0,0xaa,0xee,0x57,0x6a,0x5e,0xce,0xfd,0x95,0x33,0x99,0xbb,0x88,0x74,0x73,0x1d,0x95,0x87 --https-pin=0xf5,0x3c,0x22,0x5,0x98,0x17,0xdd,0x96,0xf4,0x0,0x65,0x16,0x39,0xd2,0xf8,0x57,0xe2,0x10,0x70,0xa5,0x9a,0xbe,0xd9,0x7,0x94,0x0,0xd9,0xf6,0x95,0x50,0x69,0x0 --https-pin=0x67,0xdc,0x4f,0x32,0xfa,0x10,0xe7,0xd0,0x1a,0x79,0xa0,0x73,0xaa,0xc,0x9e,0x2,0x12,0xec,0x2f,0xfc,0x3d,0x77,0x9e,0xa,0xa7,0xf9,0xc0,0xf0,0xe1,0xc2,0xc8,0x93 --https-pin=0x19,0x6,0xc6,0x12,0x4d,0xbb,0x43,0x85,0x78,0xd0,0xe,0x6,0x6d,0x50,0x54,0xc6,0xc3,0x7f,0xf,0xa6,0x2,0x8c,0x5,0x54,0x5e,0x9,0x94,0xed,0xda,0xec,0x86,0x29 --https-pin=0x1d,0x75,0xd0,0x83,0x1b,0x9e,0x8,0x85,0x39,0x4d,0x32,0xc7,0xa1,0xbf,0xdb,0x3d,0xbc,0x1c,0x28,0xe2,0xb0,0xe8,0x39,0x1f,0xb1,0x35,0x98,0x1d,0xbc,0x5b,0xa9,0x36 --annotation=host_int_account1_boot=33017707664 --annotation=machine_id=ac995d0c-2877-5527-aee4-a346ebd4e6be --annotation=platform=mac --annotation=platform_version=10.12.6 --handshake-fd=4
1 360 0.0 visualdrome /Applications/Dropbox.app/Contents/MacOS/Dropbox -type:crashpad-handler --no-identify-client-via-url --no-periodic-tasks --no-rate-limit --no-upload-gzip --monitor-self-annotation=buildno=Dropbox-mac-66.3.81 --monitor-self-annotation=client_session_id=b02d91c0-78ec-4608-b30a-ecba64f72837 --monitor-self-annotation=product_name=desktop_crashpad --database=/Users/visualdrome/.dropbox/Crashpad --url=https://d.dropbox.com/report_crashpad_minidump --https-pin=0x23,0xf2,0xed,0xff,0x3e,0xde,0x90,0x25,0x9a,0x9e,0x30,0xf4,0xa,0xf8,0xf9,0x12,0xa5,0xe5,0xb3,0x69,0x4e,0x69,0x38,0x44,0x3,0x41,0xf6,0x6,0xe,0x1,0x4f,0xfa --https-pin=0xaf,0xf9,0x88,0x90,0x6d,0xde,0x12,0x95,0x5d,0x9b,0xeb,0xbf,0x92,0x8f,0xdc,0xc3,0x1c,0xce,0x32,0x8d,0x5b,0x93,0x84,0xf2,0x1c,0x89,0x41,0xca,0x26,0xe2,0x3,0x91 --https-pin=0x5a,0x88,0x96,0x47,0x22,0xe,0x54,0xd6,0xbd,0x8a,0x16,0x81,0x72,0x24,0x52,0xb,0xb5,0xc7,0x8e,0x58,0x98,0x4b,0xd5,0x70,0x50,0x63,0x88,0xb9,0xde,0xf,0x7,0x5f --https-pin=0xfe,0xa2,0xb7,0xd6,0x45,0xfb,0xa7,0x3d,0x75,0x3c,0x1e,0xc9,0xa7,0x87,0xc,0x40,0xe1,0xf7,0xb0,0xc5,0x61,0xe9,0x27,0xb9,0x85,0xbf,0x71,0x18,0x66,0xe3,0x6f,0x22 --https-pin=0x76,0xee,0x85,0x90,0x37,0x4c,0x71,0x54,0x37,0xbb,0xca,0x6b,0xba,0x60,0x28,0xea,0xdd,0xe2,0xdc,0x6d,0xbb,0xb8,0xc3,0xf6,0x10,0xe8,0x51,0xf1,0x1d,0x1a,0xb7,0xf5 --https-pin=0x6d,0xbf,0xae,0x0,0xd3,0x7b,0x9c,0xd7,0x3f,0x8f,0xb4,0x7d,0xe6,0x59,0x17,0xaf,0x0,0xe0,0xdd,0xdf,0x42,0xdb,0xce,0xac,0x20,0xc1,0x7c,0x2,0x75,0xee,0x20,0x95 --https-pin=0x1e,0xa3,0xc5,0xe4,0x3e,0xd6,0x6c,0x2d,0xa2,0x98,0x3a,0x42,0xa4,0xa7,0x9b,0x1e,0x90,0x67,0x86,0xce,0x9f,0x1b,0x58,0x62,0x14,0x19,0xa0,0x4,0x63,0xa8,0x7d,0x38 --https-pin=0x87,0xaf,0x34,0xd6,0x6f,0xb3,0xf2,0xfd,0xf3,0x6e,0x9,0x11,0x1e,0x9a,0xba,0x2f,0x6f,0x44,0xb2,0x7,0xf3,0x86,0x3f,0x3d,0xb,0x54,0xb2,0x50,0x23,0x90,0x9a,0xa5 --https-pin=0xbc,0xfb,0x44,0xaa,0xb9,0xad,0x2,0x10,0x15,0x70,0x6b,0x41,0x21,0xea,0x76,0x1c,0x81,0xc9,0xe8,0x89,0x67,0x59,0xf,0x6f,0x94,0xae,0x74,0x4d,0xc8,0x8b,0x78,0xfb --https-pin=0xab,0x98,0x49,0x52,0x76,0xad,0xf1,0xec,0xaf,0xf2,0x8f,0x35,0xc5,0x30,0x48,0x78,0x1e,0x5c,0x17,0x18,0xda,0xb9,0xc8,0xe6,0x7a,0x50,0x4f,0x4f,0x6a,0x51,0x32,0x8f --https-pin=0x49,0x5,0x46,0x66,0x23,0xab,0x41,0x78,0xbe,0x92,0xac,0x5c,0xbd,0x65,0x84,0xf7,0xa1,0xe1,0x7f,0x27,0x65,0x2d,0x5a,0x85,0xaf,0x89,0x50,0x4e,0xa2,0x39,0xaa,0xaa --https-pin=0x56,0x32,0xd9,0x7b,0xfa,0x77,0x5b,0xf3,0xc9,0x9d,0xde,0xa5,0x2f,0xc2,0x55,0x34,0x10,0x86,0x40,0x16,0x72,0x9c,0x52,0xdd,0x65,0x24,0xc8,0xa9,0xc3,0xb4,0x48,0x9f --https-pin=0x2a,0x8f,0x2d,0x8a,0xf0,0xeb,0x12,0x38,0x98,0xf7,0x4c,0x86,0x6a,0xc3,0xfa,0x66,0x90,0x54,0xe2,0x3c,0x17,0xbc,0x7a,0x95,0xbd,0x2,0x34,0x19,0x2d,0xc6,0x35,0xd0 --https-pin=0x32,0xb6,0x4b,0x66,0x72,0x7a,0x20,0x63,0xe4,0x6,0x6f,0x3b,0x95,0x8c,0xb0,0xaa,0xee,0x57,0x6a,0x5e,0xce,0xfd,0x95,0x33,0x99,0xbb,0x88,0x74,0x73,0x1d,0x95,0x87 --https-pin=0xf5,0x3c,0x22,0x5,0x98,0x17,0xdd,0x96,0xf4,0x0,0x65,0x16,0x39,0xd2,0xf8,0x57,0xe2,0x10,0x70,0xa5,0x9a,0xbe,0xd9,0x7,0x94,0x0,0xd9,0xf6,0x95,0x50,0x69,0x0 --https-pin=0x67,0xdc,0x4f,0x32,0xfa,0x10,0xe7,0xd0,0x1a,0x79,0xa0,0x73,0xaa,0xc,0x9e,0x2,0x12,0xec,0x2f,0xfc,0x3d,0x77,0x9e,0xa,0xa7,0xf9,0xc0,0xf0,0xe1,0xc2,0xc8,0x93 --https-pin=0x19,0x6,0xc6,0x12,0x4d,0xbb,0x43,0x85,0x78,0xd0,0xe,0x6,0x6d,0x50,0x54,0xc6,0xc3,0x7f,0xf,0xa6,0x2,0x8c,0x5,0x54,0x5e,0x9,0x94,0xed,0xda,0xec,0x86,0x29 --https-pin=0x1d,0x75,0xd0,0x83,0x1b,0x9e,0x8,0x85,0x39,0x4d,0x32,0xc7,0xa1,0xbf,0xdb,0x3d,0xbc,0x1c,0x28,0xe2,0xb0,0xe8,0x39,0x1f,0xb1,0x35,0x98,0x1d,0xbc,0x5b,0xa9,0x36 --annotation=host_int_account1_boot=33017707664 --annotation=machine_id=ac995d0c-2877-5527-aee4-a346ebd4e6be --annotation=platform=mac --annotation=platform_version=10.12.6 --handshake-fd=5
354 361 0.0 visualdrome /Applications/Dropbox.app/Contents/MacOS/Dropbox -type:exit-monitor -method:collectupload -python-version:3.6.7 -session-token:b02d91c0-78ec-4608-b30a-ecba64f72837 -target-handle:354 -target-shutdown-event:4 -target-restart-event:6 -target-command-line:/Applications/Dropbox.app/Contents/MacOS/Dropbox
1 362 0.0 visualdrome /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/Frameworks/CloudPhotosConfigurationXPC.framework/Versions/A/XPCServices/com.apple.CloudPhotosConfiguration.xpc/Contents/MacOS/com.apple.CloudPhotosConfiguration
1 363 0.0 visualdrome /Applications/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon
1 364 0.0 visualdrome /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp
1 365 0.0 visualdrome /System/Library/PrivateFrameworks/CoreParsec.framework/parsecd
1 366 0.0 visualdrome /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd
1 367 0.0 root /usr/libexec/findmydeviced
1 368 0.0 visualdrome /System/Library/Frameworks/CryptoTokenKit.framework/ctkd -tw
1 371 0.0 visualdrome /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod
1 372 0.0 visualdrome /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeaccountd
1 373 0.0 visualdrome /usr/libexec/networkserviceproxy
1 374 0.0 visualdrome /System/Library/CoreServices/CoreLocationAgent.app/Contents/MacOS/CoreLocationAgent
1 375 0.0 visualdrome /System/Library/PrivateFrameworks/CoreWLANKit.framework/Versions/A/XPCServices/WiFiProxy.xpc/Contents/MacOS/WiFiProxy
1 376 0.0 visualdrome /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeassetd
1 377 0.0 visualdrome /System/Library/Frameworks/InputMethodKit.framework/Resources/imklaunchagent
1 378 0.0 visualdrome /System/Library/CoreServices/pbs
1 380 0.0 visualdrome /System/Library/Input Methods/PressAndHold.app/Contents/PlugIns/PAH_Extension.appex/Contents/MacOS/PAH_Extension
1 382 0.0 visualdrome /Library/Application Support/SIMBL/SIMBLAgent.app/Contents/MacOS/SIMBLAgent
1 383 0.0 visualdrome /System/Library/PrivateFrameworks/AssistantServices.framework/assistantd
1 384 0.0 visualdrome /System/Library/CoreServices/FolderActionsDispatcher.app/Contents/MacOS/FolderActionsDispatcher
1 386 0.0 visualdrome /Library/Little Snitch/Little Snitch Helper.app/Contents/MacOS/Little Snitch Helper
1 387 0.0 visualdrome /usr/libexec/spindump_agent
1 392 0.0 visualdrome /Applications/TeamViewer.app/Contents/MacOS/TeamViewer -RunAsAgent YES
1 393 0.0 visualdrome /System/Library/CoreServices/NotificationCenter.app/Contents/MacOS/NotificationCenter
1 395 0.0 visualdrome /System/Library/Image Capture/Support/icdd
1 396 0.0 visualdrome /Applications/TeamViewer.app/Contents/Helpers/TeamViewer_Desktop -RunAsAgent YES -Module Full
1 399 0.0 visualdrome /System/Library/CoreServices/PowerChime.app/Contents/MacOS/PowerChime
1 400 0.0 visualdrome /Library/Application Support/Paragon Software/com.paragon-software.ntfs.notification-agent.app/Contents/MacOS/NotificationAgent
1 401 0.0 visualdrome /System/Library/CoreServices/AirPlayUIAgent.app/Contents/MacOS/AirPlayUIAgent --launchd
1 402 0.0 visualdrome /System/Library/CoreServices/cloudpaird
1 403 0.0 visualdrome /System/Library/PrivateFrameworks/Noticeboard.framework/Versions/A/Resources/nbagent.app/Contents/MacOS/nbagent
1 405 0.0 visualdrome /System/Library/CoreServices/WiFiAgent.app/Contents/MacOS/WiFiAgent
1 406 0.0 visualdrome /System/Library/CoreServices/diagnostics_agent
1 411 0.0 root /System/Library/PrivateFrameworks/TCC.framework/Resources/tccd system
1 414 0.0 root /usr/sbin/systemsoundserverd
1 415 0.0 root /Library/Application Support/Paragon Software/com.paragon-software.ntfsd
1 416 0.0 root /Library/PrivilegedHelperTools/com.paragon-software.installer
1 417 0.0 visualdrome /System/Library/CoreServices/NotificationCenter.app/Contents/XPCServices/com.apple.notificationcenterui.WeatherSummary.xpc/Contents/MacOS/com.apple.notificationcenterui.WeatherSummary
1 418 0.0 root /usr/libexec/watchdogd
1 423 0.3 visualdrome /Library/Little Snitch/Little Snitch Network Monitor.app/Contents/MacOS/Little Snitch Network Monitor -psn_0_159783
1 428 0.0 visualdrome /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/XPCServices/ViewBridgeAuxiliary.xpc/Contents/MacOS/ViewBridgeAuxiliary
1 430 0.0 visualdrome /System/Library/Frameworks/Security.framework/Versions/A/Resources/KeychainSyncingOverIDSProxy.bundle/Contents/MacOS/KeychainSyncingOverIDSProxy
1 431 0.0 visualdrome /System/Library/Frameworks/Security.framework/Versions/A/Resources/CloudKeychainProxy.bundle/Contents/MacOS/CloudKeychainProxy
1 433 0.0 _captiveagent /usr/libexec/captiveagent
1 444 0.0 visualdrome /System/Library/PrivateFrameworks/CoreSuggestions.framework/Versions/A/Support/suggestd
1 445 0.0 visualdrome /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Support/photolibraryd
1 447 0.0 _gamecontrollerd /usr/libexec/gamecontrollerd
1 448 0.0 visualdrome /usr/libexec/videosubscriptionsd
354 455 0.0 visualdrome /Applications/Dropbox.app/Contents/Frameworks/Tungsten.framework/Versions/A/Frameworks/Dropbox Web Helper.app/Contents/MacOS/Dropbox Web Helper --type=renderer --disable-breakpad --disable-databases --primordial-pipe-token=86B0B269EAD4EAB5B6E4F2CEDA85A7D0 --lang=en-US --framework-dir-path=/Applications/Dropbox.app/Contents/Frameworks/Tungsten.framework/Versions/A/Frameworks/Chromium Embedded Framework.framework --lang=en-US --log-file=/Users/visualdrome/Library/Logs/Dropbox_debug.log --log-severity=warning --product-version=Tungsten/0.1.68 --suffix-user-agent=ShangriLa/66.3.81 --uncaught-exception-stack-size=16 --tungsten-schemes=dbx-local --enable-pinch --num-raster-threads=2 --enable-zero-copy --enable-gpu-memory-buffer-compositor-resources --enable-main-frame-before-activation --content-image-texture-target=0,0,3553;0,1,3553;0,2,3553;0,3,3553;0,4,3553;0,5,3553;0,6,3553;0,7,3553;0,8,3553;0,9,3553;0,10,34037;0,11,34037;0,12,34037;0,13,3553;0,14,3553;0,15,3553;0,16,3553;1,0,3553;1,1,3553;1,2,3553;1,3,3553;1,4,3553;1,5,3553;1,6,3553;1,7,3553;1,8,3553;1,9,3553;1,10,34037;1,11,34037;1,12,34037;1,13,3553;1,14,3553;1,15,3553;1,16,3553;2,0,3553;2,1,3553;2,2,3553;2,3,3553;2,4,3553;2,5,3553;2,6,3553;2,7,3553;2,8,3553;2,9,3553;2,10,34037;2,11,34037;2,12,34037;2,13,3553;2,14,3553;2,15,3553;2,16,3553;3,0,3553;3,1,3553;3,2,3553;3,3,3553;3,4,3553;3,5,34037;3,6,3553;3,7,3553;3,8,3553;3,9,3553;3,10,3553;3,11,3553;3,12,34037;3,13,34037;3,14,3553;3,15,34037;3,16,34037;4,0,3553;4,1,3553;4,2,3553;4,3,3553;4,4,3553;4,5,34037;4,6,3553;4,7,3553;4,8,3553;4,9,3553;4,10,3553;4,11,3553;4,12,34037;4,13,34037;4,14,3553;4,15,34037;4,16,34037 --service-request-channel-token=86B0B269EAD4EAB5B6E4F2CEDA85A7D0 --renderer-client-id=2
354 458 0.0 visualdrome /Applications/Dropbox.app/Contents/Frameworks/Tungsten.framework/Versions/A/Frameworks/Dropbox Web Helper.app/Contents/MacOS/Dropbox Web Helper --type=gpu-process --disable-breakpad --framework-dir-path=/Applications/Dropbox.app/Contents/Frameworks/Tungsten.framework/Versions/A/Frameworks/Chromium Embedded Framework.framework --lang=en-US --log-file=/Users/visualdrome/Library/Logs/Dropbox_debug.log --log-severity=warning --product-version=Tungsten/0.1.68 --suffix-user-agent=ShangriLa/66.3.81 --tungsten-schemes=dbx-local --supports-dual-gpus=false --gpu-driver-bug-workarounds=0,1,10,24,27,38,41,49,55,63,65,66,67,68,75,76,78,86,87,88,91,94 --disable-gl-extensions=GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent --gpu-vendor-id=0x8086 --gpu-device-id=0x5926 --gpu-driver-vendor --gpu-driver-version --gpu-driver-date --gpu-active-vendor-id=0x8086 --gpu-active-device-id=0x5926 --framework-dir-path=/Applications/Dropbox.app/Contents/Frameworks/Tungsten.framework/Versions/A/Frameworks/Chromium Embedded Framework.framework --lang=en-US --log-file=/Users/visualdrome/Library/Logs/Dropbox_debug.log --log-severity=warning --product-version=Tungsten/0.1.68 --suffix-user-agent=ShangriLa/66.3.81 --tungsten-schemes=dbx-local --service-request-channel-token=CA6DB4FAC54D7387BF5E44DF04295218
1 459 0.0 visualdrome /System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdate_notify_agent
1 460 0.0 _softwareupdate /System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdated
1 461 0.0 visualdrome /System/Library/Frameworks/VideoToolbox.framework/Versions/A/XPCServices/VTDecoderXPCService.xpc/Contents/MacOS/VTDecoderXPCService
1 462 0.0 root /System/Library/PrivateFrameworks/SoftwareUpdate.framework/Resources/suhelperd
1 464 0.0 visualdrome /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storelegacy
257 466 0.0 _lp Kyocera_Kyocera_TASKalfa_3511i__KPDL_ 10 visualdrome Amazon.it - Centro resi 1 AP_ColorMatchingMode=AP_ApplicationColorMatching AP_D_InputSlot= noBookletBinding..b. BookletType..n.=0 collate ColorModel=Gray com.apple.print.DocumentTicket.PMSpoolFormat=application/pdf com.apple.print.JobInfo.PMApplicationName=Firefox com.apple.print.JobInfo.PMJobName=Amazon.it\ -\ Centro\ resi com.apple.print.JobInfo.PMJobOwner=Fabrizio\ De\ Bartolomei com.apple.print.PageToPaperMappingMediaName=A4 com.apple.print.PageToPaperMappingType..n.=1 com.apple.print.preset.Orientation..n.=1 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PageFormat.PMAdjustedPageRect..a.0..n.=0 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PageFormat.PMAdjustedPageRect..a.1..n.=0 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PageFormat.PMAdjustedPageRect..a.2..n.=821.877197265625 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PageFormat.PMAdjustedPageRect..a.3..n.=571.29437351226807 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PageFormat.PMAdjustedPaperRect..a.0..n.=-10.00628662109375 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PageFormat.PMAdjustedPaperRect..a.1..n.=-11.990599632263184 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PageFormat.PMAdjustedPaperRect..a.2..n.=831.88348388671875 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PageFormat.PMAdjustedPaperRect..a.3..n.=583.28497409820557 nocom.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PaperInfo.PMCustomPaper..b. com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PaperInfo.PMPaperName=iso-a4 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PaperInfo.PMUnadjustedPageRect..a.0..n.=0 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PaperInfo.PMUnadjustedPageRect..a.1..n.=0 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PaperInfo.PMUnadjustedPageRect..a.2..n.=821.877197265625 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PaperInfo.PMUnadjustedPageRect..a.3..n.=571.29437351226807 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PaperInfo.PMUnadjustedPaperRect..a.0..n.=-10.00628662109375 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PaperInfo.PMUnadjustedPaperRect..a.1..n.=-11.990599632263184 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PaperInfo.PMUnadjustedPaperRect..a.2..n.=831.88348388671875 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PaperInfo.PMUnadjustedPaperRect..a.3..n.=583.28497409820557 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PaperInfo.ppd.PMPaperName=A4 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.ticket.type=com.apple.print.PaperInfoTicket com.apple.print.preset.PaperInfo..d.paperInfo..d.PMPPDPaperCodeName=A4 com.apple.print.preset.PaperInfo..d.paperInfo..d.PMPPDTranslationStringPaperName=A4 com.apple.print.preset.PaperInfo..d.paperInfo..d.PMTiogaPaperName=iso-a4 com.apple.print.preset.Scaling..n.=100 com.apple.print.PrinterInfo.PMColorDeviceID..n.=59500 com.apple.print.PrintSettings.PMColorSpaceModel..n.=1 com.apple.print.PrintSettings.PMCopies..n.=1 com.apple.print.PrintSettings.PMCopyCollate..b. com.apple.print.PrintSettings.PMDestinationType..n.=1 com.apple.print.PrintSettings.PMDuplexing..n.=2 com.apple.print.PrintSettings.PMFirstPage..n.=1 com.apple.print.PrintSettings.PMLastPage..n.=2147483647 com.apple.print.PrintSettings.PMPageRange..a.0..n.=1 com.apple.print.PrintSettings.PMPageRange..a.1..n.=2147483647 nocom.apple.print.PrintSettings.PMPrintSelectionOnly..b. DestinationPrinterID=Kyocera_Kyocera_TASKalfa_3511i__KPDL_ DuplexBindingEdge..n.=2 media=A4 PaperInfoIsSuggested..b. pserrorhandler-requested=standard sides=two-sided-long-edge job-uuid=urn:uuid:439258bc-0276-3345-5941-1228b29d6182 job-originating-host-name=localhost date-time-at-creation= date-time-at-processing= time-at-creation=1548230627 time-at-processing=1549176468 document-name-supplied=Amazon.it\ -\ Centro\ resi job-impressions=4 com.apple.print.PrintSettings.PMTotalSidesImaged..n.=4 com.apple.print.PrintSettings.PMTotalBeginPages..n.=4 Duplex=DuplexNoTumble PageSize=A4 /private/var/spool/cups/d00010-001
257 467 0.0 root dnssd://Kyocera%20Kyocera%20TASKalfa%203511i%20(KPDL)%20%40%20manzetti-P5QL-E-4._ipps._tcp.local./?uuid=539d6192-aca1-311f-55df-c68898023d08 10 visualdrome Amazon.it - Centro resi 1 AP_ColorMatchingMode=AP_ApplicationColorMatching AP_D_InputSlot= noBookletBinding..b. BookletType..n.=0 collate ColorModel=Gray com.apple.print.DocumentTicket.PMSpoolFormat=application/pdf com.apple.print.JobInfo.PMApplicationName=Firefox com.apple.print.JobInfo.PMJobName=Amazon.it\ -\ Centro\ resi com.apple.print.JobInfo.PMJobOwner=Fabrizio\ De\ Bartolomei com.apple.print.PageToPaperMappingMediaName=A4 com.apple.print.PageToPaperMappingType..n.=1 com.apple.print.preset.Orientation..n.=1 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PageFormat.PMAdjustedPageRect..a.0..n.=0 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PageFormat.PMAdjustedPageRect..a.1..n.=0 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PageFormat.PMAdjustedPageRect..a.2..n.=821.877197265625 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PageFormat.PMAdjustedPageRect..a.3..n.=571.29437351226807 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PageFormat.PMAdjustedPaperRect..a.0..n.=-10.00628662109375 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PageFormat.PMAdjustedPaperRect..a.1..n.=-11.990599632263184 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PageFormat.PMAdjustedPaperRect..a.2..n.=831.88348388671875 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PageFormat.PMAdjustedPaperRect..a.3..n.=583.28497409820557 nocom.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PaperInfo.PMCustomPaper..b. com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PaperInfo.PMPaperName=iso-a4 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PaperInfo.PMUnadjustedPageRect..a.0..n.=0 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PaperInfo.PMUnadjustedPageRect..a.1..n.=0 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PaperInfo.PMUnadjustedPageRect..a.2..n.=821.877197265625 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PaperInfo.PMUnadjustedPageRect..a.3..n.=571.29437351226807 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PaperInfo.PMUnadjustedPaperRect..a.0..n.=-10.00628662109375 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PaperInfo.PMUnadjustedPaperRect..a.1..n.=-11.990599632263184 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PaperInfo.PMUnadjustedPaperRect..a.2..n.=831.88348388671875 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PaperInfo.PMUnadjustedPaperRect..a.3..n.=583.28497409820557 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.PaperInfo.ppd.PMPaperName=A4 com.apple.print.preset.PaperInfo..d.paperInfo..d.com.apple.print.ticket.type=com.apple.print.PaperInfoTicket com.apple.print.preset.PaperInfo..d.paperInfo..d.PMPPDPaperCodeName=A4 com.apple.print.preset.PaperInfo..d.paperInfo..d.PMPPDTranslationStringPaperName=A4 com.apple.print.preset.PaperInfo..d.paperInfo..d.PMTiogaPaperName=iso-a4 com.apple.print.preset.Scaling..n.=100 com.apple.print.PrinterInfo.PMColorDeviceID..n.=59500 com.apple.print.PrintSettings.PMColorSpaceModel..n.=1 com.apple.print.PrintSettings.PMCopies..n.=1 com.apple.print.PrintSettings.PMCopyCollate..b. com.apple.print.PrintSettings.PMDestinationType..n.=1 com.apple.print.PrintSettings.PMDuplexing..n.=2 com.apple.print.PrintSettings.PMFirstPage..n.=1 com.apple.print.PrintSettings.PMLastPage..n.=2147483647 com.apple.print.PrintSettings.PMPageRange..a.0..n.=1 com.apple.print.PrintSettings.PMPageRange..a.1..n.=2147483647 nocom.apple.print.PrintSettings.PMPrintSelectionOnly..b. DestinationPrinterID=Kyocera_Kyocera_TASKalfa_3511i__KPDL_ DuplexBindingEdge..n.=2 media=A4 PaperInfoIsSuggested..b. pserrorhandler-requested=standard sides=two-sided-long-edge job-uuid=urn:uuid:439258bc-0276-3345-5941-1228b29d6182 job-originating-host-name=localhost date-time-at-creation= date-time-at-processing= time-at-creation=1548230627 time-at-processing=1549176468 document-name-supplied=Amazon.it\ -\ Centro\ resi job-impressions=4 com.apple.print.PrintSettings.PMTotalSidesImaged..n.=4 com.apple.print.PrintSettings.PMTotalBeginPages..n.=4 Duplex=DuplexNoTumble PageSize=A4
1 470 0.0 visualdrome /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/XPCServices/com.apple.CommerceKit.TransactionService.xpc/Contents/MacOS/com.apple.CommerceKit.TransactionService
1 485 0.0 visualdrome /System/Library/PrivateFrameworks/ContactsAgent.framework/Executables/ContactsAgent
1 490 0.0 visualdrome /Applications/Dropbox.app/Contents/XPCServices/DropboxActivityProvider.xpc/Contents/MacOS/DropboxActivityProvider
354 493 0.0 visualdrome /Applications/Dropbox.app/Contents/Frameworks/Tungsten.framework/Versions/A/Frameworks/Dropbox Web Helper.app/Contents/MacOS/Dropbox Web Helper --type=renderer --disable-breakpad --disable-databases --primordial-pipe-token=691A14C6676715713B052C5EF36735DC --lang=en-US --framework-dir-path=/Applications/Dropbox.app/Contents/Frameworks/Tungsten.framework/Versions/A/Frameworks/Chromium Embedded Framework.framework --lang=en-US --log-file=/Users/visualdrome/Library/Logs/Dropbox_debug.log --log-severity=warning --product-version=Tungsten/0.1.68 --suffix-user-agent=ShangriLa/66.3.81 --uncaught-exception-stack-size=16 --tungsten-schemes=dbx-local --enable-pinch --num-raster-threads=2 --enable-zero-copy --enable-gpu-memory-buffer-compositor-resources --enable-main-frame-before-activation --content-image-texture-target=0,0,3553;0,1,3553;0,2,3553;0,3,3553;0,4,3553;0,5,3553;0,6,3553;0,7,3553;0,8,3553;0,9,3553;0,10,34037;0,11,34037;0,12,34037;0,13,3553;0,14,3553;0,15,3553;0,16,3553;1,0,3553;1,1,3553;1,2,3553;1,3,3553;1,4,3553;1,5,3553;1,6,3553;1,7,3553;1,8,3553;1,9,3553;1,10,34037;1,11,34037;1,12,34037;1,13,3553;1,14,3553;1,15,3553;1,16,3553;2,0,3553;2,1,3553;2,2,3553;2,3,3553;2,4,3553;2,5,3553;2,6,3553;2,7,3553;2,8,3553;2,9,3553;2,10,34037;2,11,34037;2,12,34037;2,13,3553;2,14,3553;2,15,3553;2,16,3553;3,0,3553;3,1,3553;3,2,3553;3,3,3553;3,4,3553;3,5,34037;3,6,3553;3,7,3553;3,8,3553;3,9,3553;3,10,3553;3,11,3553;3,12,34037;3,13,34037;3,14,3553;3,15,34037;3,16,34037;4,0,3553;4,1,3553;4,2,3553;4,3,3553;4,4,3553;4,5,34037;4,6,3553;4,7,3553;4,8,3553;4,9,3553;4,10,3553;4,11,3553;4,12,34037;4,13,34037;4,14,3553;4,15,34037;4,16,34037 --service-request-channel-token=691A14C6676715713B052C5EF36735DC --renderer-client-id=4
1 497 0.0 visualdrome /usr/libexec/WiFiVelocityAgent
1 500 0.0 root /usr/libexec/wifivelocityd
1 504 0.0 visualdrome /System/Library/CoreServices/CoreServicesUIAgent.app/Contents/MacOS/CoreServicesUIAgent
354 506 0.0 root /Library/DropboxHelperTools/Dropbox_u501/dbfseventsd
506 507 0.0 root /Library/DropboxHelperTools/Dropbox_u501/dbfseventsd
507 508 0.0 visualdrome /Library/DropboxHelperTools/Dropbox_u501/dbfseventsd
1 509 0.0 visualdrome /Applications/Dropbox.app/Contents/XPCServices/DropboxFolderTagger.xpc/Contents/MacOS/DropboxFolderTagger
1 525 0.0 visualdrome /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
1 526 0.0 visualdrome /System/Library/PrivateFrameworks/MediaRemote.framework/Support/mediaremoteagent
1 530 0.0 visualdrome /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
1 537 0.0 visualdrome /System/Library/PrivateFrameworks/UniversalAccess.framework/Versions/A/Resources/universalAccessAuthWarn.app/Contents/MacOS/universalAccessAuthWarn launchd -s
1 547 0.0 visualdrome /System/Library/PrivateFrameworks/CommerceKit.framework/Resources/LaterAgent.app/Contents/MacOS/LaterAgent
1 549 0.0 visualdrome /System/Library/CoreServices/EscrowSecurityAlert.app/Contents/MacOS/EscrowSecurityAlert
1 550 0.0 visualdrome /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Helpers/ProtectedCloudKeySyncing
1 554 0.1 visualdrome /Applications/Backup and Sync.app/Contents/MacOS/Backup and Sync --child_process --profile_id user_bBKDEcBLEei3+9ypBJGVaA
1 573 0.0 _spotlight /usr/libexec/trustd --agent
1 575 0.0 visualdrome /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 576 0.0 visualdrome /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 577 0.0 visualdrome /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 578 0.0 visualdrome /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 583 0.0 _spotlight /usr/sbin/distnoted agent
1 589 0.0 root /usr/libexec/smd
1 590 0.0 visualdrome /System/Library/PrivateFrameworks/CoreSpotlight.framework/Support/com.apple.spotlight.IndexAgent
1 591 0.0 visualdrome /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdflagwriter
1 621 0.0 root /System/Library/PrivateFrameworks/InstallerDiagnostics.framework/Versions/A/Resources/installerdiagd
1 660 0.0 visualdrome /System/Library/Frameworks/ApplicationServices.framework/Frameworks/PrintCore.framework/Versions/A/printtool agent
1 663 0.0 visualdrome /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker -s mdworker-sizing -c MDSSizingWorker -m com.apple.mdworker.sizing
1 665 0.0 root /usr/sbin/spindump
1 666 0.0 root /System/Library/CoreServices/SubmitDiagInfo server-init
1 675 0.0 root /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod
1 676 0.0 root /usr/libexec/secinitd
1 686 0.0 root /usr/sbin/distnoted agent
1 693 0.0 visualdrome /System/Library/CoreServices/OSDUIHelper.app/Contents/MacOS/OSDUIHelper
1 735 0.0 visualdrome /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
1 740 0.0 visualdrome /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/XPCServices/com.apple.accessibility.mediaaccessibilityd.xpc/Contents/MacOS/com.apple.accessibility.mediaaccessibilityd
1 750 0.0 root /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
1 761 8.8 visualdrome /Applications/Firefox.app/Contents/MacOS/firefox
761 762 3.2 visualdrome /Applications/Firefox.app/Contents/MacOS/plugin-container.app/Contents/MacOS/plugin-container -childID 1 -isForBrowser -prefsLen 1 -prefMapSize 193470 -schedulerPrefs 0001,2 -sbStartup -sbLevel 3 -sbAllowAudio -sbAllowWindowServer -sbAppPath /Applications/Firefox.app -parentBuildID 20190124174741 -greomni /Applications/Firefox.app/Contents/Resources/omni.ja -appomni /Applications/Firefox.app/Contents/Resources/browser/omni.ja -appdir /Applications/Firefox.app/Contents/Resources/browser -profile /Users/visualdrome/Library/Application Support/Firefox/Profiles/7nmhzz3s.default-1540500395016 761 gecko-crash-server-pipe.761 org.mozilla.machname.706255949 tab
761 766 0.8 visualdrome /Applications/Firefox.app/Contents/MacOS/plugin-container.app/Contents/MacOS/plugin-container -childID 5 -isForBrowser -prefsLen 240 -prefMapSize 193470 -schedulerPrefs 0001,2 -sbStartup -sbLevel 3 -sbAllowAudio -sbAllowWindowServer -sbAppPath /Applications/Firefox.app -parentBuildID 20190124174741 -greomni /Applications/Firefox.app/Contents/Resources/omni.ja -appomni /Applications/Firefox.app/Contents/Resources/browser/omni.ja -appdir /Applications/Firefox.app/Contents/Resources/browser -profile /Users/visualdrome/Library/Application Support/Firefox/Profiles/7nmhzz3s.default-1540500395016 761 gecko-crash-server-pipe.761 org.mozilla.machname.491650041 tab
761 772 7.7 visualdrome /Applications/Firefox.app/Contents/MacOS/plugin-container.app/Contents/MacOS/plugin-container -childID 6 -isForBrowser -prefsLen 6401 -prefMapSize 193470 -schedulerPrefs 0001,2 -sbStartup -sbLevel 3 -sbAllowAudio -sbAllowWindowServer -sbAppPath /Applications/Firefox.app -parentBuildID 20190124174741 -greomni /Applications/Firefox.app/Contents/Resources/omni.ja -appomni /Applications/Firefox.app/Contents/Resources/browser/omni.ja -appdir /Applications/Firefox.app/Contents/Resources/browser -profile /Users/visualdrome/Library/Application Support/Firefox/Profiles/7nmhzz3s.default-1540500395016 761 gecko-crash-server-pipe.761 org.mozilla.machname.1121997028 tab
761 776 0.0 visualdrome /Applications/Firefox.app/Contents/MacOS/plugin-container.app/Contents/MacOS/plugin-container -childID 8 -isForBrowser -prefsLen 6401 -prefMapSize 193470 -schedulerPrefs 0001,2 -sbStartup -sbLevel 3 -sbAllowAudio -sbAllowWindowServer -sbAppPath /Applications/Firefox.app -parentBuildID 20190124174741 -greomni /Applications/Firefox.app/Contents/Resources/omni.ja -appomni /Applications/Firefox.app/Contents/Resources/browser/omni.ja -appdir /Applications/Firefox.app/Contents/Resources/browser -profile /Users/visualdrome/Library/Application Support/Firefox/Profiles/7nmhzz3s.default-1540500395016 761 gecko-crash-server-pipe.761 org.mozilla.machname.904332984 tab
554 777 0.0 visualdrome /Applications/Backup and Sync.app/Contents/MacOS/Backup and Sync --ma_controller --ma_restart
1 792 0.0 visualdrome /System/Library/PrivateFrameworks/XprotectFramework.framework/Versions/A/XPCServices/XprotectService.xpc/Contents/MacOS/XprotectService
1 793 0.0 root /usr/libexec/syspolicyd
1 795 0.0 visualdrome /System/Library/PrivateFrameworks/DiskImages.framework/Resources/diskimages-helper -uuid F2750CA9-C450-4115-958C-ED083D599300 -post-exec 4
1 800 0.0 root /System/Library/PrivateFrameworks/DiskImages.framework/Resources/hdiejectd
1 812 0.0 visualdrome /usr/libexec/swcd
1 1135 0.0 visualdrome /Applications/Preview.app/Contents/MacOS/Preview
1 1136 0.0 visualdrome /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc/Contents/MacOS/com.apple.hiservices-xpcservice
1 1137 0.0 visualdrome /Applications/Preview.app/Contents/XPCServices/com.apple.Preview.TrustedBookmarksService.xpc/Contents/MacOS/com.apple.Preview.TrustedBookmarksService
1 1138 0.0 visualdrome /System/Library/CoreServices/ScopedBookmarkAgent
355 1146 0.0 visualdrome /Applications/Backup and Sync.app/Contents/MacOS/Backup and Sync --ma_controller --ma_restart
1 1153 0.0 visualdrome /Applications/Backup and Sync.app/Contents/PlugIns/FinderSyncAPIExtension.appex/Contents/MacOS/FinderSyncAPIExtension
1 1163 0.0 visualdrome /System/Library/Frameworks/QuickLook.framework/Resources/quicklookd.app/Contents/MacOS/quicklookd
1 1164 0.0 visualdrome /System/Library/Frameworks/QuickLook.framework/Versions/A/Resources/quicklookd.app/Contents/XPCServices/QuickLookSatellite.xpc/Contents/MacOS/QuickLookSatellite
1 1426 0.0 visualdrome /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
1 1445 0.0 _netbios /usr/sbin/netbiosd
1 1453 0.0 root /usr/sbin/ocspd
1 1454 4.2 visualdrome /Applications/DetectX Swift.app/Contents/MacOS/DetectX Swift
1 1814 0.0 visualdrome /System/Library/PrivateFrameworks/SyncedDefaults.framework/Support/syncdefaultsd
1 1906 24.2 visualdrome /System/Library/Frameworks/AddressBook.framework/Versions/A/Helpers/AddressBookSourceSync.app/Contents/MacOS/AddressBookSourceSync
«»EOF»«
