Help Kernel
Crystal67
Oggetto del messaggio: Help Kernel
Messaggio Inviato: mer, 09 gen 2019 10:04
Ciao, sono preoccupata per il mio Mac, ultimamente si riavvia da solo con il classico messaggio "a causa di un problema" a settembre dopo un po' di chiusure così ho dovuto sostituire l'HD, e pensavo fosse risolto, ma ora ricomincia, sotto vi allego il resoconto, qualcuno può aiutarmi?
GraziA
Date/Time: 2019-01-09 00:15:34 +0100
OS Version: Mac OS X 10.13.6 (Build 17G4015)
Architecture: x86_64
Report Version: 26
Data Source: Stackshots
Event: Sleep Wake Failure
Duration: 0.08s
Steps: 8
Hardware model: iMac12,1
Active cpus: 4
Time Awake Since Boot: 500000s
Process: kernel_task [0]
Path: /System/Library/Kernels/kernel
Version: Darwin Kernel Version 17.7.0: Fri Nov 2 20:43:16 PDT 2018; root:xnu-4570.71.17~1/RELEASE_X86_64
Task size: 2396.81 MB
CPU Time: 0.003s
Thread 0x6b 8 samples (1-8) priority 95 (base 95)
<IO tier 0>
*8 call_continuation + 23 (kernel + 128343) [0xffffff800021f557] 1-8
*8 ??? (kernel + 756659) [0xffffff80002b8bb3] 1-8
*8 thread_block_reason + 175 (kernel + 558655) [0xffffff800028863f] 1-8
*8 ??? (kernel + 562810) [0xffffff800028967a] 1-8
*8 machine_switch_context + 205 (kernel + 1590797) [0xffffff800038460d] 1-8
Thread 0x6c 8 samples (1-8) priority 95 (base 95)
<IO tier 0>
Thread 0x6e 8 samples (1-8) priority 95 (base 95)
<IO tier 0>
*8 mapping_replenish + 465 (kernel + 1513697) [0xffffff80003718e1] 1-8
Thread 0x6f Thread name "IOServiceTerminateThread" 8 samples (1-8) priority 81 (base 81)
<IO tier 0>
*8 IOService::terminateThread(void*, int) + 132 (kernel + 6788692) [0xffffff8000879654] 1-8
*8 lck_mtx_sleep + 126 (kernel + 513278) [0xffffff800027d4fe] 1-8
Thread 0x7c 8 samples (1-8) priority 81 (base 81)
<IO tier 0>
*8 pmInitThread + 885 (AppleIntelCPUPowerManagement + 25052) [0xffffff7f81f3f1dc] 1-8
Thread 0x8f Thread name "idle #1" 8 samples (1-8) priority 0 (base 0) idle time 0.084s
<IO tier 0>
*8 idle_thread + 32 (kernel + 576112) [0xffffff800028ca70] 1-8
*8 processor_idle + 210 (kernel + 574626) [0xffffff800028c4a2] 1-8
*8 machine_idle + 778 (kernel + 1617066) [0xffffff800038acaa] (runnable) 1-8
Thread 0x92 Thread name "idle #2" 8 samples (1-8) priority 0 (base 0) idle time 0.084s
<IO tier 0>
Thread 0x95 Thread name "idle #3" 8 samples (1-8) priority 0 (base 0) idle time 0.084s
<IO tier 0>
Thread 0x161 8 samples (1-8) priority 81 (base 81)
<IO tier 0>
*8 ??? (kernel + 3156577) [0xffffff8000502a61] 1-8
*8 ??? (kernel + 5438118) [0xffffff800072faa6] 1-8
Thread 0x192 8 samples (1-8) priority 81 (base 81)
<IO tier 0>
*8 swcrypto_threadpool_worker_thread(void*, int) + 108 (apfs + 127926) [0xffffff7f814e13b6] 1-8
Thread 0x193 8 samples (1-8) priority 81 (base 81)
<IO tier 0>
Thread 0x194 8 samples (1-8) priority 81 (base 81)
<IO tier 0>
Thread 0x195 8 samples (1-8) priority 81 (base 81)
<IO tier 0>
Thread 0x1a7 8 samples (1-8) priority 81 (base 81)
<IO tier 0>
*8 ??? (kernel + 5952986) [0xffffff80007ad5da] 1-8
*8 mach_msg_receive + 178 (kernel + 405858) [0xffffff8000263162] 1-8
*8 ipc_mqueue_receive + 119 (kernel + 347671) [0xffffff8000254e17] 1-8
Thread 0x1ac 8 samples (1-8) priority 46 (base 31)
<IO tier 0>
*8 vm_pressure_thread + 32 (kernel + 1149568) [0xffffff8000318a80] 1-8
*8 memorystatus_update_vm_pressure + 69 (kernel + 5460485) [0xffffff8000735205] 1-8
*8 memorystatus_idle_exit_from_VM + 244 (kernel + 5462244) [0xffffff80007358e4] 1-8
*8 ??? (kernel + 5463680) [0xffffff8000735e80] 1-8
*8 exit_with_reason + 592 (kernel + 5328416) [0xffffff8000714e20] 1-8
*8 task_terminate_internal + 419 (kernel + 621891) [0xffffff8000297d43] 1-8
*8 vm_map_remove + 114 (kernel + 1016786) [0xffffff80002f83d2] 1-8
*8 ??? (kernel + 1019704) [0xffffff80002f8f38] 1-8
*8 ??? (kernel + 1096622) [0xffffff800030bbae] 1-8
*8 vnode_pager_last_unmap + 13 (kernel + 899021) [0xffffff80002db7cd] 1-8
*8 ??? (kernel + 5615020) [0xffffff800075adac] 1-8
*8 apfs_vnop_mnomap + 281 (apfs + 140302) [0xffffff7f814e440e] 1-8
*8 ubc_msync + 232 (kernel + 5613144) [0xffffff800075a658] 1-8
*8 memory_object_lock_request + 308 (kernel + 948212) [0xffffff80002e77f4] 1-8
*8 ??? (kernel + 951181) [0xffffff80002e838d] 1-8
*8 vnode_pager_data_return + 15 (kernel + 898879) [0xffffff80002db73f] 1-8
*8 vnode_pager_cluster_write + 271 (kernel + 899311) [0xffffff80002db8ef] 1-8
*8 vnode_pageout + 1554 (kernel + 5928786) [0xffffff80007a7752] 1-8
*8 VNOP_PAGEOUT + 91 (kernel + 2950651) [0xffffff80004d05fb] 1-8
*8 apfs_vnop_pageout + 1175 (apfs + 148115) [0xffffff7f814e6293] 1-8
*8 cluster_pageout + 21 (kernel + 2663349) [0xffffff800048a3b5] 1-8
*8 cluster_pageout_ext + 241 (kernel + 2663601) [0xffffff800048a4b1] 1-8
*8 ??? (kernel + 2664870) [0xffffff800048a9a6] 1-8
*8 VNOP_BLOCKMAP + 127 (kernel + 2952223) [0xffffff80004d0c1f] 1-8
*8 apfs_vnop_blockmap + 2604 (apfs + 151724) [0xffffff7f814e70ac] 1-8
*8 fs_map_file_offset + 4666 (apfs + 448964) [0xffffff7f8152f9c4] 1-8
*8 lookup_file_extent + 161 (apfs + 390646) [0xffffff7f815215f6] 1-8
*8 tree_lookup_le + 48 (apfs + 482277) [0xffffff7f81537be5] 1-8
*8 _bt_lookup_variant + 258 (apfs + 552112) [0xffffff7f81548cb0] 1-8
*8 btree_node_get + 106 (apfs + 518072) [0xffffff7f815407b8] 1-8
*8 btree_node_get_internal + 340 (apfs + 518427) [0xffffff7f8154091b] 1-8
*8 obj_get + 3033 (apfs + 633684) [0xffffff7f8155cb54] 1-8
*8 obj_read + 212 (apfs + 636928) [0xffffff7f8155d800] 1-8
*8 vnode_dev_read + 34 (apfs + 591191) [0xffffff7f81552557] 1-8
*8 _vnode_dev_read + 504 (apfs + 595220) [0xffffff7f81553514] 1-8
*8 nx_buf_bread + 387 (apfs + 595846) [0xffffff7f81553786] 1-8
*8 VNOP_STRATEGY + 66 (kernel + 2952530) [0xffffff80004d0d52] 1-8
*8 spec_strategy + 916 (kernel + 2985012) [0xffffff80004d8c34] 1-8
*8 dkreadwrite(void*, dkrtype_t) + 1601 (IOStorageFamily + 55172) [0xffffff7f80d89784] 1-8
*8 IOBlockStorageDriver::prepareRequest(unsigned long long, IOMemoryDescriptor*, IOStorageAttributes*, IOStorageCompletion*) + 298 (IOStorageFamily + 30478) [0xffffff7f80d8370e] 1-8
*8 IOBlockStorageDriver::executeRequest(unsigned long long, IOMemoryDescriptor*, IOStorageAttributes*, IOStorageCompletion*, IOBlockStorageDriver::Context*) + 294 (IOStorageFamily + 20016) [0xffffff7f80d80e30] 1-8
*8 IOAHCIBlockStorageDriver::AsyncReadWrite(IOMemoryDescriptor*, unsigned long long, unsigned long long, IOStorageAttributes*, IOStorageCompletion*) + 152 (IOAHCIBlockStorage + 42744) [0xffffff7f81b636f8] 1-8
*8 IOAHCIDiskQueueManager::GetRequestBlock() + 168 (IOAHCIBlockStorage + 13348) [0xffffff7f81b5c424] 1-8
*8 IOAHCIDiskQueueManager::__DISK_IS_ASLEEP__() + 49 (IOAHCIBlockStorage + 13789) [0xffffff7f81b5c5dd] 1-8
Thread 0x1ae Thread name "VM_cswap_trigger" 8 samples (1-8) priority 91 (base 91) cpu time <0.001s
<IO tier 0>
*8 ??? (kernel + 906309) [0xffffff80002dd445] 1-8
*8 ??? (kernel + 906782) [0xffffff80002dd61e] 1-8
Thread 0x1b1 8 samples (1-8) priority 91 (base 91)
<IO tier 2 and passive>
*8 ??? (kernel + 931447) [0xffffff80002e3677] 1-8
*8 vm_swap_put + 779 (kernel + 936139) [0xffffff80002e48cb] 1-8
*8 vm_swapfile_io + 189 (kernel + 5947357) [0xffffff80007abfdd] 1-8
*8 vnode_pageout + 156 (kernel + 5927388) [0xffffff80007a71dc] 1-8
*8 apfs_vnop_pageout + 587 (apfs + 147527) [0xffffff7f814e6047] 1-8
*8 ??? (kernel + 2667074) [0xffffff800048b242] 1-8
*8 apfs_vnop_strategy + 951 (apfs + 160321) [0xffffff7f814e9241] 1-8
*8 buf_strategy + 322 (kernel + 2631442) [0xffffff8000482712] 1-8
*8 dkreadwrite(void*, dkrtype_t) + 1523 (IOStorageFamily + 55094) [0xffffff7f80d89736] 1-8
*8 AppleAPFSContainerScheme::write(IOService*, unsigned long long, IOMemoryDescriptor*, IOStorageAttributes*, IOStorageCompletion*) + 525 (apfs + 120971) [0xffffff7f814df88b] 1-8
Thread 0x1e3 8 samples (1-8) priority 81 (base 81)
<IO tier 0>
*8 ??? (kernel + 5884940) [0xffffff800079cc0c] 1-8
Thread 0x5e3 8 samples (1-8) priority 97 (base 97)
<IO tier 0>
*8 AppleOSXWatchdog::watchdogMainThread() + 133 (AppleOSXWatchdog + 5613) [0xffffff7f825355ed] 1-8
Thread 0x6df 8 samples (1-8) priority 81 (base 81)
<IO tier 0>
*8 ??? (kernel + 3158065) [0xffffff8000503031] 1-8
Thread 0x6e0 Thread name "ifnet_start_en0" 8 samples (1-8) priority 82 (base 82)
<IO tier 0>
*8 ??? (kernel + 3192935) [0xffffff800050b867] 1-8
*8 msleep + 98 (kernel + 5439346) [0xffffff800072ff72] 1-8
Thread 0x6e1 8 samples (1-8) priority 82 (base 82)
<IO tier 0>
*8 ??? (kernel + 3193429) [0xffffff800050ba55] 1-8
Thread 0x6f1 Thread name "dlil_input_en2" 8 samples (1-8) priority 81 (base 81)
<IO tier 0>
*8 ??? (kernel + 3160655) [0xffffff8000503a4f] 1-8
Thread 0x6f2 Thread name "ifnet_start_en2" 8 samples (1-8) priority 82 (base 82)
<IO tier 0>
Thread 0x6f9 Thread name "dlil_input_en1" 8 samples (1-8) priority 81 (base 81)
<IO tier 0>
Thread 0x6fa Thread name "ifnet_start_en1" 8 samples (1-8) priority 82 (base 82)
<IO tier 0>
Thread 0x700 Thread name "dlil_input_p2p0" 8 samples (1-8) priority 81 (base 81)
<IO tier 0>
Thread 0x701 Thread name "ifnet_start_p2p0" 8 samples (1-8) priority 82 (base 82)
<IO tier 0>
Thread 0x772 8 samples (1-8) priority 81 (base 81)
<IO tier 0>
*8 IOCommandGate::runAction(int (*)(OSObject*, void*, void*, void*, void*), void*, void*, void*, void*) + 312 (kernel + 6927864) [0xffffff800089b5f8] 1-8
*8 IOWorkQueue::processWorkCallFromSingleThreadAction(OSObject*, void*, void*, void*, void*) + 45 (IOBluetoothFamily + 218525) [0xffffff7f81c6559d] 1-8
*8 IOWorkQueue::processWorkCallFromSingleThreadWL() + 284 (IOBluetoothFamily + 218820) [0xffffff7f81c656c4] 1-8
*8 IOEventSource::sleepGate(void*, unsigned int) + 76 (kernel + 6921452) [0xffffff8000899cec] 1-8
*8 IOWorkLoop::sleepGate(void*, unsigned int) + 123 (kernel + 6915243) [0xffffff80008984ab] 1-8
Thread 0xcef Thread name "ifnet_start_utun0" 8 samples (1-8) priority 82 (base 82)
<IO tier 0>
Thread 0x42ea3 Thread name "ifnet_start_utun1" 8 samples (1-8) priority 82 (base 82)
<IO tier 0>
Thread 0x6a562 8 samples (1-8) priority 81 (base 81) cpu time <0.001s
<IO tier 0>
*8 smb_iod_thread + 2164 (smbfs + 193739) [0xffffff7f835b64cb] 1-8
*8 ??? (kernel + 5438450) [0xffffff800072fbf2] 1-8
Thread 0x6a563 8 samples (1-8) priority 81 (base 81)
<IO tier 0>
*8 smb_iod_lease_thread + 260 (smbfs + 195400) [0xffffff7f835b6b48] 1-8
Thread 0x6a62e 8 samples (1-8) priority 81 (base 81)
<IO tier 0>
*8 notify_main + 2834 (smbfs + 240098) [0xffffff7f835c19e2] 1-8
Thread 0x3edf28 8 samples (1-8) priority 81 (base 81)
<IO tier 0>
Thread 0x3edf29 8 samples (1-8) priority 81 (base 81)
<IO tier 0>
Thread 0x48a488 8 samples (1-8) priority 81 (base 81) cpu time <0.001s
<IO tier 0 and passive>
*8 tx_flush_thread + 121 (apfs + 705194) [0xffffff7f8156e2aa] 1-8
*8 ??? (kernel + 5437880) [0xffffff800072f9b8] 1-8
*8 lck_mtx_sleep_deadline + 139 (kernel + 513851) [0xffffff800027d73b] 1-8
Thread 0x48cab2 Thread name "thread call high #11" 8 samples (1-8) priority 93 (base 93)
<IO tier 0>
*8 ??? (kernel + 684405) [0xffffff80002a7175] 1-8
*8 ??? (kernel + 685588) [0xffffff80002a7614] 1-8
*8 IOService::pmDriverCallout(IOService*) + 42 (kernel + 6812954) [0xffffff800087f51a] 1-8
*8 IOService::driverSetPowerState() + 389 (kernel + 6813557) [0xffffff800087f775] 1-8
*8 Gen6Accelerator::setPowerState(unsigned long, IOService*) + 88 (AppleIntelHD3000Graphics + 202206) [0xffffff7f82bf45de] 1-8
*8 Gen6Accelerator::forcePageOffDirtyTextures() + 119 (AppleIntelHD3000Graphics + 201941) [0xffffff7f82bf44d5] 1-8
*8 IOIntelAccelerator::pageoffDirtyTexture(Gen575TextureBuffer*) + 322 (AppleIntelHD3000Graphics + 19390) [0xffffff7f82bc7bbe] 1-8
*8 IntelAccelerator::pageoff_dirty_texture(Gen575TextureBuffer*) + 1421 (AppleIntelHD3000Graphics + 134797) [0xffffff7f82be3e8d] 1-8
*8 IOSurfaceDeviceCache::processorDataUpdated(bool) + 31 (IOSurface + 28219) [0xffffff7f82e53e3b] 1-8
*8 IOSurface::processorDataUpdated(bool, bool) + 77 (IOSurface + 11705) [0xffffff7f82e4fdb9] 1-8
*8 ??? (kernel + 131552) [0xffffff80002201e0] 1-8
*8 kernel_trap + 1058 (kernel + 1608882) [0xffffff8000388cb2] 1-8
*8 ??? (kernel + 979130) [0xffffff80002ef0ba] 1-8
*8 vm_fault_page + 1060 (kernel + 961028) [0xffffff80002eaa04] 1-8
*8 vm_compressor_pager_get + 225 (kernel + 928081) [0xffffff80002e2951] 1-8
*8 vm_compressor_get + 223 (kernel + 920223) [0xffffff80002e0a9f] 1-8
*8 ??? (kernel + 920900) [0xffffff80002e0d44] 1-8
*8 c_seg_swapin + 424 (kernel + 915560) [0xffffff80002df868] 1-8
*8 vm_swap_get + 171 (kernel + 939259) [0xffffff80002e54fb] 1-8
*8 vm_swapfile_io + 231 (kernel + 5947399) [0xffffff80007ac007] 1-8
*8 vnode_pagein + 1083 (kernel + 5930171) [0xffffff80007a7cbb] 1-8
*8 apfs_vnop_pagein + 1993 (apfs + 146657) [0xffffff7f814e5ce1] 1-8
*8 cluster_pagein + 21 (kernel + 2669797) [0xffffff800048bce5] 1-8
*8 cluster_pagein_ext + 261 (kernel + 2670069) [0xffffff800048bdf5] 1-8
Thread 0x48cab3 Thread name "thread call high #8" 8 samples (1-8) priority 93 (base 93) cpu time 0.003s
<IO tier 0>
*8 IOService::watchdog_timer_expired(void*, void*) + 46 (kernel + 6812606) [0xffffff800087f3be] 1-8
*8 IOPMrootDomain::takeStackshot(bool, bool, bool) + 901 (kernel + 7320661) [0xffffff80008fb455] 1-8
*8 stack_snapshot_from_kernel + 373 (kernel + 264517) [0xffffff8000240945] (running) 1-8
Binary Images:
*0xffffff7f80d7c000 - 0xffffff7f80d8dfff com.apple.iokit.IOStorageFamily 2.1 (2.1) <F27A8A2A-6662-3608-83BD-415037509E01> /System/Library/Extensions/IOStorageFamily.kext/Contents/MacOS/IOStorageFamily
*0xffffff7f814c2000 - 0xffffff7f8159dfff com.apple.filesystems.apfs 748.51.0 (748.51.0) <54D8BAB5-15EF-3C40-A3B6-E4F8A126E74E> /System/Library/Extensions/apfs.kext/Contents/MacOS/apfs
*0xffffff7f81b59000 - 0xffffff7f81b6ffff com.apple.iokit.IOAHCIBlockStorage 301.40.2 (301.40.2) <0D9325A5-E989-39F7-B3CF-75FC51C60627> /System/Library/Extensions/IOAHCIFamily.kext/Contents/PlugIns/IOAHCIBlockStorage.kext/Contents/MacOS/IOAHCIBlockStorage
*0xffffff7f81c30000 - 0xffffff7f81cb6fff com.apple.iokit.IOBluetoothFamily 6.0.7 (6.0.7f11) <D88C45AC-CD73-3136-B4C0-2D29AD5587BE> /System/Library/Extensions/IOBluetoothFamily.kext/Contents/MacOS/IOBluetoothFamily
*0xffffff7f81f39000 - 0xffffff7f81f55fff com.apple.driver.AppleIntelCPUPowerManagement 220.50.1 (220.50.1) <A6798B64-822D-306E-B770-77CB61D05698> /System/Library/Extensions/AppleIntelCPUPowerManagement.kext/Contents/MacOS/AppleIntelCPUPowerManagement
*0xffffff7f82534000 - 0xffffff7f82535fff com.apple.driver.AppleOSXWatchdog 1.0 (1) <10AB980B-BF01-317D-8CE7-51079C8E304C> /System/Library/Extensions/AppleOSXWatchdog.kext/Contents/MacOS/AppleOSXWatchdog
*0xffffff7f82bc3000 - 0xffffff7f82c12fff com.apple.driver.AppleIntelHD3000Graphics 10.4.14 (10.0.4) <96C49652-5E4D-3957-BE22-D617D92C116B> /System/Library/Extensions/AppleIntelHD3000Graphics.kext/Contents/MacOS/AppleIntelHD3000Graphics
*0xffffff7f82e4d000 - 0xffffff7f82e5afff com.apple.iokit.IOSurface 211.15 (211.15) <37BCC686-AF99-3381-AC4F-E54A347E0F40> /System/Library/Extensions/IOSurface.kext/Contents/MacOS/IOSurface
*0xffffff7f83587000 - 0xffffff7f835e5fff com.apple.filesystems.smbfs 3.2.3 (3.2.3) <8BD2FFC5-F081-3B29-B2AB-BEF58E24BAAD> /System/Library/Extensions/smbfs.kext/Contents/MacOS/smbfs
*0xffffff8000200000 - 0xffffff80009fffff kernel (4570.71.17) <F39BC8AD-8981-3617-BF39-E68CAA3268D5> /System/Library/Kernels/kernel
UUID: 48F315B7-D766-43BB-B478-360B93C370E3
Code: 00000004 00000014
Stackshot reason: Watchdog
Stefania
Oggetto del messaggio: Re: Help Kernel
Messaggio Inviato: mer, 09 gen 2019 11:21
Ciao, cos'è?
Non sembra un resoconto di kernel panic.
E non vedo il Thread Crashed, se fosse altro.
Quindi non si capisce il problema.
Da quel che intuisco è che si tratti di un'incongruente richiesta durante lo stato di ibernazione (stop).
Dovrebbe quindi coincidere con un bug esistente nelle prime versioni di High Sierra.
Ma che comunque è stato corretto mai completamente.
Si verificherebbe con una chiamata o un'attività scaturita da una routine di un plugin durante la sospensione.
Intanto elimina lo stop.
Poi vediamo con qualche altro strumento di analisi cosa possa essere.
Installa DetectX Swift
viewtopic.php?f=5&t=32846&p=490423#p490423
Un po' d'attenzione nello scaricarlo, perché il sito richiede registrazione, anche se gratuito.
Intanto verifichi se ci sono anomalie esogene.
Poi se tutto va bene crea e posta il profilo (come codice).
NB: alcune delle cause più frequenti vengono risolte con:
- Eliminazione antivirus (che nel tuo caso tenderei ad eliminare)
- Non usare File Vault 2
- Reimpostando la NVRAM
Quindi intanto applica anche queste condizioni
Crystal67
Messaggio Inviato: ven, 11 gen 2019 09:16
GraziE Bacio
Stefania
