ciao a tutti, sono nuovo sul forum avrei bisogno di un aiuto da quando ho cambiato hd a sdd sandisk ogni volta che accendo il macbook pro 2010 la temperatura arriva quasi a 90 gradi avendo le ventole attaccate per almeno i primi 10/15 minuti, ho effettuato EtreCheck e ho notato dal monitoraggio attivia' di avere su UserEventAgent , launchd ,fseventsd un elevato consumo CPU su quet'ultime. qualcuno puo aiutarmi tramite il seguente risultato di EtreCheck:
EtreCheck version: 5.1 (5020)
Report generated: 2018-12-15 19:42:51
Runtime: 2:60
Performance: Good
Sandbox: Enabled
Full drive access: Disabled
Major Issues: None
Minor Issues:
These issues do not need immediate attention but they may indicate future problems.
Clean up - There are orphan files that could be removed.
Unsigned files - There are unsigned software files installed. They appear to be legitimate but should be reviewed.
Vintage hardware - This machine may be considered vintage.
Abnormal shutdown - Your machine shut down abnormally.
Limited drive access - More information may be available with Full Drive Access.
Hardware Information:
MacBook Pro (13-inch, Early 2011) - Vintage!
MacBook Pro Model: MacBookPro8,1
1 2,3 GHz Intel Core i5 (i5-2415M) CPU: 2-core
8 GB RAM - At maximum
BANK 0/DIMM0 - 4 GB DDR3 1333 ok
BANK 1/DIMM0 - 4 GB DDR3 1333 ok
Battery: Health = Normal - Cycle count = 698
Video Information:
Intel HD Graphics 3000 - VRAM: 512 MB
Color LCD 1280 x 800
Drives:
disk0 - SanDisk SSD PLUS 480GB 480.11 GB (Solid State - TRIM: Yes)
Internal SATA 6 Gigabit Serial ATA
disk0s1 - EFI (MS-DOS FAT32) [EFI] 210 MB
disk0s2 [Core Storage Container] 479.25 GB
disk1 - M**********************w (Journaled HFS+) 478.88 GB (211.67 GB used)
disk0s3 - Recovery HD [Recovery] 650 MB
Mounted Volumes:
disk1 - M**********************w 478.88 GB (266.95 GB free)
Journaled HFS+
Mount point: /
Network:
Interface SAMSUNG_MDM: SAMSUNG Modem
Interface SAMSUNG_MDM9: SAMSUNG Modem 2
Interface SAMSUNG_MDM10: SAMSUNG Modem 3
Interface SAMSUNG_MDM11: SAMSUNG Modem 4
Interface SAMSUNG_MDM12: SAMSUNG Modem 5
Interface SAMSUNG_MDM13: SAMSUNG Modem 6
Interface SAMSUNG_MDM14: SAMSUNG Modem 7
Interface SAMSUNG_MDM15: SAMSUNG Modem 8
Interface SAMSUNG_MDM16: SAMSUNG Modem 9
Interface SAMSUNG_MDM17: SAMSUNG Modem 10
Interface SAMSUNG_MDM18: SAMSUNG Modem 11
Interface SAMSUNG_MDM19: SAMSUNG Modem 12
Interface SAMSUNG_MDM20: SAMSUNG Modem 13
Interface SAMSUNG_MDM21: SAMSUNG Modem 14
Interface SAMSUNG_MDM22: SAMSUNG Modem 15
Interface SAMSUNG_MDM23: SAMSUNG Modem 16
Interface SAMSUNG_MDM24: SAMSUNG Modem 17
Interface SAMSUNG_MDM25: SAMSUNG Modem 18
Interface SAMSUNG_MDM26: SAMSUNG Modem 19
Interface SAMSUNG_MDM27: SAMSUNG Modem 20
Interface SAMSUNG_MDM28: SAMSUNG Modem 21
Interface en0: Ethernet
Interface fw0: FireWire
Interface en1: Wi-Fi
802.11 a/b/g/n
Interface en3: Bluetooth PAN
Interface bridge0: Thunderbolt Bridge
Interface en4: iPhone
Interface en5: iPad
System Software:
macOS High Sierra 10.13.6 (17G4015)
Time since boot: Less than an hour
Security:
GatekeeperEnabled
System Integrity ProtectionEnabled
Unsigned Files:
Launchd: /Library/LaunchDaemons/com.oracle.java.Helper-Tool.plist
Executable: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/Helper-Tool
Details: Exact match found in the whitelist - probably OK
Launchd: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/com.oracle.java.Java-Updater.plist
Executable: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/Java Updater.app/Contents/MacOS/Java Updater -bgcheck
Launchd: /Library/LaunchDaemons/com.microsoft.office.licensing.helper.plist
Executable: /Library/PrivilegedHelperTools/com.microsoft.office.licensing.helper
Launchd: /Library/LaunchAgents/com.oracle.java.Java-Updater.plist
Launchd: ~/Library/LaunchAgents/com.dropbox.DropboxMacUpdate.agent.plist
Executable: /Users/***/Library/Dropbox/DropboxMacUpdate.app/Contents/MacOS/DropboxMacUpdate -check periodic
Launchd: ~/Library/LaunchAgents/com.divx.agent.postinstall.plist
Executable: //Library/Internet Plug-Ins/DivXBrowserPlugin.plugin/Contents/Resources/extensions-installer install safari DivXHTML5 '//Library/Internet Plug-Ins/DivXBrowserPlugin.plugin/Contents/Resources/DivXHTML5.safariextz'
Launchd: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/com.oracle.java.Helper-Tool.plist
Launchd: ~/Library/LaunchAgents/com.nds.pcshow.plist
Executable: /bin/sh -c $HOME/Library/NDSPCShowServer/NDSPCShowServer.bundle/Contents/Resources/launch.sh
Launchd: ~/Library/LaunchAgents/com.nds.pcshow.uninstall.plist
Executable: /bin/sh -c /tmp/vgconnect/condUninstall.sh
Kernel Extensions:
/System/Library/Extensions
ZTEUSBCDCACMData.kext (ZTEDriver_MacV1.3.41)
ZTEUSBMassStorageFilter.kext (ZTEDriver_MacV1.3.41)
ssuddrv.kext (DEVGURU Co., Ltd., 1.4.32 - SDK 10.6)
cdc_ecm_qmi.kext (1.0.30)
cdc.kext (1.0.30)
/System/Library/Extensions/ssuddrv.kext/Contents/PlugIns
ssudmdmcontrol.kext (DEVGURU Co., Ltd., 1.4.32 - SDK 10.6)
ssudmdmdata.kext (DEVGURU Co., Ltd., 1.4.32 - SDK 10.6)
ssudmtp.kext (DEVGURU Co., Ltd., 1.4.32 - SDK 10.5)
ssudserial.kext (DEVGURU Co., Ltd., 1.4.32 - SDK 10.6)
Startup Items:
HWNetMgr Path: /Library/StartupItems/HWNetMgr
HWPortDetect Path: /Library/StartupItems/HWPortDetect
System Launch Agents:
[Not Loaded] 17 Apple tasks
[Loaded] 181 Apple tasks
[Running] 96 Apple tasks
System Launch Daemons:
[Not Loaded] 38 Apple tasks
[Loaded] 188 Apple tasks
[Running] 109 Apple tasks
Launch Agents:
[Not Loaded] com.oracle.java.Java-Updater.plist (? f618604b - installed 2016-09-23)
[Not Loaded] SwapperUFi.plist (? 12279339 - installed 2014-01-11)
[Other] com.adobe.ARMDCHelper.cc24aef4a1b90ed56a725c38014c95072f92651fb65e1bf9c8e43c37a23d420d.plist (Adobe Systems, Inc. - installed 2018-02-15)
Launch Daemons:
[Loaded] com.adobe.fpsaud.plist (Adobe Systems, Inc. - installed 2018-11-29)
[Loaded] com.microsoft.office.licensing.helper.plist (? 6d8cb30e - installed 2010-09-23)
[Loaded] com.adobe.ARMDC.Communicator.plist (Adobe Systems, Inc. - installed 2018-02-15)
[Not Loaded] PPPMonitord.plist (? a94c92f4 - installed 2011-04-11)
[Other] com.sec.faxdb.plist (Samsung Electronics Co., Ltd. - installed 2018-11-13)
[Not Loaded] com.oracle.java.Helper-Tool.plist (? e3fefdd2 - installed 2016-09-23)
[Loaded] com.macpaw.CleanMyMac3.Agent.plist (? 7f4ba9a8 - installed 2015-10-10)
[Loaded] com.adobe.ARMDC.SMJobBlessHelper.plist (Adobe Systems, Inc. - installed 2018-02-15)
User Launch Agents:
[Loaded] com.dropbox.DropboxMacUpdate.agent.plist (? 0 - installed 2018-10-24)
[Running] com.hp.devicemonitor.plist (HP Inc. - installed 2018-12-15)
[Other] com.macpaw.CleanMyMac3.Scheduler.plist (? 0 - installed 2016-09-20)
[Loaded] com.nds.pcshow.uninstall.plist (? 0 - installed 2013-04-28)
[Other] com.facebook.videochat.***.plist (Apple - installed 2014-08-09)
[Loaded] com.divx.agent.postinstall.plist (? 0 - installed 2012-05-13)
[Other] com.google.keystone.agent.plist (? 0 - installed 2018-07-20)
[Running] com.hp.productresearch.plist (HP Inc. - installed 2018-12-15)
[Other] com.nds.pcshow.plist (? 0 - installed 2013-02-11)
User Login Items:
KiesAgent.app (? - installed 2016-07-28)
(/Applications/Kies.app/Contents/MacOS/KiesAgent.app)
fuspredownloader.app (? - installed 2015-11-08)
(~/Library/Application Support/.FUS/fuspredownloader.app)
iTunesHelper.app (Apple - installed 2018-11-28)
(/Applications/iTunes.app/Contents/MacOS/iTunesHelper.app)
smcFanControl.app (? - installed 2018-12-15)
(/Applications/smcFanControl.app)
Internet Plug-ins:
OVSHelper: 1.1 (installed 2012-05-13)
Flip4Mac WMV Plugin: 2.3.8.1 (installed 2011-01-14)
AdobePDFViewerNPAPI: 17.012.20098 (installed 2018-12-14)
FlashPlayer-10.6: 32.0.0.101 (installed 2018-12-09)
DivXBrowserPlugin: 2.2 (installed 2012-01-17)
Silverlight: 5.1.41212.0 (installed 2016-03-22)
QuickTime Plugin: 7.7.3 (installed 2018-12-07)
Flash Player: 32.0.0.101 (installed 2018-12-09)
iPhotoPhotocast: 7.0 (installed 2012-12-21)
SharePointBrowserPlugin: 14.0.0 (installed 2010-09-23)
AdobePDFViewer: 19.010.20064 (installed 2018-12-14)
JavaAppletPlugin: Java 8 Update 111 build 14 (installed 2017-01-15)
3rd Party Preference Panes:
DivX (installed 2012-01-17)
Flash Player (installed 2018-11-29)
Flip4Mac WMV (installed 2011-01-13)
Java (installed 2017-01-15)
Paragon NTFS for Mac OS X (installed 2014-09-11)
Time Machine:
Time Machine information not available without Full Drive Access.
Performance:
System Load: 1.65 (1 min ago) 4.36 (5 min ago) 5.02 (15 min ago)
Nominal I/O speed: 3.85 MB/s
File system: 38.33 seconds
Write speed: 58 MB/s
Read speed: 527 MB/s
CPU Usage:
Type Overall
System 5 %
User 28 %
Idle 67 %
Top Processes by CPU:
Process (count) CPU (Source - Location)
helpd 100.03 % (Apple)
Other processes 17.81 % (?)
EtreCheck 6.18 % (App Store)
Activity Monitor 4.60 % (Apple)
distnoted 0.43 % (Apple)
Top Processes by Memory:
Process (count) RAM usage (Source - Location)
EtreCheck 439 MB (App Store)
Google Chrome 278 MB (Google, Inc.)
helpd 88 MB (Apple)
Spotlight 77 MB (Apple)
photoanalysisd 72 MB (Apple)
Top Processes by Network Use:
Process Input / Output (Source - Location)
mDNSResponder 37 KB / 19 KB (Apple)
apsd 4 KB / 4 KB (Apple)
helpd 6 KB / 3 KB (Apple)
netbiosd 2 KB / 578 B (Apple)
kernel_task 385 B / 405 B (Apple)
Virtual Memory Information:
Available RAM 4.35 GB
Free RAM 1.78 GB
Used RAM 3.65 GB
Cached files 2.56 GB
Swap Used 0 B
Software Installs (past 30 days):
Install Date Name (Version)
2018-11-28 iTunes (12.
2018-12-07 Safari (12.0.2)
2018-12-09 Adobe Flash Player
2018-12-09 Gatekeeper Configuration Data (157)
2018-12-12 XProtectPlistConfigData (2101)
2018-12-13 MRTConfigData (1.38)
2018-12-14 Adobe Acrobat Reader DC (19.010.20064)
2018-12-15 EtreCheck (5.1)
Clean up:
~/Library/LaunchAgents/com.google.keystone.agent.plist
/Users/***/Library/Google/GoogleSoftwareUpdate/GoogleSoftwareUpdate.bundle/Contents/Resources/GoogleSoftwareUpdateAgent.app/Contents/MacOS/GoogleSoftwareUpdateAgent
Executable not found
~/Library/LaunchAgents/com.macpaw.CleanMyMac3.Scheduler.plist
'/Users/***/Library/Application Support/CleanMyMac 3/CleanMyMac 3 Scheduler.app'
Diagnostics Information (past 7 days):
2018-12-15 19:25:08 Last Shutdown Cause: 0 - Power loss
Directory /Library/Logs/DiagnosticReports is not accessible without Full Drive Access.
End of report
