sudo rm -rf ~/Library/LaunchAgents/com.cisco.videoguard10.plist ~/Library/LaunchAgents/com.cisco.videoguard10.uninstall.plist /Library/LaunchDaemons/com.microsoft.autoupdate.helpertool.plist /Library/PrivilegedHelperTools/com.microsoft.autoupdate.helpertool /System/Library/LaunchAgents/com.apple.corespeechd.plist /System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd ~/Library/LaunchAgents/com.apple.CSConfigDotMacCert* /System/Library/Frameworks/CoreServices.framework/Frameworks/OSServices.framework/Versions/A/Support/CSConfigDotMacCert* ~/Library/Logs/CSConfigDotMacCert.log*
sudo launchctl unload /Library/LaunchDaemons/com.adobe.ARMDC.Communicator.plist;sudo launchctl unload /Library/LaunchDaemons/com.adobe.ARMDC.SMJobBlessHelper.plist;sudo launchctl unload /Library/LaunchAgents/com.adobe.ARMDCHelper.*.plist
sudo rm -rf /Library/LaunchDaemons/com.adobe.ARMDC.Communicator.plist /Library/LaunchDaemons/com.adobe.ARMDC.SMJobBlessHelper.plist /Library/LaunchAgents/com.adobe.ARMDCHelper.*.plist /Applications/Adobe\ Acrobat\ Reader\ DC.app /Library/Preferences/com.adobe.reader.DC.WebResource.plist /Library/Application\ Support/Adobe/ARMDC /Library/Application\ Support/Adobe/ARMNext /Library/Application\ Support/Adobe/HelpCfg /Library/Application\ Support/Adobe/Reader/DC /Library/Internet\ Plug-Ins/AdobePDFViewer.plugin /Library/Internet\ Plug-Ins/AdobePDFViewerNPAPI.plugin /Library/PrivilegedHelperTools/com.adobe.ARMDC.* ~/Library/Application\ Support/Adobe/AcroCef ~/Library/Application\ Support/Adobe/Acrobat/DC ~/Library/Application\ Support/CEF ~/Library/Logs/DiagnosticReports/AdobeReader_*.crash ~/Library/Preferences/com.adobe.AdobeRdrCEF.plist /private/var/db/receipts/com.adobe.RdrServicesUpdater.* /private/var/db/receipts/com.adobe.acrobat.DC.* /private/var/db/receipts/com.adobe.armdc.*
sudo rm -rf /Library/Internet Plug-ins/AdobePDFViewer.plugin /Library/Internet Plug-ins/AdobePDFViewerNPAPI.plugin
sudo rm -rf /Library/LaunchDaemons/com.adobe.SwitchBoard.plist
faxus ha scritto: ↑gio, 06 set 2018 14:00Esegui questi comandi con Terminale.
Per eliminare i residui di SkyGo o qualcosa di simile, gli orfani di varie disinstallazione e passaggi di sistema:Fatto questo risolvi il disordine dovuto alle disfunzioni Adobe:Codice: Seleziona tutto
Di nuovo:Codice: Seleziona tutto
Insieme ti consiglio di disinstallare Adobe Reader ed usare Anteprima integrata di sistema.Codice: Seleziona tutto
È meglio, pesa infinitamente di meno, non dà problemi, al contrario di quell’inutilità derivante dalla cultura di Windows.
Quindi:- Togli SwitchBoard-MachInit da Preferenze di Sistema > Utenti e gruppi > Elementi del login, eliminalo, non nasconderlo.Codice: Seleziona tutto
È un residuo di antiche installazioni Adobe, inservibile, obsoleto, incuria Adobe.
Non sanno neanche loro come rimuoverlo, prova un po’ così…
Poi esegui:- Aggiorna VirtualBox:Codice: Seleziona tutto
viewtopic.php?f=5&t=4188&start=225#p483626
- Aggiorna Java:
viewtopic.php?f=5&t=19867&p=480585#p480585
- DOPO aver fatto questo, usa OnyX
http://www.titanium.free.fr/onyx.html
Ed esegui:
Menù Manutenzione
Con queste opzioni
Infine riavvia il sistema
Vediamo se si riduce l’uso della swap, pure se l’SSD ammortizza il problema.
I messaggi in rosso dovrebbero sparire
Edit: Lei.la, come va l'estensione Sci-Hub?
È più comodo che la consultazione sul sito?
Va bene così, in effetti per eliminare quel messaggio inutile (è una dimenticanza degli sviluppatori) dovresti disabilitare il SIP.
Sì (quasi, non hai tolto Adobe SwitchBoard-MachInit da Preferenze di Sistema > Utenti e gruppi > Elementi del login).
non lo trovo negli elementi del login...ti lascio la schermata in allegatoSì (quasi, non hai tolto Adobe SwitchBoard-MachInit da Preferenze di Sistema > Utenti e gruppi > Elementi del login).
Grazie a te, non avrei fatto nulla senza le tue indicazioni!Hai fatto un buon lavoro
Uhm... Come detto Adobe non ha ancora, a distanza di anni rilasciato un aggiornamento che risolva.
Non ho idea se dipenda dalla batteria.lei.la ha scritto: ↑ven, 14 set 2018 17:45... Dopo l'upgrade con SSD speravo che il mio Mac potesse lavorare meglio, e in effetti le prestazioni in termini di velocità sono migliorate, ma le ventole certe volte girano e la base si scalda molto, anche se non sto facendo lavorare troppo il mac. Può dipendere dalla batteria? Il Mac mi indica che dovrei cambiarla, ma speravo di poter aspettare ancora un po'...
solo da me, quando ho avuto occasione di aprirlo e ho eliminato la polvere che ho trovato, anche nella ventola.Paolofast ha scritto: ↑sab, 15 set 2018 12:34In questi 7 anni il tuo Mac è stato pulito internamente?
Perché con il tempo si accumula la polvere e le ventole si intasano.
Non molto tempo fa ho visto un MacBookPro trasformarsi da fornace rombante a tranquillo e fresco computer con una semplice pulita fatta da persona esperta.
Visitano il forum: SemrushBot [Bot] e 24 ospiti
