When you choose Soundflower as your Mac’s audio output you can no longer hear it through attached speakers or headphones. In order for you to monitor what’s happening, launch the Soundflowerbed application (found in /Applications/Soundflower). Click the Soundflowerbed menu bar item that appears and choose your speakers or headphones from the menu. Now, not only will your audio application capture what your Mac plays, but you’ll be able to listen to the source audio as well. (You may want to do this before setting up QuickTime or GarageBand to capture your audio, but that's up to you.)
J.T.Kirk ha scritto: ↑mar, 17 lug 2018 18:18Ti serve soundflower
https://github.com/mattingalls/Soundflo ... /tag/2.0b2
paolinoweb ha scritto: ↑mar, 17 lug 2018 18:55Soundflower ottima. Prima scelta.
Per chi ha 60/65 euro da spendere segnalo l'ottima https://rogueamoeba.com/audiohijack/
che ho scoperto adesso che ha cambiato nome - di poco -
Questa ti serve se hai bisogno di più funzionalità - vai a leggere quali -
Grazie a tutti, ho provato ad utilizzare SoundTap https://www.nch.com.au/soundtap/index.html, secondo voi meglio Soundflower?
Installing Soundflower
Run the Soundflower Installer.pkg. You will be asked for
an administrator account password. One file, Soundflower.kext,
will be installed in the Extensions Folder. The remainder of the
supporting files will be installed to /Applications/Soundflower.
If you experience difficulty installing Soundflower, it is
recommended that you run the Uninstall Soundflower applescript
that is provided on the disk image.
Using Soundflower
Soundflower presents itself as one of two coreaudio devices.
In most cases, you will want to use the 2-channel device.
To send the output of one application to another, simply select
Soundflower as the output device within the first application
and Soundflower as the input device within the second
application.
If an application does not allow you to specify audio devices,
you can make Soundflower the default input or output device
inside the Sound panel in the System Preferences, or with
the Audio MIDI Setup utility application.
Grazie, ho provato a reinstallare Soundflower ed a riavviare il Mac ma non trovo l'icona dell'Applicazione da nessuna parte; nemmeno cercando con Spotlight. Come posso fare?
J.T.Kirk ha scritto: ↑mer, 18 lug 2018 00:40Puoi usare quicktime o Audacity o un'altra applicazione che registra.
Hai guardato le immagini e verificato se puoi selezionare soundflower2ch come canale di uscita audio?
Nei sistemi recenti non compare tra le applicazioni ma solo come Extensions audio. È quello che c'è scritto nel readme allegato all'installer, che ho citato prima e che non hai letto.
Grazie, secondo voi fra SoundFlower e Audio Hijack, qual è il migliore? Nessuno ha provato SoundTap https://www.nch.com.au/soundtap/index.html ?PeT ha scritto: ↑mer, 18 lug 2018 08:24C'è anche Audio Hijack sempre Rogue Amoeba
Io almeno uso questo e mi trovo molto bene .
Grazie dei chiarimenti, se dovessi registrare audio dal web (youtube o altro) quali software mi consigli? Utilizzare Soundflower?paolinoweb ha scritto: ↑mer, 18 lug 2018 13:39Se devi registrare saltuariamente Soundflower va benissimo
1- Lo installi e riavvii il mac - non troverai nessuna applicazione
2- vai in preferenza di sistema > suono > uscita e selezioni soundflower (2ch) - Ora qualsiasi suono riprodotto sul tuo Mac non uscirà dagli altoparlanti,
verrà "catturato" da Soundflower -
3 - Apri quicktime > file > nuova registrazione audio
4 - Vicino al pulsante rosso di vedrai un cuoricino, cliccaci e seleziona soundflower (2ch)
5 - Metti un video su youtube, un brano su itunes, qualsiasi cosa che vuoi registrare.
6 - Premi il pulsante rosso e inizia la registrazione - tu non sentirai nulla -
7 - Stoppa, salva la registrazione, torna in preferenze di sistema > suono > uscita e seleziona casse interne
8 - ora puoi ascoltare la registrazione.
9 - se vuoi registrare ancora vai al passo 2
I programmi a pagamento , ti permettono di sentire quello che registri, di tagliare, di programmare registrazione, di equalizzare, pause, fade out e varie opzioni.
Dipende cosa ti serve.
Visitano il forum: Nessuno e 54 ospiti
