EtreCheck version: 4.3.2 (4D034)
Report generated: 2018-06-24 17:41:40
Runtime: 10:30
Performance: Poor
Major Issues:
Anything that appears on this list needs immediate attention.
Poor performance - EtreCheck report took over 10 minutes to run. This is very unusual.
More than one antivirus app - This machine has multiple antivirus apps installed.
Minor Issues:
These issues do not need immediate attention but they may indicate future problems.
Heavy RAM usage - This machine is using a large amount of RAM.
Apps crashing - There have been numerous app crashes.
Apps with heavy CPU usage - There have been numerous cases of apps with heavy CPU usage.
Small backup drive - Time Machine backup drive is too small.
Unsigned files - There is unsigned software installed. They appear to be legitimate but should be reviewed.
System modifications - There are a large number of system modifications running in the background.
Abnormal shutdown - Your machine shut down abnormally.
Hardware Information:
iMac (27-inch, Mid 2011)
iMac Model: iMac12,2
1 3,4 GHz Intel Core i7 (i7-2600) CPU: 4-core
16 RAM - Upgradeable
BANK 0/DIMM0 - 4 GB DDR3 1333 ok
BANK 1/DIMM0 - 4 GB DDR3 1333 ok
BANK 0/DIMM1 - 4 GB DDR3 1333 ok
BANK 1/DIMM1 - 4 GB DDR3 1333 ok
Drives:
disk0 - WDC WD1001FALS-403AA0 1.00 TB (Mechanical)
Internal SATA 3 Gigabit Serial ATA
disk0s1 - EFI (MS-DOS FAT32) [EFI] 210 MB
disk0s2 - Macintosh HD (Journaled HFS+) 999.35 GB
disk0s3 - Recovery HD [Recovery] 650 MB
disk1 - LaCie Rugged Mini USB3 2.00 TB (Unknown)
External USB 480 Mbit/s
disk1s1 - L***e (Journaled HFS+) 2.00 TB
Mounted Volumes:
disk0s2 - Macintosh HD 999.35 GB (369.70 GB free)
Journaled HFS+
Mount point: /
disk1s1 - L***e 2.00 TB (1.76 TB free)
Journaled HFS+
Mount point: /Volumes/LaCie
Network:
Interface en0: Ethernet
Interface fw0: FireWire
Interface en1: Wi-Fi
802.11 a/b/g/n
One IPv4 address
Interface en5: iPhone
One IPv4 address
Interface en4: Bluetooth PAN
Interface bridge0: Thunderbolt Bridge
iCloud Quota: 2.02 GB available
System Software:
macOS High Sierra 10.13.5 (17F77)
Time since boot: About an hour
System Load: 3.11 (1 min ago) 2.12 (5 min ago) 1.94 (15 min ago)
Configuration Files:
/etc/hosts - Count: 20
Security:
System Status
Gatekeeper Mac App Store and identified developers
System Integrity Protection Enabled
Unsigned Files:
Launchd: /Library/LaunchAgents/com.maintain.Restart.plist
Executable: /usr/bin/osascript -e delay 3 -e try -e do shell script "killall Cocktail" -e end try -e ignoring application responses -e try -e tell application "System Events" to restart -e end try -e end ignoring
Details: Exact match found in the whitelist - probably OK
Launchd: /Library/LaunchDaemons/com.adobe.fpsaud.plist
Executable: /Library/Application Support/Adobe/Flash Player Install Manager/fpsaud
Launchd: /Library/LaunchAgents/com.intego.backupassistant.agent.plist
Executable: /Library/StartupItems/Intego Backup Assistant/BackupAssistantAgent.app/Contents/MacOS/BackupAssistantAgent --launchd
Launchd: /Library/LaunchAgents/com.oracle.java.Java-Updater.plist
Executable: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/Java Updater.app/Contents/MacOS/Java Updater -bgcheck
Launchd: /Library/LaunchDaemons/com.anchorfree.ajaxserver.plist
Executable: /Library/Application Support/Hotspot Shield/ajaxserver
Launchd: ~/Library/LaunchAgents/com.valvesoftware.steamclean.plist
Executable: /Users/***/Library/Application Support/Steam/SteamApps/steamclean
Launchd: /Library/LaunchAgents/com.adobe.CS5ServiceManager.plist
Executable: /Library/Application Support/Adobe/CS5ServiceManager/CS5ServiceManager.app/Contents/MacOS/CS5ServiceManager -launchedbylogin
Launchd: /Library/LaunchDaemons/com.fxfactory.FxFactory.helper.plist
Executable: /Library/PrivilegedHelperTools/com.fxfactory.FxFactory.helper
Launchd: /Library/LaunchAgents/com.amazon.sendtokindle.launcher.plist
Executable: /usr/bin/stkLaunchAgent.sh
Launchd: /Library/LaunchDaemons/com.intego.BackupAssistant.daemon.plist
Executable: /Library/StartupItems/Intego Backup Assistant/BackupAssistantDaemon
Launchd: /Library/LaunchAgents/com.maintain.ShutDown.plist
Executable: /usr/bin/osascript -e delay 3 -e try -e do shell script "killall Cocktail" -e end try -e ignoring application responses -e try -e tell application "System Events" to shut down -e end try -e end ignoring
Launchd: /Library/LaunchAgents/com.lacie.eventsactions.launcher.agent.plist
Executable: /Library/Application Support/LaCie/DesktopManager/lacie_ea_launcher_agent
Launchd: /Library/LaunchDaemons/com.torrents-time.helper.plist
Executable: /Library/PrivilegedHelperTools/com.torrents-time.helper
Launchd: /Library/LaunchDaemons/com.adobe.SwitchBoard.plist
Executable: /Library/Application Support/Adobe/SwitchBoard/SwitchBoard.app/Contents/MacOS/launch.switchboard
Launchd: /Library/LaunchDaemons/com.oracle.java.Helper-Tool.plist
Executable: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/Helper-Tool
Launchd: /Library/LaunchDaemons/com.lacie.desktopmanager.service.plist
Executable: /Library/Application Support/LaCie/DesktopManager/lacie_dm_service
Kernel Extensions:
/Library/Extensions
[Loaded] Boom2Device.kext (1.2 - SDK 10.10)
[Loaded] MB_MBAM_Protection.kext (3.3 - SDK 10.13)
/System/Library/Extensions
[Not Loaded] Soundflower.kext (1.6.6 - SDK 10.6)
[Not Loaded] LaCieScsiType00.kext (1.2.13 - SDK 10.5)
[Not Loaded] jmPeripheralDevice.kext (2.0.4)
[Not Loaded] LaCie_RemoteComms.kext (1.0.1 - SDK 10.5)
[Not Loaded] OxsemiDeviceType00.kext (1.28.13 - SDK 10.5)
[Not Loaded] RoxioBluRaySupport.kext (1.1.6)
[Not Loaded] Pen Tablet.kext (Pen Tablet 5.3.5-4 - SDK 10.9)
Startup Items:
DynDNSUpdater Path: /Library/StartupItems/DynDNSUpdater
ProTec6b Path: /Library/StartupItems/ProTec6b
System Launch Agents:
[Not Loaded] 8 Apple tasks
[Loaded] 173 Apple tasks
[Running] 111 Apple tasks
[Other] One Apple task
System Launch Daemons:
[Not Loaded] 36 Apple tasks
[Loaded] 180 Apple tasks
[Running] 119 Apple tasks
Launch Agents:
[Running] com.maintain.SystemEvents.plist (Apple - installed 2018-05-30)
[Loaded] com.oracle.java.Java-Updater.plist (? 84c6ef4b - installed 2017-09-06)
[Running] com.adobe.AdobeCreativeCloud.plist (Adobe Systems, Inc. - installed 2018-04-27)
[Not Loaded] com.maintain.PurgeInactiveMemory.plist (Apple - installed 2018-05-30)
[Running] com.epson.scannermonitor.plist (Seiko Epson Corporation - installed 2018-02-21)
[Loaded] com.intego.backupassistant.agent.plist (? f2f62dfd - installed 2011-07-22)
[Loaded] com.google.keystone.agent.plist (Google, Inc. - installed 2018-02-04)
[Running] com.wacom.pentablet.plist (Wacom Technology Corp. - installed 2014-08-20)
[Not Loaded] com.adobe.AAM.Updater-1.0.plist (? ffb65062 - installed 2017-12-18)
[Running] com.malwarebytes.mbam.frontend.agent.plist (Malwarebytes Corporation - installed 2018-05-22)
[Loaded] com.adobe.CS5ServiceManager.plist (? 40cdc1ff - installed 2011-09-23)
[Loaded] com.lacie.eventsactions.launcher.agent.plist (? ab5cb100 - installed 2013-02-14)
[Not Loaded] com.maintain.Restart.plist (? 5421a7fd - installed 2018-03-28)
[Running] com.amazon.sendtokindle.launcher.plist (? d18c2039 - installed 2015-11-13)
[Running] com.epson.eventmanager.agent.plist (Seiko Epson Corporation - installed 2018-02-22)
[Not Loaded] com.adobe.GC.Invoker-1.0.plist (Adobe Systems, Inc. - installed 2018-05-31)
[Not Loaded] com.maintain.ShutDown.plist (? 9b7e817c - installed 2018-03-28)
[Running] com.canon.MFManager.plist (? 8a8296d7 - installed 2015-04-01)
Launch Daemons:
[Loaded] com.anchorfree.ajaxserver.plist (? b7821fb8 - installed 2013-11-08)
[Running] com.malwarebytes.mbam.rtprotection.daemon.plist (Malwarebytes Corporation - installed 2018-05-22)
[Other] com.adobe.fpsaud.plist (? 2afb3af7 - installed 2016-06-13)
[Other] com.lacie.desktopmanager.service.plist (? 834bd905 - installed 2013-02-14)
[Running] com.malwarebytes.mbam.settings.daemon.plist (Malwarebytes Corporation - installed 2018-05-22)
[Loaded] jp.co.canon.MasterInstaller.plist (? d0637166 - installed 2017-09-28)
[Running] com.adobe.acc.installer.plist (Adobe Systems, Inc. - installed 2018-04-27)
[Not Loaded] com.maintain.HideSpotlightMenuBarIcon.plist (Apple - installed 2017-10-25)
[Loaded] com.google.keystone.daemon.plist (Google, Inc. - installed 2018-03-06)
[Loaded] com.adobe.agsservice.plist (Adobe Systems, Inc. - installed 2018-05-31)
[Loaded] com.adobe.SwitchBoard.plist (? 856489a3 - installed 2015-02-09)
[Running] com.torrents-time.helper.plist (? 0 - installed 2017-02-08)
[Loaded] com.oracle.java.Helper-Tool.plist (? e3fefdd2 - installed 2017-09-06)
[Loaded] com.apple.installer.osmessagetracing.plist (Apple - installed 2018-05-30)
[Loaded] com.fxfactory.FxFactory.helper.plist (? ef9fafc0 - installed 2014-06-26)
[Loaded] com.malwarebytes.HelperTool.plist (Malwarebytes Corporation - installed 2017-11-21)
[Loaded] com.redgiant.LinkUpdateChecker.plist (Red Giant Software - installed 2017-11-21)
[Running] com.adobe.agmservice.plist (Adobe Systems, Inc. - installed 2018-05-31)
[Running] com.intego.BackupAssistant.daemon.plist (? f4eb85c2 - installed 2011-07-22)
User Launch Agents:
[Loaded] com.adobe.AAM.Updater-1.0.plist (? 0 - installed 2017-11-06)
[Loaded] com.dropbox.DropboxMacUpdate.agent.plist (Dropbox, Inc. - installed 2018-04-13)
[Loaded] com.valvesoftware.steamclean.plist (? 0 - installed 2018-04-15)
[Running] com.spotify.webhelper.plist (Spotify - installed 2018-06-24)
[Loaded] com.google.Chrome.framework.plist (? 0 - installed 2018-06-24)
[Loaded] com.bittorrent.uTorrent.plist (BitTorrent, Inc - installed 2016-03-17)
[Loaded] com.adobe.ARM.df0ab5bbe6f698196fcc21e3c1e66dcb758bd911f4d637272d9d8109.plist (? 0 - installed 2015-09-24)
User Login Items:
com.adobe.SwitchBoard.monitor.plist MachInit (?)
(/etc/mach_init_per_user.d/com.adobe.SwitchBoard.monitor.plist)
Internet Plug-ins:
JavaAppletPlugin: Java 8 Update 151 build 12 (installed 2017-11-15)
Unity Web Player: UnityPlayer version 3.4.2f3 (installed 2011-12-23)
AdobeExManDetect: AdobeExManDetect 1.1.0.0 (installed 2013-12-11)
WacomTabletPlugin: WacomTabletPlugin 2.1.0.6 (installed 2014-10-17)
AdobeAAMDetect: 3.0.0.0 (installed 2018-04-27)
AdobePDFViewerNPAPI: 10.1.16 (installed 2015-10-17)
FlashPlayer-10.6: 22.0.0.192 (installed 2016-07-04)
Silverlight: 5.1.20**3.0 (installed 2013-10-25)
QuickTime Plugin: 7.7.3 (installed 2018-06-12)
Flash Player: 22.0.0.192 (installed 2016-07-04)
AdobePDFViewer: 10.1.16 (installed 2015-10-17)
EPPEX Plugin: 10.0 (installed 2016-05-23)
DirectorShockwave: 11.6.8r638 (installed 2012-10-04)
3rd Party Preference Panes:
Flash Player (installed 2016-06-13)
Java (installed 2017-11-15)
MenuMeters (installed 2015-10-07)
Time Machine:
Skip System Files: No
Mobile backups: No
Auto backup: Yes
Volumes being backed up:
Macintosh HD: Disk size: 999.35 GB - Disk used: 629.64 GB
Destinations:
T**********e [Local] (Last used)
Total size: 999.83 GB
Total number of backups: 14
Oldest backup: 2017-06-01 08:30:18
Last backup: 2018-06-14 21:47:33
Top Processes by CPU:
Process (count) Source % of CPU Location
Google Chrome Helper (31) Google, Inc. 17
WindowServer Apple 4
Google Chrome Google, Inc. 4
Boom 2 Global Delight Technologies Pvt. Ltd 3
find Apple 2
Top Processes by Memory:
Process (count) Source RAM usage Location
Google Chrome Helper (34) Google, Inc. 3.68 GB
kernel_task Apple 1.08 GB
Adobe Lightroom ? 735 MB /Applications/Adobe Lightroom/Adobe Lightroom.app
mdworker (21) Apple 572 MB
mds_stores Apple 527 MB
Top Processes by Network Use:
Process Source Input Output Location
Spotify ? 20 MB 313 KB /Applications/Spotify.app
Mail Apple 697 KB 54 KB
mDNSResponder Apple 201 KB 73 KB
Notes Apple 38 KB 13 KB
netbiosd Apple 17 KB 4 KB
Top Processes by Energy Use:
Process (count) Source Energy (0-100) Location
System Informati ? 8
Google Chrome Helper (34) Google, Inc. 7
Google Chrome Google, Inc. 5
coreaudiod Apple 4
Virtual Memory Information:
Available RAM 6.94 GB
Free RAM 54 MB
Used RAM 9.06 GB
Cached files 6.89 GB
Swap Used 0 B
Software Installs (past 30 days):
Name Version Install Date
iTunes 12.7.5 2018-05-30
Numbers 5.0 2018-06-15
Keynote 8.0 2018-06-15
Pages 7.0 2018-06-15
EPSON Scan 3.9.4.0 2018-06-17
Epson Scanner Monitor 1.0.0 2018-06-17
Epson Event Manager 2.51.60 2018-06-17
Gatekeeper Configuration Data 142 2018-06-20
MRTConfigData 1.35 2018-06-20
Diagnostics Information (past 7 days):
2018-06-24 16:32:14 quicklookd.app Crash
/System/Library/Frameworks/QuickLook.framework/Versions/A/Resources/quicklookd.app
objc_msgSend() selector name: objectForKey:
qlmanage --diag 6872145.6785 6872145.6783 6872145.6780 6872145.6786 6872145.6779 6872145.6787 6872145.6784 6872145.6782
last generator in main thread: com.apple.iWork.iWorkQuickLookGenerator
last threaded generator: com.apple.qlgenerator.image
2018-06-24 16:16:32 Last Shutdown Cause: 0 - Power loss
2018-06-24 16:12:53 Adobe CEF Helper.app Crash
/Library/Application Support/Adobe/*/Adobe CEF Helper.app
2018-06-22 21:20:55 Adobe Lightroom.app CPU
2018-06-21 16:15:15 Adobe Photoshop CC 2014.app CPU
/Applications/Adobe Photoshop CC 2014/Adobe Photoshop CC 2014.app
2018-06-20 13:39:32 Adobe Desktop Service.app Crash
/Library/Application Support/Adobe/Adobe Desktop Common/ADS/Adobe Desktop Service.app
2018-06-18 08:41:37 trustd Crash
/usr/libexec/trustd
objc_msgSend() selector name: length
2018-06-17 23:04:27 EPSON Scan.app CPU
/Applications/Epson Software/EPSON Scan.app
End of report
Ciao a tutti, questo è il mio primo post sul forum.
Ho bisogno di un parere sul mio ormai vetusto iMac 27" 2011 su cui ho installato negli anni tutte le versioni di iOS.
Uso principalmente il Mac per lavori di foto/grafica ma da un po' è diventato molto lento a fare qualsiasi cosa.
Dal momento in cui lo avvio, fino a quando sono in grado di accedere ad esempio ad internet con Chrome, possono passare anche oltre 10 minuti.
Per questo motivo spesso lo metto in Stop, in modo da poter essere subito operativo il giorno seguente.
Molto spesso, all'avvio, ho dei crash di QuicklookSatellite e dei vari odiosi helper (adobe, ecc).
Spotlight è perennemente in indicizzazione, con un fastidioso rumore dell'attività dell'HD.
Ho EtreCheck in versione freeware. Nel caso, per correggere gli errori, devo comprare una licenza?
grazie mille !
